No audio: several seconds after system start there is no sound
Greetings, everyone! Recently got issue (I suppose, after I updated some pieces of software), that there is no audio several seconds after system start.
Here is my inxi -Faz output:
  Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=b6cfeebd-629e-4403-b8bc-becf0cf727e1 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Acer product: Aspire A317-53 v: V1.20
    serial: <superuser required>
  Mobo: TGL model: Lilac_TL v: V1.20 serial: <superuser required>
    UEFI: Insyde v: 1.20 date: 11/03/2021
  ID-1: BAT1 charge: 20.4 Wh (48.0%) condition: 42.5/41.6 Wh (102.2%)
    volts: 11.2 min: 11.2 model: LGC AP19B8K type: Li-ion serial: <filter>
    status: discharging cycles: 5
  Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xA6
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 816 high: 1163 min/max: 400/4700 scaling:
    driver: intel_pstate governor: powersave cores: 1: 421 2: 521 3: 1031
    4: 1006 5: 1011 6: 1163 7: 749 8: 630 bogomips: 44864
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics]
    vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-12.1
    process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-8:3
    chip-ID: 04f2:b72b class-ID: fe01 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: BOE Display 0x084e built: 2018 res: 1920x1080
    hz: 60 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel Xe Graphics (TGL GT2)
    direct render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio
    vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
  Sound Server-1: PulseAudio v: 16.1 running: no
  Sound Server-2: PipeWire v: 0.3.61 running: yes
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
    vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
    driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 102.48 GiB (21.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
    SDBPNPZ-512G-1114 size: 476.94 GiB block-size: physical: 512 B
    rev: 21113000 temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 102.48 GiB (21.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 34.0 C mobo: N/A
  Processes: 245 Uptime: 15m wakeups: 1870 Memory: 15.41 GiB
  used: 2.57 GiB (16.7%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1870
  pm: pacman pkgs: 1834 libs: 383 tools: pamac pm: flatpak pkgs: 36 Shell: Zsh
  v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
Additional information (if needed) from aplay -L:
null
    Discard all samples (playback) or generate zero samples (capture)
lavrate
    Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pipewire
    PipeWire Sound Server
pulse
    PulseAudio Sound Server
speex
    Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default
    Default ALSA Output (currently PipeWire Media Server)
sysdefault:CARD=sofhdadsp
    sof-hda-dsp,
    Default Audio Device
usbstream:CARD=sofhdadsp
    sof-hda-dsp
    USB Stream Output
Solved this problem by updating my kernel to 6.0.11 version
