Hello,
I just installed Manjaro as a guest machine to VMware Workstation. I get system sound (e.g. the beep when you click the Manjaro power icon at bottom right) but no application sound (e.g. from VLC or Youtube on Firefox). How could I get application sound?
I am new to Manjaro and fairly new to Linux itself, and so don’t know what is relevant information. I will just list all the steps I took so far because they are not many. I’d be happy to provide any additional information necessary to solve the issue. Thank you very much.
Steps so far
- Install manjaro-xfce-22.1.0-230421-linux61.iso as guest to VMware Workstation 17.0.2 pro running on Windows 11 pro.
- When the VM boots, notice the message: “The default sound device cannot be opened: A device ID has been used that is out of range for your system. Failed to connect virtual device sound.”
- Update Manjaro using
sudo pacman -Syu
(plus some preliminary commands for updating the mirror). - Create and enable
vmwaretools.service
(so that open-vm-tools package would start with Manjaro). - Start Manjaro > click speaker icon > Audio mixer… > see a popup named “Volume Control” > Configuration (tab) > Change Profile from “Analog Stereo Duplex” to “Analog Stereo Output”.
- Restart Manjaro > see no more the message “The default sound device cannot be opened…”.
- Start an app that plays sound (e.g. VLC, Firefox).
- Open “Volume Control” window > Output Devices (tab).
- See “ES1371/ES1371/ Creative Labs CT2518 (Audio PCI 64V/128/5200 / Creative CT4810/CT5803.CT5806 [Sound Blaster PCI]) Analog Stereo” is not muted.
- See also two bar graphs. The top one is fixed at 94%. The bottom one moves (grows and shrinks) with what would appear to be the volume of the video being played (in VLC or Firefox).
- For background, I might add that both the physical (Windows 11) machine and another VMware guest (Windows 11) machine give me sound just fine.
- Also for background, I get system sound (e.g. beep on clicking Manjaro power button) no matter which value I set Profile (in Volume Control’s Configuration tab) to, the available values being “Analog Stereo Duplex”, “Analog Stereo output”, “Analog Stereo Input”, or “Off.”
Sorry, but what I called “system sound” may not be that at all. In fact, the only sound I ever heard from this Manjaro VM is the one from clicking the power button. That beep’s volume remains constant even when I change the “System Sounds” volume in Volume Control’s Playback tab.
Thanks.
