I did something stupid and needed to reinstall Manjaro.
From past experience I have had issues with pipewire and pulseaudio conflicting. So I deleted all pulseaudio and installed pipewire pipewire-pulse and pipewire-media-session.After rebooting System setting shows no audio devices and the only configuration was for the hdmi plug which I have nothing attached at this moment.
inxi -Fxz
Kernel: 5.16.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.23.4 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: OMEN by HP Laptop 17-cb1xxx v: N/A
serial: <superuser required>
Mobo: HP model: 8748 v: 05.33 serial: <superuser required> UEFI: AMI
v: F.20 date: 11/04/2020
ID-1: BAT1 charge: 57.7 Wh (100.0%) condition: 57.7/70.0 Wh (82.5%)
volts: 17.1 min: 15.4 model: COMPAL PABAS0241231 status: Full
Info: 6-core model: Intel Core i7-10750H bits: 64 type: MT MCP
arch: Comet Lake rev: 2 cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
Speed (MHz): avg: 3475 high: 4485 min/max: 800/5000 cores: 1: 1601
2: 3522 3: 4485 4: 952 5: 4412 6: 4092 7: 4340 8: 4329 9: 1393 10: 3778
11: 4429 12: 4369 bogomips: 62431
Device-1: NVIDIA TU106M [GeForce RTX 2070 Mobile / Max-Q Refresh]
vendor: Hewlett-Packard driver: nvidia v: 495.44 bus-ID: 01:00.0
Device-2: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:4
Display: x11 server: X.org 1.21.1.2 driver: loaded: nvidia
Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3
Device-2: NVIDIA TU106 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Sound Server-1: ALSA v: k5.16.0-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3
IF: wlp0s20f3 state: down mac: <filter>
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 3d:00.0
IF: enp61s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 1-14:5
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 bus-ID: 00:17.0
Local Storage: total: 1.38 TiB used: 728.22 GiB (51.7%)
ID-1: /dev/nvme0n1 vendor: KIOXIA model: N/A size: 238.47 GiB
temp: 43.9 C
ID-2: /dev/nvme1n1 vendor: Western Digital
model: PC SN520 SDAPNUW-256G-1006 size: 238.47 GiB temp: 44.9 C
ID-3: /dev/sda vendor: Seagate model: ST1000LM049-2GH172 size: 931.51 GiB
ID-1: / size: 216.67 GiB used: 12.72 GiB (5.9%) fs: ext4
dev: /dev/nvme1n1p2
ID-2: /boot/efi size: 299.4 MiB used: 292 KiB (0.1%) fs: vfat
dev: /dev/nvme1n1p1
ID-3: /home size: 63.93 GiB used: 39.01 GiB (61.0%) fs: ext4
dev: /dev/sda1
ID-1: swap-1 type: partition size: 16.97 GiB used: 0 KiB (0.0%)
dev: /dev/nvme1n1p3
System Temperatures: cpu: 52.0 C pch: 50.0 C mobo: 10.0 C gpu: nvidia
temp: 48 C
Processes: 354 Uptime: 8m Memory: 15.47 GiB used: 3.31 GiB (21.4%)
Init: systemd Compilers: gcc: N/A Packages: 1256 Shell: Bash v: 5.1.12
inxi: 3.3.11
lspci|grep Audio
01:00.1 Audio device: NVIDIA Corporation TU106 High Definition Audio Controller (rev a1)
driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3 is my laptop sound I believe.
Am I missing a driver or something?
