I got OneDrive auto-mount working via rclone! I had to put together steps from several different blogs and forum posts here to do so.
I’d love to post this as a tutorial, but for some reason I don’t have permissions to do that.
How do I get permissions?
Hi @testingwithfire ,
We ask the @moderators what to do.
Are you able to post inside of:
Tutorials are <strong>member-contributed</strong> posts that describe how to achieve something with Manjaro.
Are you able to answer there ?
(Otherwise it will be possible to do what Teo suggests. I think this was also how i did my first post there.)
Teo
29 November 2023 13:32
4
New users cannot if i remember correctly. I just posted my tutorial and a moderator moved and tagged it properly, when i was new.
Post it support to have it proof read by the community - then a moderator or a high level member can move it when it is accepted.
Please do remember - linking to other pages - if any - should be kept at a minimum and listed as source
Teo
29 November 2023 14:50
6
I remember setting up google drive with rclone - it was pure horror. Because of the google developer website of course. So a tutorial is definitely needed.
I found onedrive easy to setup with rclone…don’t know 'bout GDrive. But both onedrive as well as dropbox was easy. (Well, for me it was anyway.)
