NFS4: Couldn't follow remote path
The Server (i.e. the remote path) is ARM, so I hope I have put this post in the right place.
Simple NFS connection as follows:-
Server (Rapberry Pi4 - Manjaro i3 - Latest)
In /etc/exports I have:
/srv/nfs/www 192.168.0.105(rw,sync,no_subtree_check,all_squash)
I then run
$ sudo exportfs -arv
[sudo] password for david:
exporting 192.168.0.105:/srv/nfs/www
Client (ix86 Manjaro i3 - Latest)
The client is 192.168.1.105 and the Systemd Unit File data-nfs-www.mount is:-
[Unit]
Description=NFS www on Webserver
After=network.target
Wants=network.target
[Mount]
What=192.168.1.79:/srv/nfs/www
Where=/data/nfs/www
Options=auto
Type=nfs
TimeoutSec=10
[Install]
WantedBy=remote-fs.target
I then run
sudo systemctl stop data-nfs-www.mount
sudo systemctl disable data-nfs-www.mount
sudo systemctl daemon-reload
sudo systemctl enable data-nfs-www.mount
That all goes fine and then I run :-
$ sudo systemctl start data-nfs-www.mount
Job failed. See "journalctl -xe" for details.
journalctl -xe contains the following :-
Oct 03 03:16:07 david-j-white systemd[1]: Mounting NFS www on Webserver...
░░ Subject: A start job for unit data-nfs-www.mount has begun execution
░░ Defined-By: systemd
░░ A start job for unit data-nfs-www.mount has begun execution.
░░ The job identifier is 4326.
Oct 03 03:16:07 david-j-white kernel: NFS4: Couldn't follow remote path
Oct 03 03:16:08 david-j-white kernel: NFS4: Couldn't follow remote path
Oct 03 03:16:11 david-j-white kernel: NFS4: Couldn't follow remote path
Oct 03 03:16:15 david-j-white kernel: NFS4: Couldn't follow remote path
Oct 03 03:16:15 david-j-white wpa_supplicant[1051]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-74 noise=9999 txrate=108000
Oct 03 03:16:18 david-j-white systemd[1]: data-nfs-www.mount: Mounting timed out. Terminating.
Oct 03 03:16:18 david-j-white systemd[1]: data-nfs-www.mount: Mount process exited, code=killed, status=15/TERM
░░ Subject: Unit process exited
░░ An n/a= process belonging to unit data-nfs-www.mount has exited.
░░ The process' exit code is 'killed' and its exit status is 15.
Oct 03 03:16:18 david-j-white systemd[1]: data-nfs-www.mount: Failed with result 'timeout'.
░░ Subject: Unit failed
░░ The unit data-nfs-www.mount has entered the 'failed' state with result 'timeout'.
Oct 03 03:16:18 david-j-white systemd[1]: data-nfs-www.mount: Unit process 38135 (mount.nfs) remains running after unit stopped.
Oct 03 03:16:18 david-j-white systemd[1]: Failed to mount NFS maindb www Mount.
I have searched the Manjaro Forums for NFS but there’s not a lot about NFS.
Internet search brings up very little if I search for NFS4: Couldn't follow remote path.
All directories referred to exist, I’ve checked. :slight_smile:
So I’m now a bit stuck.
@djaywhite, many months ago I faced perhaps a similar problem when attempting to get a pi3b+ running Ubuntu server, to connect to my MX Linux box via NFS.
I found that the problem was due to Raspberry (which I also tested) & Ubuntu Server both running NFS3 & MX running NFS4.
Anyway, for better or worse here is a link to my thread in the MX forum, where I documented my solution (after a lot of research & trial & error):
https://forum.mxlinux.org/viewtopic.php?f=104&t=54210&p=541776#p541776
I hope it helps you out. :wink:
@handy Thanks for the quick reply, I’ll go and check out your link henceforth. :slight_smile:
If needs be you can enable /etc/rc.local in systemd (simplest method imho):
This is a compressive guide.
Arch NFS Wiki
Thanks @Darksky and @handy.
A quick look at the wiki has already told me I need to run nfs-server on the server via systemd (mine is currently inactive).
So I will go away and RTFM. :slight_smile:
It has been years since I messed wit NFS and I saw a lot of things in that wiki from using different versions of NFS and even some distro’s has to use differ mount commands eg. mount -t nfs or mount -t nfs4. Also it mentioned using a machine name instead of an ip address in places. The wiki seemed to try to cover all scenarios.
It could be one of several things - check one thing at a time - then you know where the issue is buried.
  • a missing bind mount in the server’s fstab
  • or the missing export of the server’s root
    /srv/nfs            192.168.0.105(rw,sync,crossmnt,fsid=0)
And if I recall correct there is also something with using the IP in the mount unit - I think it has to be hostname.
It could be network related - disable the mount unit and add an .automount unit - then enable and start the automount unit - then navigate to the /data/nfs/www folder and watch if it populates.
/etc/systemd/system/data-nfs-www.automount
[Unit]
Description=Automount nas www
ConditionPathExists=/data/nfs/www
[Automount]
Where=/data/nfs/www
TimeoutIdleSec=10
[Install]
WantedBy=multi-user.target
