Hi Team
Long time user, Recently got the Rog strix Scar 18 laptop , primarily to use for Machine learning. So far everything is working smooth. Except the audio… so far haven’t managed to get it to work.
Happy to provide details as necessary ,
Thanks in Advance
Hi there. Hopefully you get this sorted soon. What DE are you using? Also, Pipewire, PulseAudio? The more info the better. Also, are you using 6.1 LTS kernel & what results do you get if you try 5.15? All the best with this one…
This laptop is damn new, even the soundcard is from 2022, so also use as new kernel as possible, either 6.1 or 6.2. Forget anything earlier, usually new hardware support is not backported even to the previous LTS. It’s still not a guarantee, though. Getting day-1 support on a complex machine does not typically happen. My GL503VD got its full support after 1.5 year or so from the date I bought, and that still excluded the RGB control (that one came in 2021, I think).
Thanks for your response. I’m currently using GNOME as my DE. Regarding the audio system, I am using PipeWire. I apologize for not mentioning these details earlier.
As for the kernel, I’m using the 6.2.10-1-MANJARO kernel. I haven’t tried the 5.15 kernel yet, but I can give it a shot and let you know how it goes.
Additionally, here’s the output of inxi -A:
Device-1: Intel driver: snd_hda_intel
Device-2: NVIDIA driver: snd_hda_intel
API: ALSA v: k6.2.10-1-MANJARO status: kernel-api
Server-1: PipeWire v: 0.3.68 status: active
I hope this information helps you in assisting me with this issue. Thanks again for your help!
Here’s the output of inxi -Fza :
Kernel: 6.2.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.2-x86_64
root=UUID=182723df-af4e-4300-8fae-1c8a8b56edd6 rw quiet splash apparmor=1
Desktop: GNOME v: 43.4 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: ASUSTeK product: ROG Strix G834JZ_G834JZ v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G834JZ v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G834JZ.308 date: 03/17/2023
ID-1: BAT0 charge: 90.5 Wh (100.0%) condition: 90.5/90.0 Wh (100.5%)
volts: 17.5 min: 16.0 model: AS3GYFG3KC R220358 type: Unknown
serial: <filter> status: full
Info: model: 13th Gen Intel Core i9-13980HX bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
microcode: 0x112
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 1936 high: 2400 min/max: 800/5400:5600:4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 987 2: 2400 3: 950 4: 800
5: 871 6: 2400 7: 2400 8: 2400 9: 999 10: 2400 11: 938 12: 2400 13: 800
14: 2400 15: 960 16: 898 17: 955 18: 2400 19: 2400 20: 2400 21: 2400
22: 2400 23: 2400 24: 2400 25: 2400 26: 2400 27: 2400 28: 2400 29: 2400
30: 2400 31: 2400 32: 2400 bogomips: 154880
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Raptor Lake-S UHD Graphics vendor: ASUSTeK driver: i915
v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 0000:00:02.0
chip-ID: 8086:a788 class-ID: 0300
Device-2: NVIDIA AD104M [GeForce RTX 4080 Max-Q / Mobile] vendor: ASUSTeK
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022-23+ bus-ID: 0000:01:00.0
chip-ID: 10de:27e0 class-ID: 0300
Device-3: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 2-8:3 chip-ID: 322e:2122 class-ID: 0e02
Display: x11 server: X org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1200 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: BOE Display NE180WUM-NY1 built: 2022
res: 1920x1200 hz: 165 dpi: 126 gamma: 1.2 size: 388x242mm (15.28x9.53")
diag: 457mm (18") ratio: 16:10 modes: 1920x1200
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel Graphics (RPL-S)
direct-render: Yes
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:7a50
class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:22bc class-ID: 0403
API: ALSA v: k6.2.10-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 0000:00:14.3
chip-ID: 8086:7a70 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: 4000 bus-ID: 0000:6c:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp108s0 state: down mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 2-14:4
chip-ID: 8087:0033 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 2.79 TiB used: 60.23 GiB (2.1%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung
model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: GXA7601Q temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Seagate
model: XPG GAMMIX S70 BLADE size: 1.86 TiB block-size: physical: 512 B
rev: 3.2.F.66 temp: 56.9 C scheme: GPT
ID-1: / raw-size: 343.64 GiB size: 337.18 GiB (98.12%)
used: 60.17 GiB (17.8%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:10
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 66.9 MiB (26.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
System Temperatures: cpu: 40.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2100
Processes: 510 Uptime: 3h 20m wakeups: 2 Memory: 62.42 GiB
used: 4.39 GiB (7.0%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 alt: 11 clang: 15.0.7 Packages: 1329
pm: pacman pkgs: 1319 libs: 328 tools: gnome-software,pamac,yay pm: flatpak
pkgs: 10 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.26
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
check with alsamixer is there is mute ( MM )
Turned off via keyboard? (CTRL + F??)
Not on Mute… and yeah checked with keyboard too
You my friend are a genius… I have audio… but its like 20% volume… as in sounds low… tried adjusting volume… but can’t increase for some reason…any suggestions?
