After update and reboot I don’t have analog sound device. The digital works but I don’t like it.
Please read this and provide that information:
Only important and relevant for you from alsa-info.sh
Thanks but downgrade doesn’t work for me.
That can mean 2 things.
- You wanted to
downgrade
some package and it ended in an error. - The downgraded package did not make things to work better
But, in that comment was about trying a different kernel. Probably lower version than current. Have you tried that?
I am talking about the kernel downgrade to 4.19. And I am currently after a restart on LTS 5.60.
So, how can I downgrade the package? I am talking about a manual.
Actually 5.6 is EOL = end of life, never meant to get LTS. You should stop using it.
There is no reason to downgrade kernel 4.19.141-2 to a lower version of it. Is probably the most stable LTS kernels. Just install it as is on all branches
sudo mhwd-kernel -i linux419
The downgrade
package has to be installed, then run:
downgrade <package>
will show all the available versions of it, and you can chose a number, but i recommend cautions on this.
It says invalid option
And how can I check which package should I downgrade?
Sorry, my bad. Corrected now
Unable to downgrade alsa and I used the wiki.
Update: After downgrade of the kernel 5.60 and 4.19 crashed on boot so I had to switch to 5.7 with crapy sound.
Now that you have kernel v5.7, please post the responses to these commands
sudo dmesg | grep -E 'snd|sof-'
and
lspci -vnn | grep -A1 Audio
[ 5.787277] snd_hda_intel 0000:0c:00.1: Force to non-snoop mode
[ 5.787489] snd_hda_intel 0000:0e:00.4: enabling device (0000 -> 0002)
[ 5.942812] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[ 5.942814] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 5.942816] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 5.942817] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 5.942819] snd_hda_codec_realtek hdaudioC1D0: dig-out=0x1e/0x0
[ 5.942825] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 5.942826] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
[ 5.942828] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
[ 5.942829] snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
[ 6.899328] snd_hda_intel 0000:0c:00.1: bound 0000:0c:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
0c:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 HDMI Audio [1002:ab38]
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 HDMI Audio [1002:ab38]
Flags: bus master, fast devsel, latency 0, IRQ 112, IOMMU group 170e:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
Subsystem: ASUSTeK Computer Inc. Device [1043:8735]
All looks ok in dmesg
- no errors
4 output connections
hp_outs=1 (0x1b
3 input connections
Front Mic=0x19
Rear Mic=0x18
Line=0x1a
A few online searches showed nothing about a kernel patch listed for the Analog audio device ID name or ID code [1043:8735] .
But also no mention of of any Linux audio problems.
I expected to see some because there have been audio problems on certain AMD Ryzen motherboards
Audio connections in ALSA look ok so problem may be in Pulseaudio
please post responses to
pacmd dump
and
pacmd list-sinks
Here
Configuration dump generated at Mon Aug 31 21:43:58 2020
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id=“0” name=“pci-0000_0c_00.1” card_name=“alsa_card.pci-0000_0c_00.1” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties=“module-udev-detect.discovered=1”
load-module module-alsa-card device_id=“1” name=“pci-0000_0e_00.4” card_name=“alsa_card.pci-0000_0e_00.4” namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties=“module-udev-detect.discovered=1”
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-rescue-streams
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_0e_00.4.analog-stereo 0x8ca4
set-sink-mute alsa_output.pci-0000_0e_00.4.analog-stereo no
suspend-sink alsa_output.pci-0000_0e_00.4.analog-stereo yes
set-sink-volume alsa_output.pci-0000_0c_00.1.hdmi-stereo 0x10000
set-sink-mute alsa_output.pci-0000_0c_00.1.hdmi-stereo no
suspend-sink alsa_output.pci-0000_0c_00.1.hdmi-stereo yes
set-source-volume alsa_output.pci-0000_0e_00.4.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_0e_00.4.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_0e_00.4.analog-stereo.monitor yes
set-source-volume alsa_output.pci-0000_0c_00.1.hdmi-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_0c_00.1.hdmi-stereo.monitor no
suspend-source alsa_output.pci-0000_0c_00.1.hdmi-stereo.monitor yes
set-card-profile alsa_card.pci-0000_0c_00.1 output:hdmi-stereo
set-card-profile alsa_card.pci-0000_0e_00.4 output:analog-stereo
set-default-sink alsa_output.pci-0000_0e_00.4.analog-stereo
set-default-source alsa_output.pci-0000_0e_00.4.analog-stereo.monitor
EOF
pacmd list-sinks
2 sink(s) available.
index: 0
driver: <module-alsa-card.c>
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 36004 / 55% / -15,61 dB, front-right: 36004 / 55% / -15,61 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 0,00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
sample spec: s16le 2k 48000Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
fixed latency: 100,14 ms
card: 1 <alsa_card.pci-0000_0e_00.4>
module: 7
properties:
alsa.resolution_bits = “16”
device.api = “alsa”
device.class = “sound”
alsa.class = “generic”
alsa.subclass = “generic-mix”
alsa.name = “ALC1220 Analog”
alsa.id = “ALC1220 Analog”
alsa.subdevice = “0”
alsa.subdevice_name = “subdevice #0”
alsa.device = “0”
alsa.card = “1”
alsa.card_name = “HD-Audio Generic”
alsa.long_card_name = “HD-Audio Generic at 0xfc700000 irq 114”
alsa.driver_name = “snd_hda_intel”
device.bus_path = “pci-0000:0e:00.4”
sysfs.path = “/devices/pci0000:00/0000:00:08.1/0000:0e:00.4/sound/card1”
device.bus = “pci”
device.vendor.id = “1022”
device.vendor.name = “Advanced Micro Devices, Inc. [AMD]”
device.product.id = “1487”
device.product.name = “Starship/Matisse HD Audio Controller”
device.string = “front:1”
device.buffering.buffer_size = “17664”
device.buffering.fragment_size = “2944”
device.access_mode = “mmap”
device.profile.name = “analog-stereo”
device.profile.description = “Analógový stereo”
device.description = “Starship/Matisse HD Audio Controller Analógový stereo”
alsa.mixer_name = “Realtek ALC1220”
alsa.components = “HDA:10ec1220,10438735,00100101”
module-udev-detect.discovered = “1”
device.icon_name = “audio-card-pci”
ports:
analog-output-lineout: Výstupná linka (priority 9000, latency offset 0 usec, available: yes)
properties:analog-output-headphones: Slúchadlá (priority 9900, latency offset 0 usec, available: no) properties: device.icon_name = "audio-headphones" active port: <analog-output-lineout>
index: 4
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9030
volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 4
sample spec: s16le 2k 44100Hz
Stereo
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 … 1999,82 ms
card: 0 <alsa_card.pci-0000_0c_00.1>
module: 6
properties:
device.api = “alsa”
alsa.name = “HDMI 0”
alsa.id = “HDMI 0”
alsa.device = “3”
alsa.card = “0”
alsa.card_name = “HDA ATI HDMI”
alsa.long_card_name = “HDA ATI HDMI at 0xfcba0000 irq 112”
device.bus_path = “pci-0000:0c:00.1”
sysfs.path = “/devices/pci0000:00/0000:00:03.1/0000:0a:00.0/0000:0b:00.0/0000:0c:00.1/sound/card0”
device.bus = “pci”
device.vendor.id = “1002”
device.vendor.name = “Advanced Micro Devices, Inc. [AMD/ATI]”
device.product.id = “ab38”
device.product.name = “Navi 10 HDMI Audio”
device.string = “hdmi:0”
device.buffering.buffer_size = “352768”
device.buffering.fragment_size = “176384”
device.access_mode = “mmap+timer”
device.profile.name = “hdmi-stereo”
device.profile.description = “Digital Stereo (HDMI)”
device.description = “Navi 10 HDMI Audio Digital Stereo (HDMI)”
alsa.mixer_name = “ATI R6xx HDMI”
alsa.components = “HDA:1002aa01,00aa0100,00100700”
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: yes)
properties:
device.icon_name = “video-display”
device.product.name = “ASUS VP247”
active port:
Analog device is set as the default sink for audio output
device has 2 ports (but only one is shown as available)
analog-output-lineout: Výstupná linka (priority 9000, latency offset 0 usec, available: yes) analog-output-headphones: Slúchadlá (priority 9900, latency offset 0 usec, available: no)
active port for audio playback will be (green rear jack on motherboard)
please post more information to show if headphone socket has been muted in ALSA settings
amixer -c1
Here
Simple mixer control ‘Master’,0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 66 [76%] [-15.75dB] [on]
Simple mixer control ‘Headphone’,0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control ‘PCM’,0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control ‘Front’,0
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control ‘Front Mic’,0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control ‘Front Mic Boost’,0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control ‘Surround’,0
Mono:
Simple mixer control ‘Center’,0
Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control ‘LFE’,0
Simple mixer control ‘Line’,0
Mono:
Simple mixer control ‘Line Boost’,0
Limits: 0 - 3
Simple mixer control ‘IEC958’,0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control ‘IEC958 Default PCM’,0
Mono: Playback [on]
Simple mixer control ‘Capture’,0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 39 [62%] [12.00dB] [on]
Front Right: Capture 39 [62%] [12.00dB] [on]
Simple mixer control ‘Capture’,1
Front Left: Capture 0 [0%] [-17.25dB] [off]
Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control ‘Auto-Mute Mode’,0
Capabilities: enum
Items: ‘Disabled’ ‘Enabled’
Item0: ‘Enabled’
Simple mixer control ‘Input Source’,0
Capabilities: cenum
Items: ‘Front Mic’ ‘Rear Mic’ ‘Line’
Item0: ‘Front Mic’
Simple mixer control ‘Input Source’,1
Capabilities: cenum
Item0: ‘Front Mic’
Simple mixer control ‘Loopback Mixing’,0
Capabilities: enum
Item0: ‘Disabled’
Simple mixer control ‘Rear Mic’,0
Mono:
Simple mixer control ‘Rear Mic Boost’,0
Limits: 0 - 3
ALSA control for Headphone is showing it has level 0% and is muted [off]
but line-out is not muted and 100% volume
Headphone control may have been muted by this control
Capabilities: enum
Item0: ‘Enabled’
suggest this command to change setting to disabled
amixer --card=1 sset ‘Auto-Mute Mode’ Disabled
and this to save ALSA settings
sudo alsactl store
