Hi, everyone,
nextcloud-client broke with the 2022-01-24 testing update:
zsh: segmentation fault (core dumped) nextcloud
Apparently, it has something to do with libQt5Core:
[ 105.768843] nextcloud[1263]: segfault at 8 ip 00007feee95a1814 sp 00007ffddb72df08 error 4 in libQt5Core.so.5.15.2[7feee938d000+2c9000]
[ 105.768885] audit: type=1701 audit(1643050572.144:85): auid=1000 uid=1000 gid=1000 ses=1 pid=1263 comm="nextcloud" exe="/usr/bin/nextcloud" sig=11 res=1
Here's my system info for reference:
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d362e7cd-46c1-453d-ae76-8ec6ef81bc76 rw quiet
udev.log_priority=3 "acpi_osi=Windows 2020" acpi_backlight=vendor
Desktop: sway 1.6.1 info: swaybar dm: N/A Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: HP product: HP ProBook 430 G5 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 8377 v: KBC Version 02.41.00 serial: <filter> UEFI: HP
v: Q85 Ver. 01.18.00 date: 11/26/2021
ID-1: BAT0 charge: 27.1 Wh (100.0%) condition: 27.1/48.0 Wh (56.5%)
volts: 11.9 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Full cycles: 372
Info: model: Intel Core i5-8250U socket: BGA1356 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake family: 6 model-id: 0x8E (142)
stepping: 0xA (10) microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1205 high: 2565 min/max: 400/3400 base/boost: 1600/3400
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 800 2: 574 3: 800 4: 2565 5: 2033 6: 800
7: 800 8: 1268 bogomips: 28808
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Lite-On HP HD Camera type: USB driver: uvcvideo bus-ID: 1-6:2
chip-ID: 04ca:706e class-ID: 0e02 serial: <filter>
Display: server: N/A compositor: sway v: 1.6.1 driver: loaded: intel
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: no
Sound Server-3: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
bus-ID: 1-7:3 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 372.55 GiB used: 16.41 GiB (4.4%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: SL16G
size: 14.84 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> scheme: MBR
SMART Message: Unknown smartctl error. Unable to generate data.
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKW256G8
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 005C temp: 29.9 C scheme: GPT
SMART: yes health: PASSED on: 59d 4h cycles: 1,913
read-units: 1,698,841 [869 GB] written-units: 1,898,221 [971 GB]
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD6SB1M-128G-1006
size: 119.24 GiB block-size: physical: 512 B logical: 512 B sata: 3.1
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 706 temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 2d 11h cycles: 4027
ID-1: / raw-size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 16.33 GiB (7.0%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 77.8 MiB (26.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
System Temperatures: cpu: 39.0 C pch: 35.5 C mobo: 0.0 C
Processes: 219 Uptime: 1h 33m wakeups: 1 Memory: 14.94 GiB
used: 2.57 GiB (17.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 981 lib: 191 Shell: Zsh (doas) v: 5.8
default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.12
