Looking to implement Nextcloud Desktop Client to keep a handful of files synced between my laptop and my NextCLoud instance.
On the Nextcloud site - they only offer an AppImage of the client.
However - I was able to install Nextcloud via the repo (using add/remove software).
Is the Repo using the same and current version as the Appimage?
Any pro/con to either choice?
Current repo version is 3.6.6, current flatpak is 3.7.1.
On the website, the version seems to be 3.7.1 for linux, so I guess the repo is a bit slow.
For me that is fine, the desktop client works fine and I am pretty sure that the 3.7 version will be in the repo pretty soon.
As the desktop client is working, I always stick to repo software. Flatpak just clutters my system with huge runtimes.
It’s already in the unstable branch: Packages
As I thought. Thanks for the heads up
Thanks for that!!! Will stay with the Repo.
system
Closed
6
