After booting from hibernate the system doesn’t detect the battery anymore. Charger wasn’t disconnected during hibernation. Anyone knows how to fix it?
Following are some command outputs
tlp-stat --battery
--- TLP 1.6.1 --------------------------------------------
+++ Battery Care
Plugin: generic
Supported features: none available
+++ Battery Status
No batteries detected.
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=2ea52265-a8ef-4b5e-986c-648132a61b62 rw quiet splash apparmor=1
resume=UUID=bde845f2-8313-4207-96a1-b5415e0760f1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20QKS12H1B v: ThinkPad T495s
Mobo: LENOVO model: 20QKS12H1B serial: <superuser required> UEFI: LENOVO
v: R13ET35W(1.09 ) date: 07/31/2019
System RAM: total: 16 GiB note: est. available: 13.56 GiB
used: 4.1 GiB (30.2%)
Info: model: AMD Ryzen 5 PRO 3500U w/ Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108102
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1471 high: 2312 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2312 2: 1474
3: 1397 4: 1400 5: 1227 6: 1311 7: 1227 8: 1424 bogomips: 33547
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 64.0 C
Device-2: Chicony ThinkPad T490 Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-2.1:4 chip-ID: 04f2:b681
Display: x11 server: X.org v: 1.21.1.10 compositor: xfwm v: 4.18.0 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14e4 built: 2018 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics (raven
LLVM 16.0.6 DRM 3.54 6.6.8-2-MANJARO) device-ID: 1002:15d8 memory: 1.95 GiB
unified: no
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2526 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2400 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0f0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1:2
chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 238.47 GiB used: 12.97 GiB (5.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HBHQ-000L7
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 5M2QEXH7 temp: 38.9 C
scheme: GPT
ID-1: / raw-size: 77.68 GiB size: 75.91 GiB (97.72%) used: 12.94 GiB (17.0%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 2ea52265-a8ef-4b5e-986c-648132a61b62
used: 26.7 MiB (27.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: D61A-3C7C
ID-1: swap-1 type: partition size: 20 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: bde845f2-8313-4207-96a1-b5415e0760f1
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 140.07 GiB fs: ntfs label: N/A
uuid: 4C981F8C981F7424
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 625 MiB fs: ntfs label: N/A
uuid: 12C63615C635FA15
Hub-1: 1-0:1 info: full speed or root hub ports: 1 rev: 2.0
Hub-2: 2-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-3: 3-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 4-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 4-1:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-5: 4-2:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 4-2.1:4 info: Chicony ThinkPad T490 Webcam type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 04f2:b681 class-ID: 0e02 serial: <filter>
Hub-6: 5-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 63.0 C mobo: N/A gpu: amdgpu temp: 62.0 C
Fan Speeds (rpm): fan-1: 3000 fan-2: 3000
Processes: 296 Uptime: 11m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1193 libs: 339 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.2.21
running-in: xfce4-terminal inxi: 3.3.31
ls -al /sys/class/power_supply/
insgesamt 0
drwxr-xr-x 2 root root 0 7. Jan 15:11 .
drwxr-xr-x 81 root root 0 7. Jan 14:59 ..
lrwxrwxrwx 1 root root 0 7. Jan 14:59 AC -> ../../devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:2f/PNP0C09:00/ACPI0003:00/power_supply/AC
upower -e
/org/freedesktop/UPower/devices/line_power_AC
/org/freedesktop/UPower/devices/DisplayDevice
an 07 14:59:37 laptop kernel: ACPI: battery: Slot [BAT0] (battery present)
Jan 07 14:59:38 laptop kernel: thinkpad_acpi: battery 1 registered (start 75, stop 80, behaviours: 0x7)
Jan 07 14:59:38 laptop kernel: ACPI: battery: new extension: ThinkPad Battery Extension
Jan 07 15:10:32 laptop dbus-daemon[674]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.103' (uid=0 pid=4506 comm="sudo tlp-stat --battery")
Jan 07 15:10:36 laptop sudo[4506]: thomas : TTY=pts/0 ; PWD=/home/thomas ; USER=root ; COMMAND=/usr/bin/tlp-stat --battery
journalctl -b | grep hibernate
Jan 07 15:00:14 laptop systemd-logind[690]: The system will hibernate now!
Jan 07 15:00:15 laptop systemd-sleep[2230]: Entering sleep state 'hibernate'...
Jan 07 15:01:24 laptop systemd[1]: systemd-hibernate.service: Deactivated successfully.
Jan 07 15:01:24 laptop systemd[1]: systemd-hibernate.service: Consumed 1.970s CPU time.
dmesg | grep bat
[ 0.407307] libata version 3.00 loaded.
[ 1.050007] ACPI: battery: Slot [BAT0] (battery present)
[ 8.162025] thinkpad_acpi: battery 1 registered (start 75, stop 80, behaviours: 0x7)
[ 8.162052] ACPI: battery: new extension: ThinkPad Battery Extension
dmesg | grep error
[ 46.298045] ACPI Error: Aborting method \_PR.C003._PPC due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 46.299750] ACPI Error: Aborting method \_PR.C004._PPC due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 46.301453] ACPI Error: Aborting method \_PR.C005._PPC due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 46.303413] ACPI Error: Aborting method \_PR.C006._PPC due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 46.307006] ACPI Error: Aborting method \_SI._SST due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 46.307043] ACPI Error: Aborting method \_WAK due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 46.307075] ACPI Error: Aborting method \_SI._SST due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 46.307157] ACPI Error: Aborting method \_SB.PCI0.GP17.XHC0.PUBS._STA due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 46.570915] ACPI Error: Aborting method \_SB.LID._LID due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 46.570948] ACPI Error: Aborting method \_SB.LID._LID due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 46.580584] ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0._Q9A due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 47.106799] ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.HKEY.MHKC due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 47.106813] thinkpad_acpi: error while attempting to reset the event firmware interface
[ 47.106858] ACPI Error: Aborting method \WFIO due to previous error (AE_AML_OPERAND_TYPE) (20230628/psparse-529)
[ 47.106866] ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.HKEY.WLSW due to previous error (AE_AML_OPERAND_TYPE) (20230628/psparse-529)
[ 47.106911] ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.SAUM due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 47.106947] ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.HKEY.SSMS due to previous error (AE_AML_MUTEX_NOT_ACQUIRED) (20230628/psparse-529)
[ 47.107027] ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.HKEY.MMTS due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 47.107086] ACPI Error: Aborting method \_SB.PCI0.GP17.VGA.AFN4 due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 47.107094] ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.HKEY.SSSS due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 47.107695] ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.HKEY.MLCS due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 47.792243] ACPI Error: Aborting method \_SB.PCI0.GP17.XHC0._S0W due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 48.108532] ACPI Error: Aborting method \_SB.PCI0.GP17.XHC0._S0W due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 48.108571] ACPI Error: Aborting method \_SB.PCI0.GP17.XHC0._S0W due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 48.130589] ACPI Error: Aborting method \_SB.PCI0.GP17.XHC0.PUBS._OFF due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 49.736237] ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.HKEY.SBDC due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 49.736277] ACPI Error: Aborting method \_SB.PCI0.LPC0.EC0.HKEY.GBDC due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
