Mayby this would be helpfull as well:
pacmd list
Memory blocks currently allocated: 7, size: 140.7 KiB.
Memory blocks allocated during the whole lifetime: 1518586, size: 562.6 MiB.
Memory blocks imported from other processes: 4, size: 56.3 KiB.
Memory blocks exported to other processes: 0, size: 0 B.
Total sample cache size: 11.5 KiB.
Default sample spec: s16le 2ch 44100Hz
Default channel map: front-left,front-right
Default sink name: combined
Default source name: alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1.monitor
Memory blocks of type POOL: 3 allocated/1247506 accumulated.
Memory blocks of type POOL_EXTERNAL: 0 allocated/2 accumulated.
Memory blocks of type APPENDED: 0 allocated/0 accumulated.
Memory blocks of type USER: 0 allocated/0 accumulated.
Memory blocks of type FIXED: 0 allocated/121079 accumulated.
Memory blocks of type IMPORTED: 4 allocated/150001 accumulated.
29 module(s) loaded.
index: 0
argument: <>
used: -1
load once: yes
properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "15.0"
index: 1
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the volume/mute/device state of streams"
index: 2
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore profile of cards"
index: 3
argument: <>
used: -1
load once: yes
properties:
module.description = "Augment the property sets of streams with additional static information"
index: 4
argument: <>
used: -1
load once: yes
properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
index: 5
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect available audio hardware and load matching drivers"
index: 6
argument: <device_id="0" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1">
used: 0
load once: no
properties:
module.description = "ALSA Card"
index: 7
argument: <channels=2>
used: -1
load once: yes
properties:
module.description = "Adds JACK sink/source ports when JACK is started"
index: 8
argument: <>
used: -1
load once: yes
properties:
module.author = "Frédéric Dalleau, Pali Rohár"
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
index: 9
argument: <>
used: -1
load once: yes
properties:
module.author = "João Paulo Rechi Vita"
module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
index: 10
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
index: 11
argument: <>
used: -1
load once: yes
properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
index: 12
argument: <>
used: -1
load once: no
properties:
module.description = "Native protocol (UNIX sockets)"
index: 13
argument: <>
used: -1
load once: yes
properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
index: 14
argument: <>
used: -1
load once: no
properties:
module.author = "Colin Guthrie"
module.description = "Compatibility module (module-combine rename)"
index: 15
argument: <>
used: -1
load once: no
properties:
module.description = "Combine multiple sinks to one"
index: 16
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically restore the default sink and source"
index: 17
argument: <>
used: -1
load once: yes
properties:
module.description = "Always keeps at least one sink loaded even if it's a null one"
index: 18
argument: <>
used: -1
load once: yes
properties:
module.description = "Automatically set device of streams based on intended roles of devices"
index: 19
argument: <>
used: -1
load once: yes
properties:
module.description = "When a sink/source is idle for too long, suspend it"
index: 20
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each ConsoleKit session of this user"
index: 21
argument: <>
used: -1
load once: yes
properties:
module.description = "Create a client for each login session of this user"
index: 22
argument: <>
used: -1
load once: yes
properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
index: 23
argument: <>
used: -1
load once: yes
properties:
module.description = "Mute & cork streams with certain roles while others exist"
index: 24
argument: <>
used: -1
load once: yes
properties:
module.description = "Detect when various filters are desirable"
index: 25
argument: <>
used: -1
load once: yes
properties:
module.description = "Load filter sinks automatically when needed"
index: 26
argument: <display=:0 xauthority=/home/oskar/.Xauthority>
used: -1
load once: no
properties:
module.description = "X11 credential publisher"
index: 27
argument: <display=:0 xauthority=/home/oskar/.Xauthority session_manager=local/Nigel:@/tmp/.ICE-unix/1199,unix/Nigel:/tmp/.ICE-unix/1199>
used: -1
load once: no
properties:
module.description = "X11 session management"
index: 30
argument: <>
used: -1
load once: no
properties:
module.description = "Command line interface protocol (UNIX sockets)"
2 sink(s) available.
* index: 1
driver: <module-combine-sink.c>
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1000
volume: front-left: 42598 / 65% / -11.23 dB, front-right: 42598 / 65% / -11.23 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max request: 8 KiB
max rewind: 0 KiB
monitor source: 1
Stereo
used by: 0
linked by: 2
configured latency: 0.00 ms; range is 0.50 .. 200.00 ms
module: 15
properties:
device.class = "filter"
device.description = "Simultaneous output to GP104 High Definition Audio Controller Digital Stereo (HDMI 2)"
device.icon_name = "audio-card"
index: 4
driver: <module-alsa-card.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9030
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 4
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 1999.82 ms
card: 0 <alsa_card.pci-0000_01_00.1>
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "HDMI 1"
alsa.id = "HDMI 1"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "7"
alsa.card = "0"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xdf080000 irq 17"
device.bus_path = "pci-0000:01:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "10f0"
device.product.name = "GP104 High Definition Audio Controller"
device.string = "hdmi:0,1"
device.buffering.buffer_size = "352768"
device.buffering.fragment_size = "176384"
device.access_mode = "mmap+timer"
device.profile.name = "hdmi-stereo-extra1"
device.profile.description = "Digital Stereo (HDMI 2)"
device.description = "GP104 High Definition Audio Controller Digital Stereo (HDMI 2)"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: yes)
properties:
device.product.name = "EA244WMi
active port: <hdmi-output-1>
2 source(s) available.
index: 1
state: SUSPENDED
suspend cause: IDLE
priority: 1000
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 1
module: 15
properties:
device.description = "Monitor Source of Simultaneous output to GP104 High Definition Audio Controller Digital Stereo (HDMI 2)"
device.class = "monitor"
* index: 4
state: SUSPENDED
suspend cause: IDLE
priority: 1030
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 4
module: 6
properties:
device.description = "Monitor of GP104 High Definition Audio Controller Digital Stereo (HDMI 2)"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
18 client(s) logged in.
index: 0
driver: <module-systemd-login.c>
owner module: 21
properties:
application.name = "Login Session 1"
systemd-login.session = "1"
index: 3
driver: <module-x11-xsmp.c>
owner module: 27
properties:
application.name = "XSMP Session on KDE as 10ba696765000164646600300000011990012"
xsmp.vendor = "KDE"
xsmp.client.id = "10ba696765000164646600300000011990012"
index: 4
driver: <protocol-native.c>
owner module: 12
properties:
application.name = "Plasma PA"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "35"
application.id = "org.kde.plasma-pa"
application.icon_name = "audio-card"
application.process.id = "1220"
application.process.user = "oskar"
application.process.host = "Nigel"
application.process.binary = "plasmashell"
application.language = "en_GB.UTF-8"
window.x11.display = ":0"
application.process.machine_id = "234c6d78d5ae437f901ec996b9b7f48e"
application.process.session_id = "1"
index: 5
owner module: 12
properties:
application.name = "Spotify"
application.process.id = "2144"
application.process.binary = "spotify"
application.icon_name = "spotify-client"
index: 6
owner module: 12
properties:
application.name = "libcanberra"
application.version = "0.30"
application.id = "org.freedesktop.libcanberra"
index: 7
owner module: 12
properties:
application.name = "Thunderbird"
window.x11.screen = "0"
application.process.id = "2274"
application.process.binary = "thunderbird"
application.icon_name = "thunderbird"
index: 8
owner module: 12
properties:
application.version = "91.6.1"
index: 9
owner module: 12
properties:
application.name = "Firefox"
application.process.id = "2745"
application.process.binary = "firefox"
application.icon_name = "firefox"
index: 10
owner module: 12
properties:
index: 11
owner module: 12
properties:
application.version = "97.0.1"
index: 12
owner module: 12
properties:
application.process.id = "7207"
index: 13
owner module: 12
properties:
application.name = "QPulse"
application.process.id = "1238"
application.process.binary = "kdeconnectd"
index: 14
owner module: 12
properties:
index: 15
owner module: 12
properties:
application.name = "Firefox Developer Edition"
application.version = "98.0"
index: 16
owner module: 12
properties:
application.process.id = "12321"
application.process.binary = "systemsettings"
index: 18
owner module: 12
properties:
index: 20
owner module: 12
properties:
application.name = "Konsole"
application.icon_name = "utilities-terminal"
application.id = "org.kde.konsole"
application.process.id = "9672"
application.process.binary = "konsole"
index: 21
driver: <cli.c>
owner module: 30
properties:
application.name = "UNIX socket client"
1 card(s) available.
index: 0
owner module: 6
properties:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
device.description = "GP104 High Definition Audio Controller"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 38468, available: unknown)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (priority 5700, available: no)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (priority 600, available: no)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (priority 600, available: no)
output:hdmi-stereo-extra6: Digital Stereo (HDMI 7) Output (priority 5700, available: no)
output:hdmi-surround-extra6: Digital Surround 5.1 (HDMI 7) Output (priority 600, available: no)
output:hdmi-surround71-extra6: Digital Surround 7.1 (HDMI 7) Output (priority 600, available: no)
off: Off (priority 0, available: unknown)
active profile: <output:hdmi-stereo-extra1>
sinks:
alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1/#4: GP104 High Definition Audio Controller Digital Stereo (HDMI 2)
sources:
alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1.monitor/#4: Monitor of GP104 High Definition Audio Controller Digital Stereo (HDMI 2)
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
hdmi-output-5: HDMI / DisplayPort 6 (priority 5400, latency offset 0 usec, available: no)
properties:
hdmi-output-6: HDMI / DisplayPort 7 (priority 5300, latency offset 0 usec, available: no)
properties:
2 sink input(s) available.
index: 4
flags: START_CORKED
state: CORKED
sink: 1 <combined>
volume: front-left: 39462 / 60% / -13.22 dB, front-right: 39462 / 60% / -13.22 dB
balance 0.00
muted: no
requested latency: 48.22 ms
sample spec: float32le 2ch 44100Hz
Stereo
resample method: copy
module: 12
client: 5 <Spotify>
properties:
media.role = "music"
media.name = "Spotify"
module-stream-restore.id = "sink-input-by-media-role:music"
index: 151
flags: START_CORKED
state: CORKED
sink: 1 <combined>
balance 0.00
muted: no
current latency: 128.58 ms
sample spec: float32le 2ch 48000Hz
Stereo
resample method: speex-float-1
module: 12
client: 10 <Firefox>
properties:
media.name = "(5) Kent C. Dodds's Beginners Guide to React from egghead.io - YouTube"
module-stream-restore.id = "sink-input-by-application-name:Firefox"
0 source output(s) available.
1 cache entrie(s) available.
index: 0
Stereo
length: 11776
duration: 0.1 s
volume: n/a
balance 0.00
lazy: no
filename: <n/a>
properties:
media.role = "event"
event.id = "audio-volume-change"
event.description = "Volume Control Feedback Sound"
media.name = "audio-volume-change"
media.filename = "/usr/share/sounds/freedesktop/stereo/audio-volume-change.oga"
… I am completely new to all this…
