No actualización de paquetes
Hola a todos.
Tengo una duda relacionada con actualizaciones de archivos. Estoy en la rama estable con el escritorio Gnome. Pero tengo dos paquetes que no se actualizan. Suelo usar «sudo pacman -Syy ; sudo pacman -Su» para actualizar el sistema.
Este es mi equipo:
Summary
Kernel: 6.12.68-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=37a9efe6-9c59-460d-8a0e-283b7417385d rw quiet splash apparmor=1
security=apparmor resume=UUID=1f9ee171-0982-4156-9dfd-1aa522729784
udev.log_priority=3
Desktop: GNOME v: 49.3 tk: GTK v: 3.24.51 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro base: Arch Linux
Type: Desktop System: Gigabyte product: H110M-S2H v: N/A
serial:
Mobo: Gigabyte model: H110M-S2H-CF v: x.x serial:
uuid: Firmware: UEFI vendor: American Megatrends v: F22
date: 06/12/2017
System RAM: total: 16 GiB available: 15.51 GiB used: 6.35 GiB (40.9%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2133 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Crucial part-no: CT8G4DFS824A.M8FE
serial:
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
data: 64 total: 64 manufacturer: 0000 part-no: N/A serial: N/A
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF8
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: cache:
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3326 min/max: 800/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 3326 2: 3326 3: 3326 4: 3326 bogomips: 24008
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
disabled
Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled; RSB
filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: Intel Kaby Lake-S GT2 [HD Graphics 630] vendor: Gigabyte
ports: active: DP-1,HDMI-A-1 empty: HDMI-A-2,HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:5912 class-ID: 0300
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: DP-1 model: HP 22f serial: built: 2019 res: 1920x1080
dpi: 102 gamma: 1.2 size: 476x267mm (18.74x10.51") diag: 546mm (21.5")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 model: HP M22f FHD serial: built: 2024
res: 1920x1080 dpi: 102 gamma: 1.2 size: 476x267mm (18.74x10.51")
diag: 546mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:5912 memory: 15.14 GiB unified: yes display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
API: ALSA v: k6.12.68-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac:
IP v4: type: noprefixroute scope: global broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Local Storage: total: 577.55 GiB used: 254.27 GiB (44.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: fw-rev: 71E0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD G5 BICS4
tech: SSD serial: fw-rev: 00WD scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD1 rev: LG00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 102.7 GiB size: 100.52 GiB (97.89%) used: 63.58 GiB (63.2%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 37a9efe6-9c59-460d-8a0e-283b7417385d
used: 328 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 7D49-8055
ID-3: /run/media raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 190.69 GiB (41.7%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: homeMX
uuid: ec731955-4f0e-4a37-985f-aaf5aa11c41f
dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 1f9ee171-0982-4156-9dfd-1aa522729784
Device-1: 1-7:2 info: Logitech Mouse type: mouse driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 1-8:3 info: Logitech Keyboard K120 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 90mA chip-ID: 046d:c31c class-ID: 0300
Hub-2: 1-10:4 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 36.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 270 Power: uptime: 42m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Packages: 1453 pm: pacman pkgs: 1430 libs: 385 tools: gnome-software,pamac
pm: flatpak pkgs: 23 Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: kgx
inxi: 3.3.40
Pero desde hace un tiempo recibo el mensaje de que tengo instalados paquetes más actuales que los paquetes nuevos. Uno de ellos no me preocupa mucho porque se refiere a btrfs y yo he preferido ext4. Pero el otro me preocupa un poco más. Estos son los mensajes que recibo:
:: Sincronizando las bases de datos de los paquetes…
core 146,9 KiB 544 KiB/s 00:00 [#############] 100%
extra 8,5 MiB 14,7 MiB/s 00:01 [#############] 100%
multilib 142,2 KiB 459 KiB/s 00:00 [#############] 100%
:: Iniciando actualización completa del sistema…
advertencia: archlinux-keyring: la versión instalada (20260206-1) es más nueva que core (20260107-2.0)
advertencia: btrfsmaintenance: la versión instalada (1:0.5.2-1) es más nueva que extra (0.5.2-3)
…el sistema ya está actualizado.
Tambien he probado con pamac update --no-aur, con el mismo resultado.
Los archivos que tengo instalados procedentes de AUR son estos, y están en la opción mantener los paquetes construidos, pero sin buscar actualizaciones (pacman -Qm);
Summary
botan2 2.19.5-2
clutter 1.26.4-3
clutter-gtk 1.8.4-4
cogl 1.22.8-3
configuradorfnmt 5.0.3-2
densify 0.3.2-1
gcc14-libs 14.3.1+r25+g42e99e057bd7-1
libgnome-keyring 1:3.12.0+r14+g23438cc-1
xerox-office-prtdrv 5.20.661.4684-1
¿Puedo mantener el paquete archlinux-keyring sin actualizar? ¿Corro algún riesgo si ignoro instalar archlinux-keyring? ¿Cuál sería el procedimiento correcto en este caso? No soy un usuario muy avanzado y estos últimos quince años me he movido en el mundo deb y estoy un poco verde todavía ante estas situaciones.
Tranquilo. el mensaje lo que dice es que la versión de esos paquetes en los repositorios es mas antigua que los que tienes. Esto suele pasar en 2 pasos:
  1. cuando el repositorio al que te conectas esta desactualizado(cosa que no creo que sea el caso)
  2. cuando alguno de los paquetes ha dado algún problema y vuelven a poner una versión anterior(que creo que este es el caso)
Si tu caso es el primero con sudo pacman-mirrors --continent puedes cambiar de servidor de repositorios.
A mi también me dice el mensaje de archlinux-keyring.
Lo que sugieren en estos casos es de que el paquete en cuestión lo han desactualizado y si no te da problemas, no vuelvas a la versión previa que esta en repositorios. Pero si te da problemas entonces ejecuta sudo pacman -Syyuu para descatualizar los que tienes instalados
Yo te recomiendo que a menos que tengas problemas no desactualizes. El mensaje lo puedes ignorar.
Lo del keyring te puesdes olvidar.
El otro paquete (btrfsmaintenance) me parece más curioso, porque no parece que ni Arch lo tenga. No te sabría decir de donde ha salido. ¿AUR?
Parece que bastaba con ejecutar sudo pacman -Suu archlinux-keyring
Y, de paso, se ha «actualizado» el otro paquete. Tengo habilitado AUR, pero no le permito que actualice el repositorio. Así que vete a saber :neutral_face:
Pongo la salida por si fuera de interés:
Summary
sudo pacman -Syuu archlinux-keyring
core está actualizado
extra está actualizado
multilib está actualizado
advertencia: revertiendo el paquete archlinux-keyring a una versión anterior (20260206-1 => 20260107-2.0)
advertencia: btrfsmaintenance: desactualizando de la versión 1:0.5.2-1 a la versión 0.5.2-3
resolviendo dependencias…
buscando conflictos entre paquetes…
Paquetes (2) btrfsmaintenance-0.5.2-3 archlinux-keyring-20260107-2.0
Tamaño total de la descarga: 1,22 MiB
Tamaño total de la instalación: 1,76 MiB
Tamaño neto tras actualizar: 0,01 MiB
:: ¿Continuar con la instalación? [S/n] s
:: Obteniendo los paquetes…
btrfsmaintenance-0.5.2-3-any 19,0 KiB 96,6 KiB/s 00:00 [####################################################] 100%
archlinux-keyring-20260107-2.0-any 1230,1 KiB 4,34 MiB/s 00:00 [####################################################] 100%
Total (2/2) 1249,2 KiB 3,85 MiB/s 00:00 [####################################################] 100%
(2/2) comprobando las claves del depósito [####################################################] 100%
(2/2) verificando la integridad de los paquetes [####################################################] 100%
(2/2) cargando los archivos de los paquetes [###################################################] 100%
(2/2) comprobando conflictos entre archivos [####################################################] 100%
(2/2) comprobando el espacio disponible en el disco [####################################################] 100%
:: Ejecutando los «hooks» de preinstalación…
(1/1) Creating Timeshift snapshot before upgrade…
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
:: Procesando los cambios de los paquetes…
(1/2) desactualizando archlinux-keyring [####################################################] 100%
==> Añadiendo las claves de archlinux.gpg…
==> Actualizando la base de datos de claves de confianza…
gpg: siguiente comprobación de base de datos de confianza el: 2026-03-13
(2/2) desactualizando btrfsmaintenance [####################################################] 100%
:: Ejecutando los «hooks» de posinstalación…
(1/3) Reloading system manager configuration…
(2/3) Restarting marked services…
(3/3) Arming ConditionNeedsUpdate…
Muchas gracias @ddns y @cfinnberg por vuestro interés :slightly_smiling_face:
