Hello everyone i’m newbie on manjaro and linux after most try and research for my problem i m lost. My problem and that I have no sounds and it is written that the card is dummy when I see the sound icon it is crossed out
output of sudo alsa-info.sh --upload :
!!ALSA Information Script v 0.5.1
!!Script ran on: Tue Sep 27 19:06:00 UTC 2022
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: Dell Inc.
Product Name: XPS 9315
Product Version:
Firmware Version: 1.1.3
System SKU: 0B14
Board Vendor: Dell Inc.
Board Name: 02GGG1
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/ACPI000E:00/status 15
/sys/bus/acpi/devices/DLLK0B14:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT3472:01/status 15
/sys/bus/acpi/devices/INT3472:06/status 15
/sys/bus/acpi/devices/INTC1041:00/status 15
/sys/bus/acpi/devices/INTC1046:00/status 15
/sys/bus/acpi/devices/INTC1046:01/status 15
/sys/bus/acpi/devices/INTC1046:02/status 15
/sys/bus/acpi/devices/INTC1046:03/status 15
/sys/bus/acpi/devices/INTC1046:04/status 15
/sys/bus/acpi/devices/INTC1046:05/status 15
/sys/bus/acpi/devices/INTC1046:06/status 15
/sys/bus/acpi/devices/INTC1055:00/status 15
/sys/bus/acpi/devices/INTC1070:00/status 15
/sys/bus/acpi/devices/INTC1099:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/OVTI01A0:00/status 15
/sys/bus/acpi/devices/OVTI01AB:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0C02:02/status 8
/sys/bus/acpi/devices/PNP0C02:04/status 3
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C09:00/status 15
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PRP00001:00/status 15
/sys/bus/acpi/devices/PRP00001:01/status 11
/sys/bus/acpi/devices/STM0125:00/status 15
/sys/bus/acpi/devices/TXNW3643:00/status 15
/sys/bus/acpi/devices/USBC000:00/status 15
/sys/bus/acpi/devices/VEN_04F3:00/status 15
/sys/bus/acpi/devices/device:01/status 15
/sys/bus/acpi/devices/device:0f/status 15
/sys/bus/acpi/devices/device:10/status 15
/sys/bus/acpi/devices/device:7f/status 15
/sys/bus/acpi/devices/device:87/status 15
/sys/bus/acpi/devices/device:88/status 15
/sys/bus/acpi/devices/device:89/status 15
/sys/bus/acpi/devices/device:8b/status 15
/sys/bus/acpi/devices/device:8c/status 15
/sys/bus/acpi/devices/device:8d/status 15
/sys/bus/acpi/devices/device:92/status 15
/sys/bus/acpi/devices/device:99/status 15
/sys/bus/acpi/devices/device:9b/status 15
/sys/bus/acpi/devices/device:9d/status 15
!!Kernel Information
Kernel release: 5.15.65-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.15.65-1-MANJARO
Library version: 1.2.7.2
Utilities version: 1.2.7
!!Loaded ALSA modules
snd_soc_skl_hda_dsp (card 0)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - No
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [sofhdadsp ]: sof-hda-dsp - sof-hda-dsp
DellInc.-XPS9315--02GGG1
!!PCI Soundcards installed in the system
00:1f.3 Multimedia audio controller [0401]: Intel Corporation Device [8086:51cc] (rev 01)
Subsystem: Dell Device [1028:0b14]
!!Loaded sound module options
!!Module: snd_soc_skl_hda_dsp
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/platform/drivers/skl_hda_dsp_generic
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Intel Alderlake-P HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086281c
Subsystem Id: 0x80860101
Revision Id: 0x100000
No Modem Function Group found
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
Converter: stream=0, channel=0
Digital: Enabled
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1a]: 16 24 32
formats [0x5]: PCM AC3
Power states: D0 D3 EPSS
Node 0x04 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x00:
Unsolicited: tag=00, enabled=0
Devices: 0
Connection: 0
Node 0x05 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled
PCM:
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled
PCM:
Node 0x08 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x09 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled
PCM:
Node 0x0a [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0b [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0c [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0d [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0e [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0f [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 6 Sep 27 21:00 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 5 Sep 27 21:00 /dev/snd/hwC0D2
crw-rw---- 1 root audio 116, 2 Sep 27 21:00 /dev/snd/pcmC0D1p
crw-rw---- 1 root audio 116, 3 Sep 27 21:00 /dev/snd/pcmC0D2p
crw-rw---- 1 root audio 116, 4 Sep 27 21:00 /dev/snd/pcmC0D3p
crw-rw---- 1 root audio 116, 1 Sep 27 21:00 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Sep 27 21:00 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Sep 27 21:00 .
drwxr-xr-x 3 root root 200 Sep 27 21:00 ..
lrwxrwxrwx 1 root root 12 Sep 27 21:00 pci-0000:00:1f.3-platform-skl_hda_dsp_generic -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: sofhdadsp [sof-hda-dsp], device 1: HDMI1 (*) []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: sofhdadsp [sof-hda-dsp], device 2: HDMI2 (*) []
Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 3: HDMI3 (*) []
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
!!Amixer output
!!-------Mixer controls for card sofhdadsp
Card sysdefault:0 'sofhdadsp'/'DellInc.-XPS9315--02GGG1'
Mixer name : 'Intel Alderlake-P HDMI'
Components : 'HDA:8086281c,80860101,00100000'
Controls : 24
Simple ctrls : 6
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'PGA2.0 2 Master',0
Capabilities: pvolume
Limits: Playback 0 - 32
Mono:
Front Left: Playback 32 [100%] [0.00dB]
Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA3.0 3 Master',0
Mono:
Simple mixer control 'PGA4.0 4 Master',0
Mono:
!!Alsactl output
--startcollapse--
state.sofhdadsp {
control.1 {
iface CARD
name 'HDMI/DP,pcm=1 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 1
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface CARD
name 'HDMI/DP,pcm=2 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 2
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 3
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface PCM
device 1
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.20 {
iface PCM
device 2
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.21 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.22 {
iface MIXER
name 'PGA2.0 2 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.23 {
iface MIXER
name 'PGA3.0 3 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.24 {
iface MIXER
name 'PGA4.0 4 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
--endcollapse--
!!All Loaded Modules
8250_dw
ac97_bus
acpi_pad
acpi_tad
acpi_thermal_rel
aesni_intel
af_alg
algif_hash
algif_skcipher
atkbd
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cros_ec
cros_ec_ishtp
cryptd
crypto_simd
crypto_user
dcdbas
dell_laptop
dell_smbios
dell_wmi
dell_wmi_descriptor
dell_wmi_sysman
dw_dmac
ecdh_generic
ext4
fat
firmware_attributes_class
fuse
ghash_clmulni_intel
hid_multitouch
hid_sensor_als
hid_sensor_custom
hid_sensor_custom_intel_hinge
hid_sensor_hub
hid_sensor_iio_common
hid_sensor_trigger
i2c_hid
i2c_hid_acpi
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
igen6_edac
industrialio
industrialio_triggered_buffer
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_hid
intel_ish_ipc
intel_ishtp
intel_ishtp_hid
intel_ishtp_loader
intel_lpss
intel_lpss_pci
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_skl_int3472
intel_spi
intel_spi_pci
intel_tcc_cooling
intel_uncore
ip_tables
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kfifo_buf
kvm
kvm_intel
ledtrig_audio
libarc4
libps2
mac80211
mac_hid
mbcache
mei
mei_hdcp
mei_me
mousedev
mtd
ns
pcspkr
processor_thermal_device
processor_thermal_device_pci
processor_thermal_mbox
processor_thermal_rapl
processor_thermal_rfim
psmouse
qrtr
rapl
regmap_sdw
regmap_sdw_mbq
rfcomm
rfkill
rng_core
roles
serio
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_dmic
snd_soc_hdac_hda
snd_soc_hdac_hdmi
snd_soc_intel_hda_dsp_common
snd_soc_rt1316_sdw
snd_soc_rt715_sdca
snd_soc_skl_hda_dsp
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_pci
snd_sof_pci_intel_tgl
snd_sof_xtensa_dsp
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
spi_nor
spi_pxa2xx_platform
thunderbolt
tpm
tpm_crb
tpm_tis
tpm_tis_core
ttm
typec
typec_ucsi
uas
ucsi_acpi
usb_storage
vfat
video
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D2/init_pin_configs:
0x04 0x18560010
0x06 0x18560010
0x08 0x18560010
0x0a 0x18560010
0x0b 0x18560010
0x0c 0x18560010
0x0d 0x18560010
0x0e 0x18560010
0x0f 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[ 0.124665] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.124665] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.124665] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 6.056873] iwlwifi 0000:00:14.3: Detected RF GF, rfid=0x2010d000
[ 6.081026] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 6.081613] snd_hda_intel 0000:00:1f.3: SoundWire enabled on CannonLake platform, using SOF driver
[ 6.127032] iwlwifi 0000:00:14.3: base HW address: 04:cf:4b:15:82:31
[ 6.625866] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 6.625930] sof-audio-pci-intel-tgl 0000:00:1f.3: SoundWire enabled on CannonLake platform, using SOF driver
[ 6.625946] sof-audio-pci-intel-tgl 0000:00:1f.3: enabling device (0000 -> 0002)
[ 6.626076] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[ 6.890511] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ 6.901248] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input10
[ 6.901469] sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 6.907533] fbcon: i915drmfb (fb0) is primary device
[ 6.940693] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 7.009270] sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
[ 7.136785] sof-audio-pci-intel-tgl 0000:00:1f.3: No SoundWire machine driver found
[ 7.136787] sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 4
[ 7.136789] sof-audio-pci-intel-tgl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 7.136792] sof-audio-pci-intel-tgl 0000:00:1f.3: DMICs detected in NHLT tables: 0
[ 7.140055] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 7.140057] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:18:0
[ 7.140058] sof-audio-pci-intel-tgl 0000:00:1f.3: warn: FW ABI is more recent than kernel
[ 7.140060] sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[ 7.160727] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[ 7.254879] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 7.254882] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:18:0
[ 7.254884] sof-audio-pci-intel-tgl 0000:00:1f.3: warn: FW ABI is more recent than kernel
[ 10.295021] input: PC Speaker as /devices/platform/pcspkr/input/input12
[ 11.811751] audit: type=1130 audit(1664305240.206:32): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.867268] sof-audio-pci-intel-tgl 0000:00:1f.3: Topology: ABI 3:22:1 Kernel ABI 3:18:0
[ 11.867273] sof-audio-pci-intel-tgl 0000:00:1f.3: warn: topology ABI is more recent than kernel
[ 11.867689] audit: type=1130 audit(1664305240.259:33): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.876988] sof-audio-pci-intel-tgl 0000:00:1f.3: ASoC: Parent card not yet available, widget card binding deferred
[ 11.884605] audit: type=1130 audit(1664305240.279:34): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@leds:dell::kbd_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.895925] audit: type=1130 audit(1664305240.286:35): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.897646] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
[ 11.911858] Bluetooth: BNEP socket layer initialized
[ 11.919083] input: sof-hda-dsp HDMI/DP,pcm=1 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input18
[ 11.919168] input: sof-hda-dsp HDMI/DP,pcm=2 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input19
[ 11.919242] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input20
[ 11.989337] audit: type=1130 audit(1664305240.379:36): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
output of systemctl status alsa-state :
○ alsa-state.service - Manage Sound Card State (restore and store)
Loaded: loaded (/usr/lib/systemd/system/alsa-state.service; static)
Active: inactive (dead)
Condition: start condition failed at Tue 2022-09-27 21:00:40 CEST; 6min ago
sept. 27 21:00:40 lorisp-xps9315 systemd[1]: Manage Sound Card State (restore and store) was skipped because >
output of aplay -l :
**** Liste des périphériques matériels PLAYBACK ****
carte 0 : sofhdadsp [sof-hda-dsp], périphérique 1 : HDMI1 (*) []
Sous-périphériques : 1/1
Sous-périphérique #0 : subdevice #0
carte 0 : sofhdadsp [sof-hda-dsp], périphérique 2 : HDMI2 (*) []
carte 0 : sofhdadsp [sof-hda-dsp], périphérique 3 : HDMI3 (*) []
output of systemctl --user pulseaudio :
pulseaudio.service - Sound Service
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; preset: enabled)
Active: active (running) since Tue 2022-09-27 21:00:53 CEST; 21min ago
TriggeredBy: ● pulseaudio.socket
Main PID: 997 (pulseaudio)
Tasks: 6 (limit: 18723)
Memory: 14.2M
CPU: 101ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pulseaudio.service
├─ 997 /usr/bin/pulseaudio --daemonize=no --log-target=journal
└─1002 /usr/lib/pulse/gsettings-helper
sept. 27 21:00:53 lorisp-xps9315 pulseaudio[997]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with experimental features enabled (-E flag)?
sept. 27 21:00:53 lorisp-xps9315 pulseaudio[997]: Failed to find a working profile.
sept. 27 21:00:53 lorisp-xps9315 pulseaudio[997]: Failed to load module "module-alsa-card" (argument: "device_id="0" name="pci-0000_00_1f.3-platform-skl_hda_dsp_generic" card_name="alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generi>
sept. 27 21:00:53 lorisp-xps9315 pulseaudio[997]: Tried to configure /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0 (alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic) more often than 5 times in 10s
Ouput aplay -L :
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
usbstream:CARD=sofhdadsp
sof-hda-dsp
USB Stream Output
output of lspci :
00:00.0 Host bridge: Intel Corporation Device 4602 (rev 06)
00:02.0 VGA compatible controller: Intel Corporation Device 46aa (rev 0c)
00:04.0 Signal processing controller: Intel Corporation Alder Lake Innovation Platform Framework Processor Par
ticipant (rev 06)
00:05.0 Multimedia controller: Intel Corporation Device 465d (rev 06)
00:06.0 PCI bridge: Intel Corporation 12th Gen Core Processor PCI Express x4 Controller #0 (rev 06)
00:07.0 PCI bridge: Intel Corporation Alder Lake-P Thunderbolt 4 PCI Express Root Port #0 (rev 06)
00:07.1 PCI bridge: Intel Corporation Alder Lake-P Thunderbolt 4 PCI Express Root Port #1 (rev 06)
00:08.0 System peripheral: Intel Corporation 12th Gen Core Processor Gaussian & Neural Accelerator (rev 06)
00:0d.0 USB controller: Intel Corporation Alder Lake-P Thunderbolt 4 USB Controller (rev 06)
00:0d.2 USB controller: Intel Corporation Alder Lake-P Thunderbolt 4 NHI #0 (rev 06)
00:12.0 Serial controller: Intel Corporation Device 51fc (rev 01)
00:14.0 USB controller: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller (rev 01)
00:14.2 RAM memory: Intel Corporation Alder Lake PCH Shared SRAM (rev 01)
00:14.3 Network controller: Intel Corporation Alder Lake-P PCH CNVi WiFi (rev 01)
00:15.0 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #0 (rev 01)
00:15.1 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #1 (rev 01)
00:16.0 Communication controller: Intel Corporation Alder Lake PCH HECI Controller (rev 01)
00:1e.0 Communication controller: Intel Corporation Alder Lake PCH UART #0 (rev 01)
00:1e.2 Serial bus controller: Intel Corporation Device 51aa (rev 01)
00:1e.3 Serial bus controller: Intel Corporation Device 51ab (rev 01)
00:1f.0 ISA bridge: Intel Corporation Device 5187 (rev 01)
00:1f.3 Multimedia audio controller: Intel Corporation Device 51cc (rev 01)
00:1f.4 SMBus: Intel Corporation Alder Lake PCH-P SMBus Host Controller (rev 01)
00:1f.5 Serial bus controller: Intel Corporation Alder Lake-P PCH SPI Controller (rev 01)
01:00.0 Non-Volatile memory controller: Phison Electronics Corporation Device 5019 (rev 01)
if you want more information tell me I don’t know what i can do can you help me please ? I have already installed sof-firmware and reinstall pulseaudio I had tried on archlinux the same problem however on other distribution the sound works, when I plug in a bluetooth or usb headset everything works thank you for you help (sorry my bad english)
