No audio from headphones connected to external monitor audio port
rajsahu shenronSlayer > inxi -Fazy
Kernel: 5.4.124-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=8773446f-3d3b-4edf-8b67-4bd0513f7451 rw quiet apparmor=1
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: Dell product: G7 7590 v: N/A serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Dell model: 0MXHK3 v: A00 serial: <filter> UEFI: Dell v: 1.14.0
date: 10/20/2020
ID-1: BAT0 charge: 22.4 Wh (44.8%) condition: 50.0/60.0 Wh (83.3%)
volts: 16.2 min: 15.2 model: BYD DELL HYWXJ97 type: Li-poly serial: <filter>
status: Charging
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE cache: L2: 12 MiB
bogomips: 62431
Speed: 965 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 965 2: 972 3: 939
4: 926 5: 991 6: 1000 7: 1000 8: 959 9: 992 10: 976 11: 994 12: 987
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Dell
driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:2191 class-ID: 0300
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0bda:565a class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: modesetting,nvidia unloaded: intel,nouveau alternate: fbdev,nv,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3286x1080 s-dpi: 96 s-size: 867x285mm (34.1x11.2")
s-diag: 913mm (35.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Monitor-2: HDMI-1-0 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1")
diag: 470mm (18.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.4.124-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Realtek vendor: Dell driver: r8169 v: kernel port: 3000
bus-ID: 3c:00.0 chip-ID: 10ec:2502 class-ID: 0200
IF: enp60s0 state: down mac: <filter>
Device-2: Intel Wireless-AC 9260 vendor: Rivet Networks driver: iwlwifi
v: kernel port: 3000 bus-ID: 3d:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp61s0 state: up mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.14 TiB used: 92.44 GiB (7.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KBG40ZNS256G NVMe 256GB size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 10410106 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
rotation: 5400 rpm serial: <filter> rev: SDM3 scheme: GPT
ID-1: / raw-size: 104 GiB size: 101.87 GiB (97.95%) used: 92.4 GiB (90.7%)
fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 500 MiB size: 496 MiB (99.20%)
used: 47.7 MiB (9.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 16.13 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p8 maj-min: 259:8
System Temperatures: cpu: 67.0 C mobo: N/A
Processes: 334 Uptime: 3h 02m wakeups: 142 Memory: 15.46 GiB
used: 6.68 GiB (43.2%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1546 pacman: 1539 lib: 397 flatpak: 0 snap: 7
Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.04
