After switching to the unstable branch it doesn’t reach the graphical interface is not reached, it doesn’t boot from the GRUB fallback option either.
I am convinced that it is nvidia problem and that I need to modify /etc/mkinitcpio.conf to add the nvidia modules.
How can I do this? Live USB?
BG405
2
This could possibly be a Plymouth issue; try removing “quiet” and “splash” from the GRUB command line?
As for Live USB, you can make modifications via chroot.
No, I uninstalled Plymouth, I tried adding modeset from grub, it doesn’t work.
I already had this problem with kernel 6.9 but now it appears also in kernel 6.6.
Could you please detail the command for chroot, it is something I have never done before.
BG405
4
I use manjaro-chroot -a
for this purpose.
Please note I don’t have any experience with NVidia + Linux; hopefully someone who does will chime in.
Thanks, it was very easy
but… it doesn’t boot either…
But this solution allows me to go back to another branch in the last case.
I do, very bad…
system
Closed
6
