When I try to open a file from Dolphin, the following dialog appears, and there are no applications to choose from:
I’m using dolphin from bspwm (but the problem occurs also on xfce), I installed plasma and it works fine if I open Dolphin from plasma.
Nevertheless, it worked fine on bspwm before the plasma6 update.
So technically this has nothing to do with plasma?
I advise you to ensure that bspwm can locate the mimeapps.list file in your ~/.config folder.
Perhaps you accidently removed it as part of the plasma6 update?
On second thought the mime associations is usually provided by the system - and the local mimeapps.list only contains your preferences.
Yeah, under plasma 6 it works fine, its under bspwm that I have the issue.
The mimeapps list exists, and works fine when opening files from my browser, when using xdg-open, or when using other file managers (Thunar, for example).
Btw, I just realized that If I try to open an URL of a PDF in Okular, it shows the same dialog. It doesn’t know what to open the URL with. I guess the problem is present in all KDE applications. I don’t know wether to assign the “kde” tag to this.
I have very little - if any - experience with bspwm - I think I played with once - but the mimetypes are supplied globally by the system - I cannot really see why bspwm would not know.
I am fairly certain though it is not a plasma issue - as such - more a configuration which has gone lost - again - I cannot figure out why.
If you check the mimetype - what is the reply ?
mimetype -M bla.pdf
mimetype bla.pdf
You can rebuild your mime database using
sudo update-mime-database /usr/share/mime
Mimetypes are fine, it works with other programs.
$ mimetype -M Documents/HORARIO.*
Documents/HORARIO.odt: application/vnd.oasis.opendocument.text
Documents/HORARIO.pdf: application/pdf
$ mimetype Documents/HORARIO.*
The problem also exists with other desktop environments, such as XFCE:
But works fine in Plasma:
In plasma, Okular can open links too.
Also, outside of plasma, making double click in a file on Dolphin doesn’t work.
I finally came up with the solution, the problem is that it can’t find the applications.menu
file. I have multiple .menu files in /etc/xdg/menus, but not one for bspwm.
$ ls /etc/xdg/menus
gnome-applications.menu plasma-applications.menu xfce-settings-manager.menu
kinfocenter.menu xfce-applications.menu
I had to choose one of those menu files (for example, the xfce one, as I will uninstall plasma after this test) and, either:
1. Set the XDG_MENU_PREFIX
environment variable.
Set it to XDG_MENU_PREFIX=xfce-
and restart the DE
2. Link one of the files
sudo ln -s /etc/xdg/menus/xfce-applications.menu /etc/xdg/menus/applications.menu
No need to restart, just open Dolphin again and it works.
I don’t know how it was working before plasma 6 though
