As I mentioned in the original post, the only changes I made where the ones specified in the Arch Wiki for Troubleshooting with Pulseaudio (Microphone not detected by PulseAudio) and installing sof-firmware
Apparently those two changes were enough to get the microphone to start detecting input again; however several reboots were required for Manjaro to start using the right configuration, I guess. To be honest, I don’t know exactly why or how the microphone started to work again, the first time I made the changes specified the microphone wasn’t working, neither the second or third time I rebooted.
I’ll post some information that may be useful to someone that might have the same problem I had.
inxi -Fxxxz
Kernel: 5.6.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 80WK v: Lenovo Y520-15IKBN
serial: <filter> Chassis: type: 10 v: Lenovo Y520-15IKBN serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter>
UEFI [Legacy]: LENOVO v: 4KCN40WW date: 10/17/2017
ID-1: BAT0 charge: 39.9 Wh condition: 39.9/45.0 Wh (89%) volts: 12.3/11.1
model: SMP L14M3P24 type: Li-poly serial: <filter> status: Full
Topology: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP
arch: Kaby Lake rev: 9 L2 cache: 6144 KiB
bogomips: 20004
Speed: 898 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 900 2: 900
3: 900 4: 900
Device-1: Intel HD Graphics 630 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Lenovo
driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:1c8d
Device-3: Realtek EasyCamera type: USB driver: uvcvideo bus ID: 1-6:3
chip ID: 0bda:58e5 serial: <filter>
Display: x11 server: X.Org 1.20.8 driver: intel,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa resolution: 1920x1080~60Hz
s-dpi: 96
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.1.7
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:1f.3 chip ID: 8086:a171
Sound Server: ALSA v: k5.6.19-2-MANJARO
Device-1: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel port: 4000 bus ID: 03:00.0 chip ID: 8086:3166
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus ID: 04:00.0
chip ID: 10ec:8168
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 17.60 GiB (1.9%)
ID-1: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB
speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 2E scheme: MBR
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus ID: 00:17.0 chip ID: 8086.282a rev: 31
ID-1: / size: 287.37 GiB used: 17.60 GiB (6.1%) fs: ext4 dev: /dev/sda4
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nouveau temp: 33 C
Processes: 187 Uptime: 35m Memory: 7.67 GiB used: 2.26 GiB (29.4%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1137
Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
pacmd list-cards
1 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 28
properties:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xa43a8000 irq 133"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "a171"
device.product.name = "CM238 HD Audio Controller"
device.string = "0"
device.description = "Built-in Audio"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
input:analog-stereo: Analog Stereo Input (priority 65, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: unknown)
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (priority 5965, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
output:hdmi-stereo-extra4+input:analog-stereo: Digital Stereo (HDMI 5) Output + Analog Stereo Input (priority 5765, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround-extra4+input:analog-stereo: Digital Surround 5.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround71-extra4+input:analog-stereo: Digital Surround 7.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: no)
off: Off (priority 0, available: unknown)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_00_1f.3.analog-stereo/#1: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#2: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1f.3.analog-stereo/#3: Built-in Audio Analog Stereo
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 30000 usec, available: unknown)
properties:
analog-input-mic: Microphone (priority 8700, latency offset -10000 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
pacmd list-sources
3 source(s) available.
* index: 0
driver: <module-alsa-source.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: RUNNING
suspend cause: (none)
priority: 9030
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 9.38 ms
max rewind: 0 KiB
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 1
linked by: 1
configured latency: 40.00 ms; range is 0.50 .. 2000.00 ms
module: 5
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC233 Analog"
alsa.id = "ALC233 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
device.string = "hw:0,0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.icon_name = "audio-input-microphone-pci"
index: 2
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: RUNNING
priority: 1030
volume: front-left: 65523 / 100% / -0.01 dB, front-right: 65523 / 100% / -0.01 dB
balance 0.00
volume steps: 65537
muted: no
current latency: 0.00 ms
max rewind: 7 KiB
sample spec: s16le 2ch 48000Hz
Stereo
used by: 2
linked by: 2
configured latency: 40.00 ms; range is 0.50 .. 1837.50 ms
monitor_of: 1
card: 0 <alsa_card.pci-0000_00_1f.3>
module: 28
properties:
device.description = "Monitor of Built-in Audio Analog Stereo"
device.class = "monitor"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
index: 3
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
priority: 9039
volume: front-left: 20560 / 31% / -30.21 dB, front-right: 20203 / 31% / -30.66 dB
balance -0.02
base volume: 6554 / 10% / -60.00 dB
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 1
linked by: 1
configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
module: 28
properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
device.string = "front:0"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
alsa.mixer_name = "Realtek ALC233"
alsa.components = "HDA:10ec0235,17aa3844,00100002 HDA:8086280b,80860101,00100000"
ports:
properties:
properties:
active port: <analog-input-internal-mic>
pacman -Q --info sof-firmware
Version : 1.5.1-1
Description : Sound Open Firmware
Architecture : any
URL : https://www.sofproject.org/
Licenses : custom:BSD custom:ISC
Groups : None
Provides : None
Depends On : None
Optional Deps : None
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 5.43 MiB
Packager : Jan Alexander Steffens (heftig) <heftig@archlinux.org>
Build Date : Thu 11 Jun 2020 07:04:34 PM CDT
Install Date : Tue 22 Sep 2020 09:55:54 PM CDT
Install Reason : Explicitly installed
Install Script : No
Validated By : Signature
