No Bluetooth Adapters Found
I added a Bluetooth adapter to my computer (a stand-alone USB dongle) and Manjaro isn’t identifying it.
I read in a similar post (I tried adding a link to it but got an error that I’m not allowed to do that) that an Editor (whatever that role is, I’m new here so I don’t know) asked for minimally information from inxi --admin --verbosity=7 --filter --no-host --width so here’s mine:
  Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=d60d340b-4e73-4db3-9e0a-c2a303e7b43f rw quiet apparmor=1
  Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
  Type: Desktop Mobo: Gigabyte model: Z97X-UD5H v: x.x serial: <filter>
  UEFI: American Megatrends v: F10 date: 08/03/2015
  RAM: total: 15.48 GiB used: 7.02 GiB (45.3%)
  Info: Quad Core model: Intel Core i7-4770K bits: 64 type: MT MCP
  arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
  L2: 8 MiB bogomips: 55870
  Speed: 3862 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 3862 2: 3886
  3: 3840 4: 3891 5: 3889 6: 3888 7: 3803 8: 3823
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
  clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
  dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
  ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
  movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
  pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep
  smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
  tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology
  xtpr
  Type: l1tf
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
  vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0412
  class-ID: 0300
  Device-2: NVIDIA GK110 [GeForce GTX 780] vendor: Gigabyte driver: nvidia
  v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1004 class-ID: 0300
  Device-3: Logitech HD Pro Webcam C920 type: USB
  driver: snd-usb-audio,uvcvideo bus-ID: 3-3.3:14 chip-ID: 046d:082d
  class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
  display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 95 s-size: 513x292mm (20.2x11.5")
  s-diag: 590mm (23.2")
  Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 96
  size: 509x286mm (20.0x11.3") diag: 584mm (23")
  OpenGL: renderer: GeForce GTX 780/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
  direct render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
  driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
  class-ID: 0403
  Device-2: Intel 9 Series Family HD Audio vendor: Gigabyte
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
  class-ID: 0403
  Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.26 running: yes
  Device-1: Intel Ethernet I217-V vendor: Gigabyte driver: e1000e v: kernel
  port: f080 bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
  Device-2: Qualcomm Atheros Killer E220x Gigabit Ethernet vendor: Gigabyte
  driver: alx v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 1969:e091
  class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  driver: btusb v: 0.8 bus-ID: 3-3.4:26 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 3.64 TiB used: 188.4 GiB (5.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA200 size: 1.82 TiB
  block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: ABB0 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
  model: WD My Passport 0827 size: 1.82 TiB block-size: physical: 512 B
  logical: 512 B serial: <filter> rev: 1012 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSB0 rev: LN00
  dev-links: cdrom
  Features: speed: 12 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 845.78 GiB size: 831.43 GiB (98.30%)
  used: 188.4 GiB (22.7%) fs: ext4 dev: /dev/sda9 maj-min: 8:9 label: N/A
  uuid: d60d340b-4e73-4db3-9e0a-c2a303e7b43f
  ID-2: /boot/efi raw-size: 550 MiB size: 548.9 MiB (99.80%)
  used: 324 KiB (0.1%) fs: vfat dev: /dev/sda8 maj-min: 8:8 label: NO_LABEL
  uuid: B02C-B004
  ID-1: swap-1 type: partition size: 29.8 GiB used: 1.8 MiB (0.0%)
  priority: -2 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: ada25305-bbca-4564-b0c7-e6f39d71838b
  ID-1: /dev/sda1 maj-min: 8:1 size: 1007 KiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/sda3 maj-min: 8:3 size: 498.62 GiB fs: ext4 label: N/A
  uuid: d0ec6ee7-91f6-4dc5-80dd-0c495102a08c
  ID-3: /dev/sda4 maj-min: 8:4 size: 100 MiB fs: vfat label: N/A
  uuid: B27C-3322
  ID-4: /dev/sda5 maj-min: 8:5 size: 16 MiB fs: <superuser required>
  ID-5: /dev/sda6 maj-min: 8:6 size: 487.67 GiB fs: ntfs label: N/A
  uuid: 761686031685C519
  ID-6: /dev/sda7 maj-min: 8:7 size: 505 MiB fs: ntfs label: N/A
  uuid: 483268BB3268AF9C
  ID-7: /dev/sdb1 maj-min: 8:17 size: 1.72 TiB fs: ntfs
  label: Gal's External HDD uuid: F474B7AA74B76DCC
  ID-8: /dev/sdb2 maj-min: 8:18 size: 100.34 GiB fs: ext4
  label: gal-external-hdd uuid: c4a13096-90fc-404e-bffb-1c44844c2560
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel ports: 6 rev: 2.0 speed: 480 Mb/s
  chip-ID: 8087:8009 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
  chip-ID: 8087:8001 class-ID: 0900
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
  Hub-6: 3-3:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
  chip-ID: 045b:0209 class-ID: 0900
  Device-1: 3-3.1:25 info: Contour Design Unimouse type: HID
  power: 100mA chip-ID: 0b33:1056 class-ID: 0301
  Device-2: 3-3.2:6 info: Western Digital My Passport 0827 type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
  chip-ID: 1058:0827 class-ID: 0806 serial: <filter>
  Device-3: 3-3.3:14 info: Logitech HD Pro Webcam C920 type: Video,Audio
  power: 500mA chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Device-4: 3-3.4:26 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 0a12:0001 class-ID: e001
  Hub-7: 3-5:3 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4 rev: 2.0
  speed: 480 Mb/s power: 2mA chip-ID: 0424:2514 class-ID: 0900
  Device-1: 3-9:5 info: Contour Design Contour Receiver
  type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 4 rev: 2.0
  speed: 12 Mb/s power: 100mA chip-ID: 0b33:2000 class-ID: 0300
  serial: <filter>
  Device-2: 3-10:7 info: ASUSTek ROG Claymore Gaming Keyboard
  type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
  speed: 12 Mb/s power: 100mA chip-ID: 0b05:184d class-ID: 0300
  Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  Hub-9: 4-3:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
  chip-ID: 045b:0210 class-ID: 0900
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 36 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 19%
  Processes: 360 Uptime: 31m wakeups: 0 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 Packages: 1333 pacman: 1310 lib: 390 flatpak: 8
  snap: 15 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.04
I’d appreciate help in getting this to work - I’m new to Manjaro and Arch.
Shush! It’s not even human! It’s an :alien:
:joy:
It is being identified:
So, can you elaborate as to what’s going wrong exactly?
Also:
That seems to be quite old and AMI is good about updating its firmware. Have you tried upgrading the UEFI firmware (“BIOS”) yet?
:thinking:
Not only is bluetooth being identified and present, it’s running, that is, enabled, service started, and bluetooth adapter on and active, with an hci ID of hci0.
Note that bluetooth has 3 primary modes of stop / start, in sequence:
  1. service enabled, via systemctl, if not enabled, it can’t start/stop
  2. service is started via systemctl, if not started, it can’t run
  3. bluetooth adapter is on, running, and active, with an hci ID. At least 3 things can make bluetooth not run at this 3rd level, no, 4: bluetoothctl; bt-adapter; hciconfig; rfkill. Each of these can stop or start a device/adapter, but each does not always know what the other has done, but if it shows state: up then all are good.
Getting that Report item to work for inxi took me 3 tries, 3.3.04 is the one that finally locked it down so it would almost always work re the Report: state:up/down part.
So that’s not the actual question this user has, I believe.
As an aside:
is just a kind of verbose way of doing:
inxi -azyv7
--admin == -a
--verbosity=7 == -v7
--filter --no-host == -z
--width == -y
-z activates --no-host automatically, by request, amusingly enough, of someone from Manjaro if I remember right.
Please read this:
Skip straight to Item 10… :grin:
And why I asked:
:+1:
Let’s wait for an answer, because it could indeed be a number of things…
Chuckle, you’ll either learn and quietly change, or you’ll never learn, or you’ll slowly learn, and quietly change. Meanwhile, I’ll now and then drop in and tell people the easy fast efficient way to use inxi, and point out when things are redundant or flat out wrong (like --verbosity=7 —full). And as people realize the redundant verbose options teach nothing, obfuscate, and just make it harder, not easier, on noobs, hopefully this odd little idea will drift away… Do keep in mind, the long forms never helped you understand at all what -v[0-8] and -F do, they just confused matters. And if they confused you, imagine how noobs experienced it!!
