Hi
I recently got a Thinkpad X1 8th gen, and am having issues with the battery. It’s a bit difficult to give a precise diagnostics but I will try.
I use a fresh Manjaro installation running KDE/Wayland, recently upgraded to Plasma 6. Kernel 6.9.0
- When I press the power button to wake from suspend, it typically does not respond unless power cord is connected.
- When I disconnect the power cord there is no battery icon showing. It sometimes comes for a few seconds (with a sound alert), and then disappears again (with another sound alert).
tlp-stat --battery
reports “No batteries detected.” under battery status- I upgraded to lastest bios version, did not help.
- I tried to remove
~/.config/plasma-org.kde.plasma.desktop-appletsrc
as suggested elsewhere on forum, did not help. - in journalctl I find the message
kernel: thinkpad_acpi: battery 1 registered (start 0, stop 100, behaviours: 0x7)
on regular intervals. - I tried to reload the
thinkpad-acpi
module, did not seem to help much. - I’m out of ideas pretty much…
$ inxi --full --verbosity=7 --filter --no-host
Kernel: 6.8.9-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_wayland with: krunner
vt: 1 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 20U90048MH v: ThinkPad X1 Carbon Gen 8
Mobo: LENOVO model: 20U90048MH v: SDK0J40697 WIN
serial: <superuser required> part-nu: LENOVO_MT_20U9_BU_Think_FM_ThinkPad
X1 Carbon Gen 8 uuid: <superuser required> UEFI: LENOVO
v: N2WET45W (1.35 ) date: 03/18/2024
System RAM: total: 16 GiB available: 15.29 GiB used: 8.93 GiB (58.4%)
Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: LPDDR3 detail: synchronous size: 8 GiB
speed: 2133 MT/s volts: 1 width (bits): data: 64 total: 64
manufacturer: SK Hynix part-no: N/A serial: N/A
Device-2: ChannelB-DIMM0 type: LPDDR3 detail: synchronous size: 8 GiB
Info: quad core model: Intel Core i5-10210U bits: 64 type: MT MCP
smt: enabled arch: Comet/Whiskey Lake note: check rev: C cache: L1: 256 KiB
L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 500 high: 800 min/max: 400/4200 cores: 1: 400 2: 400
3: 400 4: 800 5: 400 6: 400 7: 400 8: 800 bogomips: 33615
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-9.5 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 1-8:2 chip-ID: 04f2:b6cb class-ID: fe01
serial: <filter>
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9b41 display-ID: :1.0
API: Vulkan v: 1.3.279 layers: N/A surfaces: xcb,xlib,wayland device: 0
type: integrated-gpu driver: mesa intel device-ID: 8086:9b41
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo
driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8
class-ID: 0403
API: ALSA v: k6.8.9-3-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4f class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
speed: 12 Mb/s lanes: 1 bus-ID: 1-10:4 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 931.51 GiB used: 175.52 GiB (18.8%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD BLACK SN850X 1000GB
size: 931.51 GiB speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 620311WD temp: 36.9 C scheme: GPT
ID-1: / size: 898.97 GiB used: 175.52 GiB (19.5%) fs: ext4
dev: /dev/nvme0n1p2 label: N/A uuid: 9351ebe9-cf5c-4af2-a04f-2078c829c8be
ID-2: /boot/efi size: 299.4 MiB used: 548 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1 label: N/A uuid: FC7C-67DE
ID-1: swap-1 type: partition size: 16.82 GiB used: 2.4 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 label: swap
uuid: 42d7f1a8-bd63-43d3-bda3-69d2bec001e2
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
speed: 480 Mb/s lanes: 1 chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-8:2 info: Chicony Integrated Camera type: video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s lanes: 1
power: 500mA chip-ID: 04f2:b6cb class-ID: fe01 serial: <filter>
Device-2: 1-9:13 info: Synaptics Prometheus MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
lanes: 1 power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
Device-3: 1-10:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s lanes: 1 power: 100mA
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
lanes: 1 chip-ID: 1d6b:0003 class-ID: 0900
Hub-4: 4-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Src: /sys System Temperatures: cpu: 44.0 C pch: 51.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 369 Power: uptime: 4h 51m states: freeze,mem,disk suspend: deep
wakeups: 1 hibernate: platform Init: systemd v: 255 default: graphical
Packages: pm: pacman pkgs: 2127 Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: Zsh v: 5.9 running-in: yakuake inxi: 3.3.34
Edit: clarifications
