Hi, i recently started using linux on my new pc! i just built it today.
im having some troubles setting some things up, especially the drives.
At the moment I have one nvme drive and an ssd. i installed manjaro on my ssd and let the nvme formated, (not to ext4, i realized after, i solved that with gparted and kde partition manager.
But im having troubles with steam recognizing the nvme at all, and i have no idea where it is located on my machine, it is mounted and i see it on my file explorer but its in the media folder apparently?
Im very lost, and after a full day configuring things i could use some pointers if anyone is kind enough to help me.
also i heard you have to set up other disks to mount automatically at boot, but i havent found a good clear guide on this.
Thank you guys <3
cscs
13 June 2024 00:12
2
Hi and welcome to manjaro.
To start we might get a general inxi output
inxi -Farz
Particularly for block devices you might use
lsblk
Also here is a guide with hints like how to format code, etc.
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links whene…
lsblk outputs the following:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 223,6G 0 disk
├─sda1 8:1 0 300M 0 part /boot/efi
├─sda2 8:2 0 206,2G 0 part /
└─sda3 8:3 0 17,1G 0 part [SWAP]
nvme0n1 259:0 0 238,5G 0 disk
└─nvme0n1p1 259:1 0 238,5G 0 part
inxi -Farz (i dont know if this is too much of a dump)
outputs:
Kernel: 6.9.3-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=3ea607af-c6ff-4560-bbea-bcf4521acc28 rw quiet splash
resume=UUID=7782ae88-2c9c-4b23-bf4b-de3628770725 udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH MAX (MS-7A38) v: 8.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: B.D3 date: 09/27/2021
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3150 high: 4124 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2926 2: 3626
3: 2035 4: 3863 5: 2055 6: 4084 7: 2635 8: 4098 9: 2199 10: 4114 11: 2050
12: 4124 bogomips: 86435
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: ASUSTeK driver: nvidia
v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DVI-D-1 bus-ID: 29:00.0 chip-ID: 10de:2184 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71")
s-diag: 554mm (21.82")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.90.07
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1660/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1660 driver: nvidia v: 550.90.07
device-ID: 10de:2184 surfaces: xcb,xlib
Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
bus-ID: 29:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2b:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.9.3-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR9287 Wireless Network Adapter driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 27:00.0
chip-ID: 168c:002e class-ID: 0280
IF: wlp39s0 state: down mac: <filter>
Local Storage: total: 462.05 GiB used: 30.29 GiB (6.6%)
model: MZVPV256HDGL-00000 size: 238.47 GiB block-size: physical: 512 B
fw-rev: BXW7300Q temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: BBF0 scheme: GPT
ID-1: / raw-size: 206.17 GiB size: 201.88 GiB (97.92%)
used: 30.29 GiB (15.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 17.1 GiB used: 256 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 54.8 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 29%
Packages: pm: pacman pkgs: 1107 libs: 317 tools: pamac
1: https://manjaro.kurdy.org/stable/$repo/$arch
2: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
3: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
Memory: total: 16 GiB available: 15.55 GiB used: 3.81 GiB (24.5%)
Processes: 328 Power: uptime: 19m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.26
running-in: konsole inxi: 3.3.34
again, the drive shows up normally, i have formatted it as a big ext4 partition. steam does not recognize it and im not sure where it “lives” in my system?? or how to access it.
Thank you for the quick reply!
cscs
13 June 2024 00:36
4
Right now it does not appear to be mounted anywhere.
And I would guess we are talking about this device?
Again its not currently mounted to anything.
But the normal default would probably be /run/media/$USER/$PART-LABEL
Once it is mounted (such as by clicking it in your file manager) it will appear at its mountpoint, likely the one above.
If you want it to be automatically mounted all the time I would suggest adding it to /etc/fstab or using systemd to do it for you.
The archwiki fstab page will have most all information needed for that:
For systemd mounts there is a guide here on the forum:
Difficulty: ★☆☆☆☆
Disk device recognition
Manjaro uses udev (see Arch Wiki ) to load devices at boot time. The loading of devices is arbitrary and therefore you cannot predict which device will be available at a given path.
But static device names do exist and you can assign specific locations to your device and thus ensure e.g. scripts will work as expected.
What to learn
Overview of system mount units
Structure and Content of a mount unit
Mount at boot (immediate mount)
Mount on demand (m…
