New to arch distro - I’m a pretty basic user switching from Pop_OS since that distro became unusable with my system and letting it manage itself.
i’m trying to install the packages from input remapper (GitHub - sezanzeb/input-remapper: 🎮 An easy to use tool to change the mapping of your input device buttons. )
They are using the “pacaur” package manager and I have attempted to install pacaur and have gotten no success. I generally get stuck at “makepkg” not being an available command.
Any help how to proceed? I’m utilizing minimal install plasma
NGr
October 17, 2022, 3:27pm
#2
Have you installed base-devel
Nope! pacman -s base-devel
should have me set? (or rather a step in the right direction)
NGr
October 17, 2022, 3:33pm
#4
Yes, and press enter to select all when prompted.
kisun
#5
Hello @GreasedWalnut
you can also install AUR packages through pamac
pamac build input-remapper-git
should do the job.
Did the trick! Just so I can understand what is the difference between say pacaur
and pamac
? Just two different scripts wheras pamac is the baseline?
kisun
October 17, 2022, 4:17pm
#7
Pamac is manjaros package manager and pacman is the arch packagemanager which also work under manjaro.
system
Closed
October 20, 2022, 6:18am
#9
