I used manjaro-arm-flasher before in two instances, which proves on orangepi-800 it broke my system after flashing to 64 gb sd card formatted in NTFS (New File Transfer System) of that image kernel so manjaro-arm-flasher would recognize it, poweroff and reboot does not function with powerbutton had to manually type ```poweroff```` in terminal Konsole and when i start the newly installled sd card the screen flickers and does not load manjaro logo.
I chose Unstable over Stable because i can use sudo pacman -Syu
to update my system easier than add or remove software which is pamac, i also use it because it once before did not break for several months, and did not show flags like stable release.
202401 release does not break note got it working
Just to mentionâŚ
What branch you use has nothing to do with whether you use pacman
or pamac
You can choose to use pacman
, and even remove pamac
entirely, on any branch.
If you mean the âKnown issues and solutionsâ wiki post that exists on the Stable Update Announcement threads ⌠Iâve got news for you. They dont exist on Unstable
simply because we dont need them. It does not mean package changes requiring manual interaction, or any other issues, as described elsewhere just does not happen. Its usually what we discuss amongst ourselves that ends up in that wiki post for the other branch users.
Unless you are creating the image for another person - it is better to use the git version of manjaro-arm-installer as this give you the option of specifying unstable branch and preconfigure the image card with username etc.
git clone https://gitlab.manjaro.org/manjaro-arm/applications/manjaro-arm-installer
cd manjaro-arm-installer
sudo bash manjaro-arm-installer arm-unstable
Do you think pamac causes errors in the system, and thatâs what your insinuating, that it was to just use pacman?
so your saying that pre-installed manjaro arm flasher can cause faultiness?
and even if you have pre-installed manjaro arm flasher one might need to reinstall it ontop of the current one?
[sudo] password for sfrocker:
Pacman-mirrors version 4.24.0
Local mirror status for arm-unstable branch
Mirror #1 OK 00:16 United_States https://nocix.mm.fcix.net/manjaro/
Mirror #2 OK 00:15 United_States https://mnvoip.mm.fcix.net/manjaro/
Mirror #3 OK 00:15 United_States https://irltoolkit.mm.fcix.net/manjaro/
Mirror #4 OK 00:15 United_States https://forksystems.mm.fcix.net/manjaro/
Mirror #5 OK 00:16 United_States https://volico.mm.fcix.net/manjaro/
Mirror #6 OK 00:16 United_States https://ohioix.mm.fcix.net/manjaro/
Mirror #7 OK 00:15 United_States https://ridgewireless.mm.fcix.net/manjaro/
Mirror #8 OK 00:15 United_States https://coresite.mm.fcix.net/manjaro/
Mirror #9 OK 01:15 United_States https://mirrors.ocf.berkeley.edu/manjaro/
Mirror #10 OK 00:15 United_States https://codingflyboy.mm.fcix.net/manjaro/
Mirror #11 OK 00:16 United_States https://southfront.mm.fcix.net/manjaro/
Mirror #12 OK 00:15 United_States https://repo.ialab.dsu.edu/manjaro/
Mirror #13 OK 00:15 United_States https://opencolo.mm.fcix.net/manjaro/
Mirror #14 OK 00:15 United_States https://mirror.math.princeton.edu/pub/manjaro/
Mirror #15 OK 00:15 United_States https://uvermont.mm.fcix.net/manjaro/
Mirror #16 OK 00:15 United_States https://nnenix.mm.fcix.net/manjaro/
Mirror #17 OK 02:12 Canada https://muug.ca/mirror/manjaro/
Mirror #18 OK 00:53 Germany https://manjaro.kurdy.org/
Mirror #19 OK 00:13 Colombia https://edgeuno-bog2.mm.fcix.net/manjaro/
Mirror #20 OK 01:03 France https://mirror.ibakerserver.pt/manjaro/
Mirror #21 OK 00:33 France https://manjaro.ynh.ovh/
Mirror #22 OK 00:24 Netherlands https://manjaro.mirrors.lavatech.top/
Mirror #23 OK 00:16 United_States https://ask4.mm.fcix.net/manjaro/
Mirror #24 OK 00:22 Belgium https://mirror.futureweb.be/manjaro/
Mirror #25 OK 00:37 Switzerland https://mirror.init7.net/manjaro/
Mirror #26 OK 01:23 Costa_Rica https://mirrors.ucr.ac.cr/manjaro/
Mirror #27 OK 00:13 Germany https://mirror.alpix.eu/manjaro/
Mirror #28 OK 00:04 Austria https://mirror.easyname.at/manjaro/
Mirror #29 OK 00:13 Finland https://manjaro.kyberorg.fi/
Mirror #30 OK 00:03 Global https://mirrors2.manjaro.org/
Mirror #31 OK 00:43 Germany https://ftp.gwdg.de/pub/linux/manjaro/
Mirror #32 OK 00:15 Sweden https://ftp.lysator.liu.se/pub/manjaro/
Mirror #33 OK 00:52 Bulgaria https://manjaro.ipacct.com/manjaro/
Mirror #34 OK 00:05 Taiwan https://mirror.archlinux.tw/Manjaro/
Mirror #35 OK 00:23 Hungary https://quantum-mirror.hu/mirrors/pub/manjaro/
Mirror #36 OK 00:45 South_Korea https://mirror.funami.tech/manjaro/
Mirror #37 OK 00:52 Chile https://mirror.ufro.cl/manjaro/
Mirror #38 OK 00:06 New_Zealand https://mirror.2degrees.nz/manjaro/
Mirror #39 OK 00:15 Ukraine https://fastmirror.pp.ua/manjaro/
Mirror #40 OK 02:05 Singapore https://mirror.freedif.org/Manjaro/
Mirror #41 OK 00:11 Australia https://gsl-syd.mm.fcix.net/manjaro/
Mirror #42 OK 00:44 Japan https://mirror.phoepsilonix.love/manjaro/
Mirror #43 OK 02:05 Russia https://mirror.kamtv.ru/manjaro/
Mirror #44 OK 00:03 Global https://mirrors.manjaro.org/repo/
Mirror #45 OK 03:13 China https://mirrors.sjtug.sjtu.edu.cn/manjaro/
Mirror #46 OK 04:27 Thailand https://mirror.kku.ac.th/manjaro/
Mirror #47 OK 01:37 Russia https://mirror.truenetwork.ru/manjaro/
Mirror #48 OK 02:02 Bangladesh https://bd.mirror.vanehost.com/Manjaro/
[sfrocker@sfrocker-pc ~]$ sudo pacman -Syuu
core 263.5 KiB 573 KiB/s 00:00 [####################################] 100%
extra 9.2 MiB 3.47 MiB/s 00:03 [####################################] 100%
community is up to date
resolving dependencies...
Packages (10) firefox-ublock-origin-1.55.0-1 fontconfig-2:2.15.0-2 iputils-20231222-2 libcap-ng-0.8.4-1
linux-opi-6.6.10-1 linux-opi-headers-6.6.10-1 lz4-1:1.9.4-2 mesa-23.3.2-2
python-capng-0.8.4-1 python-psutil-5.9.7-1
Total Download Size: 106.19 MiB
Total Installed Size: 247.26 MiB
Net Upgrade Size: 8.06 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
python-psutil-5.9.7-1-aarch64 454.8 KiB 395 KiB/s 00:01 [####################################] 100%
fontconfig-2:2.15.0-2-aarch64 349.1 KiB 289 KiB/s 00:01 [####################################] 100%
firefox-ublock-origin-1.55.0-1-any 3.3 MiB 1002 KiB/s 00:03 [####################################] 100%
lz4-1:1.9.4-2-aarch64 124.3 KiB 191 KiB/s 00:01 [####################################] 100%
libcap-ng-0.8.4-1-aarch64 40.9 KiB 454 KiB/s 00:00 [####################################] 100%
python-capng-0.8.4-1-aarch64 18.9 KiB 210 KiB/s 00:00 [####################################] 100%
iputils-20231222-2-aarch64 112.3 KiB 401 KiB/s 00:00 [####################################] 100%
linux-opi-headers-6.6.10-1-aarch64 26.8 MiB 1364 KiB/s 00:20 [####################################] 100%
mesa-23.3.2-2-aarch64 25.8 MiB 1036 KiB/s 00:26 [####################################] 100%
linux-opi-6.6.10-1-aarch64 49.2 MiB 1920 KiB/s 00:26 [####################################] 100%
Total (10/10) 106.2 MiB 4.04 MiB/s 00:26 [####################################] 100%
(10/10) checking keys in keyring [####################################] 100%
(10/10) checking package integrity [####################################] 100%
(10/10) loading package files [####################################] 100%
(10/10) checking for file conflicts [####################################] 100%
(10/10) checking available disk space [####################################] 100%
( 1/10) upgrading firefox-ublock-origin [####################################] 100%
( 2/10) upgrading fontconfig [####################################] 100%
Rebuilding fontconfig cache...
( 3/10) upgrading libcap-ng [####################################] 100%
( 4/10) upgrading iputils [####################################] 100%
( 5/10) upgrading lz4 [####################################] 100%
( 6/10) upgrading linux-opi [####################################] 100%
( 7/10) upgrading linux-opi-headers [####################################] 100%
( 8/10) upgrading mesa [####################################] 100%
( 9/10) upgrading python-capng [####################################] 100%
(10/10) upgrading python-psutil [####################################] 100%
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Updating linux-opi module dependencies...
(4/5) Updating linux-opi initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-opi.preset: 'default'
==> Using configuration file: '/etc/mkinitcpio.conf'
-> -k 6.6.10-1-MANJARO-ARM -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
==> Starting build: '6.6.10-1-MANJARO-ARM'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [kms]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [fsck]
==> ERROR: module not found: 'rtc_rk808'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-linux.img'
==> WARNING: errors were encountered during the build. The image may not be complete.
error: command failed to execute correctly
(5/5) Updating fontconfig cache...
[sfrocker@sfrocker-pc ~]$```
This is what i see, the processor must of been more targeted towards some device with rk808 processor instead of the rk3399 one that is associated with mine. ==> ERROR: module not found: ``` ``ârtc_rk808â
Does your device have Real Time Clock rk808. Besides that according to this the module should be called rk808-rtc.
No I am not.
If your system is up-to-date then you have the latest version.
The flasher downloads prebuilt images which you need to configure on first launch.
The installer script on the other hand installs and configures from the repositories so it may be a better option - unless you are giving the cards away for others to use.
Personally⌠I do remove pamac and use pacman (+paru for aur helper).
But all I was trying to say was that your choice of package manager should not influence your choice of branch, because it does not matter.
i am pretty sure it does not have it, there is no way around the installation, plus when i lose these updated settings i get errors like screen is black and white until i click the desktop, and sometimes sound is disabled, and i have to reboot it until the sound and wifi is functioning properly, it asks for my wifi password if it is not getting an update somehow, i am guessing i just need to manually install things for myself.
Packages (2) linux-opi-6.6.10-1 linux-opi-headers-6.6.10-1
i think since i turned off my system from powerbrick instead of poweroff
command it messed with real time clock, because sometimes when i use the original shutdown logo button on my keyboard, it stalls on the spinning logo. but i just assume it is a lack of power going through the keyboard at once.
I am using it for personal gain, and for libre office, since i donât have to go âoh i got windows 11, I donât need microsoft word or there ad free programsâ lol
