No Audio after last update
Good evening everyone.
After the latest update, I no longer have any audio.
Some info:
[giacomob@asus ~]$ uname -r
6.18.4-1-MANJARO
[giacomob@asus ~]$ lspci -kv|grep Audio
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06) (prog-if 00 [HDA compatible])
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05) (prog-if 00 [HDA compatible])
Any ideas?
Welcome to Manjaro forum @CielitoLindo
Please post more information about system:
inxi -SMAa
and audio devices detected in PulseAudio/PipeWire:
pactl list cards; pactl list sinks
First thing to check is volume levels. For some unknown reason to me, devices and or apps will be muted, after an update.
pactl list sinks shows the mute state and volume levels of PulseAudio/PipeWire sink outputs
Manjaro Xfce also has PulseAudio Volume Control pavucontrol GUI to check mute state and volume levels
[giacomob@asus ~]$ inxi -SMAa
  Host: asus Kernel: 6.18.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
    v: 15.2.1 clocksource: tsc avail: hpet,acpi_pm
    root=UUID=db253009-7f03-4d99-b540-f7856bcccb2b rw quiet splash apparmor=1
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.51 wm: Compiz v: 0.9.14.2
    with: cairo-dock,xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: ASUSTeK product: N551JM v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: N551JM v: 1.0 serial: <superuser required>
    part-nu: ASUS-NotebookSKU uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends v: N551JM.204 date: 10/06/2014
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
    class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
    class-ID: 0403
  API: ALSA v: k6.18.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: wireplumber
    status: active tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-98-gb096 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
[giacomob@asus ~]$ pactl list cards; pactl list sinks
Scheda #0
	Nome: alsa_card.pci-0000_00_03.0
	Driver: module-alsa-card.c
	Modulo di appartenenza: 6
	Proprietà:
		alsa.card = "0"
		alsa.card_name = "HDA Intel HDMI"
		alsa.long_card_name = "HDA Intel HDMI at 0xf7a14000 irq 42"
		device.bus_path = "pci-0000:00:03.0"
		sysfs.path = "/devices/pci0000:00/0000:00:03.0/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "0c0c"
		device.product.name = "Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller"
		device.string = "0"
		device.description = "Audio interno"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	Profili:
		output:hdmi-stereo: Uscita «Digital Stereo (HDMI)» (sink: 1, sorgenti: 0, priorità: 5900, disponibile: no)
		output:hdmi-surround: Uscita «Digital Surround 5.1 (HDMI)» (sink: 1, sorgenti: 0, priorità: 800, disponibile: no)
		output:hdmi-surround71: Uscita «Digital Surround 7.1 (HDMI)» (sink: 1, sorgenti: 0, priorità: 800, disponibile: no)
		output:hdmi-stereo-extra1: Uscita «Digital Stereo (HDMI 2)» (sink: 1, sorgenti: 0, priorità: 5700, disponibile: no)
		output:hdmi-surround-extra1: Uscita «Digital Surround 5.1 (HDMI 2)» (sink: 1, sorgenti: 0, priorità: 600, disponibile: no)
		output:hdmi-surround71-extra1: Uscita «Digital Surround 7.1 (HDMI 2)» (sink: 1, sorgenti: 0, priorità: 600, disponibile: no)
		output:hdmi-stereo-extra2: Uscita «Digital Stereo (HDMI 3)» (sink: 1, sorgenti: 0, priorità: 5700, disponibile: no)
		output:hdmi-surround-extra2: Uscita «Digital Surround 5.1 (HDMI 3)» (sink: 1, sorgenti: 0, priorità: 600, disponibile: no)
		output:hdmi-surround71-extra2: Uscita «Digital Surround 7.1 (HDMI 3)» (sink: 1, sorgenti: 0, priorità: 600, disponibile: no)
		off: Spento (sink: 0, sorgenti: 0, priorità: 0, disponibile: sì)
	Profilo attivo: off
	Porte:
		hdmi-output-0: HDMI / DisplayPort (tipo: HDMI, priorità: 5900, offset latenza: 0 usec, non disponibile)
			Proprietà:
			Parte dei profili: output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
		hdmi-output-1: HDMI / DisplayPort 2 (tipo: HDMI, priorità: 5800, offset latenza: 0 usec, non disponibile)
			Proprietà:
			Parte dei profili: output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
		hdmi-output-2: HDMI / DisplayPort 3 (tipo: HDMI, priorità: 5700, offset latenza: 0 usec, non disponibile)
			Proprietà:
			Parte dei profili: output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
Scheda #1
	Nome: alsa_card.pci-0000_00_1b.0
	Modulo di appartenenza: 7
	Proprietà:
		alsa.card = "1"
		alsa.long_card_name = "HDA Intel PCH at 0xf7a10000 irq 43"
		device.bus_path = "pci-0000:00:1b.0"
		sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card1"
		device.bus = "pci"
		device.product.id = "8c20"
		device.product.name = "8 Series/C220 Series Chipset High Definition Audio Controller"
		device.string = "1"
	Profili:
		input:analog-stereo: Ingresso «Stereo analogico» (sink: 0, sorgenti: 1, priorità: 32833, disponibile: sì)
		output:analog-stereo: Uscita «Stereo analogico» (sink: 1, sorgenti: 0, priorità: 39268, disponibile: sì)
		output:analog-stereo+input:analog-stereo: Duplex stereo analogico (sink: 1, sorgenti: 1, priorità: 39333, disponibile: sì)
		output:analog-surround-21: Uscita «Surround analogico 2.1» (sink: 1, sorgenti: 0, priorità: 34068, disponibile: sì)
		output:analog-surround-21+input:analog-stereo: Uscita «Surround analogico 2.1» + Ingresso «Stereo analogico» (sink: 1, sorgenti: 1, priorità: 34133, disponibile: sì)
		output:analog-surround-40: Uscita «Surround analogico 4.0» (sink: 1, sorgenti: 0, priorità: 33968, disponibile: sì)
		output:analog-surround-40+input:analog-stereo: Uscita «Surround analogico 4.0» + Ingresso «Stereo analogico» (sink: 1, sorgenti: 1, priorità: 34033, disponibile: sì)
	Profilo attivo: output:analog-stereo+input:analog-stereo
	Porte:
		analog-input-internal-mic: Microfono interno (tipo: Mic, priorità: 8900, offset latenza: 0 usec, disponibilità sconosciuta)
			Proprietà:
			Parte dei profili: input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo
		analog-input-headphone-mic: Microfono (tipo: Mic, priorità: 8700, offset latenza: 0 usec, gruppo disponibilità: Legacy 2, non disponibile)
			Proprietà:
		analog-input-headset-mic: Microfono auricolare (tipo: Cuffie con microfono, priorità: 8800, offset latenza: 0 usec, gruppo disponibilità: Legacy 2, non disponibile)
			Proprietà:
		analog-output-speaker: Altoparlanti (tipo: Altoparlante, priorità: 10000, offset latenza: 0 usec, disponibilità sconosciuta)
			Proprietà:
			Parte dei profili: output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo
		analog-output-headphones: Cuffie analogiche (tipo: Cuffie analogiche, priorità: 9900, offset latenza: 0 usec, gruppo disponibilità: Legacy 2, non disponibile)
			Proprietà:
Sink #0
	Stato: SUSPENDED
	Nome: alsa_output.pci-0000_00_1b.0.analog-stereo
	Descrizione: Audio interno Stereo analogico
	Specifica di campionamento: s16le ch 2 44100 Hz
	Mappa dei canali: front-left,front-right
	Muto: no
	Volume: front-left: 26241 /  40% / -23,85 dB,   front-right: 26241 /  40% / -23,85 dB
	        bilanciamento 0,00
	Volume base: 65536 / 100% / 0,00 dB
	Monitor della sorgente: alsa_output.pci-0000_00_1b.0.analog-stereo.monitor
	Latenza: 0 usec, configurata 0 usec
	Flag: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Proprietà:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = "ALC668 Analog"
		alsa.id = "ALC668 Analog"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "0"
		alsa.card = "1"
		device.bus = "pci"
		device.string = "front:1"
		device.buffering.buffer_size = "352800"
		device.buffering.fragment_size = "176400"
		device.access_mode = "mmap+timer"
		device.profile.name = "analog-stereo"
		device.profile.description = "Stereo analogico"
		device.description = "Audio interno Stereo analogico"
	Porte:
		analog-output-speaker: Altoparlanti (tipo: Altoparlante, priorità: 10000, disponibilità sconosciuta)
		analog-output-headphones: Cuffie analogiche (tipo: Cuffie analogiche, priorità: 9900, gruppo disponibilità: Legacy 2, non disponibile)
	Porta attiva: analog-output-speaker
	Formati:
		pcm
[giacomob@asus ~]$
WirePlumber session/policy manager for PipeWire should be masked so it cannot cause problems for PulseAudio
systemctl --user mask wireplumber.service
I also suggest remove old user settings for PulseAudio and restart pulseaudio.service
(reset PulseAudio to default configuration)
rm ~/.config/pulse/*; systemctl --user restart pulseaudio
If PulseAudio is still not working as expected, please post more information:
pacmd dump
