No Audio on Acer Swift 3
Hello,
I am new to Manjaro and having issues with audio and have searched in the forum but I haven’t got any better solution and my audio-output is still not detected. I use fresh-installed Manjaro (Kernel 5.9.16-1) dual-boot with Windows 10 with KDE on Acer Swift 3.
My case is similar to this post but in my case I cannot use headphones, too.
The pa-info gives me this: https://pastebin.com/DiQzYmZq
ran with pa-info > "pa-info.txt" and has error
ls: cannot access '/proc/asound/card[0-9]': No such file or directory
alsactl: save_state:1595: No soundcards found...
cat: /tmp/alsa-info.e1HtERR8Yz/alsactl.tmp: No such file or directory
dmesg: read kernel buffer failed: Operation not permitted
The lspci -k gives me https://pastebin.com/RjPrMP80
Command inxi --audio gives me
itsmeyaw@itsmeYAW  ~  inxi --audio
Audio:     Device-1: Intel Sunrise Point-LP HD Audio driver: snd_soc_skl
           Sound Server: ALSA v: k5.9.16-1-MANJARO
And I already ran these command:
sudo pacman -S  sof-firmware alsa-ucm-conf
and this command, too
sudo rmmod snd_sof_pci && sudo modprobe snd_sof_pci
which gives me in journalctl -f the output https://pastebin.com/Z6C8Bnwm
However the fix with
pulseaudio --start
pulseaudio -k
pulseaudio --start
doesn’t help me.
Does anybody know how I can fix it?
ps. I cannot access my UEFI after installing Manjaro (it just went blackscreen), but I am not sure if that affect this.
Thank you in advance :smiley:
Sincerely,
Yudhis
Hello,
Try to edit the file /etc/modprobe.d/alsa-base.conf or create it and add the following lines:
options snd-hda-intel dmic_detect=0
options snd-hda-intel model=laptop-amic enable=yes
The first line is to enable the speaker, the second for the internal microphone.
For that you might have to consult this
https://wiki.archlinux.org/index.php/Advanced_Linux_Sound_Architecture#ALSA_Firmware
Not sure what you did after installing is the proper way …
Thanks for the reply!
I just noticed that the file doesn’t exists at the first place. I just make the file and added those line. And then I do a restart and now it is functioning. But it won’t detect my headset mic :sweat_smile: I am now still trying to search which is the driver for my headset mic. Maybe adding it to the alsa-base will enable it, too? :sweat_smile:
But many thanks for the solution. It is much appreciated :star:
You can try it? I don’t know if it works like that as I’ve never messed with that.
Feel free to open a new thread to ask for help with this if you’re still having issues! :smiley:
