Problem Summary:
- Installed a Vega 56 GPU into a system using an AMD APU and the HDMI audio (from the GPU) will not show up on the system.
- Audio from the onboard Analog and HDMI work just fine.
- I have a vague memory of this being an issue with support in the drivers when I first got the card, but I used onboard analog and lost track of the problem.
Steps Tried:
- Disable onboard HD Audio
- No detection
- Loss of onboard audio. Hoped this would resolve audio device collisions since they are both Vega audio devices (one on the APU, another on the GPU).
- LiveUSB Manjaro (kde-21.3.7-minimal-220816-linux515)
- No detection
- Hoped this would test the LTS kernel against 5.19 and user settings that may have created an issue.
- LiveUSB Ubuntu (ubuntu-22.04.1-desktop-amd64)
- No detection
- Removed pulseaudio, installed manjaro-pipewire
- No detection
- Checked dmesg for: “audio”, “ati”, “amd”, “snd”
- Not well versed in dmesg, not sure what to really look for but I didn’t recognize any problems.
System Information:
CPU: AMD Ryzen 5 2400G
GPU: MSI Vega 56 8GB
Motherboard: MSI B350M Bazooka
Ram: 2x 16gb DDR3200
Mesa Drivers: 22.1.6
OS: Manjaro
Kernel: 5.19.1-3
System Outputs:
- inxi -Aa
Device-1: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 29:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.19.1-3-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.1 running: no
Sound Server-4: PipeWire v: 0.3.56 running: yes
- aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Generic [HD-Audio Generic], device 0: ALC892 Analog [ALC892 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
- dmesg | grep ATI
[ 0.000000] Linux version 5.19.1-3-MANJARO (builduser@fv-az196-43) (gcc (GCC) 12.1.1 20220730, GNU ld (GNU Binutils) 2.39) #1 SMP PREEMPT_DYNAMIC Sat Aug 13 06:34:52 UTC 2022
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64 root=UUID=4e1dabd8-cc14-44cd-8351-f7e821eb2f76 rw quiet apparmor=1 security=apparmor resume=UUID=fd346e0f-9227-4b17-8a90-356f365ed9f2 udev.log_priority=3
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
[ 0.000000] signal: max sigframe size: 1776
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009d7ffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009d80000-0x0000000009ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a20afff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000000a20b000-0x000000000affffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000b020000-0x00000000dba35fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000dba36000-0x00000000dbb53fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000dbb54000-0x00000000dbcd3fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000dbcd4000-0x00000000dc0e2fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000dc0e3000-0x00000000dcefefff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000dceff000-0x00000000dcf9ffff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000dcfa0000-0x00000000deffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000df000000-0x00000000dfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fd000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000041f33ffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by American Megatrends
[ 0.000000] efi: ACPI 2.0=0xdc05f000 ACPI=0xdc05f000 SMBIOS=0xdcdeb000 MEMATTR=0xd88a1018 ESRT=0xd88b7f98
[ 0.000000] SMBIOS 2.8 present.
[ 0.000000] DMI: Micro-Star International Co., Ltd. MS-7A38/B350M BAZOOKA (MS-7A38), BIOS 1.LP 11/29/2019
[ 0.000000] tsc: Fast TSC calibration failed
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] last_pfn = 0x41f340 max_arch_pfn = 0x400000000
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000000] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[ 0.000000] last_pfn = 0xdf000 max_arch_pfn = 0x400000000
[ 0.000000] esrt: Reserving ESRT space from 0x00000000d88b7f98 to 0x00000000d88b7fd0.
[ 0.000000] e820: update [mem 0xd88b7000-0xd88b7fff] usable ==> reserved
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] Secure boot could not be determined
[ 0.000000] RAMDISK: [mem 0x37031000-0x3780ffff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000DC05F000 000024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 0x00000000DC05F0A0 0000C4 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 0x00000000DC066AB0 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT 0x00000000DC05F200 0078AE (v02 ALASKA A M I 01072009 INTL 20120913)
[ 0.000000] ACPI: FACS 0x00000000DC0CBE00 000040
[ 0.000000] ACPI: APIC 0x00000000DC066BC8 00015E (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 0x00000000DC066D28 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FIDT 0x00000000DC066D70 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT 0x00000000DC066E10 000094 (v02 ALASKA CPUSSDT 01072009 AMI 01072009)
[ 0.000000] ACPI: SSDT 0x00000000DC066EA8 005419 (v02 AMD AmdTable 00000002 MSFT 04000000)
[ 0.000000] ACPI: SSDT 0x00000000DC06C2C8 00366B (v01 AMD AMD AOD 00000001 INTL 20120913)
[ 0.000000] ACPI: MCFG 0x00000000DC06F938 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.000000] ACPI: HPET 0x00000000DC06F978 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.000000] ACPI: UEFI 0x00000000DC06F9B0 000042 (v01 ALASKA A M I 00000002 01000013)
[ 0.000000] ACPI: IVRS 0x00000000DC06F9F8 0000D0 (v02 AMD AMD IVRS 00000001 AMD 00000000)
[ 0.000000] ACPI: SSDT 0x00000000DC06FAC8 00119C (v01 AMD AMD CPU 00000001 AMD 00000001)
[ 0.000000] ACPI: CRAT 0x00000000DC070C68 000810 (v01 AMD AMD CRAT 00000001 AMD 00000001)
[ 0.000000] ACPI: CDIT 0x00000000DC071478 000029 (v01 AMD AMD CDIT 00000001 AMD 00000001)
[ 0.000000] ACPI: SSDT 0x00000000DC0714A8 0000D7 (v01 AMD AmdTable 00000001 INTL 20120913)
[ 0.000000] ACPI: SSDT 0x00000000DC071580 0010B4 (v01 AMD AmdTable 00000001 INTL 20120913)
[ 0.000000] ACPI: SSDT 0x00000000DC072638 00052C (v01 AMD AmdTable 00000001 INTL 20120913)
[ 0.000000] ACPI: SSDT 0x00000000DC072B68 001D4A (v01 AMD AmdTable 00000001 INTL 20120913)
[ 0.000000] ACPI: SSDT 0x00000000DC0748B8 0000BF (v01 AMD AMD PT 00001000 INTL 20120913)
[ 0.000000] ACPI: WSMT 0x00000000DC074978 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: Reserving FACP table memory at [mem 0xdc066ab0-0xdc066bc3]
[ 0.000000] ACPI: Reserving DSDT table memory at [mem 0xdc05f200-0xdc066aad]
[ 0.000000] ACPI: Reserving FACS table memory at [mem 0xdc0cbe00-0xdc0cbe3f]
[ 0.000000] ACPI: Reserving APIC table memory at [mem 0xdc066bc8-0xdc066d25]
[ 0.000000] ACPI: Reserving FPDT table memory at [mem 0xdc066d28-0xdc066d6b]
[ 0.000000] ACPI: Reserving FIDT table memory at [mem 0xdc066d70-0xdc066e0b]
[ 0.000000] ACPI: Reserving SSDT table memory at [mem 0xdc066e10-0xdc066ea3]
[ 0.000000] ACPI: Reserving SSDT table memory at [mem 0xdc066ea8-0xdc06c2c0]
[ 0.000000] ACPI: Reserving SSDT table memory at [mem 0xdc06c2c8-0xdc06f932]
[ 0.000000] ACPI: Reserving MCFG table memory at [mem 0xdc06f938-0xdc06f973]
[ 0.000000] ACPI: Reserving HPET table memory at [mem 0xdc06f978-0xdc06f9af]
[ 0.000000] ACPI: Reserving UEFI table memory at [mem 0xdc06f9b0-0xdc06f9f1]
[ 0.000000] ACPI: Reserving IVRS table memory at [mem 0xdc06f9f8-0xdc06fac7]
[ 0.000000] ACPI: Reserving SSDT table memory at [mem 0xdc06fac8-0xdc070c63]
[ 0.000000] ACPI: Reserving CRAT table memory at [mem 0xdc070c68-0xdc071477]
[ 0.000000] ACPI: Reserving CDIT table memory at [mem 0xdc071478-0xdc0714a0]
[ 0.000000] ACPI: Reserving SSDT table memory at [mem 0xdc0714a8-0xdc07157e]
[ 0.000000] ACPI: Reserving SSDT table memory at [mem 0xdc071580-0xdc072633]
[ 0.000000] ACPI: Reserving SSDT table memory at [mem 0xdc072638-0xdc072b63]
[ 0.000000] ACPI: Reserving SSDT table memory at [mem 0xdc072b68-0xdc0748b1]
[ 0.000000] ACPI: Reserving SSDT table memory at [mem 0xdc0748b8-0xdc074976]
[ 0.000000] ACPI: Reserving WSMT table memory at [mem 0xdc074978-0xdc07499f]
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000041f33ffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x41f33c000-0x41f33ffff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000041f33ffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x0000000009d7ffff]
[ 0.000000] node 0: [mem 0x000000000a000000-0x000000000a1fffff]
[ 0.000000] node 0: [mem 0x000000000a20b000-0x000000000affffff]
[ 0.000000] node 0: [mem 0x000000000b020000-0x00000000dba35fff]
[ 0.000000] node 0: [mem 0x00000000dbb54000-0x00000000dbcd3fff]
[ 0.000000] node 0: [mem 0x00000000dcfa0000-0x00000000deffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000041f33ffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000041f33ffff]
[ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA32: 640 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA32: 11 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA32: 32 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA32: 286 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA32: 4812 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 4096 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 3264 pages in unavailable ranges
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 9, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] IOAPIC[1]: apic_id 10, version 33, address 0xfec01000, GSI 24-55
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.000000] smpboot: Allowing 32 CPUs, 24 hotplug CPUs
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x09d80000-0x09ffffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a20afff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b01ffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xd88b7000-0xd88b7fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xdba36000-0xdbb53fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xdbcd4000-0xdc0e2fff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xdc0e3000-0xdcefefff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xdceff000-0xdcf9ffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xdf000000-0xdfffffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xf7ffffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfcffffff]
[ 0.000000] PM: hibernation: Registered nosave memory: [mem 0xfd000000-0xffffffff]
[ 0.000000] [mem 0xe0000000-0xf7ffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.000000] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:32 nr_node_ids:1
[ 0.000000] percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u262144
[ 0.000000] pcpu-alloc: s221184 r8192 d28672 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.000000] pcpu-alloc: [0] 16 17 18 19 20 21 22 23 [0] 24 25 26 27 28 29 30 31
[ 0.000000] Fallback order for Node 0: 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4115576
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64 root=UUID=4e1dabd8-cc14-44cd-8351-f7e821eb2f76 rw quiet apparmor=1 security=apparmor resume=UUID=fd346e0f-9227-4b17-8a90-356f365ed9f2 udev.log_priority=3
[ 0.000000] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64", will be passed to user space.
[ 0.000000] printk: log_buf_len individual max cpu contribution: 4096 bytes
[ 0.000000] printk: log_buf_len total cpu_extra contributions: 126976 bytes
[ 0.000000] printk: log_buf_len min size: 131072 bytes
[ 0.000000] printk: log_buf_len: 262144 bytes
[ 0.000000] printk: early log buf free: 119208(90%)
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.000000] Memory: 16222088K/16724264K available (16391K kernel code, 2090K rwdata, 11240K rodata, 2120K init, 3508K bss, 501916K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
[ 0.000000] ftrace: allocating 45516 entries in 178 pages
[ 0.000000] ftrace: allocated 178 pages with 4 groups
[ 0.000000] Dynamic Preempt: full
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=32.
[ 0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[ 0.000000] NR_IRQS: 20736, nr_irqs: 1224, preallocated irqs: 16
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.000000] random: crng init done
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] printk: console [tty0] enabled
[ 0.000000] ACPI: Core revision 20220331
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.000000] APIC: Switch to symmetric I/O mode setup
[ 0.000000] Switched APIC routing to physical flat.
[ 0.000000] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.023333] tsc: PIT calibration matches HPET. 2 loops
[ 0.023333] tsc: Detected 3600.026 MHz processor
[ 0.000003] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x33e46bf7122, max_idle_ns: 440795286380 ns
[ 0.000007] Calibrating delay loop (skipped), value calculated using timer frequency.. 7202.05 BogoMIPS (lpj=12000086)
[ 0.000010] pid_max: default: 32768 minimum: 301
[ 0.003379] LSM: Security Framework initializing
[ 0.003390] landlock: Up and running.
[ 0.003391] Yama: becoming mindful.
[ 0.003399] LSM support for eBPF active
[ 0.003415] AppArmor: AppArmor initialized
[ 0.003464] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.003492] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.003955] LVT offset 1 assigned for vector 0xf9
[ 0.003994] LVT offset 2 assigned for vector 0xf4
[ 0.004006] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
[ 0.004007] Last level dTLB entries: 4KB 1536, 2MB 1536, 4MB 768, 1GB 0
[ 0.004011] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.004013] Spectre V2 : Mitigation: Retpolines
[ 0.004014] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.004014] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.004015] Spectre V2 : Enabling Speculation Barrier for firmware calls
[ 0.004015] RETBleed: Mitigation: untrained return thunk
[ 0.004017] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.004018] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.011901] Freeing SMP alternatives memory: 36K
[ 0.121036] smpboot: CPU0: AMD Ryzen 5 2400G with Radeon Vega Graphics (family: 0x17, model: 0x11, stepping: 0x0)
[ 0.121162] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.121165] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.121179] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.121192] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.121202] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[ 0.121205] ... version: 0
[ 0.121206] ... bit width: 48
[ 0.121207] ... generic registers: 6
[ 0.121207] ... value mask: 0000ffffffffffff
[ 0.121208] ... max period: 00007fffffffffff
[ 0.121209] ... fixed-purpose events: 0
[ 0.121209] ... event mask: 000000000000003f
[ 0.121273] rcu: Hierarchical SRCU implementation.
[ 0.121273] rcu: Max phase no-delay instances is 1000.
[ 0.121618] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.121811] smp: Bringing up secondary CPUs ...
[ 0.121892] x86: Booting SMP configuration:
[ 0.121893] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7
[ 0.136720] smp: Brought up 1 node, 8 CPUs
[ 0.136720] smpboot: Max logical packages: 4
[ 0.136720] smpboot: Total of 8 processors activated (57623.43 BogoMIPS)
[ 0.137601] devtmpfs: initialized
[ 0.137601] x86/mm: Memory block size: 128MB
[ 0.140458] ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20afff] (45056 bytes)
[ 0.140458] ACPI: PM: Registering ACPI NVS region [mem 0xdbcd4000-0xdc0e2fff] (4255744 bytes)
[ 0.140458] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.140458] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.140458] pinctrl core: initialized pinctrl subsystem
[ 0.140458] PM: RTC time: 16:27:09, date: 2022-09-03
[ 0.140846] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.141107] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.141295] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.141476] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.141494] audit: initializing netlink subsys (disabled)
[ 0.141513] audit: type=2000 audit(1662222428.163:1): state=initialized audit_enabled=0 res=1
[ 0.141513] thermal_sys: Registered thermal governor 'fair_share'
[ 0.141513] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.141513] thermal_sys: Registered thermal governor 'step_wise'
[ 0.141513] thermal_sys: Registered thermal governor 'user_space'
[ 0.141513] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.141513] cpuidle: using governor ladder
[ 0.141513] cpuidle: using governor menu
[ 0.141513] HugeTLB: can optimize 4095 vmemmap pages for hugepages-1048576kB
[ 0.141513] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.141513] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.141513] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.141513] PCI: Using configuration type 1 for base access
[ 0.143777] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.143783] HugeTLB: can optimize 7 vmemmap pages for hugepages-2048kB
[ 0.143783] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.143783] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.143783] ACPI: Added _OSI(Module Device)
[ 0.143783] ACPI: Added _OSI(Processor Device)
[ 0.143783] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.143783] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.143783] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.143783] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.143783] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.154195] ACPI: 10 ACPI AML tables successfully acquired and loaded
[ 0.155461] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.160595] ACPI: Interpreter enabled
[ 0.160619] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.160620] ACPI: Using IOAPIC for interrupt routing
[ 0.161143] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.161145] PCI: Using E820 reservations for host bridge windows
[ 0.161684] ACPI: Enabled 2 GPEs in block 00 to 1F
[ 0.170471] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.170476] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.170572] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug PME LTR DPC]
[ 0.170745] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug AER PCIeCapability]
[ 0.170756] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.171074] PCI host bridge to bus 0000:00
[ 0.171075] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.171077] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.171078] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.171080] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.171081] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[ 0.171082] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfec2ffff window]
[ 0.171083] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[ 0.171084] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.171099] pci 0000:00:00.0: [1022:15d0] type 00 class 0x060000
[ 0.171214] pci 0000:00:00.2: [1022:15d1] type 00 class 0x080600
[ 0.171351] pci 0000:00:01.0: [1022:1452] type 00 class 0x060000
[ 0.171433] pci 0000:00:01.1: [1022:15d3] type 01 class 0x060400
[ 0.171541] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[ 0.171731] pci 0000:00:01.2: [1022:15d3] type 01 class 0x060400
[ 0.171777] pci 0000:00:01.2: enabling Extended Tags
[ 0.171843] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 0.172051] pci 0000:00:08.0: [1022:1452] type 00 class 0x060000
[ 0.172135] pci 0000:00:08.1: [1022:15db] type 01 class 0x060400
[ 0.172184] pci 0000:00:08.1: enabling Extended Tags
[ 0.172240] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.172400] pci 0000:00:08.2: [1022:15dc] type 01 class 0x060400
[ 0.172450] pci 0000:00:08.2: enabling Extended Tags
[ 0.172516] pci 0000:00:08.2: PME# supported from D0 D3hot D3cold
[ 0.172731] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.172894] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.173060] pci 0000:00:18.0: [1022:15e8] type 00 class 0x060000
[ 0.173085] pci 0000:00:18.1: [1022:15e9] type 00 class 0x060000
[ 0.173110] pci 0000:00:18.2: [1022:15ea] type 00 class 0x060000
[ 0.173137] pci 0000:00:18.3: [1022:15eb] type 00 class 0x060000
[ 0.173161] pci 0000:00:18.4: [1022:15ec] type 00 class 0x060000
[ 0.173185] pci 0000:00:18.5: [1022:15ed] type 00 class 0x060000
[ 0.173208] pci 0000:00:18.6: [1022:15ee] type 00 class 0x060000
[ 0.173232] pci 0000:00:18.7: [1022:15ef] type 00 class 0x060000
[ 0.173354] pci 0000:10:00.0: [1022:1470] type 01 class 0x060400
[ 0.173370] pci 0000:10:00.0: reg 0x10: [mem 0xfce00000-0xfce03fff]
[ 0.173481] pci 0000:10:00.0: PME# supported from D0 D3hot D3cold
[ 0.173552] pci 0000:10:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x8 link at 0000:00:01.1 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.173627] pci 0000:00:01.1: PCI bridge to [bus 10-12]
[ 0.173632] pci 0000:00:01.1: bridge window [io 0xf000-0xffff]
[ 0.173635] pci 0000:00:01.1: bridge window [mem 0xfcd00000-0xfcefffff]
[ 0.173640] pci 0000:00:01.1: bridge window [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.173695] pci 0000:11:00.0: [1022:1471] type 01 class 0x060400
[ 0.173812] pci 0000:11:00.0: PME# supported from D0 D3hot D3cold
[ 0.173920] pci 0000:10:00.0: PCI bridge to [bus 11-12]
[ 0.173925] pci 0000:10:00.0: bridge window [io 0xf000-0xffff]
[ 0.173929] pci 0000:10:00.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.173934] pci 0000:10:00.0: bridge window [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.173981] pci 0000:12:00.0: [1002:687f] type 00 class 0x030000
[ 0.174001] pci 0000:12:00.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.174015] pci 0000:12:00.0: reg 0x18: [mem 0xf0000000-0xf01fffff 64bit pref]
[ 0.174024] pci 0000:12:00.0: reg 0x20: [io 0xf000-0xf0ff]
[ 0.174033] pci 0000:12:00.0: reg 0x24: [mem 0xfcd00000-0xfcd7ffff]
[ 0.174042] pci 0000:12:00.0: reg 0x30: [mem 0xfcd80000-0xfcd9ffff pref]
[ 0.174069] pci 0000:12:00.0: BAR 0: assigned to efifb
[ 0.174077] pci 0000:12:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.174154] pci 0000:12:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.174240] pci 0000:12:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x8 link at 0000:00:01.1 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.174290] pci 0000:11:00.0: PCI bridge to [bus 12]
[ 0.174296] pci 0000:11:00.0: bridge window [io 0xf000-0xffff]
[ 0.174299] pci 0000:11:00.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.174304] pci 0000:11:00.0: bridge window [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.174386] pci 0000:13:00.0: [1022:43bb] type 00 class 0x0c0330
[ 0.174407] pci 0000:13:00.0: reg 0x10: [mem 0xfcca0000-0xfcca7fff 64bit]
[ 0.174456] pci 0000:13:00.0: enabling Extended Tags
[ 0.174521] pci 0000:13:00.0: PME# supported from D3hot D3cold
[ 0.174639] pci 0000:13:00.1: [1022:43b7] type 00 class 0x010601
[ 0.174696] pci 0000:13:00.1: reg 0x24: [mem 0xfcc80000-0xfcc9ffff]
[ 0.174705] pci 0000:13:00.1: reg 0x30: [mem 0xfcc00000-0xfcc7ffff pref]
[ 0.174713] pci 0000:13:00.1: enabling Extended Tags
[ 0.174762] pci 0000:13:00.1: PME# supported from D3hot D3cold
[ 0.174840] pci 0000:13:00.2: [1022:43b2] type 01 class 0x060400
[ 0.174893] pci 0000:13:00.2: enabling Extended Tags
[ 0.174948] pci 0000:13:00.2: PME# supported from D3hot D3cold
[ 0.175060] pci 0000:00:01.2: PCI bridge to [bus 13-28]
[ 0.175065] pci 0000:00:01.2: bridge window [io 0xe000-0xefff]
[ 0.175068] pci 0000:00:01.2: bridge window [mem 0xfcb00000-0xfccfffff]
[ 0.175180] pci 0000:20:04.0: [1022:43b4] type 01 class 0x060400
[ 0.175237] pci 0000:20:04.0: enabling Extended Tags
[ 0.175307] pci 0000:20:04.0: PME# supported from D3hot D3cold
[ 0.175413] pci 0000:20:05.0: [1022:43b4] type 01 class 0x060400
[ 0.175470] pci 0000:20:05.0: enabling Extended Tags
[ 0.175540] pci 0000:20:05.0: PME# supported from D3hot D3cold
[ 0.175640] pci 0000:20:06.0: [1022:43b4] type 01 class 0x060400
[ 0.175696] pci 0000:20:06.0: enabling Extended Tags
[ 0.175766] pci 0000:20:06.0: PME# supported from D3hot D3cold
[ 0.175868] pci 0000:20:07.0: [1022:43b4] type 01 class 0x060400
[ 0.175924] pci 0000:20:07.0: enabling Extended Tags
[ 0.175994] pci 0000:20:07.0: PME# supported from D3hot D3cold
[ 0.176107] pci 0000:13:00.2: PCI bridge to [bus 20-28]
[ 0.176113] pci 0000:13:00.2: bridge window [io 0xe000-0xefff]
[ 0.176117] pci 0000:13:00.2: bridge window [mem 0xfcb00000-0xfcbfffff]
[ 0.176196] pci 0000:25:00.0: [10ec:8168] type 00 class 0x020000
[ 0.176227] pci 0000:25:00.0: reg 0x10: [io 0xe000-0xe0ff]
[ 0.176268] pci 0000:25:00.0: reg 0x18: [mem 0xfcb04000-0xfcb04fff 64bit]
[ 0.176294] pci 0000:25:00.0: reg 0x20: [mem 0xfcb00000-0xfcb03fff 64bit]
[ 0.176462] pci 0000:25:00.0: supports D1 D2
[ 0.176463] pci 0000:25:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.176662] pci 0000:20:04.0: PCI bridge to [bus 25]
[ 0.176668] pci 0000:20:04.0: bridge window [io 0xe000-0xefff]
[ 0.176673] pci 0000:20:04.0: bridge window [mem 0xfcb00000-0xfcbfffff]
[ 0.176716] pci 0000:20:05.0: PCI bridge to [bus 26]
[ 0.176765] pci 0000:20:06.0: PCI bridge to [bus 27]
[ 0.176815] pci 0000:20:07.0: PCI bridge to [bus 28]
[ 0.176958] pci 0000:29:00.0: [1022:145a] type 00 class 0x130000
[ 0.177049] pci 0000:29:00.0: enabling Extended Tags
[ 0.177217] pci 0000:29:00.2: [1022:15df] type 00 class 0x108000
[ 0.177258] pci 0000:29:00.2: reg 0x18: [mem 0xfc900000-0xfc9fffff]
[ 0.177290] pci 0000:29:00.2: reg 0x24: [mem 0xfca08000-0xfca09fff]
[ 0.177309] pci 0000:29:00.2: enabling Extended Tags
[ 0.177468] pci 0000:29:00.3: [1022:15e0] type 00 class 0x0c0330
[ 0.177494] pci 0000:29:00.3: reg 0x10: [mem 0xfc800000-0xfc8fffff 64bit]
[ 0.177554] pci 0000:29:00.3: enabling Extended Tags
[ 0.177626] pci 0000:29:00.3: PME# supported from D0 D3hot D3cold
[ 0.177717] pci 0000:29:00.4: [1022:15e1] type 00 class 0x0c0330
[ 0.177742] pci 0000:29:00.4: reg 0x10: [mem 0xfc700000-0xfc7fffff 64bit]
[ 0.177802] pci 0000:29:00.4: enabling Extended Tags
[ 0.177875] pci 0000:29:00.4: PME# supported from D0 D3hot D3cold
[ 0.177966] pci 0000:29:00.6: [1022:15e3] type 00 class 0x040300
[ 0.177986] pci 0000:29:00.6: reg 0x10: [mem 0xfca00000-0xfca07fff]
[ 0.178056] pci 0000:29:00.6: enabling Extended Tags
[ 0.178123] pci 0000:29:00.6: PME# supported from D0 D3hot D3cold
[ 0.178238] pci 0000:00:08.1: PCI bridge to [bus 29]
[ 0.178246] pci 0000:00:08.1: bridge window [mem 0xfc700000-0xfcafffff]
[ 0.178336] pci 0000:2a:00.0: [1022:7901] type 00 class 0x010601
[ 0.178407] pci 0000:2a:00.0: reg 0x24: [mem 0xfcf00000-0xfcf007ff]
[ 0.178427] pci 0000:2a:00.0: enabling Extended Tags
[ 0.178519] pci 0000:2a:00.0: PME# supported from D3hot D3cold
[ 0.178655] pci 0000:00:08.2: PCI bridge to [bus 2a]
[ 0.178662] pci 0000:00:08.2: bridge window [mem 0xfcf00000-0xfcffffff]
[ 0.179346] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.179405] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.179455] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.179519] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.179576] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.179622] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.179669] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.179715] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.181058] iommu: Default domain type: Translated
[ 0.181059] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.181181] SCSI subsystem initialized
[ 0.181193] libata version 3.00 loaded.
[ 0.181193] ACPI: bus type USB registered
[ 0.181193] usbcore: registered new interface driver usbfs
[ 0.181193] usbcore: registered new interface driver hub
[ 0.181193] usbcore: registered new device driver usb
[ 0.181193] pps_core: LinuxPPS API ver. 1 registered
[ 0.181193] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.181193] PTP clock support registered
[ 0.181193] EDAC MC: Ver: 3.0.0
[ 0.181193] Registered efivars operations
[ 0.181193] NetLabel: Initializing
[ 0.181193] NetLabel: domain hash size = 128
[ 0.181193] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.181193] NetLabel: unlabeled traffic allowed by default
[ 0.181193] mctp: management component transport protocol core
[ 0.181193] NET: Registered PF_MCTP protocol family
[ 0.181193] PCI: Using ACPI for IRQ routing
[ 0.184141] PCI: pci_cache_line_size set to 64 bytes
[ 0.184220] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 0.184222] e820: reserve RAM buffer [mem 0x09d80000-0x0bffffff]
[ 0.184223] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[ 0.184224] e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff]
[ 0.184225] e820: reserve RAM buffer [mem 0xd88b7000-0xdbffffff]
[ 0.184226] e820: reserve RAM buffer [mem 0xdba36000-0xdbffffff]
[ 0.184227] e820: reserve RAM buffer [mem 0xdbcd4000-0xdbffffff]
[ 0.184227] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[ 0.184228] e820: reserve RAM buffer [mem 0x41f340000-0x41fffffff]
[ 0.184238] pci 0000:12:00.0: vgaarb: setting as boot VGA device
[ 0.184238] pci 0000:12:00.0: vgaarb: bridge control possible
[ 0.184238] pci 0000:12:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.184238] vgaarb: loaded
[ 0.184238] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.184238] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.185482] clocksource: Switched to clocksource tsc-early
[ 0.185582] VFS: Disk quotas dquot_6.6.0
[ 0.185598] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.185691] AppArmor: AppArmor Filesystem Enabled
[ 0.185699] pnp: PnP ACPI init
[ 0.185699] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.185699] system 00:01: [mem 0x1000000000000 window] could not be reserved
[ 0.185699] system 00:03: [io 0x0a00-0x0a0f] has been reserved
[ 0.185699] system 00:03: [io 0x0a10-0x0a1f] has been reserved
[ 0.185699] system 00:03: [io 0x0a20-0x0a2f] has been reserved
[ 0.185699] system 00:03: [io 0x0a40-0x0a4f] has been reserved
[ 0.185699] pnp 00:04: [dma 0 disabled]
[ 0.185699] pnp 00:05: [dma 0 disabled]
[ 0.185699] system 00:06: [io 0x04d0-0x04d1] has been reserved
[ 0.185699] system 00:06: [io 0x040b] has been reserved
[ 0.185699] system 00:06: [io 0x04d6] has been reserved
[ 0.185699] system 00:06: [io 0x0c00-0x0c01] has been reserved
[ 0.185699] system 00:06: [io 0x0c14] has been reserved
[ 0.185699] system 00:06: [io 0x0c50-0x0c51] has been reserved
[ 0.185699] system 00:06: [io 0x0c52] has been reserved
[ 0.185699] system 00:06: [io 0x0c6c] has been reserved
[ 0.185699] system 00:06: [io 0x0c6f] has been reserved
[ 0.185699] system 00:06: [io 0x0cd0-0x0cd1] has been reserved
[ 0.185699] system 00:06: [io 0x0cd2-0x0cd3] has been reserved
[ 0.185699] system 00:06: [io 0x0cd4-0x0cd5] has been reserved
[ 0.185699] system 00:06: [io 0x0cd6-0x0cd7] has been reserved
[ 0.185699] system 00:06: [io 0x0cd8-0x0cdf] has been reserved
[ 0.185699] system 00:06: [io 0x0800-0x089f] has been reserved
[ 0.185699] system 00:06: [io 0x0b00-0x0b0f] has been reserved
[ 0.185699] system 00:06: [io 0x0b20-0x0b3f] has been reserved
[ 0.185699] system 00:06: [io 0x0900-0x090f] has been reserved
[ 0.185699] system 00:06: [io 0x0910-0x091f] has been reserved
[ 0.185699] system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.185699] system 00:06: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 0.185699] system 00:06: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 0.185699] system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.185699] system 00:06: [mem 0xfed80000-0xfed8ffff] could not be reserved
[ 0.185699] system 00:06: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.185699] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.185699] pnp: PnP ACPI: found 7 devices
[ 0.191010] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.191072] NET: Registered PF_INET protocol family
[ 0.191277] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.193849] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.193882] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.193974] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.194154] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.194223] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.194326] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.194371] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.194407] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.194471] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.194475] NET: Registered PF_XDP protocol family
[ 0.194492] pci 0000:11:00.0: PCI bridge to [bus 12]
[ 0.194496] pci 0000:11:00.0: bridge window [io 0xf000-0xffff]
[ 0.194501] pci 0000:11:00.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.194504] pci 0000:11:00.0: bridge window [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.194510] pci 0000:10:00.0: PCI bridge to [bus 11-12]
[ 0.194512] pci 0000:10:00.0: bridge window [io 0xf000-0xffff]
[ 0.194517] pci 0000:10:00.0: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 0.194520] pci 0000:10:00.0: bridge window [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.194525] pci 0000:00:01.1: PCI bridge to [bus 10-12]
[ 0.194527] pci 0000:00:01.1: bridge window [io 0xf000-0xffff]
[ 0.194532] pci 0000:00:01.1: bridge window [mem 0xfcd00000-0xfcefffff]
[ 0.194535] pci 0000:00:01.1: bridge window [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.194542] pci 0000:20:04.0: PCI bridge to [bus 25]
[ 0.194544] pci 0000:20:04.0: bridge window [io 0xe000-0xefff]
[ 0.194548] pci 0000:20:04.0: bridge window [mem 0xfcb00000-0xfcbfffff]
[ 0.194557] pci 0000:20:05.0: PCI bridge to [bus 26]
[ 0.194569] pci 0000:20:06.0: PCI bridge to [bus 27]
[ 0.194581] pci 0000:20:07.0: PCI bridge to [bus 28]
[ 0.194592] pci 0000:13:00.2: PCI bridge to [bus 20-28]
[ 0.194594] pci 0000:13:00.2: bridge window [io 0xe000-0xefff]
[ 0.194599] pci 0000:13:00.2: bridge window [mem 0xfcb00000-0xfcbfffff]
[ 0.194607] pci 0000:00:01.2: PCI bridge to [bus 13-28]
[ 0.194609] pci 0000:00:01.2: bridge window [io 0xe000-0xefff]
[ 0.194613] pci 0000:00:01.2: bridge window [mem 0xfcb00000-0xfccfffff]
[ 0.194622] pci 0000:00:08.1: PCI bridge to [bus 29]
[ 0.194626] pci 0000:00:08.1: bridge window [mem 0xfc700000-0xfcafffff]
[ 0.194635] pci 0000:00:08.2: PCI bridge to [bus 2a]
[ 0.194639] pci 0000:00:08.2: bridge window [mem 0xfcf00000-0xfcffffff]
[ 0.194648] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.194650] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.194651] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.194652] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.194653] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[ 0.194654] pci_bus 0000:00: resource 9 [mem 0xe0000000-0xfec2ffff window]
[ 0.194655] pci_bus 0000:00: resource 10 [mem 0xfee00000-0xffffffff window]
[ 0.194657] pci_bus 0000:10: resource 0 [io 0xf000-0xffff]
[ 0.194658] pci_bus 0000:10: resource 1 [mem 0xfcd00000-0xfcefffff]
[ 0.194659] pci_bus 0000:10: resource 2 [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.194660] pci_bus 0000:11: resource 0 [io 0xf000-0xffff]
[ 0.194661] pci_bus 0000:11: resource 1 [mem 0xfcd00000-0xfcdfffff]
[ 0.194662] pci_bus 0000:11: resource 2 [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.194663] pci_bus 0000:12: resource 0 [io 0xf000-0xffff]
[ 0.194664] pci_bus 0000:12: resource 1 [mem 0xfcd00000-0xfcdfffff]
[ 0.194665] pci_bus 0000:12: resource 2 [mem 0xe0000000-0xf01fffff 64bit pref]
[ 0.194667] pci_bus 0000:13: resource 0 [io 0xe000-0xefff]
[ 0.194668] pci_bus 0000:13: resource 1 [mem 0xfcb00000-0xfccfffff]
[ 0.194669] pci_bus 0000:20: resource 0 [io 0xe000-0xefff]
[ 0.194670] pci_bus 0000:20: resource 1 [mem 0xfcb00000-0xfcbfffff]
[ 0.194671] pci_bus 0000:25: resource 0 [io 0xe000-0xefff]
[ 0.194672] pci_bus 0000:25: resource 1 [mem 0xfcb00000-0xfcbfffff]
[ 0.194673] pci_bus 0000:29: resource 1 [mem 0xfc700000-0xfcafffff]
[ 0.194674] pci_bus 0000:2a: resource 1 [mem 0xfcf00000-0xfcffffff]
[ 0.194934] pci 0000:29:00.3: extending delay after power-on from D3hot to 20 msec
[ 0.195062] pci 0000:29:00.4: extending delay after power-on from D3hot to 20 msec
[ 0.195156] PCI: CLS 64 bytes, default 64
[ 0.195168] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.195196] Trying to unpack rootfs image as initramfs...
[ 0.195207] pci 0000:00:00.2: can't derive routing for PCI INT A
[ 0.195208] pci 0000:00:00.2: PCI INT A: not connected
[ 0.195230] pci 0000:00:01.0: Adding to iommu group 0
[ 0.195240] pci 0000:00:01.1: Adding to iommu group 1
[ 0.195249] pci 0000:00:01.2: Adding to iommu group 2
[ 0.195264] pci 0000:00:08.0: Adding to iommu group 3
[ 0.195271] pci 0000:00:08.1: Adding to iommu group 3
[ 0.195281] pci 0000:00:08.2: Adding to iommu group 4
[ 0.195295] pci 0000:00:14.0: Adding to iommu group 5
[ 0.195301] pci 0000:00:14.3: Adding to iommu group 5
[ 0.195332] pci 0000:00:18.0: Adding to iommu group 6
[ 0.195339] pci 0000:00:18.1: Adding to iommu group 6
[ 0.195346] pci 0000:00:18.2: Adding to iommu group 6
[ 0.195353] pci 0000:00:18.3: Adding to iommu group 6
[ 0.195361] pci 0000:00:18.4: Adding to iommu group 6
[ 0.195368] pci 0000:00:18.5: Adding to iommu group 6
[ 0.195375] pci 0000:00:18.6: Adding to iommu group 6
[ 0.195382] pci 0000:00:18.7: Adding to iommu group 6
[ 0.195391] pci 0000:10:00.0: Adding to iommu group 7
[ 0.195400] pci 0000:11:00.0: Adding to iommu group 8
[ 0.195429] pci 0000:12:00.0: Adding to iommu group 9
[ 0.195446] pci 0000:13:00.0: Adding to iommu group 10
[ 0.195456] pci 0000:13:00.1: Adding to iommu group 10
[ 0.195465] pci 0000:13:00.2: Adding to iommu group 10
[ 0.195469] pci 0000:20:04.0: Adding to iommu group 10
[ 0.195472] pci 0000:20:05.0: Adding to iommu group 10
[ 0.195476] pci 0000:20:06.0: Adding to iommu group 10
[ 0.195479] pci 0000:20:07.0: Adding to iommu group 10
[ 0.195482] pci 0000:25:00.0: Adding to iommu group 10
[ 0.195486] pci 0000:29:00.0: Adding to iommu group 3
[ 0.195489] pci 0000:29:00.2: Adding to iommu group 3
[ 0.195493] pci 0000:29:00.3: Adding to iommu group 3
[ 0.195496] pci 0000:29:00.4: Adding to iommu group 3
[ 0.195500] pci 0000:29:00.6: Adding to iommu group 3
[ 0.195510] pci 0000:2a:00.0: Adding to iommu group 11
[ 0.198051] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.198054] AMD-Vi: Extended features (0x4f77ef22294ada): PPR NX GT IA GA PC GA_vAPIC
[ 0.198059] AMD-Vi: Interrupt remapping enabled
[ 0.198060] AMD-Vi: Virtual APIC enabled
[ 0.277922] Freeing initrd memory: 8060K
[ 0.294287] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.294289] software IO TLB: mapped [mem 0x00000000d464c000-0x00000000d864c000] (64MB)
[ 0.294368] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 0.295540] Initialise system trusted keyrings
[ 0.295549] Key type blacklist registered
[ 0.295585] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 0.296639] zbud: loaded
[ 0.296882] integrity: Platform Keyring initialized
[ 0.296884] integrity: Machine keyring initialized
[ 0.305892] Key type asymmetric registered
[ 0.305894] Asymmetric key parser 'x509' registered
[ 0.308106] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 0.308121] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.308156] io scheduler mq-deadline registered
[ 0.308157] io scheduler kyber registered
[ 0.308177] io scheduler bfq registered
[ 0.309900] pcieport 0000:00:01.1: AER: enabled with IRQ 26
[ 0.310130] pcieport 0000:00:01.2: AER: enabled with IRQ 27
[ 0.310523] pcieport 0000:00:08.2: AER: enabled with IRQ 29
[ 0.311889] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.312001] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.312019] ACPI: button: Power Button [PWRB]
[ 0.312048] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.312088] ACPI: button: Power Button [PWRF]
[ 0.312135] Monitor-Mwait will be used to enter C-1 state
[ 0.312141] ACPI: \_PR_.C000: Found 2 idle states
[ 0.312241] ACPI: \_PR_.C002: Found 2 idle states
[ 0.312357] ACPI: \_PR_.C004: Found 2 idle states
[ 0.312478] ACPI: \_PR_.C006: Found 2 idle states
[ 0.312574] ACPI: \_PR_.C001: Found 2 idle states
[ 0.312689] ACPI: \_PR_.C003: Found 2 idle states
[ 0.312769] ACPI: \_PR_.C005: Found 2 idle states
[ 0.312875] ACPI: \_PR_.C007: Found 2 idle states
[ 0.313153] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.313356] 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.315030] Non-volatile memory driver v1.3
[ 0.315031] Linux agpgart interface v0.103
[ 0.315066] AMD-Vi: AMD IOMMUv2 loaded and initialized
[ 0.315116] ACPI: bus type drm_connector registered
[ 0.315845] ahci 0000:13:00.1: version 3.0
[ 0.315954] ahci 0000:13:00.1: SSS flag set, parallel bus scan disabled
[ 0.315999] ahci 0000:13:00.1: AHCI 0001.0301 32 slots 8 ports 6 Gbps 0x33 impl SATA mode
[ 0.316002] ahci 0000:13:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[ 0.316383] scsi host0: ahci
[ 0.316476] scsi host1: ahci
[ 0.316546] scsi host2: ahci
[ 0.316621] scsi host3: ahci
[ 0.316687] scsi host4: ahci
[ 0.316758] scsi host5: ahci
[ 0.316826] scsi host6: ahci
[ 0.316886] scsi host7: ahci
[ 0.316914] ata1: SATA max UDMA/133 abar m131072@0xfcc80000 port 0xfcc80100 irq 42
[ 0.316917] ata2: SATA max UDMA/133 abar m131072@0xfcc80000 port 0xfcc80180 irq 42
[ 0.316918] ata3: DUMMY
[ 0.316919] ata4: DUMMY
[ 0.316921] ata5: SATA max UDMA/133 abar m131072@0xfcc80000 port 0xfcc80300 irq 42
[ 0.316923] ata6: SATA max UDMA/133 abar m131072@0xfcc80000 port 0xfcc80380 irq 42
[ 0.316924] ata7: DUMMY
[ 0.316924] ata8: DUMMY
[ 0.327698] ahci 0000:2a:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.327702] ahci 0000:2a:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.327878] scsi host8: ahci
[ 0.327916] ata9: SATA max UDMA/133 abar m2048@0xfcf00000 port 0xfcf00100 irq 44
[ 0.327948] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.327951] ehci-pci: EHCI PCI platform driver
[ 0.327964] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.327966] ohci-pci: OHCI PCI platform driver
[ 0.327972] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.327999] usbcore: registered new interface driver usbserial_generic
[ 0.328003] usbserial: USB Serial support registered for generic
[ 0.328085] rtc_cmos 00:02: RTC can wake from S4
[ 0.328395] rtc_cmos 00:02: registered as rtc0
[ 0.328443] rtc_cmos 00:02: setting system clock to 2022-09-03T16:27:09 UTC (1662222429)
[ 0.328456] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.328574] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.328741] efifb: probing for efifb
[ 0.328766] efifb: No BGRT, not showing boot graphics
[ 0.328766] efifb: framebuffer at 0xe0000000, using 3072k, total 3072k
[ 0.328768] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 0.328769] efifb: scrolling: redraw
[ 0.328770] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.328800] fbcon: Deferring console take-over
[ 0.328801] fb0: EFI VGA frame buffer device
[ 0.328821] hid: raw HID events driver (C) Jiri Kosina
[ 0.328914] drop_monitor: Initializing network drop monitor service
[ 0.338948] Initializing XFRM netlink socket
[ 0.339031] NET: Registered PF_INET6 protocol family
[ 0.341653] Segment Routing with IPv6
[ 0.341655] RPL Segment Routing with IPv6
[ 0.341661] In-situ OAM (IOAM) with IPv6
[ 0.341676] NET: Registered PF_PACKET protocol family
[ 0.342245] microcode: CPU0: patch_level=0x08101016
[ 0.342253] microcode: CPU1: patch_level=0x08101016
[ 0.342274] microcode: CPU2: patch_level=0x08101016
[ 0.342283] microcode: CPU3: patch_level=0x08101016
[ 0.342288] microcode: CPU4: patch_level=0x08101016
[ 0.342294] microcode: CPU5: patch_level=0x08101016
[ 0.342312] microcode: CPU6: patch_level=0x08101016
[ 0.342321] microcode: CPU7: patch_level=0x08101016
[ 0.342324] microcode: Microcode Update Driver: v2.2.
[ 0.342327] IPI shorthand broadcast: enabled
[ 0.342342] sched_clock: Marking stable (365494619, -23327203)->(362915279, -20747863)
[ 0.342559] registered taskstats version 1
[ 0.342724] Loading compiled-in X.509 certificates
[ 0.345225] Loaded X.509 cert 'Build time autogenerated kernel key: a79eaf520fee2b4b1cc63b196c2a681703b07612'
[ 0.347235] zswap: loaded using pool zstd/z3fold
[ 0.347427] Key type ._fscrypt registered
[ 0.347429] Key type .fscrypt registered
[ 0.347429] Key type fscrypt-provisioning registered
[ 0.347459] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.349245] PM: Magic number: 6:865:488
[ 0.349302] regulator regulator.0: hash matches
[ 0.349382] RAS: Correctable Errors collector initialized.
[ 0.643003] ata9: SATA link down (SStatus 0 SControl 300)
[ 0.795483] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.796156] ata1.00: ATA-11: SanDisk SDSSDH3 512G, 40101000, max UDMA/133
[ 0.796770] ata1.00: 1000215216 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 0.798321] ata1.00: Features: Dev-Sleep
[ 0.806651] ata1.00: configured for UDMA/133
[ 0.806849] scsi 0:0:0:0: Direct-Access ATA SanDisk SDSSDH3 1000 PQ: 0 ANSI: 5
[ 0.807204] sd 0:0:0:0: [sda] 1000215216 512-byte logical blocks: (512 GB/477 GiB)
[ 0.807220] sd 0:0:0:0: [sda] Write Protect is off
[ 0.807224] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.807246] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.807275] sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[ 0.875833] sda: sda1 sda2 sda3
[ 0.876110] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.124311] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.310401] tsc: Refined TSC clocksource calibration: 3599.999 MHz
[ 1.310420] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x33e4525366a, max_idle_ns: 440795257657 ns
[ 1.310469] clocksource: Switched to clocksource tsc
[ 1.434590] ata5: SATA link down (SStatus 0 SControl 300)
[ 1.743789] ata6: SATA link down (SStatus 0 SControl 300)
[ 1.745945] Freeing unused decrypted memory: 2036K
[ 1.746223] Freeing unused kernel image (initmem) memory: 2120K
[ 1.746227] Write protecting the kernel read-only data: 30720k
[ 1.746730] Freeing unused kernel image (text/rodata gap) memory: 2040K
[ 1.746928] Freeing unused kernel image (rodata/data gap) memory: 1048K
[ 1.796332] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.796335] rodata_test: all tests were successful
[ 1.796350] Run /init as init process
[ 1.796351] with arguments:
[ 1.796352] /init
[ 1.796353] with environment:
[ 1.796354] HOME=/
[ 1.796354] TERM=linux
[ 1.796355] BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
[ 1.928422] xhci_hcd 0000:13:00.0: xHCI Host Controller
[ 1.928429] xhci_hcd 0000:13:00.0: new USB bus registered, assigned bus number 1
[ 1.983875] xhci_hcd 0000:13:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000010048000410
[ 1.984087] xhci_hcd 0000:13:00.0: xHCI Host Controller
[ 1.984090] xhci_hcd 0000:13:00.0: new USB bus registered, assigned bus number 2
[ 1.984094] xhci_hcd 0000:13:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.984146] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 1.984148] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.984150] usb usb1: Product: xHCI Host Controller
[ 1.984151] usb usb1: Manufacturer: Linux 5.19.1-3-MANJARO xhci-hcd
[ 1.984152] usb usb1: SerialNumber: 0000:13:00.0
[ 1.984246] hub 1-0:1.0: USB hub found
[ 1.984262] hub 1-0:1.0: 10 ports detected
[ 1.984564] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.984580] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.19
[ 1.984582] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.984583] usb usb2: Product: xHCI Host Controller
[ 1.984584] usb usb2: Manufacturer: Linux 5.19.1-3-MANJARO xhci-hcd
[ 1.984585] usb usb2: SerialNumber: 0000:13:00.0
[ 1.984647] hub 2-0:1.0: USB hub found
[ 1.984655] hub 2-0:1.0: 4 ports detected
[ 1.984863] xhci_hcd 0000:29:00.3: xHCI Host Controller
[ 1.984867] xhci_hcd 0000:29:00.3: new USB bus registered, assigned bus number 3
[ 1.985053] xhci_hcd 0000:29:00.3: hcc params 0x0270ffe5 hci version 0x110 quirks 0x0000000840000410
[ 1.985498] xhci_hcd 0000:29:00.3: xHCI Host Controller
[ 1.985500] xhci_hcd 0000:29:00.3: new USB bus registered, assigned bus number 4
[ 1.985502] xhci_hcd 0000:29:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.985568] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 1.985569] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.985571] usb usb3: Product: xHCI Host Controller
[ 1.985572] usb usb3: Manufacturer: Linux 5.19.1-3-MANJARO xhci-hcd
[ 1.985573] usb usb3: SerialNumber: 0000:29:00.3
[ 1.985635] hub 3-0:1.0: USB hub found
[ 1.985644] hub 3-0:1.0: 4 ports detected
[ 1.986083] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.986098] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.19
[ 1.986100] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.986101] usb usb4: Product: xHCI Host Controller
[ 1.986102] usb usb4: Manufacturer: Linux 5.19.1-3-MANJARO xhci-hcd
[ 1.986103] usb usb4: SerialNumber: 0000:29:00.3
[ 1.986165] hub 4-0:1.0: USB hub found
[ 1.986174] hub 4-0:1.0: 4 ports detected
[ 1.986691] xhci_hcd 0000:29:00.4: xHCI Host Controller
[ 1.986695] xhci_hcd 0000:29:00.4: new USB bus registered, assigned bus number 5
[ 1.986855] xhci_hcd 0000:29:00.4: hcc params 0x0260ffe5 hci version 0x110 quirks 0x0000000840000410
[ 1.987259] xhci_hcd 0000:29:00.4: xHCI Host Controller
[ 1.987262] xhci_hcd 0000:29:00.4: new USB bus registered, assigned bus number 6
[ 1.987264] xhci_hcd 0000:29:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.987314] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.19
[ 1.987316] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.987317] usb usb5: Product: xHCI Host Controller
[ 1.987318] usb usb5: Manufacturer: Linux 5.19.1-3-MANJARO xhci-hcd
[ 1.987319] usb usb5: SerialNumber: 0000:29:00.4
[ 1.987379] hub 5-0:1.0: USB hub found
[ 1.987385] hub 5-0:1.0: 1 port detected
[ 1.987468] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.987484] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.19
[ 1.987485] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.987486] usb usb6: Product: xHCI Host Controller
[ 1.987487] usb usb6: Manufacturer: Linux 5.19.1-3-MANJARO xhci-hcd
[ 1.987488] usb usb6: SerialNumber: 0000:29:00.4
[ 1.987546] hub 6-0:1.0: USB hub found
[ 1.987552] hub 6-0:1.0: 1 port detected
[ 2.236726] usb 5-1: new full-speed USB device number 2 using xhci_hcd
[ 2.300052] usb 1-1: new full-speed USB device number 2 using xhci_hcd
[ 2.347855] PM: Image not found (code -22)
[ 2.396442] usb 5-1: New USB device found, idVendor=2550, idProduct=8761, bcdDevice= 2.00
[ 2.396447] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.396450] usb 5-1: Product: Bluetooth Radio
[ 2.396451] usb 5-1: Manufacturer: Realtek
[ 2.396453] usb 5-1: SerialNumber: 00E04C239987
[ 2.532858] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
[ 2.603628] usb 1-1: New USB device found, idVendor=25a7, idProduct=fa23, bcdDevice= 2.41
[ 2.603633] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.603636] usb 1-1: Product: 2.4G Receiver
[ 2.603637] usb 1-1: Manufacturer: Compx
[ 2.704864] systemd[1]: systemd 251.4-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 2.704871] systemd[1]: Detected architecture x86-64.
[ 2.729183] systemd[1]: Hostname set to <BT2400G>.
[ 2.800063] usb 1-3: new full-speed USB device number 3 using xhci_hcd
[ 3.186789] usb 1-3: New USB device found, idVendor=28de, idProduct=1142, bcdDevice= 0.01
[ 3.186798] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.186802] usb 1-3: Product: Steam Controller
[ 3.186805] usb 1-3: Manufacturer: Valve Software
[ 3.390079] usb 1-4: new full-speed USB device number 4 using xhci_hcd
[ 3.425039] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.426077] systemd[1]: Created slice Slice /system/getty.
[ 3.426374] systemd[1]: Created slice Slice /system/modprobe.
[ 3.426632] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 3.426882] systemd[1]: Created slice User and Session Slice.
[ 3.426943] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.426989] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.427125] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.427163] systemd[1]: Reached target Local Encrypted Volumes.
[ 3.427178] systemd[1]: Reached target Login Prompts.
[ 3.427192] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 3.427213] systemd[1]: Reached target Path Units.
[ 3.427230] systemd[1]: Reached target Remote File Systems.
[ 3.427240] systemd[1]: Reached target Slice Units.
[ 3.427261] systemd[1]: Reached target System Time Set.
[ 3.427283] systemd[1]: Reached target Local Verity Protected Volumes.
[ 3.427345] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 3.428751] systemd[1]: Listening on LVM2 poll daemon socket.
[ 3.431137] systemd[1]: Listening on Process Core Dump Socket.
[ 3.431259] systemd[1]: Listening on Journal Audit Socket.
[ 3.431349] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.431443] systemd[1]: Listening on Journal Socket.
[ 3.431678] systemd[1]: Listening on udev Control Socket.
[ 3.431756] systemd[1]: Listening on udev Kernel Socket.
[ 3.432680] systemd[1]: Mounting Huge Pages File System...
[ 3.433330] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.433977] systemd[1]: Mounting Kernel Debug File System...
[ 3.434589] systemd[1]: Mounting Kernel Trace File System...
[ 3.435400] systemd[1]: Starting Load AppArmor profiles...
[ 3.436238] systemd[1]: Starting Create List of Static Device Nodes...
[ 3.436904] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 3.437619] systemd[1]: Starting Load Kernel Module configfs...
[ 3.438235] systemd[1]: Starting Load Kernel Module drm...
[ 3.438904] systemd[1]: Starting Load Kernel Module fuse...
[ 3.438983] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 3.440426] systemd[1]: Starting Journal Service...
[ 3.442023] systemd[1]: Starting Load Kernel Modules...
[ 3.442778] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.442856] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 3.443778] systemd[1]: Starting Coldplug All udev Devices...
[ 3.445174] systemd[1]: Mounted Huge Pages File System.
[ 3.445282] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.445361] systemd[1]: Mounted Kernel Debug File System.
[ 3.445446] systemd[1]: Mounted Kernel Trace File System.
[ 3.445636] systemd[1]: Finished Create List of Static Device Nodes.
[ 3.445914] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 3.446043] systemd[1]: Finished Load Kernel Module configfs.
[ 3.446281] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 3.446402] systemd[1]: Finished Load Kernel Module drm.
[ 3.447191] systemd[1]: Mounting Kernel Configuration File System...
[ 3.451202] fuse: init (API version 7.36)
[ 3.451718] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 3.451817] systemd[1]: Finished Load Kernel Module fuse.
[ 3.452519] systemd[1]: Mounting FUSE Control File System...
[ 3.453598] systemd[1]: Mounted FUSE Control File System.
[ 3.454252] systemd[1]: Mounted Kernel Configuration File System.
[ 3.468098] EXT4-fs (sda2): re-mounted. Quota mode: none.
[ 3.468983] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 3.469049] audit: type=1130 audit(1662222432.635:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.469156] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 3.470092] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 3.470985] systemd[1]: Starting Load/Save Random Seed...
[ 3.471054] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 3.471600] vhba: loading out-of-tree module taints kernel.
[ 3.471634] vhba: module verification failed: signature and/or required key missing - tainting kernel
[ 3.471945] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 3.472375] scsi host9: vhba
[ 3.482161] systemd[1]: Finished Load/Save Random Seed.
[ 3.482221] audit: type=1130 audit(1662222432.648:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.482299] systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 3.485625] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3.503809] systemd[1]: Finished Load Kernel Modules.
[ 3.503853] audit: type=1130 audit(1662222432.672:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.504654] systemd[1]: Starting Apply Kernel Variables...
[ 3.509413] systemd[1]: Started Journal Service.
[ 3.509481] audit: type=1130 audit(1662222432.675:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.521815] systemd-journald[277]: Received client request to flush runtime journal.
[ 3.540429] audit: type=1130 audit(1662222432.708:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.561560] audit: type=1130 audit(1662222432.728:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.593679] audit: type=1130 audit(1662222432.762:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.594449] audit: type=1334 audit(1662222432.762:9): prog-id=9 op=LOAD
[ 3.594501] audit: type=1334 audit(1662222432.762:10): prog-id=10 op=LOAD
[ 3.776471] usb 1-4: New USB device found, idVendor=28de, idProduct=1142, bcdDevice= 0.01
[ 3.776477] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.776479] usb 1-4: Product: Steam Controller
[ 3.776481] usb 1-4: Manufacturer: Valve Software
[ 3.895819] acpi_cpufreq: overriding BIOS provided _PSD data
[ 3.976697] usb 1-8: new full-speed USB device number 5 using xhci_hcd
[ 3.997369] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 4.002583] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 4.002938] acpi device:02: registered as cooling_device8
[ 4.002996] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/LNXVIDEO:00/input/input2
[ 4.012375] ACPI: video: Video Device [VGA1] (multi-head: yes rom: no post: no)
[ 4.012565] acpi device:14: registered as cooling_device9
[ 4.012611] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input3
[ 4.114022] parport_pc 00:04: reported by Plug and Play ACPI
[ 4.114117] parport0: PC-style at 0x378, irq 5 [PCSPP]
[ 4.117836] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 4.118314] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 4.118318] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 4.118385] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 4.149102] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 4.149267] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 4.149408] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 4.164737] Adding 15771436k swap on /dev/sda3. Priority:-2 extents:1 across:15771436k SSFS
[ 4.206405] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 4.206410] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 4.271646] ccp 0000:29:00.2: ccp enabled
[ 4.271663] ccp 0000:29:00.2: psp: unable to access the device: you might be running a broken BIOS.
[ 4.292847] usb 1-8: New USB device found, idVendor=1ea7, idProduct=0066, bcdDevice= 2.00
[ 4.292853] usb 1-8: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.292855] usb 1-8: Product: 2.4G Mouse
[ 4.310038] cryptd: max_cpu_qlen set to 1000
[ 4.409020] ppdev: user-space parallel port driver
[ 4.542934] AVX2 version of gcm_enc/dec engaged.
[ 4.542964] AES CTR mode by8 optimization enabled
[ 4.548774] r8169 0000:25:00.0 eth0: RTL8168h/8111h, 30:9c:23:6d:19:c8, XID 541, IRQ 66
[ 4.548780] r8169 0000:25:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 4.644448] r8169 0000:25:00.0 enp37s0: renamed from eth0
[ 5.004997] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC892: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 5.005005] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 5.005008] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 5.005011] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 5.005013] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 5.005016] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 5.005019] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 5.005021] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 5.027676] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:29:00.6/sound/card0/input5
[ 5.027726] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:29:00.6/sound/card0/input6
[ 5.027768] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:29:00.6/sound/card0/input7
[ 5.027823] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:08.1/0000:29:00.6/sound/card0/input8
[ 5.027866] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:29:00.6/sound/card0/input9
[ 5.197882] kauditd_printk_skb: 177 callbacks suppressed
[ 5.197885] audit: type=1130 audit(1662222434.365:76): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.254448] audit: type=1130 audit(1662222434.422:77): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.259882] audit: type=1127 audit(1662222434.425:78): pid=535 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 5.263187] audit: type=1130 audit(1662222434.428:79): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.268295] audit: type=1130 audit(1662222434.435:80): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.276538] audit: type=1334 audit(1662222434.442:81): prog-id=12 op=LOAD
[ 5.276631] audit: type=1334 audit(1662222434.442:82): prog-id=13 op=LOAD
[ 5.276658] audit: type=1334 audit(1662222434.442:83): prog-id=14 op=LOAD
[ 5.282852] audit: type=1334 audit(1662222434.448:84): prog-id=15 op=LOAD
[ 5.285605] audit: type=1130 audit(1662222434.452:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.317902] loop: module loaded
[ 6.318553] [drm] amdgpu kernel modesetting enabled.
[ 6.318631] amdgpu: Ignoring ACPI CRAT on non-APU system
[ 6.318635] amdgpu: Virtual CRAT table created for CPU
[ 6.318648] amdgpu: Topology: Add CPU node
[ 6.318808] amdgpu 0000:12:00.0: vgaarb: deactivate vga console
[ 6.318927] [drm] initializing kernel modesetting (VEGA10 0x1002:0x687F 0x1462:0x3681 0xC3).
[ 6.318940] [drm] register mmio base: 0xFCD00000
[ 6.318941] [drm] register mmio size: 524288
[ 6.319005] [drm] add ip block number 0 <soc15_common>
[ 6.319008] [drm] add ip block number 1 <gmc_v9_0>
[ 6.319010] [drm] add ip block number 2 <vega10_ih>
[ 6.319011] [drm] add ip block number 3 <psp>
[ 6.319012] [drm] add ip block number 4 <powerplay>
[ 6.319014] [drm] add ip block number 5 <dm>
[ 6.319015] [drm] add ip block number 6 <gfx_v9_0>
[ 6.319017] [drm] add ip block number 7 <sdma_v4_0>
[ 6.319018] [drm] add ip block number 8 <uvd_v7_0>
[ 6.319019] [drm] add ip block number 9 <vce_v4_0>
[ 6.320669] loop0: detected capacity change from 0 to 8
[ 6.321020] NET: Registered PF_QIPCRTR protocol family
[ 6.324125] input: Compx 2.4G Receiver as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-1/1-1:1.0/0003:25A7:FA23.0001/input/input10
[ 6.325321] SVM: TSC scaling supported
[ 6.325324] kvm: Nested Virtualization enabled
[ 6.325325] SVM: kvm: Nested Paging enabled
[ 6.325331] SEV supported: 16 ASIDs
[ 6.325332] SEV-ES supported: 4294967295 ASIDs
[ 6.325353] SVM: Virtual VMLOAD VMSAVE supported
[ 6.325353] SVM: Virtual GIF supported
[ 6.325354] SVM: LBR virtualization supported
[ 6.335703] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 6.336546] MCE: In-kernel MCE decoding enabled.
[ 6.365446] amdgpu 0000:12:00.0: No more image in the PCI ROM
[ 6.365473] amdgpu 0000:12:00.0: amdgpu: Fetched VBIOS from ROM BAR
[ 6.365476] amdgpu: ATOM BIOS: xxx-xxx-xxx
[ 6.370704] [drm] UVD(0) is enabled in VM mode
[ 6.370706] [drm] UVD(0) ENC is enabled in VM mode
[ 6.370707] [drm] VCE enabled in VM mode
[ 6.370709] amdgpu 0000:12:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[ 6.370746] amdgpu 0000:12:00.0: amdgpu: MEM ECC is not presented.
[ 6.370747] amdgpu 0000:12:00.0: amdgpu: SRAM ECC is not presented.
[ 6.370755] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[ 6.370762] amdgpu 0000:12:00.0: amdgpu: VRAM: 8176M 0x000000F400000000 - 0x000000F5FEFFFFFF (8176M used)
[ 6.370764] amdgpu 0000:12:00.0: amdgpu: GART: 512M 0x0000000000000000 - 0x000000001FFFFFFF
[ 6.370766] amdgpu 0000:12:00.0: amdgpu: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
[ 6.370773] [drm] Detected VRAM RAM=8176M, BAR=256M
[ 6.370774] [drm] RAM width 2048bits HBM
[ 6.370808] [drm] amdgpu: 8176M of VRAM memory ready
[ 6.370809] [drm] amdgpu: 7970M of GTT memory ready.
[ 6.370817] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 6.371056] [drm] PCIE GART of 512M enabled.
[ 6.371056] [drm] PTB located at 0x000000F400900000
[ 6.377294] amdgpu 0000:12:00.0: amdgpu: PSP runtime database doesn't exist
[ 6.377300] amdgpu 0000:12:00.0: amdgpu: PSP runtime database doesn't exist
[ 6.377397] amdgpu: hwmgr_sw_init smu backed is vega10_smu
[ 6.380192] hid-generic 0003:25A7:FA23.0001: input,hidraw0: USB HID v1.10 Keyboard [Compx 2.4G Receiver] on usb-0000:13:00.0-1/input0
[ 6.387184] input: Compx 2.4G Receiver Mouse as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-1/1-1:1.1/0003:25A7:FA23.0002/input/input11
[ 6.387247] input: Compx 2.4G Receiver as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-1/1-1:1.1/0003:25A7:FA23.0002/input/input12
[ 6.387248] [drm] Found UVD firmware Version: 66.43 Family ID: 17
[ 6.387286] [drm] PSP loading UVD firmware
[ 6.387304] input: Compx 2.4G Receiver Consumer Control as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-1/1-1:1.1/0003:25A7:FA23.0002/input/input13
[ 6.389477] [drm] Found VCE firmware Version: 57.6 Binary ID: 4
[ 6.389526] [drm] PSP loading VCE firmware
[ 6.423477] Bluetooth: Core ver 2.22
[ 6.423511] NET: Registered PF_BLUETOOTH protocol family
[ 6.423512] Bluetooth: HCI device and connection manager initialized
[ 6.423516] Bluetooth: HCI socket layer initialized
[ 6.423519] Bluetooth: L2CAP socket layer initialized
[ 6.423523] Bluetooth: SCO socket layer initialized
[ 6.426898] Generic FE-GE Realtek PHY r8169-0-2500:00: attached PHY driver (mii_bus:phy_addr=r8169-0-2500:00, irq=MAC)
[ 6.438412] intel_rapl_common: Found RAPL domain package
[ 6.438416] intel_rapl_common: Found RAPL domain core
[ 6.443449] input: Compx 2.4G Receiver System Control as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-1/1-1:1.1/0003:25A7:FA23.0002/input/input14
[ 6.443560] hid-generic 0003:25A7:FA23.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [Compx 2.4G Receiver] on usb-0000:13:00.0-1/input1
[ 6.449055] input: Valve Software Steam Controller Keyboard as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-3/1-3:1.0/0003:28DE:1142.0003/input/input16
[ 6.506846] input: Valve Software Steam Controller Mouse as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-3/1-3:1.0/0003:28DE:1142.0003/input/input17
[ 6.506908] hid-generic 0003:28DE:1142.0003: input,hidraw2: USB HID v1.11 Keyboard [Valve Software Steam Controller] on usb-0000:13:00.0-3/input0
[ 6.511025] hid-generic 0003:28DE:1142.0004: hiddev97,hidraw3: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-3/input1
[ 6.515995] hid-generic 0003:28DE:1142.0005: hiddev98,hidraw4: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-3/input2
[ 6.521032] hid-generic 0003:28DE:1142.0006: hiddev99,hidraw5: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-3/input3
[ 6.526037] hid-generic 0003:28DE:1142.0007: hiddev100,hidraw6: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-3/input4
[ 6.532143] input: Valve Software Steam Controller Keyboard as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-4/1-4:1.0/0003:28DE:1142.0008/input/input18
[ 6.575524] usbcore: registered new interface driver btusb
[ 6.578395] Bluetooth: hci0: RTL: examining hci_ver=0a hci_rev=000b lmp_ver=0a lmp_subver=8761
[ 6.578862] [drm] reserve 0x400000 from 0xf5fec00000 for PSP TMR
[ 6.581395] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 6.581402] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_fw.bin
[ 6.586833] input: Valve Software Steam Controller Mouse as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-4/1-4:1.0/0003:28DE:1142.0008/input/input19
[ 6.586879] hid-generic 0003:28DE:1142.0008: input,hidraw7: USB HID v1.11 Keyboard [Valve Software Steam Controller] on usb-0000:13:00.0-4/input0
[ 6.591197] hid-generic 0003:28DE:1142.0009: hiddev101,hidraw8: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-4/input1
[ 6.592525] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_config.bin
[ 6.593721] Bluetooth: hci0: RTL: cfg_sz 6, total sz 27814
[ 6.596101] hid-generic 0003:28DE:1142.000A: hiddev102,hidraw9: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-4/input2
[ 6.601012] hid-generic 0003:28DE:1142.000B: hiddev103,hidraw10: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-4/input3
[ 6.605973] hid-generic 0003:28DE:1142.000C: hiddev104,hidraw11: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-4/input4
[ 6.616860] r8169 0000:25:00.0 enp37s0: Link is Down
[ 6.618147] input: 2.4G Mouse as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-8/1-8:1.0/0003:1EA7:0066.000D/input/input20
[ 6.633303] [drm] Display Core initialized with v3.2.187!
[ 6.673553] hid-generic 0003:1EA7:0066.000D: input,hidraw12: USB HID v1.10 Keyboard [2.4G Mouse] on usb-0000:13:00.0-8/input0
[ 6.674740] [drm] kiq ring mec 2 pipe 1 q 0
[ 6.680914] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.680918] Bluetooth: BNEP filters: protocol multicast
[ 6.680922] Bluetooth: BNEP socket layer initialized
[ 6.696383] [drm] UVD and UVD ENC initialized successfully.
[ 6.700457] input: 2.4G Mouse as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-8/1-8:1.1/0003:1EA7:0066.000E/input/input21
[ 6.700554] input: 2.4G Mouse as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-8/1-8:1.1/0003:1EA7:0066.000E/input/input22
[ 6.700662] input: 2.4G Mouse Consumer Control as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-8/1-8:1.1/0003:1EA7:0066.000E/input/input23
[ 6.756787] input: 2.4G Mouse System Control as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-8/1-8:1.1/0003:1EA7:0066.000E/input/input24
[ 6.756916] hid-generic 0003:1EA7:0066.000E: input,hiddev105,hidraw13: USB HID v1.10 Mouse [2.4G Mouse] on usb-0000:13:00.0-8/input1
[ 6.756968] usbcore: registered new interface driver usbhid
[ 6.756971] usbhid: USB HID core driver
[ 6.797094] [drm] VCE initialized successfully.
[ 6.798448] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[ 6.798503] amdgpu: sdma_bitmap: f
[ 6.856240] memmap_init_zone_device initialised 2097152 pages in 14ms
[ 6.856247] amdgpu: HMM registered 8176MB device memory
[ 6.856277] amdgpu: SRAT table not found
[ 6.856278] amdgpu: Virtual CRAT table created for GPU
[ 6.856397] amdgpu: Topology: Add dGPU node [0x687f:0x1002]
[ 6.856400] kfd kfd: amdgpu: added device 1002:687f
[ 6.856418] amdgpu 0000:12:00.0: amdgpu: SE 4, SH per SE 1, CU per SH 16, active_cu_number 56
[ 6.856498] amdgpu 0000:12:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
[ 6.856500] amdgpu 0000:12:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[ 6.856501] amdgpu 0000:12:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[ 6.856503] amdgpu 0000:12:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
[ 6.856504] amdgpu 0000:12:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
[ 6.856505] amdgpu 0000:12:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
[ 6.856506] amdgpu 0000:12:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
[ 6.856507] amdgpu 0000:12:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
[ 6.856509] amdgpu 0000:12:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
[ 6.856510] amdgpu 0000:12:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
[ 6.856511] amdgpu 0000:12:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
[ 6.856512] amdgpu 0000:12:00.0: amdgpu: ring page0 uses VM inv eng 1 on hub 1
[ 6.856513] amdgpu 0000:12:00.0: amdgpu: ring sdma1 uses VM inv eng 4 on hub 1
[ 6.856514] amdgpu 0000:12:00.0: amdgpu: ring page1 uses VM inv eng 5 on hub 1
[ 6.856515] amdgpu 0000:12:00.0: amdgpu: ring uvd_0 uses VM inv eng 6 on hub 1
[ 6.856516] amdgpu 0000:12:00.0: amdgpu: ring uvd_enc_0.0 uses VM inv eng 7 on hub 1
[ 6.856518] amdgpu 0000:12:00.0: amdgpu: ring uvd_enc_0.1 uses VM inv eng 8 on hub 1
[ 6.856519] amdgpu 0000:12:00.0: amdgpu: ring vce0 uses VM inv eng 9 on hub 1
[ 6.856520] amdgpu 0000:12:00.0: amdgpu: ring vce1 uses VM inv eng 10 on hub 1
[ 6.856521] amdgpu 0000:12:00.0: amdgpu: ring vce2 uses VM inv eng 11 on hub 1
[ 6.858176] [drm] Initialized amdgpu 3.47.0 20150101 for 0000:12:00.0 on minor 0
[ 6.860666] fbcon: amdgpudrmfb (fb0) is primary device
[ 6.860669] fbcon: Deferring console take-over
[ 6.860670] amdgpu 0000:12:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[ 6.954390] Bluetooth: hci0: RTL: fw version 0x09a98a6b
[ 6.997022] mousedev: PS/2 mouse device common for all mice
[ 7.020696] ahci 0000:13:00.1: port does not support device sleep
[ 7.053666] input: Valve Software Steam Controller as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-3/1-3:1.0/0003:28DE:1142.0003/input/input26
[ 7.097907] NET: Registered PF_ALG protocol family
[ 7.110206] hid-steam 0003:28DE:1142.0003: input,hidraw2: USB HID v1.11 Keyboard [Valve Software Steam Controller] on usb-0000:13:00.0-3/input0
[ 7.110387] hid-steam 0003:28DE:1142.0004: hiddev97: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-3/input1
[ 7.110493] hid-steam 0003:28DE:1142.000F: hidraw3: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-3/input1
[ 7.166690] hid-steam 0003:28DE:1142.0004: Steam wireless receiver connected
[ 7.168115] hid-steam 0003:28DE:1142.0005: hiddev98: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-3/input2
[ 7.168220] hid-steam 0003:28DE:1142.0010: hidraw4: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-3/input2
[ 7.223356] hid-steam 0003:28DE:1142.0005: Steam wireless receiver connected
[ 7.225114] hid-steam 0003:28DE:1142.0006: hiddev99: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-3/input3
[ 7.225213] hid-steam 0003:28DE:1142.0011: hidraw5: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-3/input3
[ 7.280020] hid-steam 0003:28DE:1142.0006: Steam wireless receiver connected
[ 7.282160] hid-steam 0003:28DE:1142.0007: hiddev100: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-3/input4
[ 7.282271] hid-steam 0003:28DE:1142.0012: hidraw6: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-3/input4
[ 7.336728] hid-steam 0003:28DE:1142.0007: Steam wireless receiver connected
[ 7.527031] input: Valve Software Steam Controller as /devices/pci0000:00/0000:00:01.2/0000:13:00.0/usb1/1-4/1-4:1.0/0003:28DE:1142.0008/input/input27
[ 7.583766] hid-steam 0003:28DE:1142.0008: input,hidraw7: USB HID v1.11 Keyboard [Valve Software Steam Controller] on usb-0000:13:00.0-4/input0
[ 7.584110] hid-steam 0003:28DE:1142.0009: hiddev101: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-4/input1
[ 7.584345] hid-steam 0003:28DE:1142.0013: hidraw8: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-4/input1
[ 7.640022] hid-steam 0003:28DE:1142.0009: Steam wireless receiver connected
[ 7.642177] hid-steam 0003:28DE:1142.000A: hiddev102: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-4/input2
[ 7.642261] hid-steam 0003:28DE:1142.0014: hidraw9: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-4/input2
[ 7.696700] hid-steam 0003:28DE:1142.000A: Steam wireless receiver connected
[ 7.698276] hid-steam 0003:28DE:1142.000B: hiddev103: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-4/input3
[ 7.698449] hid-steam 0003:28DE:1142.0015: hidraw10: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-4/input3
[ 7.756914] hid-steam 0003:28DE:1142.000B: Steam wireless receiver connected
[ 7.759439] hid-steam 0003:28DE:1142.000C: hiddev104: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-4/input4
[ 7.759649] hid-steam 0003:28DE:1142.0016: hidraw11: USB HID v1.11 Device [Valve Software Steam Controller] on usb-0000:13:00.0-4/input4
[ 7.813594] hid-steam 0003:28DE:1142.000C: Steam wireless receiver connected
[ 9.626972] r8169 0000:25:00.0 enp37s0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 9.626986] IPv6: ADDRCONF(NETDEV_CHANGE): enp37s0: link becomes ready
[ 11.598159] kauditd_printk_skb: 44 callbacks suppressed
