New to Manjaro - Fresh KDE install - No Sound
Hi! I’m brand new to Manjaro, though I have been using linux in one flavor or another for many years. Long story short: I am adding a pc to my home theater, primarily to run kodi (but also vlc, basic web browsing, etc.)
Several fresh installs, and lots of poking and prodding later, I can’t get the audio to function properly. Unfortunately, I am not experienced enough to know where else to go for help. So, many apologies in advance if this is the wrong place to be, or if I just missed the solution somewhere else. I’ll include a few more details below, but first:
$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.10.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=a4665344-f763-460c-9214-f13ee0118b11 rw quiet apparmor=1
  Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop System: GIGABYTE product: BRi3(H)-10110 v: 1.x
  serial: <filter>
  Mobo: GIGABYTE model: MCMLUCB-00 v: 1.x serial: <filter>
  UEFI: American Megatrends v: F2 date: 12/05/2019
  Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400
  serial: <filter> charge: 100% (should be ignored) rechargeable: yes
  status: Discharging
  RAM: total: 7.61 GiB used: 2.06 GiB (27.1%)
  Info: Dual Core model: Intel Core i3-10110U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
  microcode: EA cache: L2: 4 MiB bogomips: 20810
  Speed: 800 MHz min/max: 400/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 801
  4: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
  est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
  popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
  ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
  tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
  xsaveopt xsaves xtopology xtpr
  Type: srbds mitigation: TSX disabled
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Gigabyte driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
  screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (20.0x11.2")
  s-diag: 582mm (22.9")
  Monitor-1: DP1 res: 1920x1080 dpi: 40 size: 1210x680mm (47.6x26.8")
  diag: 1388mm (54.6")
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.1.4
  direct render: Yes
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: Gigabyte
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
  bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.49-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.31 running: yes
  Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
  port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15be class-ID: 0200
  Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
  v: kernel port: efa0 bus-ID: 01:00.0 chip-ID: 8086:24fb class-ID: 0280
  Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
  bus-ID: 1-10:3 chip-ID: 8087:0aa7 class-ID: e001
  Permissions: Unable to run lvs. Root privileges required.
  Local Storage: total: 465.76 GiB used: 10.08 GiB (2.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 500GB
  size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 rotation: SSD serial: <filter> rev: 1B4QFXO7 temp: 51.9 C
  scheme: GPT
  ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
  used: 10.08 GiB (2.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  label: N/A uuid: a4665344-f763-460c-9214-f13ee0118b11
  label: NO_LABEL uuid: 5715-5CE3
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-4:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-10:3 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 47.0 C mobo: N/A
  Processes: 175 Uptime: 20m wakeups: 2 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 1197 lib: 328 flatpak: 0 Shell: Bash
  v: 5.1.8 running-in: yakuake inxi: 3.3.05
What happened immediately before I came here:
  1. Fresh install of Manjaro 21.07, via a USB drive.
  2. Changed the display resolution from 4k to 1080p
  3. Installed Kodi-x11 using Pamac
At each stage, I tested audio by opening a video on YouTube in Firefox AND by clicking the speaker test buttons found under “System Settings>Audio>Configure…” After Kodi was installed, I also checked that sounds worked for at least the user interface actions. Everything was going great… then I ate some lunch, the system went to sleep. I woke it up, and there was no sound. I restarted, and still no sound. So, here I am.
One thing I did notice is that playback streams do appear in the volume control interface when sound should be playing, and indicate that something is playing. However, nothing is audible.
Any help is welcome. Thank you!
Welcome here, @cos5000 :wave:,
two solutions are described here:
Some good background information about PipeWire is given in the Arch wiki:
Also interesting to read:
Thank you! I’ll give this a shot and report back.
Yikes, I spoke too soon (in [deleted post]). My audio has disapeared again, after some time off.
For proposed Solution 1
 sudo pacman -Ru --nodeps pulseaudio pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf pulseaudio-bluetooth pulseaudio-pa pulseaudio-alsa pulseaudio-ctl manjaro-pulse && sudo pacman -S manjaro-pipewire
[sudo] password for marcos:
error: target not found: pulseaudio-pa
For proposed solution 2:
$sudo pacman -Rud pulseaudio-bluetooth pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf
checking dependencies...
warning: removing pulseaudio-jack from target list
warning: removing pulseaudio-zeroconf from target list
warning: removing pulseaudio-lirc from target list
warning: removing pulseaudio-rtp from target list
warning: removing pulseaudio-equalizer from target list
warning: removing pulseaudio-bluetooth from target list
 there is nothing to do
I have a rough understanding of what PipeWire does, and I’m more than happy to work with it over pulse. However, I think I still need a little bit of a push in the right direction.
Here is some more information…
Kernel ring buffer logs:
$sudo dmesg | less
[    0.000000] microcode: microcode updated early to revision 0xea, date = 2021-01-05
[    0.000000] Linux version 5.10.49-1-MANJARO (builduser@LEGION) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Sun Jul 11 12:59:43 UTC 2021
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=a4665344-f763-460c-9214-f13ee0118b11 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000976a6fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000976a7000-0x0000000099157fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000099158000-0x00000000991d8fff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000991d9000-0x00000000991d9fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000991da000-0x0000000099287fff] ACPI data
[    0.000000] BIOS-e820: [mem 0x0000000099288000-0x0000000099387fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000099388000-0x0000000099993fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000099994000-0x0000000099c4dfff] type 20
[    0.000000] BIOS-e820: [mem 0x0000000099c4e000-0x0000000099c4efff] usable
[    0.000000] BIOS-e820: [mem 0x0000000099c4f000-0x000000009f7fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000025e7fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.70 by American Megatrends
[    0.000000] efi: ACPI=0x9932d000 ACPI 2.0=0x9932d014 TPMFinalLog=0x99335000 SMBIOS=0x99811000 SMBIOS 3.0=0x99810000 MEMATTR=0x92b61018 ESRT=0x9397e098
[    0.000000] SMBIOS 3.2.0 present.
[    0.000000] DMI: GIGABYTE BRi3(H)-10110/MCMLUCB-00, BIOS F2 12/05/2019
[    0.000000] tsc: Detected 2600.000 MHz processor
[    0.000000] tsc: Detected 2599.992 MHz TSC
[    0.001015] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.001019] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.001027] last_pfn = 0x25e800 max_arch_pfn = 0x400000000
[    0.001043] MTRR default type: write-back
[    0.001044] MTRR fixed ranges enabled:
[    0.001046]   00000-9FFFF write-back
[    0.001047]   A0000-BFFFF uncachable
[    0.001048]   C0000-FFFFF write-protect
[    0.001049] MTRR variable ranges enabled:
[    0.001051]   0 base 00C0000000 mask 7FC0000000 uncachable
[    0.001052]   1 base 00A0000000 mask 7FE0000000 uncachable
[    0.001054]   2 base 009C000000 mask 7FFC000000 uncachable
[    0.001055]   3 base 009B000000 mask 7FFF000000 uncachable
[    0.001056]   4 base 2000000000 mask 6000000000 uncachable
[    0.001057]   5 base 1000000000 mask 7000000000 uncachable
[    0.001058]   6 base 0800000000 mask 7800000000 uncachable
[    0.001060]   7 base 0400000000 mask 7C00000000 uncachable
[    0.001061]   8 base 4000000000 mask 4000000000 uncachable
[    0.001062]   9 disabled
[    0.001696] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.002167] last_pfn = 0x99c4f max_arch_pfn = 0x400000000
[    0.026675] esrt: Reserving ESRT space from 0x000000009397e098 to 0x000000009397e0d0.
[    0.026685] e820: update [mem 0x9397e000-0x9397efff] usable ==> reserved
[    0.026748] check: Scanning 1 areas for low memory corruption
[    0.026754] Using GB pages for direct mapping
[    0.027133] Secure boot disabled
[    0.027134] RAMDISK: [mem 0x3674f000-0x3739efff]
[    0.027139] ACPI: Early table checksum verification disabled
[    0.027143] ACPI: RSDP 0x000000009932D014 000024 (v02 GBT   )
[    0.027147] ACPI: XSDT 0x000000009932C728 0000CC (v01 GBT    GBTUACPI 01072009 AMI  01000013)
[    0.027154] ACPI: FACP 0x0000000099282000 000114 (v06 GBT    GBTUACPI 01072009 AMI  00010013)
[    0.027161] ACPI: DSDT 0x0000000099241000 040CAC (v02 GBT    GBTUACPI 01072009 INTL 20160527)
[    0.027165] ACPI: FACS 0x0000000099387000 000040
[    0.027169] ACPI: MCFG 0x0000000099285000 00003C (v01 GBT    GBTUACPI 01072009 MSFT 00000097)
[    0.027173] ACPI: SSDT 0x0000000099283000 001B4A (v02 CpuRef CpuSsdt  00003000 INTL 20160527)
[    0.027177] ACPI: FIDT 0x0000000099240000 00009C (v01 GBT    GBTUACPI 01072009 AMI  00010013)
[    0.027182] ACPI: SSDT 0x000000009923C000 0031CB (v02 SaSsdt SaSsdt   00003000 INTL 20160527)
[    0.027186] ACPI: HPET 0x0000000099287000 000038 (v01 GBT    GBTUACPI 01072009 AMI  01000013)
[    0.027190] ACPI: SSDT 0x000000009923A000 00147B (v02 GBT    Ther_Rvp 00001000 INTL 20160527)
[    0.027194] ACPI: SSDT 0x0000000099236000 0032B9 (v02 INTEL  xh_cmud4 00000000 INTL 20160527)
[    0.027198] ACPI: NHLT 0x0000000099234000 001821 (v00 GBT    GBTUACPI 01072009 AMI  01000013)
[    0.027201] ACPI: LPIT 0x0000000099286000 000094 (v01 GBT    GBTUACPI 01072009 AMI  01000013)
[    0.027205] ACPI: SSDT 0x0000000099230000 002720 (v02 GBT    PtidDevc 00001000 INTL 20160527)
[    0.027209] ACPI: SSDT 0x000000009922D000 0025B2 (v02 GBT    TbtTypeC 00000000 INTL 20160527)
[    0.027213] ACPI: DBGP 0x000000009922C000 000034 (v01 GBT    GBTUACPI 01072009 AMI  01000013)
[    0.027217] ACPI: DBG2 0x000000009922B000 000054 (v00 GBT    GBTUACPI 01072009 AMI  01000013)
[    0.027221] ACPI: SSDT 0x0000000099229000 001B67 (v02 GBT    UsbCTabl 00001000 INTL 20160527)
[    0.027225] ACPI: DMAR 0x0000000099228000 0000A8 (v01 INTEL  EDK2     00000002      01000013)
[    0.027228] ACPI: BGRT 0x0000000099227000 000038 (v01 GBT    GBTUACPI 01072009 AMI  00010013)
[    0.027232] ACPI: TPM2 0x0000000099226000 00004C (v04 GBT    GBTUACPI 00000001 AMI  00000000)
[    0.027236] ACPI: WSMT 0x0000000099233000 000028 (v01 GBT    GBTUACPI 01072009 AMI  00010013)
[    0.027240] ACPI: APIC 0x0000000099225000 000084 (v04 GBT    GBTUACPI 01072009 AMI  00010013)
[    0.027244] ACPI: FPDT 0x0000000099224000 000044 (v01 GBT    CML-ULT  01072009 AMI  01000013)
[    0.027248] ACPI: Reserving FACP table memory at [mem 0x99282000-0x99282113]
[    0.027249] ACPI: Reserving DSDT table memory at [mem 0x99241000-0x99281cab]
[    0.027250] ACPI: Reserving FACS table memory at [mem 0x99387000-0x9938703f]
[    0.027252] ACPI: Reserving MCFG table memory at [mem 0x99285000-0x9928503b]
[    0.027253] ACPI: Reserving SSDT table memory at [mem 0x99283000-0x99284b49]
[    0.027254] ACPI: Reserving FIDT table memory at [mem 0x99240000-0x9924009b]
[    0.027255] ACPI: Reserving SSDT table memory at [mem 0x9923c000-0x9923f1ca]
[    0.027256] ACPI: Reserving HPET table memory at [mem 0x99287000-0x99287037]
[    0.027258] ACPI: Reserving SSDT table memory at [mem 0x9923a000-0x9923b47a]
[    0.027259] ACPI: Reserving SSDT table memory at [mem 0x99236000-0x992392b8]
[    0.027260] ACPI: Reserving NHLT table memory at [mem 0x99234000-0x99235820]
[    0.027261] ACPI: Reserving LPIT table memory at [mem 0x99286000-0x99286093]
[    0.027262] ACPI: Reserving SSDT table memory at [mem 0x99230000-0x9923271f]
[    0.027264] ACPI: Reserving SSDT table memory at [mem 0x9922d000-0x9922f5b1]
[    0.027265] ACPI: Reserving DBGP table memory at [mem 0x9922c000-0x9922c033]
[    0.027266] ACPI: Reserving DBG2 table memory at [mem 0x9922b000-0x9922b053]
[    0.027267] ACPI: Reserving SSDT table memory at [mem 0x99229000-0x9922ab66]
[    0.027268] ACPI: Reserving DMAR table memory at [mem 0x99228000-0x992280a7]
[    0.027269] ACPI: Reserving BGRT table memory at [mem 0x99227000-0x99227037]
[    0.027271] ACPI: Reserving TPM2 table memory at [mem 0x99226000-0x9922604b]
[    0.027272] ACPI: Reserving WSMT table memory at [mem 0x99233000-0x99233027]
[    0.027273] ACPI: Reserving APIC table memory at [mem 0x99225000-0x99225083]
[    0.027274] ACPI: Reserving FPDT table memory at [mem 0x99224000-0x99224043]
[    0.027286] ACPI: Local APIC address 0xfee00000
[    0.027429] No NUMA configuration found
[    0.027430] Faking a node at [mem 0x0000000000000000-0x000000025e7fffff]
[    0.027435] NODE_DATA(0) allocated [mem 0x25e7fc000-0x25e7fffff]
[    0.060185] Zone ranges:
[    0.060187]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.060189]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.060191]   Normal   [mem 0x0000000100000000-0x000000025e7fffff]
[    0.060192]   Device   empty
[    0.060194] Movable zone start for each node
[    0.060194] Early memory node ranges
[    0.060196]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.060197]   node   0: [mem 0x0000000000100000-0x00000000976a6fff]
[    0.060199]   node   0: [mem 0x0000000099c4e000-0x0000000099c4efff]
[    0.060200]   node   0: [mem 0x0000000100000000-0x000000025e7fffff]
[    0.060202] Initmem setup node 0 [mem 0x0000000000001000-0x000000025e7fffff]
[    0.060204] On node 0 totalpages: 2055750
[    0.060205]   DMA zone: 64 pages used for memmap
[    0.060206]   DMA zone: 27 pages reserved
[    0.060208]   DMA zone: 3998 pages, LIFO batch:0
[    0.060592]   DMA zone: 28770 pages in unavailable ranges
[    0.060593]   DMA32 zone: 9627 pages used for memmap
[    0.060594]   DMA32 zone: 616104 pages, LIFO batch:63
[    0.070567]   DMA32 zone: 35160 pages in unavailable ranges
[    0.070568]   Normal zone: 22432 pages used for memmap
[    0.070569]   Normal zone: 1435648 pages, LIFO batch:63
[    0.093229]   Normal zone: 6144 pages in unavailable ranges
[    0.093262] Reserving Intel graphics memory at [mem 0x9b800000-0x9f7fffff]
[    0.093513] ACPI: PM-Timer IO Port: 0x1808
[    0.093515] ACPI: Local APIC address 0xfee00000
[    0.093523] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.093524] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.093525] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.093525] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.093578] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.093581] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.093582] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.093584] ACPI: IRQ0 used by override.
[    0.093585] ACPI: IRQ9 used by override.
[    0.093588] Using ACPI (MADT) for SMP configuration information
[    0.093589] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.093601] e820: update [mem 0x93926000-0x9397dfff] usable ==> reserved
[    0.093612] TSC deadline timer available
[    0.093613] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.093642] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.093645] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[    0.093647] PM: hibernation: Registered nosave memory: [mem 0x93926000-0x9397efff]
[    0.093649] PM: hibernation: Registered nosave memory: [mem 0x976a7000-0x99157fff]
[    0.093650] PM: hibernation: Registered nosave memory: [mem 0x99158000-0x991d8fff]
[    0.093651] PM: hibernation: Registered nosave memory: [mem 0x991d9000-0x991d9fff]
[    0.093652] PM: hibernation: Registered nosave memory: [mem 0x991da000-0x99287fff]
[    0.093653] PM: hibernation: Registered nosave memory: [mem 0x99288000-0x99387fff]
[    0.093653] PM: hibernation: Registered nosave memory: [mem 0x99388000-0x99993fff]
[    0.093654] PM: hibernation: Registered nosave memory: [mem 0x99994000-0x99c4dfff]
[    0.093657] PM: hibernation: Registered nosave memory: [mem 0x99c4f000-0x9f7fffff]
[    0.093658] PM: hibernation: Registered nosave memory: [mem 0x9f800000-0xdfffffff]
[    0.093658] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.093659] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[    0.093660] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.093661] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[    0.093662] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.093663] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.093664] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[    0.093664] PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfedfffff]
[    0.093665] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.093666] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.093667] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.093669] [mem 0x9f800000-0xdfffffff] available for PCI devices
[    0.093671] Booting paravirtualized kernel on bare hardware
[    0.093674] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.100569] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[    0.100843] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u524288
[    0.100852] pcpu-alloc: s192512 r8192 d28672 u524288 alloc=1*2097152
[    0.100853] pcpu-alloc: [0] 0 1 2 3
[    0.100882] Built 1 zonelists, mobility grouping on.  Total pages: 2023600
[    0.100883] Policy zone: Normal
[    0.100885] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=a4665344-f763-460c-9214-f13ee0118b11 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[    0.101838] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.102314] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.102370] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.147195] Memory: 7882492K/8223000K available (14344K kernel code, 2061K rwdata, 8884K rodata, 1704K init, 4248K bss, 340248K reserved, 0K cma-reserved)
[    0.147205] random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
[    0.147373] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.147390] ftrace: allocating 41892 entries in 164 pages
[    0.167743] ftrace: allocated 164 pages with 3 groups
[    0.167891] rcu: Preemptible hierarchical RCU implementation.
[    0.167892] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.167893] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[    0.167894] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.167895] 	Trampoline variant of Tasks RCU enabled.
[    0.167896] 	Rude variant of Tasks RCU enabled.
[    0.167897] 	Tracing variant of Tasks RCU enabled.
[    0.167898] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.167899] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.172732] NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
[    0.173462] Console: colour dummy device 80x25
[    0.173483] printk: console [tty0] enabled
[    0.173507] ACPI: Core revision 20200925
[    0.174121] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[    0.174254] APIC: Switch to symmetric I/O mode setup
[    0.174257] DMAR: Host address width 39
[    0.174258] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.174265] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[    0.174266] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.174270] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.174272] DMAR: RMRR base: 0x000000995a1000 end: 0x000000997eafff
[    0.174274] DMAR: RMRR base: 0x0000009b000000 end: 0x0000009f7fffff
[    0.174276] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.174277] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.174278] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.177231] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.177233] x2apic enabled
[    0.177264] Switched APIC routing to cluster x2apic.
[    0.184469] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.200792] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x257a34a6eea, max_idle_ns: 440795264358 ns
[    0.200797] Calibrating delay loop (skipped), value calculated using timer frequency.. 5202.65 BogoMIPS (lpj=8666640)
[    0.200800] pid_max: default: 32768 minimum: 301
[    0.205799] LSM: Security Framework initializing
[    0.205807] Yama: becoming mindful.
[    0.205838] AppArmor: AppArmor initialized
[    0.205882] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.205932] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.206304] mce: CPU0: Thermal monitoring enabled (TM1)
[    0.206326] process: using mwait in idle threads
[    0.206330] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.206330] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.206334] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.206336] Spectre V2 : Mitigation: Enhanced IBRS
[    0.206337] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.206339] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.206340] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.206344] SRBDS: Mitigation: TSX disabled
[    0.206659] Freeing SMP alternatives memory: 36K
[    0.207917] smpboot: CPU0: Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz (family: 0x6, model: 0x8e, stepping: 0xc)
[    0.208076] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.208089] ... version:                4
[    0.208090] ... bit width:              48
[    0.208091] ... generic registers:      4
[    0.208092] ... value mask:             0000ffffffffffff
[    0.208092] ... max period:             00007fffffffffff
[    0.208093] ... fixed-purpose events:   3
[    0.208094] ... event mask:             000000070000000f
[    0.208226] rcu: Hierarchical SRCU implementation.
[    0.208975] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.209027] smp: Bringing up secondary CPUs ...
[    0.209170] x86: Booting SMP configuration:
[    0.209172] .... node  #0, CPUs:      #1 #2 #3
[    0.214537] smp: Brought up 1 node, 4 CPUs
[    0.214537] smpboot: Max logical packages: 1
[    0.214537] smpboot: Total of 4 processors activated (20808.60 BogoMIPS)
[    0.215941] devtmpfs: initialized
[    0.215941] x86/mm: Memory block size: 128MB
[    0.215941] PM: Registering ACPI NVS region [mem 0x99288000-0x99387fff] (1048576 bytes)
[    0.215941] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.215941] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.215941] pinctrl core: initialized pinctrl subsystem
[    0.215941] PM: RTC time: 00:30:31, date: 2021-07-20
[    0.215941] NET: Registered protocol family 16
[    0.215941] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.215941] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.215941] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.215941] audit: initializing netlink subsys (disabled)
[    0.217500] audit: type=2000 audit(1626741031.036:1): state=initialized audit_enabled=0 res=1
[    0.217577] thermal_sys: Registered thermal governor 'fair_share'
[    0.217578] thermal_sys: Registered thermal governor 'bang_bang'
[    0.217579] thermal_sys: Registered thermal governor 'step_wise'
[    0.217580] thermal_sys: Registered thermal governor 'user_space'
[    0.217581] thermal_sys: Registered thermal governor 'power_allocator'
[    0.217598] cpuidle: using governor ladder
[    0.217598] cpuidle: using governor menu
[    0.217598] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.217598] ACPI: bus type PCI registered
[    0.217598] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.217598] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.217598] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.217598] PCI: Using configuration type 1 for base access
[    0.217848] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.218554] Kprobes globally optimized
[    0.218554] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.218554] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.220893] ACPI: Added _OSI(Module Device)
[    0.220894] ACPI: Added _OSI(Processor Device)
[    0.220895] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.220896] ACPI: Added _OSI(Processor Aggregator Device)
[    0.220897] ACPI: Added _OSI(Linux-Dell-Video)
[    0.220899] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.220900] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.305108] ACPI: 8 ACPI AML tables successfully acquired and loaded
[    0.314615] ACPI: Dynamic OEM Table Load:
[    0.314627] ACPI: SSDT 0xFFFF93EA00E43100 0000F4 (v02 PmRef  Cpu0Psd  00003000 INTL 20160527)
[    0.316480] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[    0.318998] ACPI: Dynamic OEM Table Load:
[    0.319006] ACPI: SSDT 0xFFFF93EA00E58400 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160527)
[    0.321052] ACPI: Dynamic OEM Table Load:
[    0.321060] ACPI: SSDT 0xFFFF93EA00FC5000 000605 (v02 PmRef  Cpu0Ist  00003000 INTL 20160527)
[    0.323222] ACPI: Dynamic OEM Table Load:
[    0.323228] ACPI: SSDT 0xFFFF93EA01080E00 00011B (v02 PmRef  Cpu0Hwp  00003000 INTL 20160527)
[    0.325169] ACPI: Dynamic OEM Table Load:
[    0.325178] ACPI: SSDT 0xFFFF93EA00CD7000 000BE2 (v02 PmRef  HwpLvt   00003000 INTL 20160527)
[    0.327521] ACPI: Dynamic OEM Table Load:
[    0.327530] ACPI: SSDT 0xFFFF93EA00FC7800 000778 (v02 PmRef  ApIst    00003000 INTL 20160527)
[    0.332610] ACPI: Dynamic OEM Table Load:
[    0.332617] ACPI: SSDT 0xFFFF93EA0094C800 0003D7 (v02 PmRef  ApHwp    00003000 INTL 20160527)
[    0.334836] ACPI: Dynamic OEM Table Load:
[    0.334845] ACPI: SSDT 0xFFFF93EA00114000 000D74 (v02 PmRef  ApPsd    00003000 INTL 20160527)
[    0.338157] ACPI: Dynamic OEM Table Load:
[    0.338164] ACPI: SSDT 0xFFFF93EA0094F800 0003CA (v02 PmRef  ApCst    00003000 INTL 20160527)
[    0.344874] ACPI: Interpreter enabled
[    0.344932] ACPI: (supports S0 S3 S4 S5)
[    0.344934] ACPI: Using IOAPIC for interrupt routing
[    0.344990] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.346905] ACPI: Enabled 8 GPEs in block 00 to 7F
[    0.356773] ACPI: Power Resource [WRST] (on)
[    0.356902] ACPI: Power Resource [DRST] (on)
[    0.366830] ACPI: Power Resource [USBC] (on)
[    0.371764] ACPI: Power Resource [V0PR] (on)
[    0.372098] ACPI: Power Resource [V1PR] (on)
[    0.372428] ACPI: Power Resource [V2PR] (on)
[    0.378080] ACPI: Power Resource [WRST] (on)
[    0.387891] ACPI: Power Resource [FN00] (off)
[    0.388025] ACPI: Power Resource [FN01] (off)
[    0.388155] ACPI: Power Resource [FN02] (off)
[    0.388284] ACPI: Power Resource [FN03] (off)
[    0.388414] ACPI: Power Resource [FN04] (off)
[    0.389333] ACPI: Power Resource [PIN] (off)
[    0.389960] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.389968] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.392768] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[    0.392769] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.394106] PCI host bridge to bus 0000:00
[    0.394109] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.394110] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.394112] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.394113] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[    0.394114] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[    0.394115] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[    0.394117] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[    0.394118] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[    0.394119] pci_bus 0000:00: root bus resource [mem 0x9f800000-0xdfffffff window]
[    0.394120] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[    0.394122] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.394145] pci 0000:00:00.0: [8086:9b71] type 00 class 0x060000
[    0.394840] pci 0000:00:02.0: [8086:9b41] type 00 class 0x030000
[    0.394852] pci 0000:00:02.0: reg 0x10: [mem 0xb0000000-0xb0ffffff 64bit]
[    0.394859] pci 0000:00:02.0: reg 0x18: [mem 0xa0000000-0xafffffff 64bit pref]
[    0.394864] pci 0000:00:02.0: reg 0x20: [io  0x3000-0x303f]
[    0.394887] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.395204] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[    0.395216] pci 0000:00:08.0: reg 0x10: [mem 0xb133e000-0xb133efff 64bit]
[    0.395513] pci 0000:00:12.0: [8086:02f9] type 00 class 0x118000
[    0.395531] pci 0000:00:12.0: reg 0x10: [mem 0xb133d000-0xb133dfff 64bit]
[    0.395831] pci 0000:00:14.0: [8086:02ed] type 00 class 0x0c0330
[    0.395848] pci 0000:00:14.0: reg 0x10: [mem 0xb1320000-0xb132ffff 64bit]
[    0.395920] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.396416] pci 0000:00:14.2: [8086:02ef] type 00 class 0x050000
[    0.396434] pci 0000:00:14.2: reg 0x10: [mem 0xb1336000-0xb1337fff 64bit]
[    0.396446] pci 0000:00:14.2: reg 0x18: [mem 0xb133c000-0xb133cfff 64bit]
[    0.396730] pci 0000:00:16.0: [8086:02e0] type 00 class 0x078000
[    0.396752] pci 0000:00:16.0: reg 0x10: [mem 0xb133b000-0xb133bfff 64bit]
[    0.396835] pci 0000:00:16.0: PME# supported from D3hot
[    0.397327] pci 0000:00:17.0: [8086:02d3] type 00 class 0x010601
[    0.397343] pci 0000:00:17.0: reg 0x10: [mem 0xb1334000-0xb1335fff]
[    0.397352] pci 0000:00:17.0: reg 0x14: [mem 0xb133a000-0xb133a0ff]
[    0.397361] pci 0000:00:17.0: reg 0x18: [io  0x3090-0x3097]
[    0.397370] pci 0000:00:17.0: reg 0x1c: [io  0x3080-0x3083]
[    0.397380] pci 0000:00:17.0: reg 0x20: [io  0x3060-0x307f]
[    0.397389] pci 0000:00:17.0: reg 0x24: [mem 0xb1339000-0xb13397ff]
[    0.397438] pci 0000:00:17.0: PME# supported from D3hot
[    0.397840] pci 0000:00:1c.0: [8086:02bf] type 01 class 0x060400
[    0.397926] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.397950] pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
[    0.398569] pci 0000:00:1d.0: [8086:02b4] type 01 class 0x060400
[    0.398655] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.398677] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[    0.399296] pci 0000:00:1f.0: [8086:0284] type 00 class 0x060100
[    0.399879] pci 0000:00:1f.3: [8086:02c8] type 00 class 0x040300
[    0.399930] pci 0000:00:1f.3: reg 0x10: [mem 0xb1330000-0xb1333fff 64bit]
[    0.399993] pci 0000:00:1f.3: reg 0x20: [mem 0xb1000000-0xb10fffff 64bit]
[    0.400125] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.400958] pci 0000:00:1f.4: [8086:02a3] type 00 class 0x0c0500
[    0.400984] pci 0000:00:1f.4: reg 0x10: [mem 0xb1338000-0xb13380ff 64bit]
[    0.401015] pci 0000:00:1f.4: reg 0x20: [io  0xefa0-0xefbf]
[    0.401366] pci 0000:00:1f.5: [8086:02a4] type 00 class 0x0c8000
[    0.401383] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[    0.401673] pci 0000:00:1f.6: [8086:15be] type 00 class 0x020000
[    0.401714] pci 0000:00:1f.6: reg 0x10: [mem 0xb1300000-0xb131ffff]
[    0.401942] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[    0.402348] pci 0000:01:00.0: [8086:24fb] type 00 class 0x028000
[    0.402385] pci 0000:01:00.0: reg 0x10: [mem 0xb1200000-0xb1201fff 64bit]
[    0.402577] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    0.402782] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.402787] pci 0000:00:1c.0:   bridge window [mem 0xb1200000-0xb12fffff]
[    0.402929] pci 0000:02:00.0: [144d:a809] type 00 class 0x010802
[    0.402951] pci 0000:02:00.0: reg 0x10: [mem 0xb1100000-0xb1103fff 64bit]
[    0.403190] pci 0000:00:1d.0: PCI bridge to [bus 02]
[    0.403195] pci 0000:00:1d.0:   bridge window [mem 0xb1100000-0xb11fffff]
[    0.406427] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    0.406595] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *1
[    0.406760] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    0.406925] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    0.407093] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    0.407257] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    0.407421] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    0.407590] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0
[    0.408457] iommu: Default domain type: Translated
[    0.408474] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.408474] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.408474] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.408474] vgaarb: loaded
[    0.408474] SCSI subsystem initialized
[    0.408474] libata version 3.00 loaded.
[    0.408474] ACPI: bus type USB registered
[    0.408474] usbcore: registered new interface driver usbfs
[    0.408474] usbcore: registered new interface driver hub
[    0.408474] usbcore: registered new device driver usb
[    0.408474] pps_core: LinuxPPS API ver. 1 registered
[    0.408474] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.408474] PTP clock support registered
[    0.408474] EDAC MC: Ver: 3.0.0
[    0.408474] Registered efivars operations
[    0.408474] NetLabel: Initializing
[    0.408474] NetLabel:  domain hash size = 128
[    0.408474] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.408474] NetLabel:  unlabeled traffic allowed by default
[    0.408474] PCI: Using ACPI for IRQ routing
[    0.453216] PCI: pci_cache_line_size set to 64 bytes
[    0.453288] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.453290] e820: reserve RAM buffer [mem 0x93926000-0x93ffffff]
[    0.453291] e820: reserve RAM buffer [mem 0x976a7000-0x97ffffff]
[    0.453292] e820: reserve RAM buffer [mem 0x99c4f000-0x9bffffff]
[    0.453293] e820: reserve RAM buffer [mem 0x25e800000-0x25fffffff]
[    0.454828] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.454835] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    0.457507] clocksource: Switched to clocksource tsc-early
[    0.470762] VFS: Disk quotas dquot_6.6.0
[    0.470779] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.470911] AppArmor: AppArmor Filesystem Enabled
[    0.470945] pnp: PnP ACPI init
[    0.471113] system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
[    0.471119] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.471500] system 00:01: [io  0x0a00-0x0a0f] has been reserved
[    0.471501] system 00:01: [io  0x0a10-0x0a8f] has been reserved
[    0.471503] system 00:01: [io  0x0a90-0x0a9f] has been reserved
[    0.471507] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.472030] pnp 00:02: [dma 0 disabled]
[    0.472081] pnp 00:02: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.472244] system 00:03: [io  0x0680-0x069f] has been reserved
[    0.472246] system 00:03: [io  0x164e-0x164f] has been reserved
[    0.472250] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.472417] system 00:04: [io  0x1854-0x1857] has been reserved
[    0.472421] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.472777] system 00:05: [io  0x1800-0x18fe] could not be reserved
[    0.472782] system 00:05: [mem 0xfd000000-0xfd69ffff] has been reserved
[    0.472784] system 00:05: [mem 0xfd6b0000-0xfd6cffff] has been reserved
[    0.472785] system 00:05: [mem 0xfd6f0000-0xfdffffff] has been reserved
[    0.472787] system 00:05: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.472788] system 00:05: [mem 0xfe200000-0xfe7fffff] has been reserved
[    0.472790] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[    0.472794] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.473258] system 00:06: [io  0x2000-0x20fe] has been reserved
[    0.473262] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.474450] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.474452] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.474454] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.474456] system 00:07: [mem 0xe0000000-0xefffffff] has been reserved
[    0.474457] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.474459] system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.474460] system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.474462] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.474466] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.475029] system 00:08: [mem 0xfe038000-0xfe038fff] has been reserved
[    0.475033] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.475698] pnp: PnP ACPI: found 9 devices
[    0.481426] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.481487] NET: Registered protocol family 2
[    0.481628] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.482888] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.482939] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.483119] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.483206] TCP: Hash tables configured (established 65536 bind 65536)
[    0.483297] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[    0.483335] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.483364] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.483593] NET: Registered protocol family 1
[    0.483600] NET: Registered protocol family 44
[    0.483616] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.483623] pci 0000:00:1c.0:   bridge window [mem 0xb1200000-0xb12fffff]
[    0.483629] pci 0000:00:1d.0: PCI bridge to [bus 02]
[    0.483633] pci 0000:00:1d.0:   bridge window [mem 0xb1100000-0xb11fffff]
[    0.483640] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.483641] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.483643] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.483644] pci_bus 0000:00: resource 7 [mem 0x000e0000-0x000e3fff window]
[    0.483645] pci_bus 0000:00: resource 8 [mem 0x000e4000-0x000e7fff window]
[    0.483646] pci_bus 0000:00: resource 9 [mem 0x000e8000-0x000ebfff window]
[    0.483648] pci_bus 0000:00: resource 10 [mem 0x000ec000-0x000effff window]
[    0.483649] pci_bus 0000:00: resource 11 [mem 0x000f0000-0x000fffff window]
[    0.483650] pci_bus 0000:00: resource 12 [mem 0x9f800000-0xdfffffff window]
[    0.483651] pci_bus 0000:00: resource 13 [mem 0xfc800000-0xfe7fffff window]
[    0.483653] pci_bus 0000:01: resource 1 [mem 0xb1200000-0xb12fffff]
[    0.483654] pci_bus 0000:02: resource 1 [mem 0xb1100000-0xb11fffff]
[    0.483923] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.484449] PCI: CLS 64 bytes, default 64
[    0.484521] Trying to unpack rootfs image as initramfs...
[    0.656069] Freeing initrd memory: 12608K
[    0.656143] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.656146] software IO TLB: mapped [mem 0x000000008e966000-0x0000000092966000] (64MB)
[    0.656257] platform rtc_cmos: registered platform RTC device (no PNP device found)
[    0.656620] check: Scanning for low memory corruption every 60 seconds
[    0.656938] Initialise system trusted keyrings
[    0.656950] Key type blacklist registered
[    0.657002] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[    0.658202] zbud: loaded
[    0.669527] Key type asymmetric registered
[    0.669528] Asymmetric key parser 'x509' registered
[    0.669536] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.669574] io scheduler mq-deadline registered
[    0.669575] io scheduler kyber registered
[    0.669599] io scheduler bfq registered
[    0.669673] atomic64_test: passed for x86-64 platform with CX8 and with SSE
[    0.672227] pcieport 0000:00:1c.0: PME: Signaling with IRQ 122
[    0.672292] pcieport 0000:00:1c.0: AER: enabled with IRQ 122
[    0.672336] pcieport 0000:00:1c.0: DPC: enabled with IRQ 122
[    0.672338] pcieport 0000:00:1c.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[    0.672637] pcieport 0000:00:1d.0: PME: Signaling with IRQ 123
[    0.672696] pcieport 0000:00:1d.0: AER: enabled with IRQ 123
[    0.672737] pcieport 0000:00:1d.0: DPC: enabled with IRQ 123
[    0.672739] pcieport 0000:00:1d.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[    0.672828] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.672859] efifb: probing for efifb
[    0.672885] efifb: showing boot graphics
[    0.677146] efifb: framebuffer at 0xa0000000, using 32448k, total 32448k
[    0.677147] efifb: mode is 3840x2160x32, linelength=15360, pages=1
[    0.677148] efifb: scrolling: redraw
[    0.677149] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.677189] fbcon: Deferring console take-over
[    0.677190] fb0: EFI VGA frame buffer device
[    0.677198] intel_idle: MWAIT substates: 0x11142120
[    0.677199] intel_idle: v0.5.1 model 0x8E
[    0.677456] intel_idle: Local APIC timer is reliable in all C-states
[    0.677663] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[    0.677684] ACPI: Sleep Button [SLPB]
[    0.677717] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    0.677731] ACPI: Power Button [PWRB]
[    0.677758] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    0.684168] ACPI: Power Button [PWRF]
[    0.686027] thermal LNXTHERM:00: registered as thermal_zone0
[    0.686028] ACPI: Thermal Zone [TZ00] (28 C)
[    0.686265] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.686749] 00:02: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.690586] Non-volatile memory driver v1.3
[    0.690588] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    0.690589] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[    0.691117] nvme nvme0: pci function 0000:02:00.0
[    0.691152] ahci 0000:00:17.0: version 3.0
[    0.691609] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[    0.691611] ahci 0000:00:17.0: flags: 64bit ncq sntf clo only pio slum part deso sadm sds apst
[    0.691830] scsi host0: ahci
[    0.691891] ata1: SATA max UDMA/133 abar m2048@0xb1339000 port 0xb1339100 irq 125
[    0.691941] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.691947] ehci-pci: EHCI PCI platform driver
[    0.691960] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.691962] ohci-pci: OHCI PCI platform driver
[    0.691968] uhci_hcd: USB Universal Host Controller Interface driver
[    0.692004] usbcore: registered new interface driver usbserial_generic
[    0.692008] usbserial: USB Serial support registered for generic
[    0.692026] i8042: PNP: No PS/2 controller found.
[    0.692128] rtc_cmos rtc_cmos: RTC can wake from S4
[    0.692966] rtc_cmos rtc_cmos: registered as rtc0
[    0.693140] rtc_cmos rtc_cmos: setting system clock to 2021-07-20T00:30:31 UTC (1626741031)
[    0.693152] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    0.693181] intel_pstate: Intel P-state driver initializing
[    0.693468] intel_pstate: HWP enabled
[    0.693492] ledtrig-cpu: registered to indicate activity on CPUs
[    0.693734] hid: raw HID events driver (C) Jiri Kosina
[    0.693764] ashmem: initialized
[    0.693790] intel_pmc_core INT33A1:00:  initialized
[    0.693858] drop_monitor: Initializing network drop monitor service
[    0.693900] Initializing XFRM netlink socket
[    0.693951] NET: Registered protocol family 10
[    0.696925] Segment Routing with IPv6
[    0.696926] RPL Segment Routing with IPv6
[    0.696963] NET: Registered protocol family 17
[    0.697138] microcode: sig=0x806ec, pf=0x4, revision=0xea
[    0.697148] microcode: Microcode Update Driver: v2.2.
[    0.697151] IPI shorthand broadcast: enabled
[    0.697156] sched_clock: Marking stable (689487085, 7577946)->(698284914, -1219883)
[    0.697227] registered taskstats version 1
[    0.697234] Loading compiled-in X.509 certificates
[    0.698937] Loaded X.509 cert 'Build time autogenerated kernel key: 5e649498937fba3fd452e8e68fc816deb54d4711'
[    0.699519] zswap: loaded using pool zstd/z3fold
[    0.699693] Key type ._fscrypt registered
[    0.699694] Key type .fscrypt registered
[    0.699694] Key type fscrypt-provisioning registered
[    0.699726] AppArmor: AppArmor sha1 policy hashing enabled
[    0.700657] PM:   Magic number: 13:981:506
[    0.700845] RAS: Correctable Errors collector initialized.
[    0.706202] nvme nvme0: Shutdown timeout set to 8 seconds
[    0.733763] nvme nvme0: allocated 64 MiB host memory buffer.
[    0.770631] nvme nvme0: 4/0/0 default/read/poll queues
[    0.783004]  nvme0n1: p1 p2
[    1.007586] ata1: SATA link down (SStatus 4 SControl 300)
[    1.009742] Freeing unused decrypted memory: 2036K
[    1.010311] Freeing unused kernel image (initmem) memory: 1704K
[    1.010315] Write protecting the kernel read-only data: 26624k
[    1.011256] Freeing unused kernel image (text/rodata gap) memory: 2036K
[    1.011793] Freeing unused kernel image (rodata/data gap) memory: 1356K
[    1.040356] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.040362] rodata_test: all tests were successful
[    1.040370] Run /init as init process
[    1.040373]   with arguments:
[    1.040374]     /init
[    1.040375]   with environment:
[    1.040377]     HOME=/
[    1.040378]     TERM=linux
[    1.040379]     BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
[    1.113067] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.113074] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.114164] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[    1.114169] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.114367] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    1.114368] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.114370] usb usb1: Product: xHCI Host Controller
[    1.114371] usb usb1: Manufacturer: Linux 5.10.49-1-MANJARO xhci-hcd
[    1.114371] usb usb1: SerialNumber: 0000:00:14.0
[    1.114468] hub 1-0:1.0: USB hub found
[    1.114491] hub 1-0:1.0: 12 ports detected
[    1.116423] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.116430] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.116433] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[    1.116468] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    1.116469] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.116470] usb usb2: Product: xHCI Host Controller
[    1.116471] usb usb2: Manufacturer: Linux 5.10.49-1-MANJARO xhci-hcd
[    1.116472] usb usb2: SerialNumber: 0000:00:14.0
[    1.116618] hub 2-0:1.0: USB hub found
[    1.116637] hub 2-0:1.0: 6 ports detected
[    1.117766] usb: port power management may be unreliable
[    1.150143] fbcon: Taking over console
[    1.150413] Console: switching to colour frame buffer device 240x67
[    1.184474] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.196764] random: fast init done
[    1.230018] systemd[1]: systemd 248.3-3-manjaro running in system mode. (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[    1.244327] systemd[1]: Detected architecture x86-64.
[    1.244919] systemd[1]: Hostname set to <marcos-htpc>.
[    1.340143] random: lvmconfig: uninitialized urandom read (4 bytes read)
[    1.364139] usb 1-4: new full-speed USB device number 2 using xhci_hcd
[    1.374010] systemd[1]: Queued start job for default target Graphical Interface.
[    1.374843] systemd[1]: Created slice system-getty.slice.
[    1.374963] systemd[1]: Created slice system-modprobe.slice.
[    1.375117] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    1.375203] systemd[1]: Created slice User and Session Slice.
[    1.375236] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    1.375260] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    1.375346] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    1.375363] systemd[1]: Reached target Local Encrypted Volumes.
[    1.375371] systemd[1]: Reached target Login Prompts.
[    1.375383] systemd[1]: Reached target Remote File Systems.
[    1.375388] systemd[1]: Reached target Slices.
[    1.375400] systemd[1]: Reached target Local Verity Integrity Protected Volumes.
[    1.375435] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    1.375557] systemd[1]: Listening on LVM2 poll daemon socket.
[    1.376128] systemd[1]: Listening on Process Core Dump Socket.
[    1.376200] systemd[1]: Listening on Journal Audit Socket.
[    1.376249] systemd[1]: Listening on Journal Socket (/dev/log).
[    1.376297] systemd[1]: Listening on Journal Socket.
[    1.376675] systemd[1]: Listening on udev Control Socket.
[    1.376723] systemd[1]: Listening on udev Kernel Socket.
[    1.377162] systemd[1]: Mounting Huge Pages File System...
[    1.377701] systemd[1]: Mounting POSIX Message Queue File System...
[    1.378330] systemd[1]: Mounting Kernel Debug File System...
[    1.379004] systemd[1]: Mounting Kernel Trace File System...
[    1.379657] systemd[1]: Starting Load AppArmor profiles...
[    1.380368] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    1.381117] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    1.381887] systemd[1]: Starting Load Kernel Module configfs...
[    1.382635] systemd[1]: Starting Load Kernel Module drm...
[    1.383468] systemd[1]: Starting Load Kernel Module fuse...
[    1.384080] random: lvm: uninitialized urandom read (4 bytes read)
[    1.384641] systemd[1]: Starting Set Up Additional Binary Formats...
[    1.384718] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    1.386115] systemd[1]: Starting Load Kernel Modules...
[    1.386802] systemd[1]: Starting Remount Root and Kernel File Systems...
[    1.386857] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[    1.387507] systemd[1]: Starting Coldplug All udev Devices...
[    1.388905] systemd[1]: Mounted Huge Pages File System.
[    1.389000] systemd[1]: Mounted POSIX Message Queue File System.
[    1.389091] systemd[1]: Mounted Kernel Debug File System.
[    1.389144] systemd[1]: Mounted Kernel Trace File System.
[    1.389357] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    1.389564] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    1.389712] systemd[1]: Finished Load Kernel Module configfs.
[    1.390322] Linux agpgart interface v0.103
[    1.390568] systemd[1]: Mounting Kernel Configuration File System...
[    1.393358] EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
[    1.395209] systemd[1]: Finished Remount Root and Kernel File Systems.
[    1.395352] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 201 (systemd-binfmt)
[    1.396181] systemd[1]: Activating swap /swapfile...
[    1.397128] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[    1.397197] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[    1.397566] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    1.398329] systemd[1]: Starting Load/Save Random Seed...
[    1.398409] systemd[1]: Condition check resulted in Create System Users being skipped.
[    1.399078] systemd[1]: Starting Create Static Device Nodes in /dev...
[    1.406038] fuse: init (API version 7.32)
[    1.406758] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[    1.408024] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    1.408357] systemd[1]: Finished Load Kernel Module fuse.
[    1.409131] systemd[1]: Finished Set Up Additional Binary Formats.
[    1.412488] systemd[1]: Mounting FUSE Control File System...
[    1.412717] systemd[1]: Mounted Kernel Configuration File System.
[    1.415001] systemd[1]: Finished Create Static Device Nodes in /dev.
[    1.416100] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[    1.417470] systemd[1]: Starting Journal Service...
[    1.418705] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    1.419562] systemd[1]: Mounted FUSE Control File System.
[    1.424613] systemd[1]: Finished Load Kernel Modules.
[    1.424671] audit: type=1130 audit(1626741032.229:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    1.434674] Adding 524284k swap on /swapfile.  Priority:-2 extents:3 across:712700k SSFS
[    1.441652] systemd[1]: Starting Apply Kernel Variables...
[    1.441737] systemd[1]: Activated swap /swapfile.
[    1.444482] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    1.444691] systemd[1]: Finished Load Kernel Module drm.
[    1.444742] audit: type=1130 audit(1626741032.249:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    1.444763] audit: type=1131 audit(1626741032.249:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    1.444886] systemd[1]: Reached target Swap.
[    1.445627] systemd[1]: Mounting Temporary Directory (/tmp)...
[    1.448009] systemd[1]: Mounted Temporary Directory (/tmp).
[    1.454477] systemd[1]: Finished Apply Kernel Variables.
[    1.454521] audit: type=1130 audit(1626741032.259:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    1.458947] systemd[1]: Finished Coldplug All udev Devices.
[    1.458984] audit: type=1130 audit(1626741032.263:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    1.472905] systemd[1]: Started Journal Service.
[    1.473761] audit: type=1130 audit(1626741032.276:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    1.481176] systemd-journald[218]: Received client request to flush runtime journal.
[    1.497514] audit: type=1400 audit(1626741032.299:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=224 comm="apparmor_parser"
[    1.497700] audit: type=1130 audit(1626741032.303:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    1.510663] usb 1-4: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.10
[    1.510667] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.510668] usb 1-4: Product: USB Receiver
[    1.510669] usb 1-4: Manufacturer: Logitech
[    1.530088] audit: type=1130 audit(1626741032.333:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    1.627992] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[    1.644854] usb 2-1: New USB device found, idVendor=1058, idProduct=0748, bcdDevice=10.10
[    1.644857] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[    1.644858] usb 2-1: Product: My Passport 0748
[    1.644860] usb 2-1: Manufacturer: Western Digital
[    1.644861] usb 2-1: SerialNumber: 575842314331323033313133
[    1.674168] tsc: Refined TSC clocksource calibration: 2592.023 MHz
[    1.674174] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x255ccc9c242, max_idle_ns: 440795304150 ns
[    1.674205] clocksource: Switched to clocksource tsc
[    1.695397] random: crng init done
[    1.767482] usb 1-10: new full-speed USB device number 3 using xhci_hcd
[    1.908705] usb 1-10: New USB device found, idVendor=8087, idProduct=0aa7, bcdDevice= 0.01
[    1.908707] usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.030873] usb 2-2: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[    2.048331] usb 2-2: New USB device found, idVendor=0bc2, idProduct=ac36, bcdDevice=17.07
[    2.048335] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.048336] usb 2-2: Product: BUP Portable
[    2.048337] usb 2-2: Manufacturer: Seagate
[    2.048338] usb 2-2: SerialNumber: 00000000NABAMRV7
[    2.239531] intel_pch_thermal 0000:00:12.0: enabling device (0000 -> 0002)
[    2.240298] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[    2.331970] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[    2.340659] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    2.340714] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    2.342700] i2c i2c-0: 1/2 memory slots populated (from DMI)
[    2.395413] intel-spi 0000:00:1f.5: mx25l25635e (32768 Kbytes)
[    2.395490] e1000e: Intel(R) PRO/1000 Network Driver
[    2.395496] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.395758] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    2.404452] Creating 1 MTD partitions on "0000:00:1f.5":
[    2.404455] 0x000000000000-0x000002000000 : "BIOS"
[    2.404681] input: PC Speaker as /devices/platform/pcspkr/input/input3
[    2.405118] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    2.410336] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    2.479809] Intel(R) Wireless WiFi driver for Linux
[    2.479865] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[    2.485744] iwlwifi 0000:01:00.0: loaded firmware version 29.198743027.0 3168-29.ucode op_mode iwlmvm
[    2.526832] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[    2.526834] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    2.526835] RAPL PMU: hw unit of domain package 2^-14 Joules
[    2.526836] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    2.526836] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    2.636998] cryptd: max_cpu_qlen set to 1000
[    2.681459] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 3168, REV=0x220
[    2.681865] AVX2 version of gcm_enc/dec engaged.
[    2.681865] AES CTR mode by8 optimization enabled
[    2.699448] iwlwifi 0000:01:00.0: base HW address: f8:ac:65:07:fe:ea
[    2.737193] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    2.737672] thermal thermal_zone2: failed to read out thermal zone (-61)
[    2.768146] loop: module loaded
[    2.768607] iTCO_vendor_support: vendor-support=0
[    2.791353] iwlwifi 0000:01:00.0 wlp1s0: renamed from wlan0
[    2.812157] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.812932] checking generic (a0000000 1fb0000) vs hw (b0000000 1000000)
[    2.812934] checking generic (a0000000 1fb0000) vs hw (a0000000 10000000)
[    2.812935] fb0: switching to inteldrmfb from EFI VGA
[    2.813065] Console: switching to colour dummy device 80x25
[    2.813097] i915 0000:00:02.0: vgaarb: deactivate vga console
[    2.821268] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    2.822216] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[    2.823098] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[    2.829071] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    2.829111] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[    2.911013] [drm] Initialized i915 1.6.0 20200917 for 0000:00:02.0 on minor 0
[    2.914395] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    2.914685] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4
[    2.931391] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[    2.967497] Registered IR keymap rc-cec
[    2.967538] rc rc0: DP-1 as /devices/pci0000:00/0000:00:02.0/rc/rc0
[    2.967572] input: DP-1 as /devices/pci0000:00/0000:00:02.0/rc/rc0/input5
[    2.992396] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    2.997455] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    3.010825] fbcon: i915drmfb (fb0) is primary device
[    3.040332] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) 18:c0:4d:00:c4:11
[    3.040334] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[    3.040748] e1000e 0000:00:1f.6 eth0: MAC: 13, PHY: 12, PBA No: FFFFFF-0FF
[    3.043765] e1000e 0000:00:1f.6 eno1: renamed from eth0
[    3.053201] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC255: line_outs=1 (0x21/0x0/0x0/0x0/0x0) type:hp
[    3.053202] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.053203] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.053204] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    3.053205] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    3.092821] Console: switching to colour frame buffer device 240x67
[    3.095530] intel_rapl_common: Found RAPL domain package
[    3.095532] intel_rapl_common: Found RAPL domain core
[    3.095533] intel_rapl_common: Found RAPL domain uncore
[    3.095533] intel_rapl_common: Found RAPL domain dram
[    3.122666] snd_hda_codec_hdmi hdaudioC0D2: Monitor plugged-in, Failed to power up codec ret=[-13]
[    3.135691] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input6
[    3.135722] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input7
[    3.135754] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input8
[    3.135779] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input9
[    3.135805] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
[    3.135845] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[    3.146443] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[    3.515658] usb-storage 2-1:1.0: USB Mass Storage device detected
[    3.516114] scsi host1: usb-storage 2-1:1.0
[    3.516319] usbcore: registered new interface driver usb-storage
[    3.526339] scsi host2: uas
[    3.526707] usbcore: registered new interface driver uas
[    3.526948] scsi 2:0:0:0: Direct-Access     Seagate  BUP Portable     1707 PQ: 0 ANSI: 6
[    3.528960] sd 2:0:0:0: Attached scsi generic sg0 type 0
[    3.529615] sd 2:0:0:0: [sda] 9767541167 512-byte logical blocks: (5.00 TB/4.55 TiB)
[    3.529620] sd 2:0:0:0: [sda] 4096-byte physical blocks
[    3.529781] sd 2:0:0:0: [sda] Write Protect is off
[    3.529786] sd 2:0:0:0: [sda] Mode Sense: 03 00 00 00
[    3.530099] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.530407] sd 2:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
[    3.581371] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:046D:C52B.0001/input/input12
[    3.625511] Bluetooth: Core ver 2.22
[    3.625565] NET: Registered protocol family 31
[    3.625566] Bluetooth: HCI device and connection manager initialized
[    3.625571] Bluetooth: HCI socket layer initialized
[    3.625573] Bluetooth: L2CAP socket layer initialized
[    3.625577] Bluetooth: SCO socket layer initialized
[    3.633949] usbcore: registered new interface driver btusb
[    3.637759] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-4/input0
[    3.639606] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:046D:C52B.0002/input/input13
[    3.639694] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:046D:C52B.0002/input/input14
[    3.644011] Bluetooth: hci0: read Intel version: 370810225019140f34
[    3.644012] Bluetooth: hci0: Intel device is already patched. patch num: 34
[    3.651321] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.651322] Bluetooth: BNEP filters: protocol multicast
[    3.651325] Bluetooth: BNEP socket layer initialized
[    3.694511] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:046D:C52B.0002/input/input15
[    3.694946] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-4/input1
[    3.696962] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-4/input2
[    3.697089] usbcore: registered new interface driver usbhid
[    3.697093] usbhid: USB HID core driver
[    3.713354] NET: Registered protocol family 38
[    3.865206] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-4/input2
[    3.980256] input: Logitech Wireless Device PID:4024 Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input17
[    3.980380] input: Logitech Wireless Device PID:4024 Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input18
[    3.980434] input: Logitech Wireless Device PID:4024 Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input19
[    3.980476] hid-generic 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4024] on usb-0000:00:14.0-4/input2:1
[    3.991187] mousedev: PS/2 mouse device common for all mice
[    4.027179]  sda: sda1 sda2
[    4.028549] sd 2:0:0:0: [sda] Attached SCSI disk
[    4.174111] input: Logitech K400 as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input23
[    4.174401] logitech-hidpp-device 0003:046D:4024.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400] on usb-0000:00:14.0-4/input2:1
[    4.528619] scsi 1:0:0:0: Direct-Access     WD       My Passport 0748 1010 PQ: 0 ANSI: 6
[    4.529119] scsi 1:0:0:1: Enclosure         WD       SES Device       1010 PQ: 0 ANSI: 6
[    4.531420] scsi 1:0:0:0: Attached scsi generic sg1 type 0
[    4.531931] scsi 1:0:0:1: Attached scsi generic sg2 type 13
[    4.534624] sd 1:0:0:0: [sdb] 1953458176 512-byte logical blocks: (1.00 TB/931 GiB)
[    4.534895] sd 1:0:0:0: [sdb] Write Protect is off
[    4.534899] sd 1:0:0:0: [sdb] Mode Sense: 47 00 10 08
[    4.535182] sd 1:0:0:0: [sdb] No Caching mode page found
[    4.535187] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[    4.552832]  sdb: sdb1
[    4.553588] sd 1:0:0:0: [sdb] Attached SCSI disk
[    4.556697] scsi 1:0:0:1: Wrong diagnostic page; asked for 1 got 8
[    4.556703] scsi 1:0:0:1: Failed to get diagnostic page 0x1
[    4.556705] scsi 1:0:0:1: Failed to bind enclosure -19
[    4.556716] ses 1:0:0:1: Attached Enclosure device
[    5.683301] kauditd_printk_skb: 53 callbacks suppressed
[    5.683302] audit: type=1130 audit(1626741036.484:64): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.824656] audit: type=1130 audit(1626741036.627:65): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.833129] audit: type=1334 audit(1626741036.634:66): prog-id=17 op=LOAD
[    5.834251] audit: type=1334 audit(1626741036.637:67): prog-id=18 op=LOAD
[    5.870934] Bluetooth: RFCOMM TTY layer initialized
[    5.870964] Bluetooth: RFCOMM socket layer initialized
[    5.870995] Bluetooth: RFCOMM ver 1.11
[    6.032953] audit: type=1130 audit(1626741036.834:68): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    7.547695] wlp1s0: authenticate with 34:6b:46:69:ce:b3
[    7.552556] wlp1s0: send auth to 34:6b:46:69:ce:b3 (try 1/3)
[    7.556726] wlp1s0: authenticated
[    7.557532] wlp1s0: associate with 34:6b:46:69:ce:b3 (try 1/3)
[    7.561184] wlp1s0: RX AssocResp from 34:6b:46:69:ce:b3 (capab=0x411 status=0 aid=4)
[    7.561706] wlp1s0: associated
[    7.601582] IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
[    7.610908] wlp1s0: Limiting TX power to 27 (30 - 3) dBm as advertised by 34:6b:46:69:ce:b3
[    7.878146] audit: type=1131 audit(1626741038.681:69): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.643371] audit: type=1131 audit(1626741039.447:70): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   12.052010] logitech-hidpp-device 0003:046D:4024.0004: HID++ 2.0 device connected.
[   13.022610] audit: type=1131 audit(1626741043.824:71): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   33.686458] audit: type=1131 audit(1626741064.487:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   33.767753] audit: type=1334 audit(1626741064.574:73): prog-id=15 op=UNLOAD
[   33.767766] audit: type=1334 audit(1626741064.574:74): prog-id=14 op=UNLOAD
[   33.767773] audit: type=1334 audit(1626741064.574:75): prog-id=13 op=UNLOAD
[   91.191245] audit: type=1100 audit(1626741121.994:76): pid=1332 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="marcos" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[   91.192224] audit: type=1101 audit(1626741121.994:77): pid=1332 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="marcos" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[   91.192398] audit: type=1110 audit(1626741121.994:78): pid=1332 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[   91.194721] audit: type=1105 audit(1626741121.997:79): pid=1332 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[   91.216371] audit: type=1106 audit(1626741122.017:80): pid=1332 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[   91.216444] audit: type=1104 audit(1626741122.017:81): pid=1332 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  484.243030] audit: type=1100 audit(1626741515.044:82): pid=2152 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="marcos" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  484.246132] audit: type=1101 audit(1626741515.047:83): pid=2152 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="marcos" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  484.246722] audit: type=1110 audit(1626741515.047:84): pid=2152 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  484.253197] audit: type=1105 audit(1626741515.054:85): pid=2152 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  484.280548] audit: type=1106 audit(1626741515.081:86): pid=2152 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  484.280614] audit: type=1104 audit(1626741515.081:87): pid=2152 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[  918.765321] audit: type=1130 audit(1626741949.567:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  918.765325] audit: type=1131 audit(1626741949.567:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2233.980077] audit: type=1100 audit(1626743264.781:90): pid=4688 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="marcos" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 2233.983430] audit: type=1101 audit(1626743264.784:91): pid=4688 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="marcos" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 2233.984064] audit: type=1110 audit(1626743264.787:92): pid=4688 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 2233.990076] audit: type=1105 audit(1626743264.791:93): pid=4688 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
also
$sudo dmesg | grep usb
Same as above, but pared down:
$sudo dmesg --level emerg,alert,crit,err,warn
Journal logs:
$ journalctl --catalog --priority=3 --boot=-1
-- Journal begins at Mon 2021-07-19 12:45:26 MDT, ends at Mon 2021-07-19 19:16:59 MDT. --
Jul 19 18:23:20 marcos-htpc kernel: snd_hda_codec_hdmi hdaudioC0D2: Monitor plugged-in, Failed to power up codec ret=[-13]
Jul 19 18:23:22 marcos-htpc kernel: sd 1:0:0:0: [sdb] No Caching mode page found
Jul 19 18:23:22 marcos-htpc kernel: sd 1:0:0:0: [sdb] Assuming drive cache: write through
Jul 19 18:23:22 marcos-htpc kernel: scsi 1:0:0:1: Wrong diagnostic page; asked for 1 got 8
Jul 19 18:23:22 marcos-htpc kernel: scsi 1:0:0:1: Failed to get diagnostic page 0x1
Jul 19 18:23:22 marcos-htpc kernel: scsi 1:0:0:1: Failed to bind enclosure -19
Jul 19 18:30:09 marcos-htpc pulseaudio[892]: Error opening PCM device front:0: No such file or directory
Jul 19 18:30:09 marcos-htpc pulseaudio[892]: Error opening PCM device hdmi:0: No such file or directory
Current session logs:
 $cat /var/log/Xorg.0.log
[     3.294] (--) Log file renamed from "/var/log/Xorg.pid-641.log" to "/var/log/Xorg.0.log"
[     3.295]
X.Org X Server 1.20.11
[     3.295] Build Operating System: Linux Manjaro Linux
[     3.295] Current Operating System: Linux marcos-htpc 5.10.49-1-MANJARO #1 SMP PREEMPT Sun Jul 11 12:59:43 UTC 2021 x86_64
[     3.295] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=a4665344-f763-460c-9214-f13ee0118b11 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[     3.295] Build Date: 13 April 2021  04:11:08PM
[     3.295]
[     3.295] Current version of pixman: 0.40.0
[     3.295] 	Before reporting problems, check http://wiki.x.org
[     3.295] Markers: (--) probed, (**) from config file, (==) default setting,
[     3.295] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jul 19 18:30:34 2021
[     3.295] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     3.295] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     3.296] (==) No Layout section.  Using the first Screen section.
[     3.296] (==) No screen section available. Using defaults.
[     3.296] (**) |-->Screen "Default Screen Section" (0)
[     3.296] (**) |   |-->Monitor "<default monitor>"
[     3.296] (==) No monitor specified for screen "Default Screen Section".
[     3.296] (==) Automatically adding devices
[     3.296] (==) Automatically enabling devices
[     3.296] (==) Automatically adding GPU devices
[     3.296] (==) Automatically binding GPU devices
[     3.296] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     3.297] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     3.297] 	Entry deleted from font path.
[     3.297] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     3.297] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     3.297] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     3.297] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     3.297] (==) ModulePath set to "/usr/lib/xorg/modules"
[     3.297] (II) The server relies on udev to provide the list of input devices.
[     3.297] (II) Module ABI versions:
[     3.297] 	X.Org ANSI C Emulation: 0.4
[     3.297] 	X.Org Video Driver: 24.1
[     3.297] 	X.Org XInput driver : 24.1
[     3.297] 	X.Org Server Extension : 10.0
[     3.297] (++) using VT number 1
[     3.297] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     3.298] (II) xfree86: Adding drm device (/dev/dri/card0)
[     3.420] (--) PCI:*(0@0:2:0) 8086:9b41:1458:1000 rev 2, Mem @ 0xb0000000/16777216, 0xa0000000/268435456, I/O @ 0x00003000/64, BIOS @ 0x????????/131072
[     3.420] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     3.420] (II) LoadModule: "glx"
[     3.422] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     3.427] (II) Module glx: vendor="X.Org Foundation"
[     3.427] 	compiled for 1.20.11, module version = 1.0.0
[     3.427] 	ABI class: X.Org Server Extension, version 10.0
[     3.427] (==) Matched intel as autoconfigured driver 0
[     3.427] (==) Matched modesetting as autoconfigured driver 1
[     3.427] (==) Matched fbdev as autoconfigured driver 2
[     3.427] (==) Matched vesa as autoconfigured driver 3
[     3.427] (==) Assigned the driver to the xf86ConfigLayout
[     3.427] (II) LoadModule: "intel"
[     3.428] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[     3.429] (II) Module intel: vendor="X.Org Foundation"
[     3.429] 	compiled for 1.20.10, module version = 2.99.917
[     3.429] 	Module class: X.Org Video Driver
[     3.429] 	ABI class: X.Org Video Driver, version 24.1
[     3.429] (II) LoadModule: "modesetting"
[     3.430] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     3.431] (II) Module modesetting: vendor="X.Org Foundation"
[     3.431] 	compiled for 1.20.11, module version = 1.20.11
[     3.431] 	Module class: X.Org Video Driver
[     3.431] 	ABI class: X.Org Video Driver, version 24.1
[     3.431] (II) LoadModule: "fbdev"
[     3.431] (WW) Warning, couldn't open module fbdev
[     3.431] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     3.431] (II) LoadModule: "vesa"
[     3.431] (WW) Warning, couldn't open module vesa
[     3.431] (EE) Failed to load module "vesa" (module does not exist, 0)
[     3.431] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[     3.432] (II) intel: Driver for Intel(R) HD Graphics
[     3.432] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[     3.432] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[     3.432] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     3.432] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20200917
[     3.432] (II) intel(0): SNA compiled from 2.99.917-916-g31486f40
[     3.433] (WW) Falling back to old probe method for modesetting
[     3.433] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics
[     3.433] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 2 threads
[     3.433] (II) intel(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[     3.433] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[     3.433] (==) intel(0): RGB weight 888
[     3.433] (==) intel(0): Default visual is TrueColor
[     3.434] (II) intel(0): Output DP1 has no monitor section
[     3.434] (II) intel(0): Enabled output DP1
[     3.434] (II) intel(0): Output DP2 has no monitor section
[     3.434] (II) intel(0): Enabled output DP2
[     3.434] (II) intel(0): Output DP3 has no monitor section
[     3.434] (II) intel(0): Enabled output DP3
[     3.434] (II) intel(0): Output HDMI1 has no monitor section
[     3.434] (II) intel(0): Enabled output HDMI1
[     3.434] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[     3.434] (II) intel(0): Output VIRTUAL1 has no monitor section
[     3.434] (II) intel(0): Enabled output VIRTUAL1
[     3.435] (--) intel(0): Output DP1 using initial mode 3840x2160 on pipe 0
[     3.435] (==) intel(0): TearFree enabled
[     3.435] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[     3.435] (==) intel(0): DPI set to (96, 96)
[     3.435] (II) Loading sub module "dri3"
[     3.435] (II) LoadModule: "dri3"
[     3.435] (II) Module "dri3" already built-in
[     3.435] (II) Loading sub module "dri2"
[     3.435] (II) LoadModule: "dri2"
[     3.435] (II) Module "dri2" already built-in
[     3.435] (II) Loading sub module "present"
[     3.435] (II) LoadModule: "present"
[     3.435] (II) Module "present" already built-in
[     3.435] (II) UnloadModule: "modesetting"
[     3.435] (II) Unloading modesetting
[     3.436] (II) intel(0): SNA initialized with Coffeelake (gen9) backend
[     3.436] (==) intel(0): Backing store enabled
[     3.436] (==) intel(0): Silken mouse disabled
[     3.436] (II) intel(0): HW Cursor enabled
[     3.436] (==) intel(0): DPMS enabled
[     3.436] (==) intel(0): Display hotplug detection enabled
[     3.436] (II) intel(0): [DRI2] Setup complete
[     3.436] (II) intel(0): [DRI2]   DRI driver: i965
[     3.436] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[     3.436] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[     3.436] (II) intel(0): hardware support for Present enabled
[     3.436] (II) Initializing extension Generic Event Extension
[     3.437] (II) Initializing extension SHAPE
[     3.437] (II) Initializing extension MIT-SHM
[     3.437] (II) Initializing extension XInputExtension
[     3.437] (II) Initializing extension XTEST
[     3.438] (II) Initializing extension BIG-REQUESTS
[     3.438] (II) Initializing extension SYNC
[     3.438] (II) Initializing extension XKEYBOARD
[     3.438] (II) Initializing extension XC-MISC
[     3.438] (II) Initializing extension SECURITY
[     3.439] (II) Initializing extension XFIXES
[     3.439] (II) Initializing extension RENDER
[     3.439] (II) Initializing extension RANDR
[     3.439] (II) Initializing extension COMPOSITE
[     3.440] (II) Initializing extension DAMAGE
[     3.440] (II) Initializing extension MIT-SCREEN-SAVER
[     3.440] (II) Initializing extension DOUBLE-BUFFER
[     3.440] (II) Initializing extension RECORD
[     3.440] (II) Initializing extension DPMS
[     3.440] (II) Initializing extension Present
[     3.441] (II) Initializing extension DRI3
[     3.441] (II) Initializing extension X-Resource
[     3.441] (II) Initializing extension XVideo
[     3.441] (II) Initializing extension XVideo-MotionCompensation
[     3.441] (II) Initializing extension GLX
[     3.476] (II) AIGLX: Loaded and initialized i965
[     3.476] (II) GLX: Initialized DRI2 GL provider for screen 0
[     3.476] (II) Initializing extension XFree86-VidModeExtension
[     3.476] (II) Initializing extension XFree86-DGA
[     3.477] (II) Initializing extension XFree86-DRI
[     3.477] (II) Initializing extension DRI2
[     3.503] (II) intel(0): switch to mode 3840x2160@30.0 on DP1 using pipe 0, position (0, 0), rotation normal, reflection none
[     3.518] (II) intel(0): Setting screen physical size to 1016 x 571
[     3.592] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[     3.593] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     3.593] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     3.593] (**) Power Button: Applying InputClass "system-keyboard"
[     3.593] (II) LoadModule: "libinput"
[     3.593] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     3.595] (II) Module libinput: vendor="X.Org Foundation"
[     3.595] 	compiled for 1.20.11, module version = 1.1.0
[     3.595] 	Module class: X.Org XInput Driver
[     3.595] 	ABI class: X.Org XInput driver, version 24.1
[     3.595] (II) Using input driver 'libinput' for 'Power Button'
[     3.595] (**) Power Button: always reports core events
[     3.595] (**) Option "Device" "/dev/input/event2"
[     3.595] (**) Option "_source" "server/udev"
[     3.597] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     3.597] (II) event2  - Power Button: device is a keyboard
[     3.597] (II) event2  - Power Button: device removed
[     3.619] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[     3.619] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     3.620] (**) Option "xkb_layout" "us"
[     3.620] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     3.620] (II) event2  - Power Button: device is a keyboard
[     3.621] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[     3.621] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     3.621] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     3.621] (**) Video Bus: Applying InputClass "system-keyboard"
[     3.621] (II) Using input driver 'libinput' for 'Video Bus'
[     3.621] (**) Video Bus: always reports core events
[     3.621] (**) Option "Device" "/dev/input/event4"
[     3.621] (**) Option "_source" "server/udev"
[     3.621] (II) event4  - Video Bus: is tagged by udev as: Keyboard
[     3.622] (II) event4  - Video Bus: device is a keyboard
[     3.622] (II) event4  - Video Bus: device removed
[     3.653] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4/event4"
[     3.653] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[     3.653] (**) Option "xkb_layout" "us"
[     3.655] (II) event4  - Video Bus: is tagged by udev as: Keyboard
[     3.655] (II) event4  - Video Bus: device is a keyboard
[     3.656] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     3.656] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     3.656] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     3.656] (**) Power Button: Applying InputClass "system-keyboard"
[     3.656] (II) Using input driver 'libinput' for 'Power Button'
[     3.656] (**) Power Button: always reports core events
[     3.656] (**) Option "Device" "/dev/input/event1"
[     3.656] (**) Option "_source" "server/udev"
[     3.658] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     3.658] (II) event1  - Power Button: device is a keyboard
[     3.658] (II) event1  - Power Button: device removed
[     3.687] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[     3.687] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[     3.687] (**) Option "xkb_layout" "us"
[     3.690] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     3.690] (II) event1  - Power Button: device is a keyboard
[     3.692] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[     3.692] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[     3.692] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[     3.692] (**) Sleep Button: Applying InputClass "system-keyboard"
[     3.692] (II) Using input driver 'libinput' for 'Sleep Button'
[     3.692] (**) Sleep Button: always reports core events
[     3.692] (**) Option "Device" "/dev/input/event0"
[     3.692] (**) Option "_source" "server/udev"
[     3.694] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[     3.694] (II) event0  - Sleep Button: device is a keyboard
[     3.694] (II) event0  - Sleep Button: device removed
[     3.711] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[     3.711] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[     3.711] (**) Option "xkb_layout" "us"
[     3.714] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[     3.714] (II) event0  - Sleep Button: device is a keyboard
[     3.717] (II) config/udev: Adding input device DP-1 (/dev/input/event5)
[     3.717] (**) DP-1: Applying InputClass "evdev keyboard catchall"
[     3.717] (**) DP-1: Applying InputClass "libinput keyboard catchall"
[     3.717] (**) DP-1: Applying InputClass "system-keyboard"
[     3.717] (II) Using input driver 'libinput' for 'DP-1'
[     3.717] (**) DP-1: always reports core events
[     3.717] (**) Option "Device" "/dev/input/event5"
[     3.717] (**) Option "_source" "server/udev"
[     3.720] (II) event5  - DP-1: is tagged by udev as: Keyboard Pointingstick
[     3.721] (II) event5  - DP-1: device is a pointer
[     3.721] (II) event5  - DP-1: device is a keyboard
[     3.722] (II) event5  - DP-1: device removed
[     3.730] (II) libinput: DP-1: needs a virtual subdevice
[     3.730] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/rc/rc0/input5/event5"
[     3.730] (II) XINPUT: Adding extended input device "DP-1" (type: MOUSE, id 10)
[     3.730] (**) Option "AccelerationScheme" "none"
[     3.730] (**) DP-1: (accel) selected scheme none/0
[     3.730] (**) DP-1: (accel) acceleration factor: 2.000
[     3.730] (**) DP-1: (accel) acceleration threshold: 4
[     3.733] (II) event5  - DP-1: is tagged by udev as: Keyboard Pointingstick
[     3.733] (II) event5  - DP-1: device is a pointer
[     3.734] (II) event5  - DP-1: device is a keyboard
[     3.736] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event10)
[     3.736] (II) No input driver specified, ignoring this device.
[     3.736] (II) This device may have been added with another device file.
[     3.737] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event11)
[     3.738] (II) No input driver specified, ignoring this device.
[     3.738] (II) This device may have been added with another device file.
[     3.739] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event6)
[     3.739] (II) No input driver specified, ignoring this device.
[     3.739] (II) This device may have been added with another device file.
[     3.740] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event7)
[     3.740] (II) No input driver specified, ignoring this device.
[     3.740] (II) This device may have been added with another device file.
[     3.741] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event8)
[     3.741] (II) No input driver specified, ignoring this device.
[     3.741] (II) This device may have been added with another device file.
[     3.742] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event9)
[     3.742] (II) No input driver specified, ignoring this device.
[     3.742] (II) This device may have been added with another device file.
[     3.743] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[     3.743] (II) No input driver specified, ignoring this device.
[     3.743] (II) This device may have been added with another device file.
[     3.785] (**) DP-1: Applying InputClass "evdev keyboard catchall"
[     3.785] (**) DP-1: Applying InputClass "libinput keyboard catchall"
[     3.785] (**) DP-1: Applying InputClass "system-keyboard"
[     3.785] (II) Using input driver 'libinput' for 'DP-1'
[     3.785] (**) DP-1: always reports core events
[     3.785] (**) Option "Device" "/dev/input/event5"
[     3.785] (**) Option "_source" "_driver/libinput"
[     3.785] (II) libinput: DP-1: is a virtual subdevice
[     3.785] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/rc/rc0/input5/event5"
[     3.785] (II) XINPUT: Adding extended input device "DP-1" (type: KEYBOARD, id 11)
[     3.785] (**) Option "xkb_layout" "us"
[     4.242] (II) config/udev: Adding input device Logitech K400 (/dev/input/mouse0)
[     4.242] (**) Logitech K400: Applying InputClass "system-keyboard"
[     4.242] (II) No input driver specified, ignoring this device.
[     4.242] (II) This device may have been added with another device file.
[     4.273] (II) config/udev: Adding input device Logitech K400 (/dev/input/event12)
[     4.273] (**) Logitech K400: Applying InputClass "evdev pointer catchall"
[     4.273] (**) Logitech K400: Applying InputClass "evdev keyboard catchall"
[     4.273] (**) Logitech K400: Applying InputClass "libinput pointer catchall"
[     4.273] (**) Logitech K400: Applying InputClass "libinput keyboard catchall"
[     4.273] (**) Logitech K400: Applying InputClass "system-keyboard"
[     4.273] (II) Using input driver 'libinput' for 'Logitech K400'
[     4.273] (**) Logitech K400: always reports core events
[     4.273] (**) Option "Device" "/dev/input/event12"
[     4.273] (**) Option "_source" "server/udev"
[     4.274] (II) event12 - Logitech K400: is tagged by udev as: Keyboard Mouse
[     4.274] (II) event12 - Logitech K400: device is a pointer
[     4.274] (II) event12 - Logitech K400: device is a keyboard
[     4.274] (II) event12 - Logitech K400: device removed
[     4.280] (II) libinput: Logitech K400: needs a virtual subdevice
[     4.280] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input23/event12"
[     4.280] (II) XINPUT: Adding extended input device "Logitech K400" (type: MOUSE, id 12)
[     4.280] (**) Option "AccelerationScheme" "none"
[     4.280] (**) Logitech K400: (accel) selected scheme none/0
[     4.280] (**) Logitech K400: (accel) acceleration factor: 2.000
[     4.280] (**) Logitech K400: (accel) acceleration threshold: 4
[     4.281] (II) event12 - Logitech K400: is tagged by udev as: Keyboard Mouse
[     4.281] (II) event12 - Logitech K400: device is a pointer
[     4.281] (II) event12 - Logitech K400: device is a keyboard
[     4.281] (**) Logitech K400: Applying InputClass "evdev pointer catchall"
[     4.281] (**) Logitech K400: Applying InputClass "evdev keyboard catchall"
[     4.281] (**) Logitech K400: Applying InputClass "libinput pointer catchall"
[     4.281] (**) Logitech K400: Applying InputClass "libinput keyboard catchall"
[     4.281] (**) Logitech K400: Applying InputClass "system-keyboard"
[     4.281] (II) Using input driver 'libinput' for 'Logitech K400'
[     4.281] (**) Logitech K400: always reports core events
[     4.281] (**) Option "Device" "/dev/input/event12"
[     4.281] (**) Option "_source" "_driver/libinput"
[     4.281] (II) libinput: Logitech K400: is a virtual subdevice
[     4.281] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.2/0003:046D:C52B.0003/0003:046D:4024.0004/input/input23/event12"
[     4.281] (II) XINPUT: Adding extended input device "Logitech K400" (type: KEYBOARD, id 13)
[     4.281] (**) Option "xkb_layout" "us"
[     5.038] (II) intel(0): EDID vendor "SAM", prod id 4078
[     5.038] (II) intel(0): Using EDID range info for horizontal sync
[     5.038] (II) intel(0): Using EDID range info for vertical refresh
[     5.038] (II) intel(0): Printing DDC gathered Modelines:
[     5.038] (II) intel(0): Modeline "3840x2160"x0.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.5 kHz eP)
[     5.038] (II) intel(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[     5.038] (II) intel(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[     5.038] (II) intel(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     5.038] (II) intel(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     5.038] (II) intel(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[     5.038] (II) intel(0): Modeline "1920x1080i"x0.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[     5.038] (II) intel(0): Modeline "1920x1080i"x0.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[     5.038] (II) intel(0): Modeline "1920x1080"x0.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     5.038] (II) intel(0): Modeline "1920x1080"x0.0   74.25  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[     5.038] (II) intel(0): Modeline "1920x1080"x0.0   74.25  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[     5.038] (II) intel(0): Modeline "1440x480i"x0.0   27.00  1440 1478 1602 1716  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[     5.038] (II) intel(0): Modeline "1440x576i"x0.0   27.00  1440 1464 1590 1728  576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[     5.038] (II) intel(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     5.038] (II) intel(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     5.038] (II) intel(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     5.038] (II) intel(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[     5.038] (II) intel(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[     5.038] (II) intel(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[     5.038] (II) intel(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     5.038] (II) intel(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[     5.038] (II) intel(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[     5.038] (II) intel(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[     5.038] (II) intel(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[     5.038] (II) intel(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     5.038] (II) intel(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[     5.038] (II) intel(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[     5.038] (II) intel(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[     5.038] (II) intel(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     5.038] (II) intel(0): Modeline "1280x800"x0.0   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[     5.038] (II) intel(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     5.038] (II) intel(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[     5.038] (II) intel(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
[     5.038] (II) intel(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[     5.038] (--) intel(0): HDMI max TMDS frequency 300000KHz
[     5.936] (--) intel(0): HDMI max TMDS frequency 300000KHz
[     6.031] (II) intel(0): switch to mode 1920x1080@30.0 on DP1 using pipe 0, position (0, 0), rotation normal, reflection none
[     6.141] (II) intel(0): resizing framebuffer to 1920x1080
[    31.220] (--) intel(0): HDMI max TMDS frequency 300000KHz
[   174.855] (EE) event12 - Logitech K400: client bug: event processing lagging behind by 31ms, your system is too slow
[   247.762] (EE) event12 - Logitech K400: client bug: event processing lagging behind by 15ms, your system is too slow
[   491.644] (EE) event12 - Logitech K400: client bug: event processing lagging behind by 17ms, your system is too slow
[   772.107] (EE) event12 - Logitech K400: client bug: event processing lagging behind by 11ms, your system is too slow
[   773.879] (EE) event12 - Logitech K400: client bug: event processing lagging behind by 13ms, your system is too slow
[   773.879] (EE) event12 - Logitech K400: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
What additional information can I provide that might be helpful?
