Newbie having trouble installing ExpressVPN as per site's instruction
Newbie having trouble installing expressvpn as per site’s instruction for Arch Linux 64bit install.
Open a terminal:
pamac build expressvpn
That will install the expressvpn package from the AUR and worked for me in the past when I had a expressvpn subscription. From there just follow the instructions from the expressvpn site.
The Problem is the correct key is not being imported run:
Blockquote
wgethttps://www.expressvpn.com/expressvpn_release_public_key_0xAFF2A1415F6A3A38.asc
(the forum wont let me place a URL even if it is needed for the command so had to get creative after the first word in the command “weget” just add a space)
Blockquote
gpg --import expressvpn_release_public_key_0xAFF2A1415F6A3A38.asc
respectively to get the correct keys
found the problem on the AUR page of ExpressVPN.
