After an update from 513 to 515 I have been locked out of my computer. My computer froze a few hours after installing the new kernel, and after waiting 20 minutes it was still frozen, so I held the power button to shut it down. I have not removed the 513 kernel, and I have tried to boot to it from grub.
Booting to 515 displays: and then freezes. When the power button is pressed a kernel panic happens
t/dev/sdb2: clean, 191748/61030400 files, 93037898/244112696 blocks
Booting to 513 displays the same error message, the error below, and then goes into emergency mode. I cannot access a text command line outside of emergency mode.
[Failed] Failed to start Load Kernal Modules
[Failed]Failed to mount unit for anbox-installer, revision 24
[Failed]Failed to mount unit for bare, revision 5
[Failed]Failed to mount unit for code , revision 90
[Failed]Failed to mount unit for code , revision 91
[Failed]Failed to mount unit for core18, revision 2253
[Failed]Failed to mount unit for core18, revision 2284
[Failed]Failed to mount unit for core20, revision 2253
[Failed]Failed to mount unit for core20, revision 2284
[Failed]Failed to mount unit for gnome-3-28-1804, revision 161
[Failed]Failed to mount unit for gtk-common-themes, revision 1519
[Failed]Failed to mount /boot/efi
I have tried the fixes listed below:
in chroot:
run pacman -Syyu, no updates were needed
update-grub, no effect
uninstall and reinstall 515 kernel. no effect. I wanted to try doing this on the 513 kernel since it gets me further in the boot process, but I cannot reinstall the kernel since it is EOL, so I have not tried. I have not removed 513 either since I cant get it back.
While reinstalling 515/510 I got the following messages
WARNING: Possible missing firmware for module: bfa
WARNING: Possible missing firmware for module: qla2xxx
WARNING: Possible missing firmware for module: qed
WARNING: Possible missing firmware for module: qla1200
installing kernal 510. booting into this gives a black screen.
running startx gives (using free drivers, with GTX1080)
(EE)Fatal server error:(EE) no screens found (EE)
Xorg log
[ 1030.754]
X.Org X Server 1.21.1.3
[ 1030.755] Current Operating System: Linux danie-alienwareaurorar6 5.13.19-2-MANJARO #1 SMP PREEMPT Sun Sep 19 21:31:53 UTC 2021 x86_64
[ 1030.755] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=3c36663a-002b-4f75-aa01-4df25f6d9901 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 1030.756]
[ 1030.757] Current version of pixman: 0.40.0
[ 1030.758] Before reporting problems, check http://wiki.x.org
[ 1030.758] Markers: (--) probed, (**) from config file, (==) default setting,
[ 1030.760] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Mar 15 17:39:45 2022
[ 1030.761] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 1030.761] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 1030.761] (==) ServerLayout "layout"
[ 1030.761] (==) No screen section available. Using defaults.
[ 1030.761] (**) |-->Screen "Default Screen Section" (0)
[ 1030.761] (**) | |-->Monitor "<default monitor>"
[ 1030.761] (==) No monitor specified for screen "Default Screen Section".
[ 1030.761] (==) Automatically adding devices
[ 1030.761] (==) Automatically enabling devices
[ 1030.761] (==) Automatically adding GPU devices
[ 1030.761] (==) Automatically binding GPU devices
[ 1030.761] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 1030.762] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 1030.762] Entry deleted from font path.
[ 1030.762] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 1030.762] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 1030.762] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 1030.762] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 1030.762] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 1030.762] (II) The server relies on udev to provide the list of input devices.
[ 1030.762] (II) Module ABI versions:
[ 1030.762] X.Org ANSI C Emulation: 0.4
[ 1030.762] X.Org Video Driver: 25.2
[ 1030.762] X.Org XInput driver : 24.4
[ 1030.762] X.Org Server Extension : 10.0
[ 1030.762] (EE) dbus-core: error connecting to system bus: org.freedesktop.DBus.Error.FileNotFound (Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory)
[ 1030.762] (++) using VT number 1
[ 1030.763] (--) PCI: (0@0:2:0) 8086:5912:1028:07db rev 4, Mem @ 0xdd000000/16777216, 0xb0000000/268435456, I/O @ 0x0000f000/64
[ 1030.763] (--) PCI:*(1@0:0:0) 10de:1b80:1028:3366 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 1030.763] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 1030.763] (II) LoadModule: "glx"
[ 1030.763] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 1030.764] (II) Module glx: vendor="X.Org Foundation"
[ 1030.764] compiled for 1.21.1.3, module version = 1.0.0
[ 1030.764] ABI class: X.Org Server Extension, version 10.0
[ 1030.864] (==) Matched nouveau as autoconfigured driver 0
[ 1030.864] (==) Matched nv as autoconfigured driver 1
[ 1030.864] (==) Matched modesetting as autoconfigured driver 2
[ 1030.864] (==) Matched fbdev as autoconfigured driver 3
[ 1030.864] (==) Matched vesa as autoconfigured driver 4
[ 1030.864] (==) Assigned the driver to the xf86ConfigLayout
[ 1030.864] (II) LoadModule: "nouveau"
[ 1030.864] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 1030.864] (II) Module nouveau: vendor="X.Org Foundation"
[ 1030.864] compiled for 1.21.1.1, module version = 1.0.17
[ 1030.864] Module class: X.Org Video Driver
[ 1030.864] ABI class: X.Org Video Driver, version 25.2
[ 1030.864] (II) LoadModule: "nv"
[ 1030.864] (WW) Warning, couldn't open module nv
[ 1030.864] (EE) Failed to load module "nv" (module does not exist, 0)
[ 1030.864] (II) LoadModule: "modesetting"
[ 1030.864] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 1030.864] (II) Module modesetting: vendor="X.Org Foundation"
[ 1030.864] compiled for 1.21.1.3, module version = 1.21.1
[ 1030.864] (II) LoadModule: "fbdev"
[ 1030.865] (WW) Warning, couldn't open module fbdev
[ 1030.865] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 1030.865] (II) LoadModule: "vesa"
[ 1030.865] (WW) Warning, couldn't open module vesa
[ 1030.865] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 1030.865] (II) NOUVEAU driver
[ 1030.865] (II) NOUVEAU driver for NVIDIA chipset families :
[ 1030.865] RIVA TNT (NV04)
[ 1030.865] RIVA TNT2 (NV05)
[ 1030.865] GeForce 256 (NV10)
[ 1030.865] GeForce 2 (NV11, NV15)
[ 1030.865] GeForce 4MX (NV17, NV18)
[ 1030.865] GeForce 3 (NV20)
[ 1030.865] GeForce 4Ti (NV25, NV28)
[ 1030.865] GeForce FX (NV3x)
[ 1030.865] GeForce 6 (NV4x)
[ 1030.865] GeForce 7 (G7x)
[ 1030.865] GeForce 8 (G8x)
[ 1030.865] GeForce 9 (G9x)
[ 1030.865] GeForce GTX 2xx/3xx (GT2xx)
[ 1030.865] GeForce GTX 4xx/5xx (GFxxx)
[ 1030.865] GeForce GTX 6xx/7xx (GKxxx)
[ 1030.865] GeForce GTX 9xx (GMxxx)
[ 1030.865] GeForce GTX 10xx (GPxxx)
[ 1030.865] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 1030.950] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
[ 1030.950] (EE) open /dev/dri/card0: No such file or directory
[ 1030.950] (WW) Falling back to old probe method for modesetting
[ 1030.950] (EE) Screen 0 deleted because of no matching config section.
[ 1030.950] (II) UnloadModule: "modesetting"
[ 1030.950] (EE) Device(s) detected, but none match those in the config file.
[ 1030.950] (EE)
Fatal server error:
[ 1030.950] (EE) no screens found(EE)
[ 1030.950] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 1030.950] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 1030.950] (EE)
[ 1030.955] (EE) Server terminated with error (1). Closing log file.
Any recommendations? I’m a newbie, so I’m pretty lost.
