I installed pipewire and removed pulse-audio. Now, I do not have sound, camera or microphone working.
This is the output of systemctl --user status wireplumber pipewire pipewire-pulse
● wireplumber.service - Multimedia Service Session Manager
Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset: enabled)
Active: active (running) since Thu 2023-08-24 12:34:36 IST; 1s ago
Main PID: 8270 (wireplumber)
Tasks: 8 (limit: 18865)
Memory: 9.2M
CPU: 219ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
└─8270 /usr/bin/wireplumber
Aug 24 12:34:36 ritchie systemd[1325]: Started Multimedia Service Session Manager.
Aug 24 12:34:36 ritchie wireplumber[8270]: [1:14:48.793944383] [8270] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
Aug 24 12:34:36 ritchie wireplumber[8270]: [1:14:48.793962183] [8270] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
Aug 24 12:34:36 ritchie wireplumber[8270]: [1:14:48.793989216] [8270] INFO Camera camera_manager.cpp:284 libcamera v0.1.0
Aug 24 12:34:37 ritchie wireplumber[8270]: <WpPortalPermissionStorePlugin:0x5606a9431740> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
TriggeredBy: ● pipewire.socket
Main PID: 8269 (pipewire)
Tasks: 4 (limit: 18865)
Memory: 5.1M
CPU: 78ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─8269 /usr/bin/pipewire
Aug 24 12:34:36 ritchie systemd[1325]: Started PipeWire Multimedia Service.
Aug 24 12:34:37 ritchie pipewire[8269]: [1:14:49.156814667] [8269] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
Aug 24 12:34:37 ritchie pipewire[8269]: [1:14:49.156855402] [8269] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
Aug 24 12:34:37 ritchie pipewire[8269]: [1:14:49.156920316] [8269] INFO Camera camera_manager.cpp:284 libcamera v0.1.0
× pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Thu 2023-08-24 12:34:37 IST; 333ms ago
Duration: 90ms
TriggeredBy: × pipewire-pulse.socket
Process: 8302 ExecStart=/usr/bin/pipewire-pulse (code=exited, status=239/CACHE_DIRECTORY)
Main PID: 8302 (code=exited, status=239/CACHE_DIRECTORY)
CPU: 57ms
Aug 24 12:34:37 ritchie systemd[1325]: pipewire-pulse.service: Scheduled restart job, restart counter is at 5.
Aug 24 12:34:37 ritchie systemd[1325]: Stopped PipeWire PulseAudio.
Aug 24 12:34:37 ritchie systemd[1325]: pipewire-pulse.service: Start request repeated too quickly.
Aug 24 12:34:37 ritchie systemd[1325]: pipewire-pulse.service: Failed with result 'exit-code'.
Aug 24 12:34:37 ritchie systemd[1325]: Failed to start PipeWire PulseAudio.
This is the output of sudo fuser -v /dev/snd/*
USER PID ACCESS COMMAND
/dev/snd/controlC0: jmonreal 8270 F.... wireplumber
/dev/snd/seq: jmonreal 8269 F.... pipewire
This is the output of journalctl --user -xeu pipewire-pulse.service
Subject: Unit failed
Defined-By: systemd
Support: https://forum.manjaro.org/c/support
The unit UNIT has entered the 'failed' state with result 'exit-code'.
Subject: A start job for unit UNIT has failed
Defined-By: systemd
A start job for unit UNIT has finished with a failure.
The job identifier is 1512 and the job result is failed.
Does anyone have any idea of a workaround?
