hello everyone, i have problem with bluetooth when using kernel 5.15, it says no bluetooth adapter available and the icon set to be disabled like this , even though my wifi adapter still working fine, but when i downgrade to kernel 5.14 the bluetooth adapter working again
output of lspci -v
~ lspci -v ✔
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
Subsystem: Dell Device 0830
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: skl_uncore
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (rev 07) (prog-if 00 [VGA controller])
DeviceName: Onboard IGD
Flags: bus master, fast devsel, latency 0, IRQ 128
Memory at de000000 (64-bit, non-prefetchable) [size=16M]
Memory at b0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 08)
Flags: fast devsel, IRQ 16
Memory at df320000 (64-bit, non-prefetchable) [size=32K]
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device_pci_legacy
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 126
Memory at df310000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
Flags: fast devsel, IRQ 18
Memory at df337000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at df336000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
Flags: bus master, fast devsel, latency 0, IRQ 127
Memory at df335000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 21)
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 125
Memory at df330000 (32-bit, non-prefetchable) [size=8K]
Memory at df334000 (32-bit, non-prefetchable) [size=256]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at df333000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: df200000-df2fffff [size=1M]
Prefetchable memory behind bridge: 00000000c0000000-00000000d01fffff [size=258M]
Kernel driver in use: pcieport
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000d000-0000dfff [size=4K]
Memory behind bridge: df100000-df1fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 124
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: df000000-df0fffff [size=1M]
00:1f.0 ISA bridge: Intel Corporation Sunrise Point LPC Controller/eSPI Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
Flags: fast devsel
Memory at df32c000 (32-bit, non-prefetchable) [disabled] [size=16K]
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
Flags: bus master, fast devsel, latency 32, IRQ 132
Memory at df328000 (64-bit, non-prefetchable) [size=16K]
Memory at df300000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
Flags: medium devsel, IRQ 16
Memory at df332000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Topaz XT [Radeon R7 M260/M265 / M340/M360 / M440/M445 / 530/535 / 620/625 Mobile] (rev c1)
Flags: bus master, fast devsel, latency 0, IRQ 131
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=2M]
I/O ports at e000 [size=256]
Memory at df200000 (32-bit, non-prefetchable) [size=256K]
Expansion ROM at df240000 [disabled] [size=128K]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
I/O ports at d000 [size=256]
Memory at df104000 (64-bit, non-prefetchable) [size=4K]
Memory at df100000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169
03:00.0 Network controller: Intel Corporation Wireless 3165 (rev 79)
Subsystem: Intel Corporation Device 4410
Flags: bus master, fast devsel, latency 0, IRQ 130
Memory at df000000 (64-bit, non-prefetchable) [size=8K]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
output of lsusb
~ lsusb ✔
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 27c6:5301 Shenzhen Goodix Technology Co.,Ltd. Fingerprint Reader
Bus 001 Device 004: ID 8087:0a2a Intel Corp. Bluetooth wireless interface
Bus 001 Device 003: ID 1bcf:28c1 Sunplus Innovation Technology Inc. Integrated_Webcam_HD
Bus 001 Device 002: ID 046d:c534 Logitech, Inc. Unifying Receiver
Output of RFKILL
~ rfkill ✔
ID TYPE DEVICE SOFT HARD
0 bluetooth hci0 unblocked unblocked
1 wlan phy0 unblocked unblocked
Output of inxi -N
~ inxi -n ✔
driver: r8169
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: 54:b2:03:09:d0:4e
Device-2: Intel Wireless 3165 driver: iwlwifi
IF: wlp3s0 state: up mac: b4:6b:fc:45:6d:ed
Device-3: Intel Bluetooth wireless interface type: USB driver: btusb
Output of inxi -Fxz
~ inxi -Fxz INT ✘
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.23.4 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Vostro 5471 v: N/A
serial: <superuser required>
Mobo: Dell model: 05F5VX v: A00 serial: <superuser required> UEFI: Dell
v: 1.20.0 date: 10/06/2021
ID-1: BAT0 charge: 3.2 Wh (91.4%) condition: 3.5/42.0 Wh (8.3%) volts: 12.9
min: 11.4 model: Samsung SDI DELL CYMGM84 status: Charging
Info: quad core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Coffee Lake rev: A cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 702 high: 719 min/max: 400/4000 cores: 1: 719 2: 700
3: 700 4: 700 5: 700 6: 700 7: 700 8: 700 bogomips: 32012
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0
Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 / M440/M445 /
vendor: Dell driver: amdgpu v: kernel bus-ID: 01:00.0
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-5:3
Display: x11 server: X.Org 1.21.1.2 driver:
loaded: amdgpu,ati,modesetting resolution: 1: 1920x1080~60Hz
2: 1440x900~60Hz
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
vendor: Dell driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel bus-ID: 03:00.0
bus-ID: 1-7:4
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 bus-ID: 00:17.0
Local Storage: total: 585 GiB used: 289.42 GiB (49.5%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDH3 500G size: 465.76 GiB
ID-2: /dev/sdb vendor: LITE-ON model: CV8-8E128-11 SATA 128GB
ID-1: / size: 449.26 GiB used: 289.42 GiB (64.4%) fs: btrfs dev: /dev/sda2
ID-2: /boot/efi size: 511 MiB used: 572 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 449.26 GiB used: 289.42 GiB (64.4%) fs: btrfs
dev: /dev/sda2
ID-4: /var/log size: 449.26 GiB used: 289.42 GiB (64.4%) fs: btrfs
dev: /dev/sda2
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) dev: /dev/sda3
System Temperatures: cpu: 45.0 C pch: 42.0 C mobo: 41.0 C sodimm: SODIMM C
gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): cpu: 3073
Processes: 290 Uptime: 7m Memory: 15.53 GiB used: 3.79 GiB (24.4%)
Init: systemd Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1385
Shell: Zsh v: 5.8 inxi: 3.3.11
Output of pacman
~ pacman -Qs bluet INT ✘
local/bluedevil 1:5.23.4-1 (plasma)
Integrate the Bluetooth technology within KDE workspace and applications
local/bluez 5.62-1
Daemons for the bluetooth protocol stack
local/bluez-libs 5.62-1
Deprecated libraries for the bluetooth protocol stack
local/hidapi 0.11.0-1
Simple library for communicating with USB and Bluetooth HID devices
local/libldac 2.0.2.3-1
LDAC Bluetooth encoder library
local/pulseaudio-bluetooth 15.0-1
Bluetooth support for PulseAudio
local/sbc 1.5-2
Bluetooth Subband Codec (SBC) library
i have read some topic but not find solutions that work for me, so if there someone with more knowledge might be able to help me with this
Thanks in advance for any help
