HP U28 monitor’s audio device isn’t appearing in System Settings → Audio.
The monitor is connected via USB-C
The audio device works under Windows 11.
Kernel: 5.15.53-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=3c0a0710-4b10-4ce3-8e02-e2205254503a rw quiet
resume=UUID=8e200f12-4c57-483b-a3a1-1c35cecc0a7f udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: Z490 VISION D v: -CF
serial: <superuser required>
Mobo: Gigabyte model: Z490 VISION D serial: <superuser required>
UEFI: American Megatrends v: F21 date: 11/24/2021
RAM: total: 31.2 GiB used: 8.63 GiB (27.7%)
RAM Report:
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 5 microcode: 0xF0
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2898 high: 4800 min/max: 800/5100 scaling:
driver: intel_pstate governor: powersave cores: 1: 4639 2: 4004 3: 800
4: 1743 5: 1621 6: 4659 7: 803 8: 2309 9: 4512 10: 800 11: 800 12: 1297
13: 4691 14: 4800 15: 4323 16: 4581 bogomips: 121639
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb
pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good
sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: Gigabyte
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: DP-1 empty: DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:9bc5 class-ID: 0300
Device-2: Microsoft LifeCam HD-3000 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-3:2 chip-ID: 045e:0810
class-ID: 0102
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
s-diag: 1165mm (45.88")
Monitor-1: DP-1 model: HP U28 4K HDR serial: <filter> built: 2022
res: 3840x2160 hz: 60 dpi: 157 gamma: 1.2 size: 621x341mm (24.45x13.43")
diag: 708mm (27.9") ratio: 16:9 modes: max: 3840x2160 min: 720x400
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CML GT2) v: 4.6 Mesa 22.1.3
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 1-3:2 alternate: snd_soc_skl,snd_sof_pci_intel_cnl
chip-ID: 045e:0810 bus-ID: 00:1f.3 class-ID: 0102 chip-ID: 8086:06c8
class-ID: 0403
Sound Server-1: ALSA v: k5.15.53-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.54 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4d class-ID: 0200
IF: eno2 state: down mac: <filter>
Device-3: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
chip-ID: 8086:15f3 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
IP v4: <filter> scope: global
Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1 all]
bus-ID: 1-14:9 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 8.24 TiB used: 28.42 GiB (0.3%)
model: WD Blue SN570 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 234100WD temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Western Digital
rev: 234100WD temp: 33.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:2 vendor: Western Digital
rev: 234100WD temp: 31.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD60EZAZ-00SF3B0 size: 5.46 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A80 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 57.75 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 896.9 GiB size: 881.75 GiB (98.31%) used: 28.4 GiB (3.2%)
fs: ext4 dev: /dev/nvme2n1p2 maj-min: 259:8 label: N/A
uuid: 3c0a0710-4b10-4ce3-8e02-e2205254503a
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme2n1p1 maj-min: 259:7
label: NO_LABEL uuid: 62A6-59A3
ID-3: /run/media/New Volume raw-size: 1.05 TiB
size: 1.05 TiB (100.00%) used: 2 MiB (0.0%) fs: exfat dev: /dev/sda4
maj-min: 8:4 label: New Volume uuid: 8061-43CE
ID-4: /run/media/New Volume1 raw-size: 2.31 TiB
size: 2.31 TiB (100.00%) used: 4 MiB (0.0%) fs: exfat dev: /dev/sda5
maj-min: 8:5 label: New Volume uuid: EE7D-1456
ID-1: swap-1 type: partition size: 34.31 GiB used: 9 MiB (0.0%)
priority: -2 dev: /dev/nvme2n1p3 maj-min: 259:9 label: swap
uuid: 8e200f12-4c57-483b-a3a1-1c35cecc0a7f
ID-1: /dev/nvme0n1p1 maj-min: 259:3 size: 100 MiB fs: vfat label: N/A
uuid: 2CC6-0E05
ID-2: /dev/nvme0n1p2 maj-min: 259:4 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:5 size: 930.8 GiB fs: ntfs label: N/A
uuid: 282ACA6E2ACA3898
ID-4: /dev/nvme0n1p4 maj-min: 259:6 size: 611 MiB fs: ntfs label: N/A
uuid: 4CDCC914DCC8F8EA
ID-5: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-6: /dev/sda2 maj-min: 8:2 size: 1.05 TiB fs: ntfs label: NTFS-HDD
uuid: 54443EEF443ED388
ID-7: /dev/sda3 maj-min: 8:3 size: 1.05 TiB fs: exfat label: New Volume
uuid: F058-84EA
ID-8: /dev/sdb1 maj-min: 8:17 size: 3.27 GiB fs: iso9660
ID-9: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 07DE-4587
ID-10: /dev/sdb3 maj-min: 8:19 size: 54.47 GiB fs: ext4 label: Backup
uuid: e3479b9b-6c29-4f69-9ef1-8322698f1c9b
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-3:2 info: Microsoft LifeCam HD-3000 type: Video,Audio
power: 500mA chip-ID: 045e:0810 class-ID: 0102
Hub-2: 1-7:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 0bda:5411 class-ID: 0900
Hub-3: 1-8:4 info: HP Z24i Monitor Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 03f0:0610 class-ID: 0900
Device-1: 1-9:5 info: Logitech Internet 350 Keyboard type: Keyboard,HID
power: 70mA chip-ID: 046d:c313 class-ID: 0300
Device-2: 1-10:13 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2521 class-ID: 0301
Hub-4: 1-11:7 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-12:8 info: Integrated Express ITE Device type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-2: 1-14:9 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-5: 2-0:1 info: Super-speed hub ports: 10 rev: 3.1 speed: 10 Gb/s
Device-1: 2-6:4 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s
power: 504mA chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
Hub-6: 2-7:2 info: Realtek Hub ports: 4 rev: 3.2 speed: 5 Gb/s power: 96mA
chip-ID: 0bda:0411 class-ID: 0900
System Temperatures: cpu: 31.0 C pch: 39.0 C mobo: N/A
Processes: 380 Uptime: 8h 38m wakeups: 43 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
Packages: pacman: 1180 lib: 319 flatpak: 0 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.19
