Hi all,
I just installed Nextcloud using the guide Nextcloud setup on archlinux. I ran in an error, translated with deepl:
Internal server error The server could not complete the request.
Further details can be found in the server log.
The server log includes the following:
[ManjaroServer share]# tail /var/log/nextcloud/nextcloud.log
{"...method":"","url":"--","message":{"Exception":"Error","Message":"file_put_contents(/usr/share/webapps/nextcloud/.htaccess):
Failed to open stream: Permission denied at **/usr/share/webapps/nextcloud/lib/private/Setup.php**#565","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"}, ...
The rights of the mentioned file are:
ls -al /usr/share/webapps/nextcloud/lib/private/Setup.php
-rw-r--r-- 1 root root 19480 24. Feb 00:04 /usr/share/webapps/nextcloud/lib/private/Setup.php
Should I chown this to the webserver? Or nextcloud-user? Which group? Only rigths?
Regards CJC
