PulseAudio has detected 2 onboard onboard audio devices correctly but they are turned off
set-card-profile alsa_card.pci-0000_26_00.1 off
set-card-profile alsa_card.pci-0000_28_00.4 off
inxi data shows 1st device (NVIDIA GP104) for digital HDMI audio output has bus-ID: 26:00.1
2nd device (AMD Starship/Matisse HD Audio) for analog audio to jack sockets has bus-ID: 28:00.4
Use this command to change PulseAudio profile to enable audio playback analog audio jacks on motherboard
I used the command pactl set-card-profile alsa_card.pci-0000_26_00.4 output:analog-stereo and got Failure: no such entity but I then tried it with 28_00.4 and that did nothing.
output of amixer --card=1:
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 64
Mono: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-64.00dB] [off]
Front Right: Playback 0 [0%] [-64.00dB] [off]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
Mono:
Front Left: Playback 64 [100%] [0.00dB] [on]
Front Right: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'Front Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
Mono:
Simple mixer control 'Center',0
Simple mixer control 'LFE',0
Simple mixer control 'Side',0
Mono:
Simple mixer control 'Line',0
Mono:
Simple mixer control 'Line Boost',0
Limits: 0 - 3
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 46
Front Left: Capture 28 [61%] [12.00dB] [on]
Front Right: Capture 28 [61%] [12.00dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-16.00dB] [off]
Front Right: Capture 0 [0%] [-16.00dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Front Mic' 'Rear Mic' 'Line'
Item0: 'Front Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
Mono:
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
According to the inxi, even though this has an NVIDIA card and is an AMD based system, it looks like it still using snd_hda_intel driver. You may try this at your own risk; from the terminal, run;
echo "options snd-hda-intel dmic_detect=0" | sudo tee -a /etc/modprobe.d/alsa-base.conf
echo "blacklist snd_soc_skl" | sudo tee -a /etc/modprobe.d/blacklist.conf
Null response with no error suggests command worked as intended
Please post more information about PulseAudio configuration
pacmd dump; pactl list sinks
I expect data to confirm PulseAudio has replaced inaudible auto_null sink (Dummy Output) with analog output sink for audio jacks
ALSA controls for card 1 are good for audio playback to rear jack sockets, but Headphone output is muted because Auto-Mute Mode is enabled
Auto-mute is useful for laptop systems so that built-in speakers are muted when headphones are plugged in, but it can be an annoyance for desktop systems
To disable Auto-Mute:
