abc123
25 December 2024 11:13
1
Hi,
Ubuntu based distros don’t do it for me anymore.
Tried some new distros I never used before in VirtualBox.
I ended up clean installing “Manjaro” KDE Plasma.
Very solid OS, never used Arch Linux before and this was my chance.
I have an nVidia GeForce RTX 3060 12GB.
The proprietary display driver is running version: 550.135.
But OpenGL reports version: 1.4?
Is something wrong? I was expecting a higher version of OpenGL.
Let me know.
abc123
cscs
25 December 2024 11:36
2
Hi and welcome,
System info would be a good start;
inxi -Farz
Also see this guide for how to format code, etc ..
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links whene…
abc123
25 December 2024 11:55
3
cscs:
inxi -Farz
OpenGL looks ok.
Does everything look ok?
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=e6904fb9-88c7-445f-92eb-bd71124dfe33 rw quiet
cryptdevice=UUID=ea95b186-2441-4a26-bc26-1445436021f6:luks-ea95b186-2441-4a26-bc26-1445436021f6
root=/dev/mapper/luks-ea95b186-2441-4a26-bc26-1445436021f6 splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
UEFI: American Megatrends v: 5003 date: 10/07/2023
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3593 min/max: 550/4851 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3593 2: 3593 3: 3593
4: 3593 5: 3593 6: 3593 7: 3593 8: 3593 9: 3593 10: 3593 11: 3593 12: 3593
13: 3593 14: 3593 15: 3593 16: 3593 bogomips: 121414
affected
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 550.135
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 0a:00.0 chip-ID: 10de:2504
class-ID: 0300
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 161 s-size: 303x170mm (11.93x6.69")
s-diag: 347mm (13.68")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 81
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: gbm,wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.135
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.4.303 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: N/A device-ID: 10de:2504
surfaces: xcb,xlib
Device-1: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 0a:00.1 chip-ID: 10de:228e class-ID: 0403
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:4
chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 12.73 TiB used: 103 GiB (0.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 36.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST12000VN0008-2YS101
size: 10.91 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 103 GiB (5.6%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ea95b186-2441-4a26-bc26-1445436021f6
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 42.8 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Packages: 1396 pm: pacman pkgs: 1380 libs: 453 tools: pamac pm: rpm pkgs: 0
pm: flatpak pkgs: 16
1: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
3: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
Memory: total: 64 GiB note: est. available: 62.71 GiB used: 5.69 GiB (9.1%)
Processes: 410 Power: uptime: 2h 32m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.05 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.36
You have no swap space defined. If you wish to hibernate, you won’t be able to as it stands. It is usually recommended to configure swap even if its rarely used.
Nothing else to add.
Ben
25 December 2024 13:53
5
soundofthunder:
Maybe a swapfile
Instructions already in this forum - just a quick search…
abc123
25 December 2024 14:07
6
Hi,
Thanks.
I have 64GB RAM.
On previous distro installs I did have a swap.
The swap would kick in when I was only using 15% of RAM.
I gave it up, no problems.
abc123
NOTE - I’ve gone through many distros - Manjaro has the easiest nvidia driver install out of all of them.
ben75
25 December 2024 14:14
7
Your inxi results show OpenGL 4.6, GLX 1.4, and EGL 1.5, all of which are the latest versions.
ydar
25 December 2024 14:15
8
The default swappiness most distro’s use is 60. I too have a lot of RAM so I changed it to 0. Swap is pretty much never touched on my system.
As for the opengl question, if you’re referring to the glx 1.4, that is correct even if your opengl is a higher version. This is mine:
glxinfo | egrep 'OpenGL|glx' ✔
egrep: warning: egrep is obsolescent; using grep -E
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: NVIDIA GeForce RTX 4070 Ti SUPER/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 565.77
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6.0 NVIDIA 565.77
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 565.77
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
Ben:
Maybe a swapfile
swap space infers a provision for swap; which could be either a swap partition or a swap file ; depending on the need. Here’s the wink.
cscs
25 December 2024 21:16
10
This does look off.
Have you done anything to install/configure components for nvidia?
I might wonder what glxinfo produces.
glxinfo | grep -E 'Device|renderer string'
system
Closed
28 December 2024 21:17
11
