Got a new usb wifi device. Installed drivers for the same (rtl88xxau-aircrack-dkms-git) on manjaro. Device is detected as lsusb output:
Bus 002 Device 003: ID 2357:011e TP-Link AC600 wireless Realtek RTL8811AU [Archer T2U Nano]
Output of ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether 7e:05:28:c9:fb:14 brd ff:ff:ff:ff:ff:ff permaddr ac:9e:17:f0:cb:b0
3: wlp0s29u1u2: <NO-CARRIER,BROADCAST,MULTICAST,UP,LOWER_UP> mtu 2312 qdisc mq state DORMANT mode DORMANT group default qlen 1000
link/ether 7a:8d:09:82:51:2a brd ff:ff:ff:ff:ff:ff permaddr 24:2f:d0:d9:b4:e3
However, no networks are shown with nmcli dev wifi
, the output of which is:
IN-USE BSSID SSID MODE CHAN RATE SIGNAL BARS SECURITY
I even set the country code with iw
, but result is still the same.
Even iw dev wlp0s29u1u2 scan | less
shows unending lines of ~
So, what should I try next?
