Nextcloud Tray Icon Missing
Hi, I have reinstalled Manjaro the first time since about 5 years ago three weeks ago. It was time to renew. I haven copied all the old stuff from configs etc. to the new installation, so that everything is “brand new”.
Unfortunately, the nextcloud-sync-client (v3.9.4git) app wont show up in the tray menu anymore. I have tried to add it to the startup applications, tried a workaround so it starts some time later after the initial startup, but no luck. Do I probably need some extension (as I am quite short on extensions)?
Any help is appreciated :slight_smile:
You might need the ‘Appindicator and KStatusNotifierItem Support’ to get the icon to display. This extension is in the repo.
