New potential Kernel/GPU issue after recent system update
After rebooting from the latest system update which included Linux (6.18.12-1 → 6.18.18-1), firmware updates, and Vulkan library updates, I am observing a new Kernel issue which recurrs 2 or more time per day. Here is the relevant system journal entry for the latest occurence
Mar 27 12:21:34 b85m-lxdt kernel: ------------[ cut here ]------------
Mar 27 12:21:34 b85m-lxdt kernel: atomic remove_fb failed with -22
Mar 27 12:21:34 b85m-lxdt kernel: WARNING: CPU: 1 PID: 384069 at drivers/gpu/drm/drm_framebuffer.c:1176 drm_framebuffer_remove+0x575/0x590
Mar 27 12:21:34 b85m-lxdt kernel: Modules linked in: cmac ccm nls_utf8 cifs nls_ucs2_utils rdma_cm iw_cm ib_cm ib_core libarc4 cifs_md4 dns_resolver netfs snd_seq_dummy snd_hrtimer snd_seq xfs vfat fat intel_rapl_msr intel_rapl_common x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel snd_hda_codec_alc882 snd_hda_codec_atihdmi at24 mei_hdcp mei_pxp snd_hda_codec_realtek_lib ppdev snd_hda_codec_generic snd_hda_codec_hdmi kvm snd_hda_intel irqbypass snd_hda_codec snd_usb_audio polyval_clmulni snd_hda_core r8169 ghash_clmulni_intel snd_usbmidi_lib snd_intel_dspcfg aesni_intel i2c_i801 snd_ump realtek snd_intel_sdw_acpi rapl snd_rawmidi spi_nor intel_cstate mdio_devres snd_hwdep snd_seq_device i2c_smbus iTCO_wdt intel_uncore mei_me i2c_mux snd_pcm intel_pmc_bxt libphy mtd pcspkr snd_timer mei mc mdio_bus iTCO_vendor_support snd soundcore intel_oc_wdt parport_pc parport joydev mousedev mac_hid cfg80211 rfkill ip6t_REJECT nf_reject_ipv6 xt_hl ip6t_rt ipt_REJECT nf_reject_ipv4 xt_LOG nf_log_syslog xt_limit xt_addrtype xt_tcpudp xt_conntrack
Mar 27 12:21:34 b85m-lxdt kernel:  nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 ip6table_filter ip6_tables iptable_filter ip_tables x_tables dm_mod crypto_user nfnetlink hid_jabra amdgpu spi_intel_platform spi_intel amdxcp i2c_algo_bit drm_ttm_helper ttm drm_exec drm_panel_backlight_quirks gpu_sched drm_suballoc_helper sr_mod drm_buddy cdrom drm_display_helper video cec wmi lpc_ich
Mar 27 12:21:34 b85m-lxdt kernel: CPU: 1 UID: 0 PID: 384069 Comm: kworker/1:5 Tainted: G        W           6.18.18-1-MANJARO #1 PREEMPT(full)  f3f3509c1a7837237e85ac9a93e17af2cc71ec8f
Mar 27 12:21:34 b85m-lxdt kernel: Tainted: [W]=WARN
Mar 27 12:21:34 b85m-lxdt kernel: Hardware name: Gigabyte Technology Co., Ltd. B85M-DS3H-A/B85M-DS3H-A, BIOS F3 06/23/2017
Mar 27 12:21:34 b85m-lxdt kernel: Workqueue: events drm_mode_rmfb_work_fn
Mar 27 12:21:34 b85m-lxdt kernel: RIP: 0010:drm_framebuffer_remove+0x575/0x590
Mar 27 12:21:34 b85m-lxdt kernel: Code: 27 eb d6 48 8d 7c 24 18 e8 48 e7 00 00 48 8d 7c 24 18 e8 fe e4 00 00 b9 f4 ff ff ff 89 ce 48 c7 c7 f8 91 3f a6 e8 cb 41 4c ff <0f> 0b e9 fd fc ff ff 31 ff eb 9b e8 bb 97 52 00 66 66 2e 0f 1f 84
Mar 27 12:21:34 b85m-lxdt kernel: RSP: 0018:ffffcda488bcbda0 EFLAGS: 00010246
Mar 27 12:21:34 b85m-lxdt kernel: RAX: 0000000000000000 RBX: ffff8c4bfe193d00 RCX: 0000000000000027
Mar 27 12:21:34 b85m-lxdt kernel: RDX: ffff8c4e8ec9d008 RSI: 0000000000000001 RDI: ffff8c4e8ec9d000
Mar 27 12:21:34 b85m-lxdt kernel: RBP: ffff8c4b07636300 R08: 0000000000000000 R09: 00000000ffffefff
Mar 27 12:21:34 b85m-lxdt kernel: R10: ffffffffa6c61440 R11: ffffcda488bcbc38 R12: ffff8c4b8bf00010
Mar 27 12:21:34 b85m-lxdt kernel: R13: ffff8c4b8bf002c0 R14: 00000000ffffffea R15: 0000000000000000
Mar 27 12:21:34 b85m-lxdt kernel: FS:  0000000000000000(0000) GS:ffff8c4ee736d000(0000) knlGS:0000000000000000
Mar 27 12:21:34 b85m-lxdt kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Mar 27 12:21:34 b85m-lxdt kernel: CR2: 00007f6e18c5ee88 CR3: 000000040a726002 CR4: 00000000001726f0
Mar 27 12:21:34 b85m-lxdt kernel: Call Trace:
Mar 27 12:21:34 b85m-lxdt kernel:  <TASK>
Mar 27 12:21:34 b85m-lxdt kernel:  drm_mode_rmfb_work_fn+0x7e/0xa0
Mar 27 12:21:34 b85m-lxdt kernel:  process_one_work+0x193/0x350
Mar 27 12:21:34 b85m-lxdt kernel:  worker_thread+0x1a1/0x310
Mar 27 12:21:34 b85m-lxdt kernel:  ? __pfx_worker_thread+0x10/0x10
Mar 27 12:21:34 b85m-lxdt kernel:  kthread+0xfc/0x240
Mar 27 12:21:34 b85m-lxdt kernel:  ? __pfx_kthread+0x10/0x10
Mar 27 12:21:34 b85m-lxdt kernel:  ret_from_fork+0x22d/0x260
Mar 27 12:21:34 b85m-lxdt kernel:  ret_from_fork_asm+0x1a/0x30
Mar 27 12:21:34 b85m-lxdt kernel:  </TASK>
Mar 27 12:21:34 b85m-lxdt kernel: ---[ end trace 0000000000000000 ]---
System info (from inxi)
  Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=bdda48f9-bcbb-4fe0-869c-30ab3eabe248 rw udev.log_level=3
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.51 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: avail: light-locker vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop Mobo: Gigabyte model: B85M-DS3H-A serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends v: F3
    date: 06/23/2017
  System RAM: total: 16 GiB available: 15.58 GiB used: 3.05 GiB (19.6%)
  Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: no module installed
  Device-2: ChannelA-DIMM1 type: DDR3 detail: synchronous size: 8 GiB
    speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Chips and Technologies part-no: F3-1600C9-8GXM serial: N/A
  Device-3: ChannelB-DIMM0 type: no module installed
  Device-4: ChannelB-DIMM1 type: DDR3 detail: synchronous size: 8 GiB
  Info: model: Intel Core i5-4590S bits: 64 type: MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 874 min/max: 800/3700 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 874 2: 874 3: 874 4: 874 bogomips: 23944
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
    fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
    rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xsave xsaveopt xtopology xtpr
    * Info can be provided if needed *
  Device-1: Advanced Micro Devices [AMD/ATI] Lexa PRO [Radeon
    540/540X/550/550X / RX 540X/550/550X] vendor: Micro-Star MSI
    driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm
    built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 8 ports: active: DVI-D-1
    empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 1002:699f class-ID: 0300
    temp: 28.0 C
  Display: x11 server: X.Org v: 21.1.21 compositor: xfwm4 v: 4.20.0 driver:
    X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
    s-diag: 584mm (22.99")
  Monitor-1: DVI-D-1 mapped: DVI-D-0 model: Dell E2314H serial: <filter>
    built: 2013 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 gamma: 1.2
    chroma: red: x: 0.639 y: 0.333 green: x: 0.310 y: 0.627 blue: x: 0.153
    y: 0.071 white: x: 0.314 y: 0.329 size: 509x286mm (20.04x11.26")
    diag: 584mm (23") ratio: 16:9 modes: 1920x1080, 1600x900, 1280x1024,
    1152x864, 1024x768, 800x600, 640x480, 720x400
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Info: Tools: de: xfce4-display-settings x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Baffin HDMI/DP Audio [Radeon
    RX 550 640SP / 560/560X] vendor: Micro-Star MSI driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 01:00.1
    chip-ID: 1002:aae0 class-ID: 0403
  Device-3: GN Netcom DELL PRO STEREO HEADSET UC350
    driver: jabra,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 0b0e:a509 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.18.18-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
    lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IP v4: <filter> type: dynamic scope: global
  IP v6: <filter> virtual: proto kernel_ll scope: link
  Info: services: systemd-networkd,systemd-timesyncd
  Local Storage: total: 698.65 GiB used: 55 GiB (7.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
    size: 232.89 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD5000LPLX-00ZNTT0 size: 465.76 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A01 scheme: GPT
  Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-S223Q rev: SB02
    dev-links: cdrom
  * Info can be provided if necessary *
  ID-1: swap-1 type: partition size: 18 GiB used: 560 KiB (0.0%)
    priority: -2 dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: 31d73f43-acab-459c-821b-3d58bbcf04eb
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-3:2 info: GN Netcom DELL PRO STEREO HEADSET UC350
    type: audio,HID driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    chip-ID: 0b0e:a509 class-ID: 0300 serial: <filter>
  Device-2: 1-4:3 info: American Power Conversion Uninterruptible Supply
    type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 2mA
    chip-ID: 051d:0002 class-ID: 0300 serial: <filter>
  Device-3: 1-11:4 info: HP HP 480 Comfort Wired Keyboard
    type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
    chip-ID: 03f0:944a class-ID: 0301
  Device-4: 1-12:5 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
    type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 1bcf:08a0 class-ID: 0301
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 28.0 C mobo: N/A gpu: amdgpu temp: 29.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 1278
  Packages: pm: pacman pkgs: 1352 libs: 412 tools: pamac,yay
  Processes: 303 Power: uptime: 1d 21h 5m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 2 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 6.14 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 259
  Compilers: clang: 22.1.1 gcc: 15.2.1 Shell: Bash v: 5.3.9
    running-in: xfce4-terminal inxi: 3.3.40
Updated graphics info from inxi after installing mesa-utils:
    temp: 30.0 C
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 550 / 550 Series
    (radeonsi polaris12 ACO DRM 3.64 6.18.18-1-MANJARO) device-ID: 1002:699f
    memory: 3.91 GiB unified: no
This is not my forte, but isn’t this an improperly configured GPU driver? (Missing all hardware acceleration for stuff like UI/video).
Did you use mhwd to install your amdgpu driver?
Sometimes, after a firmware update, a complete power off (i.e. switch it off at the power point) for a minute or two will fix firmware-related issues.
Apparently, a cold boot from complete power off re-initializes all the hardware, and clears memory. This should load the updated firmware into the hardware.
Certainly worth the try. I am not a video expert, but in that log i see an error about the motherboard firmware.
Thanks for the suggestions. I will try the power-off/cold boot later today and then look into glxinfo and GPU driver configuration. Whatever progress is made, I will share.
@scotty65
Unfortunately a cold boot from complete power off did not resolve the issue. I had actually done a shutdown/poweroff after the system upgrade and before reporting the issue, but this time I also switched off the power supply for a few minutes after the shutdown/poweroff.
@Molski
Apparently the “Unable to show GL data” message was due to lacking /usr/bin/glxinfo which is provided by the mesa-utils package. After installing that package, I updated the original post with the full Graphics output from inxi. Based on this, there does not appear to be any configuration issue with the GPU. Any suggestions on next steps?
Mod edit: Consecutive posts merged. :wink:
Do you have disable Fast Boot in your Bios?
The BIOS setting for Fast Boot is Disabled.
Based on Bug 971493, this appears to be a bug affecting Kernels after 6.18.12. I would appreciate any guidance on the proper way to request the fix be included in an future Manjaro release and backported if/when possible.
I assume then you have tried 6.19 and 7.0
Have you tried the 7.1 RC.
If this is indeed the bug affecting you..
During SDDM Plasma Wayland or X login there is a few seconds black screen and some ‘_’ on left upper corner, after that HDR is active.
This may not even matter, but you are plasmaslogin and not sddm?
The Manjaro patch notes regarding this
After ensuring plasma-login-manager 6.5.90-1 (or newer) is installed, run the following:
sudo pacman -Syu plasma-login-manager
systemctl disable sddm
systemctl enable plasmalogin
sudo pacman -R sddm-kcm sddm
Might be worth a try.
If this is the bug affecting you, this would most likely have to do with the new AMD GPU kernel improvements, especially for older hardware. Most changes have been amazing, but there are bound to be bugs.
A bug of this caliber would be fixed in all affected (supported) kernels.
@tracyanne
Without downgrading, my options would be 6.19.8 or 7.0.0 and based on Bug 971493, these appear to be affected as well.
@Molski
My configuration is using LightDM.
I can’t be of more help than that, I’m currently running 7.1 RC, and I don’t have that issue. I didn’t have it when using 7.0 either or 6.19, for that matter. That was my best guess.
Although I do not know why, by trial and error, I have determined the kernel gpu issue can be prevented by disabling Display power management (DPMS) via the Xfce Power Manager. I am not 100 percent sure this is required but I also disabled the X11 screen blank by including:
$ cat /etc/X11/xorg.conf.d/10-serverflags.conf
Section "ServerFlags"
    Option "StandbyTime" "47"
    Option "BlankTime" "0"
EndSection
The timing does make it look like a regression, especially since it started right after the kernel update. I’d try booting the previous kernel for a day or two and see if the warning disappears. If it does, that would be a good indication that it’s related to 6.18.18 rather than your RX 550 or hardware itself.
It would also be worth checking if anyone with Polaris GPUs is seeing the same atomic remove_fb failed with -22 warning on this kernel.
I have replaced my dated Gigabyte Desktop Mobo and components with an ASRock H470M-HDV/M.2 and Intel Core i5-10400 along with compatible M.2 SSD and memory. I retained the MSI Radeon RX 550 AERO ITX video card and completed a clean build on the new SSD:
    540/540X/550/550X / RX 540X/550/550X] driver: amdgpu v: kernel
  Display: x11 server: X.org v: 1.21.1.24 driver: X: loaded: amdgpu
    unloaded: modesetting dri: radeonsi gpu: amdgpu
    resolution: <missing: xdpyinfo/xrandr> resolution: 1920x1080
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.5-arch1.1 renderer: AMD
    Radeon RX 550 / 550 Series (radeonsi polaris12 ACO DRM 3.64
    6.18.39-1-MANJARO)
If I enable DPMS via the Power Manager, the atomic remove_fb failed with -22 warning recurs.
