No access to german forum manjaro-forum.de and problem with grub customizer
hello,
I had started a thread in the german forum concerning problems with grub: When I try to stat Manjaro, I get “memory tester”. In the “extended” entry I find about 10 or 12 “memory tester” entries and the last entry “manjaro”, which indeed starts the sytem. There seem to be some answers, but I can’t access the forum anymore, instead get
“Forbidden
You don’t have permission to access this resource.Server unable to read htaccess file, denying access to be safe
Apache Server at manjaro-forum.de Port 443”
when I try to login. I can’t even use the Page where I am logged in!
So I ask here, even if my english is not so good:
Is there a hidden? place, where grub can store entries where Grub-customizer can’t find them? Maybe efi-nvram or so? How can I kill this and return to ordinary grub?
here my /etc/default/grub:
# GRUB boot loader configuration
GRUB_DEFAULT="saved"
GRUB_TIMEOUT="5"
GRUB_DISTRIBUTOR="EndeavourOS"
GRUB_CMDLINE_LINUX_DEFAULT="nowatchdog nvme_load=YES nvidia_drm.modeset=1 loglevel=3"
GRUB_CMDLINE_LINUX=""
#GRUB_ENABLE_CRYPTODISK="y"
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE="menu"
GRUB_TERMINAL_INPUT="console"
#GRUB_TERMINAL_OUTPUT="console"
# you can see them in real GRUB with the command `videoinfo'
GRUB_GFXMODE="auto"
GRUB_GFXPAYLOAD_LINUX="keep"
GRUB_DISABLE_LINUX_UUID="true"
GRUB_DISABLE_RECOVERY="true"
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
GRUB_BACKGROUND="/usr/share/endeavouros/splash.png"
GRUB_THEME="/path/to/gfxtheme"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
GRUB_SAVEDEFAULT="true"
# Uncomment to disable submenus in boot menu
GRUB_DISABLE_SUBMENU="false"
# Probing for other operating systems is disabled for security reasons. Read
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
# functionality install os-prober and uncomment to detect and include other
# operating systems.
#GRUB_DISABLE_OS_PROBER="false"
GRUB_EARLY_INITRD_LINUX_STOCK=''
Thanks in advance
That is not an official forum. Can’t acces is too right now (from O2 mobile net). Maybe the server is down (i have set 403 when i updated the machine when i had a forum).
P.s. do NOT use grub customizer! It breaks things.
If you need further help with this, open a new topic.
This forum here has got a german section - as well as many other languages, although there might not be as many responses as in the english section because not as many people here spear/read/write the german language.
Deutsch - Manjaro Linux Forum
manjaro-forum.de
is, as far as I know, not associated with this forum here - which is the “official” forum for anything Manjaro.
It seems to be offline - perhaps permanently.
Perhaps search here for hints and instructions on how to remove the package “grub-customizer”
and then restore the “normal” grub configuration.
It (grub customizer) is known to create problems such as yours.
    ~  inxi -zv8         ✔
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=416f78c8-2146-488e-804e-37379cd5488d rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
  Type: Desktop System: Hewlett-Packard product: HP Z420 Workstation v: N/A
    serial: <superuser required> Chassis: type: 6 serial: <superuser required>
  Mobo: Hewlett-Packard model: 1589 v: 0.00 serial: <superuser required>
    part-nu: LJ449AV uuid: <superuser required> UEFI: Hewlett-Packard
    v: J61 v03.91 date: 10/17/2016
  System RAM: total: 64 GiB available: 62.72 GiB used: 3.33 GiB (5.3%)
  Array-1: capacity: 256 GiB slots: 8 modules: 4 EC: Multi-bit ECC
  Device-1: CPU0-DIMM1 type: DDR3 detail: synchronous registered (buffered)
    size: 16 GiB speed: 1866 MT/s volts: N/A width (bits): data: 64 total: 72
    manufacturer: Micron part-no: 36JSF2G72PZ-1G9E1 serial: <filter>
  Device-2: CPU0-DIMM2 type: no module installed
  Device-3: CPU0-DIMM3 type: DDR3 detail: synchronous registered (buffered)
  Device-4: CPU0-DIMM4 type: no module installed
  Device-5: CPU0-DIMM5 type: no module installed
  Device-6: CPU0-DIMM6 type: DDR3 detail: synchronous registered (buffered)
  Device-7: CPU0-DIMM7 type: no module installed
  Device-8: CPU0-DIMM8 type: DDR3 detail: synchronous registered (buffered)
  Info: model: Intel Xeon E5-2696 v2 bits: 64 type: MCP arch: Ivy Bridge
    level: v2 built: 2012-15 process: Intel 22nm family: 6 model-id: 0x3E (62)
    stepping: 4 microcode: 0x42E
  Topology: cpus: 1x dies: 1 clusters: 12 cores: 12 smt: <unsupported>
    cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 3 MiB desc: 12x256 KiB
    L3: 30 MiB desc: 1x30 MiB
  Speed (MHz): avg: 1200 min/max: 1200/2500 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1200 2: 1200 3: 1200 4: 1200 5: 1200 6: 1200
    7: 1200 8: 1200 9: 1200 10: 1200 11: 1200 12: 1200 bogomips: 59875
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 dca de ds_cpl dtes64 dtherm dts
    epb ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb
    ibrs lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
    pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
    pti pts rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1
    sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme
    vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
    disabled
    STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] driver: nvidia v: 580.82.09
    alternate: nouveau,nvidia_drm non-free: 550-580.xx+ status: current (as of
    2025-08; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
    built: 2018-2022 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s ports: active: none off: DP-1 empty: DVI-D-1,HDMI-A-1
    bus-ID: 05:00.0 chip-ID: 10de:2182 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: nvidia
    gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
    s-diag: 692mm (27.26") monitors: <missing: xrandr>
  Monitor-1: DP-1 model: LG (GoldStar) ULTRAGEAR serial: <filter>
    built: 2021 res: 2560x1440 dpi: 109 gamma: 1.2 chroma: red: x: 0.686
    y: 0.310 green: x: 0.263 y: 0.671 blue: x: 0.149 y: 0.055 white: x: 0.314
    y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 2560x1440, 1920x1080, 1280x720, 1024x768, 800x600, 720x480,
    640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.82.09
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
    memory: 5.86 GiB
  API: Vulkan v: 1.4.321 layers: 2 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1660 Ti driver: nvidia v: 580.82.09 device-ID: 10de:2182
    surfaces: N/A
    wl: wayland-info x11: xdpyinfo,xprop
  Device-1: Intel C600/X79 series High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1d20 class-ID: 0403
  Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.1
    chip-ID: 10de:1aeb class-ID: 0403
  Device-3: DigiTech Lexicon Alpha driver: snd-usb-audio type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1.2:3 chip-ID: 1210:000a
    class-ID: fe01
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
  Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
    driver: e1000e v: kernel port: e040 bus-ID: 00:19.0 chip-ID: 8086:1502
    class-ID: 0200
  Device-1: Actions general adapter driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1.5:6 chip-ID: 10d7:b012
  Report: rfkill ID: hci1 rfk-id: 1 state: up address: see --recommends
  Device-2: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1
    bus-ID: 5-1.6:7 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 20.44 TiB used: 10.85 TiB (53.1%)
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 33.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Intenso model: SATA III SSD
    size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 61.2 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Verbatim model: Vi550 S3
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 916a scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST16000NM001G-2KK103
    size: 14.55 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: SN03 scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 vendor: Toshiba model: HDWE140 size: 3.64 TiB
    block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s tech: HDD
    rpm: 7200 serial: <filter> fw-rev: FP2A scheme: GPT
  Optical-1: /dev/sr0 vendor: hp model: DVD A DH16AESH rev: 3HH6
    dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 77.88 GiB size: 76.11 GiB (97.72%) used: 30.16 GiB (39.6%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 416f78c8-2146-488e-804e-37379cd5488d
  ID-2: /boot/efi raw-size: 650 MiB size: 648.7 MiB (99.80%)
    used: 476 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 9A26-8245
  ID-3: /home raw-size: 68.36 GiB size: 66.74 GiB (97.62%)
    used: 12.79 GiB (19.2%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 0f13b1dc-c0c8-4e99-bd00-df955a92d6ed
  ID-4: /run/media/peterb/ed5d360a-844a-448f-b6ce-7d49c1855e06
    raw-size: 53.35 GiB size: 52.21 GiB (97.87%) used: 10.31 GiB (19.7%)
    fs: ext4 dev: /dev/sda15 maj-min: 8:15 label: N/A
    uuid: ed5d360a-844a-448f-b6ce-7d49c1855e06
  ID-5: /windoze/D raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
    used: 10.66 GiB (6.1%) fs: ntfs dev: /dev/sdd2 maj-min: 8:50
    label: /windoze/D uuid: 48CD062C73B37B0D
  ID-6: /windoze/E raw-size: 14.55 TiB size: 14.43 TiB (99.20%)
    used: 8.09 TiB (56.0%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
    label: /windoze/E uuid: 59e56ca2-5553-46af-a55b-13ac97630229
  ID-7: /windoze/F raw-size: 3.47 TiB size: 3.41 TiB (98.40%)
    used: 2.14 TiB (62.8%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49
    label: /windoze/F uuid: 1e55949a-8f8b-4108-acec-742c58b5aa78
  ID-8: /windoze/data raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
    used: 566.87 GiB (61.9%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
    label: /windoze/data uuid: 9f3c0569-1289-4f4f-9170-d231bfa6e294
  ID-1: /dev/sda10 maj-min: 8:10 size: 58.59 GiB fs: ext4 label: N/A
    uuid: d0237983-0350-4eea-9c41-c2c45fccacdf
  ID-2: /dev/sda11 maj-min: 8:11 size: 39.06 GiB fs: ext4 label: N/A
    uuid: 1148c390-3e26-45b1-b752-24a3245f0bc0
  ID-3: /dev/sda12 maj-min: 8:12 size: 146.48 GiB fs: btrfs label: N/A
    uuid: 0ff33897-2595-47e5-8a9d-70b902911b27
  ID-4: /dev/sda13 maj-min: 8:13 size: 68.36 GiB fs: ext4 label: N/A
    uuid: 80a36f80-4860-423b-aa1c-90606fb388ad
  ID-5: /dev/sda14 maj-min: 8:14 size: 29.3 GiB fs: ext4 label: N/A
    uuid: f66bf974-5b72-4ffe-841d-42090d35f431
  ID-6: /dev/sda4 maj-min: 8:4 size: 48.82 GiB fs: ext4 label: N/A
    uuid: 657931b1-66dd-4f10-a96b-e20b59be248a
  ID-7: /dev/sda5 maj-min: 8:5 size: 112.62 GiB fs: ext4 label: N/A
    uuid: f8561e23-d5ed-48c7-b2e6-c5eaf4947a8f
  ID-8: /dev/sda6 maj-min: 8:6 size: 58.59 GiB fs: ext4 label: N/A
    uuid: 9fe94345-1210-421e-9d72-aa33b96940b6
  ID-9: /dev/sda7 maj-min: 8:7 size: 39.06 GiB fs: ext4 label: N/A
    uuid: e504ce29-daac-46e1-bce6-37d20749896d
  ID-10: /dev/sda8 maj-min: 8:8 size: 55.88 GiB fs: ext4 label: N/A
    uuid: 0baef279-3b76-429a-b68a-d1fe5d414487
  ID-11: /dev/sda9 maj-min: 8:9 size: 37.25 GiB fs: ext4 label: N/A
    uuid: 5d914459-8dd0-4ed4-a56f-03cd0fee0e43
  ID-12: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A
    uuid: 3877-29FD
  ID-13: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-14: /dev/sdb3 maj-min: 8:19 size: 476.12 GiB fs: ntfs label: N/A
    uuid: 5E32785B327839DB
  ID-15: /dev/sdb4 maj-min: 8:20 size: 723 MiB fs: ntfs label: N/A
    uuid: 42787E1A787E0CC3
  ID-16: /dev/sdc2 maj-min: 8:34 size: 4.88 GiB fs: swap label: N/A
    uuid: d4049e4f-a409-48d3-8f56-4a2cb2dd3b31
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Hub-5: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-6: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 4-1.2:3 info: DigiTech Lexicon Alpha type: audio
    driver: snd-usb-audio interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1210:000a class-ID: fe01
  Hub-7: 4-1.3:4 info: Saitek PLC Pro Flight Yoke integrated hub ports: 4
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA
    chip-ID: 06a3:712c class-ID: 0900
  Device-1: 4-1.3.4:6 info: Saitek PLC Pro Flight Yoke type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 06a3:0bac class-ID: 0300
  Device-2: 4-1.4:5 info: Saitek PLC Pro Flight Cessna Rudder Pedals
    type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 40mA
    chip-ID: 06a3:0765 class-ID: 0300 serial: <filter>
  Hub-8: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-9: 5-1:2 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
    chip-ID: 1a40:0201 class-ID: 0900
  Device-1: 5-1.3:4 info: YICHIP Wireless Device type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:3020 class-ID: 0301
  Device-2: 5-1.4:5 info: Alcor Micro AU6477 Card Reader Controller
    type: mass storage,HID driver: hid-generic,usb-storage,usbhid interfaces: 2
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 250mA
    chip-ID: 058f:6364 class-ID: 0300 serial: <filter>
  Device-3: 5-1.5:6 info: Actions general adapter type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 10d7:b012 class-ID: e001 serial: <filter>
  Device-4: 5-1.6:7 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
    mode) type: bluetooth driver: btusb interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a12:0001
    class-ID: e001
  Device-5: 5-3:3 info: Sony USB Bus-powered Device type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 054c:0830 class-ID: 0300
    serial: <filter>
  Hub-10: 6-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 39 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 38%
  Packages: 1541 pm: pacman pkgs: 1528 libs: 383 tools: pamac,yay pm: flatpak
    pkgs: 13
    1: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    2: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    3: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    4: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    5: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    6: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    7: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    8: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 331
  1: cpu: 100% command: ps pid: 19050 mem: 3.98 MiB (0.0%)
  2: cpu: 26.4% command: firefox pid: 18368 mem: 626.5 MiB (0.9%)
  3: cpu: 14.3% command: firefox pid: 18614 mem: 329.4 MiB (0.5%)
  4: cpu: 7.8% command: zsh pid: 18964 mem: 10.5 MiB (0.0%)
  5: cpu: 5.2% command: konsole pid: 18952 mem: 188.0 MiB (0.2%)
  Memory top: 5 of 331
  1: mem: 741.9 MiB (1.1%) command: plasmashell pid: 948 cpu: 1.2%
  2: mem: 626.5 MiB (0.9%) command: firefox pid: 18368 cpu: 26.4%
  3: mem: 329.4 MiB (0.5%) command: firefox pid: 18614 cpu: 14.3%
  4: mem: 297.9 MiB (0.4%) command: firefox pid: 18535 cpu: 3.4%
  5: mem: 268.7 MiB (0.4%) command: firefox pid: 18601 cpu: 2.0%
  Processes: 331 Power: uptime: 44m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.06 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.39
Hello Theo
from your /etc/default/grub
How did this get there?
From this, it seems you don’t even run Manjaro, but EOS instead - which is nearly the same as Arch.
Posting this request on their forums would be more appropriate.
But your inxi output says “Manjaro” …
Installing grub-customizer is still not a good idea, be it on Manjaro or Arch/EOS.
grub-customizer is a package from AUR
You should remove it and restore the “normal” grub configuration.
It is a Very Bad™ idea, actually. It completely ruins Manjaro’s customized grub configuration. That’s why we removed grub-customizer from the repository a number of years ago already.
@bssmusic, remove grub-customizer, clean out your /etc/grub.d, and reinstall grub from the official Manjaro repositories. :backhand_index_pointing_down:
sudo pacman -Rns grub-customizer
sudo rm -f /etc/grub.d/*
sudo pacman -Syu grub install-grub
sudo install-grub && sudo update-grub
Good resource right there… and obviously another reason to completely avoid reading anything in reddit as more than a joke (for every sane nay-sayer, there’s another dozen who come up saying ‘works great for me, never had an issue…’).
the amazon cloud services are disturbed at the moment. it’s a huge impact and affects a lot of services direct and indirect. possible a reason why the server is not avaiable.
Yes - clear instructions.
One good thing about the package is that they apparently have backed up all the original configurations
and put a file with instructions on how to restore them:
And here is how to remove it:
If you do already use grub-customizer and want to remove it follow this from /etc/grub.d/backup/RESTORE_INSTRUCTIONS to revert changes it has done to your system:
Whenever you wish to paste command output in the forum, please prefix all commands with LC_ALL=C to have the output in English.
Example:
LC_ALL=C sudo pacman -Rns grub-customizer
In this instance, your output indicates that grub-customizer is not installed – which is good – as it is neither available or supported in Manjaro.
Note that your previous post has been removed;
Pasted output followed by a series of question-marks is not a valid substitute for actually asking a question.
That’s perhaps because I have more than one system on my workstation:
-Manjaro with 6.12.48-1 (my production system)
-UbuntuStudio ( for music)
-EOS
-windoze11 (for DXO, Photoshop, Lightroom)
-Manjaro unstable (playground)
I have such setups for more than 10 years (since SuSE) and never had problems before UEFI came on the scene…
And that is the reason why I asked for the hidden place where the completely wrong grub config could be stored - I could not find it neither in /etc/grub nore in /etc/default/grub and suspect - as I mentioned before - it hides in the UEFI-BIOS.
Sorry if I was misunderstood
A more manageable solution to multi-booting with several Linux flavours in the mix, is to use the refind boot manager as your initial boot loader, which in turn will effectively chainload every UEFI boot loader GRUB in your system, including that of Windows or BSD.
This allows one to leave each GRUB untouched and managed by it’s respective OS – this means less maintenance (no juggling settings just to enable a successful boot) – plus, the added convenience of being able to bypass any installed GRUB and boot the respective kernel stub directly.
and when I try to start Manjaro:
and now?
( I write this from my Ubuntu, because this grub-install broke manjaro completely)
VERY BAD IDEA?
@soundofthunder
“A more manageable solution to multi-booting with several Linux flavours in the mix, is to use the refind boot manager as your initial boot loader, which in turn will effectively chainload every UEFI boot loader GRUB in your system, including that of Windows or BSD.
This allows one to leave each GRUB untouched and managed by it’s respective OS – this means less maintenance (no juggling settings just to enable a successful boot) – plus, the added convenience of being able to bypass any installed GRUB and boot the respective kernel stub directly.”
Ah, that seems to be a reasonable solution, but
  1. where do I find it - edit : OK, Rod Smith
  2. first install the “refind boot manager” and then grub, or reverse?
  3. how to get rid of the sense- and useless configuration I have on my startscreen
It
efi: EFI v2.3.1 by American Megatrends
[    0.000000] efi: ACPI 2.0=0xcb095000 SMBIOS=0xcb7d6b98 ACPI=0xcb095000 INITRD=0xc4110b18
[    0.000000] efi: Remove mem127: MMIO range=[0xf0000000-0xf7ffffff] (128MB) from e820 map
[    0.000000] efi: Not removing mem128: MMIO range=[0xfed1c000-0xfed1ffff] (16KB) from e820 map
[    0.000000] efi: Not removing mem129: MMIO range=[0xfed20000-0xfed3ffff] (128KB) from e820 map
[    0.000000] efi: Remove mem130: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
[    0.009411] ACPI: UEFI 0x00000000CB172968 000042 (v01 HPQOEM SLIC-WKS 01072009      00000000)
[    0.009435] ACPI: Reserving UEFI table memory at [mem 0xcb172968-0xcb1729a9]
[    0.143688] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.752239] efivars: Registered efivars operations
[    1.095731] integrity: Loading X.509 certificate: UEFI:db
[    1.095769] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[    1.095772] integrity: Loading X.509 certificate: UEFI:db
[    1.095797] integrity: Loading X.509 certificate: UEFI:db
[    1.095817] integrity: Loaded X.509 cert 'Hewlett-Packard UEFI Secure Boot DB Key: e7203ac28b848d3c03432f6a485dd1f4c7b8e529'
[    1.095818] integrity: Loading X.509 certificate: UEFI:db
[    1.095838] integrity: Loaded X.509 cert 'Microsoft UEFI CA 2023: 81aa6b3244c935bce0d6628af39827421e32497d'
[    1.095840] integrity: Loading X.509 certificate: UEFI:db
[    1.095864] integrity: Loaded X.509 cert 'Microsoft Option ROM UEFI CA 2023: 514fbf937fa46fb57bf07af8bed84b3b864b1711'
[    1.599749] isci 0000:02:00.0: Unable to obtain EFI var data for OEM parms
[    1.888861] tsc: Refined TSC clocksource calibration: 2493.989 MHz
[    3.796453] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    3.797866] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[    3.820671] pstore: Registered efi_pstore as persistent store backend
[    3.821441] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    3.821675] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
it seems that my both Manjaros have screwed up each other. I’m afraid there is a lot of work waiting for me :wink:
Well with default settings, they will write the boot files and efi variable with the same name, so yeah, this is to be expected.
When you restore grub, do not forget to name one of them something different than manjaro.
This and many more pains can be saved using refind in such complex multiboot scenarios.
Thanks for asking. I mention refind briefly toward the end of a multi-boot tutorial I authored;
refind is available from the official Manjaro repositories, and installation can be as simple as:
1. Install the refind package so that it’s available to your system:
sudo pacman -S refind
2. Use refind’s own internal command to install it:
refind-install
  • The default install location is $ESP/EFI/refind.
    3. Reboot and immediately boot to BIOS to ensure that refind is first in boot order – this typically happens automatically, but it’s better to check.
Preferred:
  • Ideally, each GRUB would already allow booting to each OS (so that refind will find and detect them)
  • Install and update refind only from Manjaro; ensuring that it installs to Manjaro’s $ESP for consistent management.
Workaround for your current state:
Boot a Manjaro Installer USB and enter a chroot environment - install refind from there. This may not be ideal, as GRUB still won’t be working, but you can still bypass GRUB and boot to Manjaro via the kernel stub, from refind.
From that point, you can fix GRUB at your leisure.
There should be two Manjaro icons (possibly only one if GRUB isn’t working) when you reach the refind menu. Beneath the icon(s) will be an indication of which is which.
Configuration is in a single file within the $ESP/EFI/refind directory - it’s well documented - and shouldn’t take you long to configure it to your preference; though it already installs with what I like to call “sane defaults”; most only play with the theming.
As they are separate entities, the important factor is to make sure refind is first to boot.
The “memtest” entries, I’ll leave for others to address. Regarding how the GRUB menu displays; that can be configured in /etc/default/grub.
I hope this information is useful.
The memtests are probably ignorable. You have several linuxes, and each has 1 or 2 copies of it. So if all are detected, here are your 6 entries.
There were 2 methods to attack this: the duplication inside 1 os was solved uninstalling some package, and then there was some config to disable the detection from other oses. Maybe some sub setting in os prober. I have forgotten already, at the end i didn’t bother solving it (i have 1 manjaro so i had it 2 times).
Leave it be for now.
Musing:
After refind is working as expected, os-prober can probably be disabled completely, as there would be no more need to boot other boot loaders from GRUB – those extraneous entries should no longer be an issue.
Not so fast, and a little more humility, please. You may not have been here that long, but I still remember well the time when this forum was completely wrecked due to a lack of certification (and not just for a few hours). Who gave us shelter? Yes, the girls and boys there! I haven’t been there for a while, and it would be a real shame if this is more than a temporary glitch.
