@ldhacker output of command: mhwd -lh -d --pci
06: PCI 300.0: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:00.0
SysFS BusID: 0000:03:00.0
Hardware Class: bridge
Model: “AMD 400 Series Chipset PCIe Port”
Vendor: pci 0x1022 “AMD”
Device: pci 0x43c7 “400 Series Chipset PCIe Port”
SubVendor: pci 0x1b21 “ASMedia Technology Inc.”
SubDevice: pci 0x3306
Revision: 0x01
Driver: “pcieport”
IRQ: 35 (no events)
Module Alias: “pci:v00001022d000043C7sv00001B21sd00003306bc06sc04i00”
Attached to: #12 (PCI bridge)
07: PCI 03.1: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:03.1
SysFS BusID: 0000:00:03.1
Model: “AMD Family 17h (Models 00h-0fh) PCIe GPP Bridge”
Device: pci 0x1453 “Family 17h (Models 00h-0fh) PCIe GPP Bridge”
SubVendor: pci 0x1022 “AMD”
SubDevice: pci 0x1453
Driver: “pcieport”
IRQ: 30 (no events)
Module Alias: “pci:v00001022d00001453sv00001022sd00001453bc06sc04i00”
08: PCI c00.0: 1300 Non-Essential Instrumentation
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:0c:00.0
SysFS BusID: 0000:0c:00.0
Hardware Class: unknown
Model: “AMD Zeppelin/Renoir PCIe Dummy Function”
Device: pci 0x1455 “Zeppelin/Renoir PCIe Dummy Function”
SubDevice: pci 0x1455
Module Alias: “pci:v00001022d00001455sv00001022sd00001455bc13sc00i00”
Attached to: #32 (PCI bridge)
09: PCI 08.0: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:08.0
SysFS BusID: 0000:00:08.0
Model: “AMD Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge”
Device: pci 0x1452 “Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge”
Module Alias: “pci:v00001022d00001452sv00000000sd00000000bc06sc00i00”
10: PCI 18.3: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.3
SysFS BusID: 0000:00:18.3
Model: “AMD Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3”
Device: pci 0x1463 “Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3”
Driver: “k10temp”
Driver Modules: “k10temp”
Module Alias: “pci:v00001022d00001463sv00000000sd00000000bc06sc00i00”
Driver Info #0:
Driver Status: k10temp is active
Driver Activation Cmd: “modprobe k10temp”
11: PCI 900.0: 0c03 USB Controller (XHCI)
SysFS ID: /devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:09.0/0000:09:00.0
SysFS BusID: 0000:09:00.0
Hardware Class: usb controller
Model: “ASMedia ASM1143 USB 3.1 Host Controller”
Device: pci 0x1343 “ASM1143 USB 3.1 Host Controller”
SubVendor: pci 0x1458 “Gigabyte Technology Co., Ltd”
SubDevice: pci 0x5007
Driver: “xhci_hcd”
Driver Modules: “xhci_pci”
Memory Range: 0xf7500000-0xf7507fff (rw,non-prefetchable)
IRQ: 25 (no events)
Module Alias: “pci:v00001B21d00001343sv00001458sd00005007bc0Csc03i30”
Driver Info #0:
Driver Status: xhci_pci is active
Driver Activation Cmd: “modprobe xhci_pci”
Attached to: #21 (PCI bridge)
12: PCI 200.2: 0604 PCI bridge (Normal decode)
SysFS BusID: 0000:02:00.2
Model: “AMD 400 Series Chipset PCIe Bridge”
Device: pci 0x43c6 “400 Series Chipset PCIe Bridge”
SubDevice: pci 0x0201
Revision: 0x01
Driver: “pcieport”
IRQ: 34 (no events)
Module Alias: “pci:v00001022d000043C6sv00001B21sd00000201bc06sc04i00”
Attached to: #34 (PCI bridge)
13: PCI b00.2: 1080 Encryption controller
SysFS ID: /devices/pci0000:00/0000:00:07.1/0000:0b:00.2
SysFS BusID: 0000:0b:00.2
Model: “AMD Family 17h (Models 00h-0fh) Platform Security Processor”
Device: pci 0x1456 “Family 17h (Models 00h-0fh) Platform Security Processor”
SubDevice: pci 0x1456
Driver: “ccp”
Driver Modules: “ccp”
Memory Range: 0xf7300000-0xf73fffff (rw,non-prefetchable)
Memory Range: 0xf7400000-0xf7401fff (rw,non-prefetchable)
IRQ: 108 (no events)
Module Alias: “pci:v00001022d00001456sv00001022sd00001456bc10sc80i00”
Driver Info #0:
Driver Status: ccp is active
Driver Activation Cmd: “modprobe ccp”
Attached to: #45 (PCI bridge)
14: PCI 303.0: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:03.0
SysFS BusID: 0000:03:03.0
Revision: 0x01
Driver: “pcieport”
IRQ: 39 (no events)
15: PCI 18.1: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.1
SysFS BusID: 0000:00:18.1
Model: “AMD Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1”
Device: pci 0x1461 “Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1”
Module Alias: “pci:v00001022d00001461sv00000000sd00000000bc06sc00i00”
16: PCI 200.0: 0c03 USB Controller (XHCI)
SysFS ID: /devices/pci0000:00/0000:00:01.3/0000:02:00.0
SysFS BusID: 0000:02:00.0
Model: “AMD USB Controller”
Device: pci 0x43d0
SubDevice: pci 0x1142
Revision: 0x01
Driver: “xhci_hcd”
Memory Range: 0xf77a0000-0xf77a7fff (rw,non-prefetchable)
IRQ: 32 (no events)
Module Alias: “pci:v00001022d000043D0sv00001B21sd00001142bc0Csc03i30”
Driver Info #0:
17: PCI 01.0: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:01.0
SysFS BusID: 0000:00:01.0
18: PCI b00.0: 1300 Non-Essential Instrumentation
SysFS ID: /devices/pci0000:00/0000:00:07.1/0000:0b:00.0
SysFS BusID: 0000:0b:00.0
Model: “AMD Zeppelin/Raven/Raven2 PCIe Dummy Function”
Device: pci 0x145a “Zeppelin/Raven/Raven2 PCIe Dummy Function”
SubDevice: pci 0x145a
Module Alias: “pci:v00001022d0000145Asv00001022sd0000145Abc13sc00i00”
19: PCI a00.2: 0c03 USB Controller (XHCI)
SysFS ID: /devices/pci0000:00/0000:00:03.1/0000:0a:00.2
SysFS BusID: 0000:0a:00.2
Model: “nVidia TU106 USB 3.1 Host Controller”
Vendor: pci 0x10de “nVidia Corporation”
Device: pci 0x1ada “TU106 USB 3.1 Host Controller”
SubDevice: pci 0x37c2
Revision: 0xa1
Driver: “xhci_hcd”
Memory Range: 0xf2000000-0xf203ffff (ro,non-prefetchable)
Memory Range: 0xf2040000-0xf204ffff (ro,non-prefetchable)
IRQ: 95 (no events)
Module Alias: “pci:v000010DEd00001ADAsv00001458sd000037C2bc0Csc03i30”
Driver Info #0:
Attached to: #7 (PCI bridge)
20: PCI 04.0: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:04.0
SysFS BusID: 0000:00:04.0
21: PCI 309.0: 0604 PCI bridge (Normal decode)
SysFS BusID: 0000:03:09.0
Revision: 0x01
Driver: “pcieport”
IRQ: 41 (no events)
22: PCI 14.3: 0601 ISA bridge
SysFS ID: /devices/pci0000:00/0000:00:14.3
SysFS BusID: 0000:00:14.3
Model: “AMD FCH LPC Bridge”
Device: pci 0x790e “FCH LPC Bridge”
SubDevice: pci 0x5001
Revision: 0x51
Module Alias: “pci:v00001022d0000790Esv00001458sd00005001bc06sc01i00”
23: PCI 100.0: 0108 Non-Volatile memory controller (NVM Express)
SysFS ID: /devices/pci0000:00/0000:00:01.1/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: storage
Model: “Samsung Electronics NVMe SSD Controller SM981/PM981/PM983”
Vendor: pci 0x144d “Samsung Electronics Co Ltd”
Device: pci 0xa808 “NVMe SSD Controller SM981/PM981/PM983”
SubVendor: pci 0x144d “Samsung Electronics Co Ltd”
SubDevice: pci 0xa801
Driver: “nvme”
Driver Modules: “nvme”
Memory Range: 0xf7900000-0xf7903fff (rw,non-prefetchable)
IRQ: 42 (no events)
Module Alias: “pci:v0000144Dd0000A808sv0000144Dsd0000A801bc01sc08i02”
Attached to: #39 (PCI bridge)
24: PCI a00.0: 0300 VGA compatible controller (VGA)
SysFS ID: /devices/pci0000:00/0000:00:03.1/0000:0a:00.0
SysFS BusID: 0000:0a:00.0
Hardware Class: graphics card
Model: “nVidia TU106 [GeForce RTX 2070]”
Device: pci 0x1f02 “TU106 [GeForce RTX 2070]”
Revision: 0xa1
Driver: “nvidia”
Driver Modules: “nvidia”
Memory Range: 0xf6000000-0xf6ffffff (rw,non-prefetchable)
Memory Range: 0xe0000000-0xefffffff (ro,non-prefetchable)
Memory Range: 0xf0000000-0xf1ffffff (ro,non-prefetchable)
I/O Ports: 0xe000-0xe07f (rw)
Memory Range: 0xf7000000-0xf707ffff (ro,non-prefetchable,disabled)
IRQ: 119 (2630 events)
Module Alias: “pci:v000010DEd00001F02sv00001458sd000037C2bc03sc00i00”
Driver Info #0:
Driver Status: nouveau is not active
Driver Activation Cmd: “modprobe nouveau”
Driver Info #1:
Driver Status: nvidia_drm is active
Driver Activation Cmd: “modprobe nvidia_drm”
Driver Info #2:
Driver Status: nvidia is active
Driver Activation Cmd: “modprobe nvidia”
25: PCI 07.0: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:07.0
SysFS BusID: 0000:00:07.0
26: PCI c00.3: 0403 Audio device
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:0c:00.3
SysFS BusID: 0000:0c:00.3
Hardware Class: sound
Model: “AMD Family 17h (Models 00h-0fh) HD Audio Controller”
Device: pci 0x1457 “Family 17h (Models 00h-0fh) HD Audio Controller”
SubDevice: pci 0xa0c3
Driver: “snd_hda_intel”
Driver Modules: “snd_hda_intel”
Memory Range: 0xf7800000-0xf7807fff (rw,non-prefetchable)
IRQ: 118 (2169 events)
Module Alias: “pci:v00001022d00001457sv00001458sd0000A0C3bc04sc03i00”
Driver Info #0:
Driver Status: snd_hda_intel is active
Driver Activation Cmd: “modprobe snd_hda_intel”
27: PCI 700.0: 0200 Ethernet controller
SysFS ID: /devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:03.0/0000:07:00.0
SysFS BusID: 0000:07:00.0
Hardware Class: network
Model: “Intel I211 Gigabit Network Connection”
Vendor: pci 0x8086 “Intel Corporation”
Device: pci 0x1539 “I211 Gigabit Network Connection”
SubDevice: pci 0xe000
Revision: 0x03
Driver: “igb”
Driver Modules: “igb”
Device File: enp7s0
Memory Range: 0xf7600000-0xf761ffff (rw,non-prefetchable)
I/O Ports: 0xf000-0xf01f (rw)
Memory Range: 0xf7620000-0xf7623fff (rw,non-prefetchable)
IRQ: 38 (no events)
HW Address: b4:2e:99:30:c8:d2
Permanent HW Address: b4:2e:99:30:c8:d2
Link detected: yes
Module Alias: “pci:v00008086d00001539sv00001458sd0000E000bc02sc00i00”
Driver Info #0:
Driver Status: igb is active
Driver Activation Cmd: “modprobe igb”
Attached to: #14 (PCI bridge)
28: PCI 00.2: 0806 IOMMU
SysFS ID: /devices/pci0000:00/0000:00:00.2
SysFS BusID: 0000:00:00.2
Model: “AMD Family 17h (Models 00h-0fh) I/O Memory Management Unit”
Device: pci 0x1451 “Family 17h (Models 00h-0fh) I/O Memory Management Unit”
SubDevice: pci 0x1451
IRQ: 27 (no events)
Module Alias: “pci:v00001022d00001451sv00001022sd00001451bc08sc06i00”
29: PCI 302.0: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:02.0
SysFS BusID: 0000:03:02.0
Revision: 0x01
Driver: “pcieport”
IRQ: 37 (no events)
30: PCI 18.6: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.6
SysFS BusID: 0000:00:18.6
Model: “AMD Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6”
Device: pci 0x1466 “Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6”
Module Alias: “pci:v00001022d00001466sv00000000sd00000000bc06sc00i00”
31: PCI 00.0: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:00.0
SysFS BusID: 0000:00:00.0
Model: “AMD Family 17h (Models 00h-0fh) Root Complex”
Device: pci 0x1450 “Family 17h (Models 00h-0fh) Root Complex”
SubDevice: pci 0x1450
Module Alias: “pci:v00001022d00001450sv00001022sd00001450bc06sc00i00”
32: PCI 08.1: 0604 PCI bridge (Normal decode)
SysFS BusID: 0000:00:08.1
Model: “AMD Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B”
Device: pci 0x1454 “Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B”
SubDevice: pci 0x1454
Driver: “pcieport”
IRQ: 33 (no events)
Module Alias: “pci:v00001022d00001454sv00001022sd00001454bc06sc04i00”
33: PCI 18.4: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.4
SysFS BusID: 0000:00:18.4
Model: “AMD Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4”
Device: pci 0x1464 “Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4”
Module Alias: “pci:v00001022d00001464sv00000000sd00000000bc06sc00i00”
34: PCI 01.3: 0604 PCI bridge (Normal decode)
SysFS BusID: 0000:00:01.3
Driver: “pcieport”
IRQ: 29 (no events)
35: PCI b00.3: 0c03 USB Controller (XHCI)
SysFS ID: /devices/pci0000:00/0000:00:07.1/0000:0b:00.3
SysFS BusID: 0000:0b:00.3
Model: “AMD Zeppelin USB 3.0 Host controller”
Device: pci 0x145f “Zeppelin USB 3.0 Host controller”
Driver: “xhci_hcd”
Memory Range: 0xf7200000-0xf72fffff (rw,non-prefetchable)
IRQ: 96 (no events)
Module Alias: “pci:v00001022d0000145Fsv00001458sd00005007bc0Csc03i30”
Driver Info #0:
36: PCI 03.0: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:03.0
SysFS BusID: 0000:00:03.0
37: PCI 18.2: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.2
SysFS BusID: 0000:00:18.2
Model: “AMD Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2”
Device: pci 0x1462 “Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2”
Module Alias: “pci:v00001022d00001462sv00000000sd00000000bc06sc00i00”
38: PCI 200.1: 0106 SATA controller (AHCI 1.0)
SysFS ID: /devices/pci0000:00/0000:00:01.3/0000:02:00.1
SysFS BusID: 0000:02:00.1
Model: “AMD 400 Series Chipset SATA Controller”
Device: pci 0x43c8 “400 Series Chipset SATA Controller”
SubDevice: pci 0x1062
Revision: 0x01
Driver: “ahci”
Driver Modules: “ahci”
Memory Range: 0xf7780000-0xf779ffff (rw,non-prefetchable)
Memory Range: 0xf7700000-0xf777ffff (ro,non-prefetchable,disabled)
IRQ: 44 (116246 events)
Module Alias: “pci:v00001022d000043C8sv00001B21sd00001062bc01sc06i01”
39: PCI 01.1: 0604 PCI bridge (Normal decode)
SysFS BusID: 0000:00:01.1
Driver: “pcieport”
IRQ: 28 (no events)
40: PCI a00.3: 0c80 Serial bus controller
SysFS ID: /devices/pci0000:00/0000:00:03.1/0000:0a:00.3
SysFS BusID: 0000:0a:00.3
Model: “nVidia TU106 USB Type-C UCSI Controller”
Device: pci 0x1adb “TU106 USB Type-C UCSI Controller”
Revision: 0xa1
Driver: “nvidia-gpu”
Driver Modules: “i2c_nvidia_gpu”
Memory Range: 0xf7084000-0xf7084fff (rw,non-prefetchable)
IRQ: 107 (21 events)
Module Alias: “pci:v000010DEd00001ADBsv00001458sd000037C2bc0Csc80i00”
Driver Info #0:
Driver Status: i2c_nvidia_gpu is active
Driver Activation Cmd: “modprobe i2c_nvidia_gpu”
41: PCI 301.0: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:01.0
SysFS BusID: 0000:03:01.0
Revision: 0x01
Driver: “pcieport”
IRQ: 36 (no events)
42: PCI 18.0: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.0
SysFS BusID: 0000:00:18.0
Model: “AMD Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0”
Device: pci 0x1460 “Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0”
Module Alias: “pci:v00001022d00001460sv00000000sd00000000bc06sc00i00”
43: PCI a00.1: 0403 Audio device
SysFS ID: /devices/pci0000:00/0000:00:03.1/0000:0a:00.1
SysFS BusID: 0000:0a:00.1
Model: “nVidia TU106 High Definition Audio Controller”
Device: pci 0x10f9 “TU106 High Definition Audio Controller”
Revision: 0xa1
Memory Range: 0xf7080000-0xf7083fff (rw,non-prefetchable)
IRQ: 116 (1387 events)
Module Alias: “pci:v000010DEd000010F9sv00001458sd000037C2bc04sc03i00”
Driver Info #0:
44: PCI 304.0: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:04.0
SysFS BusID: 0000:03:04.0
Revision: 0x01
Driver: “pcieport”
IRQ: 40 (no events)
45: PCI 07.1: 0604 PCI bridge (Normal decode)
SysFS BusID: 0000:00:07.1
Driver: “pcieport”
IRQ: 31 (no events)
46: PCI 02.0: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:02.0
SysFS BusID: 0000:00:02.0
Device Name: “Onboard IGD”
47: PCI 18.7: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.7
SysFS BusID: 0000:00:18.7
Model: “AMD Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7”
Device: pci 0x1467 “Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7”
Module Alias: “pci:v00001022d00001467sv00000000sd00000000bc06sc00i00”
48: PCI 14.0: 0c05 SMBus
SysFS ID: /devices/pci0000:00/0000:00:14.0
SysFS BusID: 0000:00:14.0
Model: “AMD FCH SMBus Controller”
Device: pci 0x790b “FCH SMBus Controller”
Revision: 0x59
Driver: “piix4_smbus”
Driver Modules: “i2c_piix4”
Module Alias: “pci:v00001022d0000790Bsv00001458sd00005001bc0Csc05i00”
Driver Info #0:
Driver Status: i2c_piix4 is active
Driver Activation Cmd: “modprobe i2c_piix4”
Driver Info #1:
Driver Status: sp5100_tco is active
Driver Activation Cmd: “modprobe sp5100_tco”
49: PCI c00.2: 0106 SATA controller (AHCI 1.0)
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:0c:00.2
SysFS BusID: 0000:0c:00.2
Model: “AMD FCH SATA Controller [AHCI mode]”
Device: pci 0x7901 “FCH SATA Controller [AHCI mode]”
SubDevice: pci 0xb002
Revision: 0x51
Driver: “ahci”
Memory Range: 0xf7808000-0xf7808fff (rw,non-prefetchable)
IRQ: 46 (no events)
Module Alias: “pci:v00001022d00007901sv00001458sd0000B002bc01sc06i01”
50: PCI 18.5: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.5
SysFS BusID: 0000:00:18.5
Model: “AMD Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5”
Device: pci 0x1465 “Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5”
Module Alias: “pci:v00001022d00001465sv00000000sd00000000bc06sc00i00”
