No audio devices detected. (Fujitsu Lifebook U7411)
Hi all.
I have just installed Manjaro Cinnamon DE yesterday. No significant modifications have been made to the system, other than the built-in theming options.
I was trying to watch a video, when I realized that there was no audio.
I went into the audio settings and the only available output device was a non-functional device called
“Dummy Output”
inxi -A
  Device-1: Intel Tiger Lake-LP Smart Sound Audio
    driver: sof-audio-pci-intel-tgl
  API: ALSA v: k6.5.3-1-MANJARO status: kernel-api
  Server-1: PulseAudio v: 17.0 status: active
inxi -Fazy
  Kernel: 6.5.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
    root=UUID=21230fba-8824-4c33-bdd3-b4f7f565ca1a rw quiet apparmor=1
  Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.41 wm: Muffin v: 6.0.1 tools:
    avail: cinnamon-screensaver vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: FUJITSU CLIENT product: LIFEBOOK U7411 v: 10601736746
    serial: <superuser required> Chassis: type: 10 v: LIFEBOOK U7411
  Mobo: FUJITSU CLIENT model: FJNB2E7 v: C3 serial: <superuser required>
    part-nu: SK02 uuid: <superuser required> UEFI: FUJITSU CLIENT v: Version 2.40
    date: 06/30/2023
  ID-1: CMB1 charge: 38.9 Wh (62.0%) condition: 62.7/64.6 Wh (97.0%)
    volts: 15.3 min: 15.1 model: Fujitsu CP811122-01 type: Li-ion
    serial: <filter> status: discharging cycles: 72
  Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xB4
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 2380 high: 2995 min/max: 400/4800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1894 2: 2417 3: 2492
    4: 2593 5: 2598 6: 2826 7: 2995 8: 1232 bogomips: 47936
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Fujitsu Client
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1, HDMI-A-2,
    HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Chicony FJ Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:2 chip-ID: 04f2:b703
  Display: x11 server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: LG Display 0x0660 built: 2019 res: 1920x1080 hz: 60
    dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1920x1080
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
    device-ID: 8086:9a49 memory: 30.23 GiB unified: yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Fujitsu Client
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  API: ALSA v: k6.5.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.3 status: off tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
  Device-2: Intel Ethernet I219-LM vendor: Fujitsu Client driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fb class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  IF-ID-1: mhi_hwip0 state: down mac: N/A
  Info: services: NetworkManager,wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 1.84 TiB used: 16.71 GiB (0.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
    model: KBG4AZNS1T02 KIOXIA size: 953.87 GiB block-size: physical: 512 B
    fw-rev: AEJA1103 temp: 35.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
    serial: <filter>
  ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 16.7 GiB (1.8%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 62.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 32 GiB available: 30.96 GiB used: 3.9 GiB (12.6%)
  Processes: 274 Power: uptime: 59m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
    test_resume image: 12.37 GiB services: csd-power,upowerd Init: systemd
    v: 255 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1108 libs: 310 tools: pamac,yay pm: flatpak
    pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
    running-in: gnome-terminal inxi: 3.3.33
pacmd dump
### Configuration dump generated at Thu Mar 28 12:22:24 2024
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-null-sink sink_name=auto_null sink_properties='device.description="Dummy Output"'
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-cli-protocol-unix
set-sink-volume auto_null 0x10000
set-sink-mute auto_null no
suspend-sink auto_null yes
set-source-volume auto_null.monitor 0x10000
set-source-mute auto_null.monitor no
suspend-source auto_null.monitor yes
set-default-sink auto_null
set-default-source auto_null.monitor
### EOF
Any help is appreciated!
use the searchfunction of this forum for “tiger lake”. you’ll find your answers already solved.
Thanks!
