I couldn’t make my bluetooth headphones work as in pavucontrol, the only output devices I had are speakers and headphones (unplugged). I tried installing things to solve it, but I made it worse:
$ history
424 sudo pacman -Syu
425 sudo pacman -Syu
426 exit
427 sudo pacman -S pavucontrol
428 pavucontrol
429 sudo pacman -S pulseaudio pulseaudio-module-bluetooth
430 sudo pacman -S pulseaudio
431 ls .config
432 mv ~/.config/pulse/ Downloads/pulse
433 systemctl --user restart pulseaudio
434 reboot
435 diff Downloads/pulse/ .config/pulse/
436 rm -rf .config/pulse/
437 mv Downloads/pulse/ .config/pulse
438 systemctl --user restart pulseaudio
439 pactl list | grep -C2 A2DP
440 pacmd list-cards
441 pacmd list-sinks
442 dmesg | grep -i bluetooth
443 alsamixer
444 amixer -c 0 scontrols
445 pulseaudio -k
446 pactl load-module module-bluetooth-discover
447 pactl
448 sudo systemctl restart bluetooth
449 pavucontrol --show-all-sinks
450 pavucontrol --restart
451 sudo pacman -S bluez-libs bluez-alsa
452 yay -S pulseaudio-bluetooth-git
453 yay -R pulseaudio-bluetooth-git
454 sudo pacman -R pulseaudio-bluetooth-git
455 sudo pacman -S bluez-libs
456 yay -S bluez-alsa-git
457 sudo systemctl status bluetooth
458 pacman -Qqt
459 pacman -Q bluez
460 sudo hciconfig hci0 down
461 hciconfig hci0 down
462 reboot
463 pacmd dump; pactl list cards
464 pamac install manjaro-pipewire
465 reboot
466 sudo pacman -R manjaro-pipewire
467 sudo pacman -R pipewire
468 sudo pacman -Rns pipewire gst-plugin-pipewire pipewire-alsa pipewire-audio pipewire-pulse telegram-desktop wireplumber xdg-desktop-portal xdg-desktop-portal-wlr
469 sudo pacman -Rns pipewire
470 sudo pacman -Rns gst-plugin-pipewire pipewire-alsa pipewire-audio pipewire-pulse telegram-desktop wireplumber xdg-desktop-portal xdg-desktop-portal-wlr
471 sudo pacman -S pulseaudio
472 reboot
473 bluetoothctl devices
474 pactl list sinks short
475 pactl list sinks short
476 pactl list sinks short
477 blueman
478 sudo pacman -S blueman
479 blueman-manager
480 lxappearance
481 history
482 history
483 yay -R pulseaudio-bluetooth-git
484 sudo pacman -R pulseaudio-bluetooth-git
485 sudo pacman -R pulseaudio-bluetooth
486 sudo pacman -R bluez-alsa-git
487 sudo pacman -R manjaro-pipewire
488 sudo systemctl status bluetooth
489 pavucontrol --restart
490 pulseaudio --restart
491 sudo systemctl status bluetooth
492 sudo systemctl stop bluetooth
493 sudo systemctl start bluetooth
494 alsamixer
495 sudo pacman -R pipewire
496 alsamixer
497 alsamixer
498 exit
499 xterm
500 xprop
501 urxvt
502 qt5ct
503 sudo pacman -S ffmeg
504 sudo pacman -S ffmpeg
505 sudo pacman -R ffmpeg
Most of these commands didn’t work, I was trying anything I saw online. The output is that audio stopped working and now, any video or audio also fails to run. I tried videos on qutebrowser, chromium, and whatsdesk, and an audio on whatsdesk.
For further information, I run in my i3-config file “exec --no-startup-id volumeicon”, but when I start using my pc, it isn’t there, but I can open it myself. Also, when I open alsamixer, I can see that the default card is pipewire now (which wasn’t before)
