Hi guys, long time I haven´t seek for help on the forum. For a couple days now I’ve been with an issue in Zoom in where I am able to listen to the other party in the meeting but they cannot hear me. The microphone is not silenced, and other apps like Google Meet/Teamspeak works fine. Is only zoom that is not recording the microphone.
I had checked the audio configuration in zoom but everything seems fine, but when I talk the recording bar doesnt move. I have already updated to the last version of Manjaro.
Here some info of my system.
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=37d79bae-29ba-41d6-9182-710f49530050 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: LENOVO product: F0EW005SUS v: IdeaCentre AIO 3 24ARE05
serial: <superuser required> Chassis: type: 13 serial: <superuser required>
Mobo: LENOVO model: 371C v: SDK0J40700 WIN 3258192621239
serial: <superuser required> UEFI: LENOVO v: O4SKT25A date: 12/21/2020
Info: model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2341 high: 3117 min/max: 1400/2375 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3117 2: 2200
3: 2243 4: 2133 5: 2188 6: 2167 bogomips: 28453
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 174f:243e class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: Lenovo LEN-A350-B-A serial: <filter>
built: 2019 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.42 5.15.38-1-MANJARO)
v: 4.6 Mesa 22.0.3 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: no
Sound Server-3: PipeWire v: 0.3.51 running: yes
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:c822
class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 125.72 GiB (26.4%)
model: MZALQ512HALU-000L1 size: 476.94 GiB block-size: physical: 512 B
rev: 9L1QFXV7 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 125.72 GiB (26.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 48.0 C
Processes: 234 Uptime: 1h 24m wakeups: 0 Memory: 15.12 GiB
used: 4.69 GiB (31.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1308 lib: 381 flatpak: 0
Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.15
