On an Intel 1135G7 HP laptop, Manjaro Gnome:
sudo pacman-mirrors -g --continent ✔ 1m 25s
::INFO => Mirror status: http://repo.manjaro.org/status.json
File "/usr/lib/python3.9/site-packages/urllib3/connection.py", line 169, in _new_conn
conn = connection.create_connection(
File "/usr/lib/python3.9/site-packages/urllib3/util/connection.py", line 96, in create_connection
raise err
File "/usr/lib/python3.9/site-packages/urllib3/util/connection.py", line 86, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
File "/usr/lib/python3.9/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/lib/python3.9/site-packages/urllib3/connectionpool.py", line 382, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3.9/site-packages/urllib3/connectionpool.py", line 1010, in _validate_conn
conn.connect()
File "/usr/lib/python3.9/site-packages/urllib3/connection.py", line 353, in connect
conn = self._new_conn()
File "/usr/lib/python3.9/site-packages/urllib3/connection.py", line 181, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7fc8c0a220d0>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/lib/python3.9/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/lib/python3.9/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/lib/python3.9/site-packages/urllib3/util/retry.py", line 574, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='get.geojs.io', port=443): Max retries exceeded with url: /v1/ip/country/full (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fc8c0a220d0>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/usr/bin/pacman-mirrors", line 28, in <module>
pm.run()
File "/usr/lib/python3.9/site-packages/pacman_mirrors/pacman_mirrors.py", line 112, in run
defaultFn.load_config_mirror_pool(self)
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/defaultFn.py", line 44, in load_config_mirror_pool
self.selected_countries = pools.build_country_list(self)
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/pools.py", line 78, in build_country_list
continent_mirror_countries = get_continent_countries(get_geo_continent(), self.mirrors.mirror_pool)
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/pools.py", line 119, in get_geo_continent
return _get_ip_continent().replace(" ", "_")
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/pools.py", line 148, in _get_ip_continent
country = _get_ip_country()
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/pools.py", line 140, in _get_ip_country
return get_ip_country().strip()
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/httpFn.py", line 125, in get_ip_country
resp = requests.get("https://get.geojs.io/v1/ip/country/full",
File "/usr/lib/python3.9/site-packages/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/usr/lib/python3.9/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3.9/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3.9/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3.9/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='get.geojs.io', port=443): Max retries exceeded with url: /v1/ip/country/full (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fc8c0a220d0>: Failed to establish a new connection: [Errno 111] Connection refused'))
I use this for now sudo pacman-mirrors -g -P https --api but I would like to limit the testing to my continent. FYI I am based in NL. Location Services is enabled in Settings (Weather via clock in notification bar works for example).
