Night Color feature is set to turn on/off at custom times. Recently, it will pass the cutoff time to disengage, but stays on until manually set to off.
I’m seeing these entries in the log:
Apr 28 09:00:00 local-user kwin_x11[3710]: kwin_nightcolor: Error in time calculation. Deactivating Night Color.
May 01 09:00:00 local-user kwin_x11[3775]: kwin_nightcolor: Error in time calculation. Deactivating Night Color.
May 16 09:00:00 local-user kwin_x11[3749]: kwin_nightcolor: Error in time calculation. Deactivating Night Color.
System Info:
Kernel: 5.15.109-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1 Desktop: KDE Plasma
v: 5.27.4 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-I GAMING v: Rev X.0x
serial: UEFI: American Megatrends v: 4005 date: 07/13/2021
Info: 8-core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ rev: 0 cache:
L1: 512 KiB L2: 4 MiB L3: 32 MiB
Speed (MHz): avg: 3990 high: 4655 min/max: 2200/4850 boost: enabled cores: 1: 3385 2: 3432
3: 4164 4: 4001 5: 4277 6: 4655 7: 4637 8: 3415 9: 4508 10: 3417 11: 3318 12: 3991 13: 4381
14: 4140 15: 3852 16: 4280 bogomips: 121417
Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: Gigabyte driver: nvidia v: 530.41.03
arch: Turing bus-ID: 0a:00.0
Device-2: Logitech HD Webcam C510 driver: snd-usb-audio,uvcvideo type: USB bus-ID: 3-1:2
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: nvidia gpu: nvidia resolution:
1: 2560x1440 2: 2560x1440 3: 2560x1440
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
direct-render: Yes
Device-1: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 0a:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0c:00.4
Device-3: Logitech HD Webcam C510 driver: snd-usb-audio,uvcvideo type: USB bus-ID: 3-1:2
Device-4: Kingston HyperX Cloud Alpha S driver: hid-generic,snd-usb-audio,usbhid type: USB
bus-ID: 3-2:3
API: ALSA v: k5.15.109-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.70 status: active
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 05:00.0
IF: wlp5s0 state: down mac:
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel port: f000
bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac:
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB bus-ID: 3-6:5
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: see --recommends
Device-1: md127 type: mdraid level: mirror status: active size: 1.82 TiB
Info: report: 2/2 UU blocks: 1953381376 chunk-size: N/A
Components: Online: 0: sda1 1: sdb1
Local Storage: total: raw: 9.21 TiB usable: 7.39 TiB used: 735.83 GiB (9.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB temp: 41.9 C
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB temp: 32.9 C
ID-3: /dev/sda vendor: Crucial model: CT2000MX500SSD1 size: 1.82 TiB
ID-4: /dev/sdb vendor: Crucial model: CT2000MX500SSD1 size: 1.82 TiB
ID-5: /dev/sdc vendor: PNY model: CS900 120GB SSD size: 111.79 GiB
ID-6: /dev/sdd vendor: Western Digital model: WD40EZRX-00SPEB0 size: 3.64 TiB type: USB
ID-1: / size: 915.53 GiB used: 735.83 GiB (80.4%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 111.79 GiB used: 0 KiB (0.0%) dev: /dev/sdc1
System Temperatures: cpu: 51.9 C mobo: N/A
Processes: 403 Uptime: 7h 15m Memory: available: 62.71 GiB used: 9.25 GiB (14.7%) Init: systemd
Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1767 Client: KDE Plasma v: 5.27.4 inxi: 3.3.27
