I am trying to find the best way to setup a nextcloud server with a rpi, I found this tutorial for debian based systems:
https://pimylifeup.com/raspberry-pi-nextcloud-server/
Is there a similar tutorial for manjaro?
Thanks in advance.
Thanks in advance.
Any tutorial using Docker or snaps will work. That’s how I have mine set up.
Only one difference is that you use pacman
or pamac
instead apt
and several packages may have other names (or are connected or splitted). If you need help you can look into Arch Wiki:
Thank you both for the info, I will dig deeper about it.
