New Plugins for deepin dock
I have had to remove this, because its not Manjaro specific According to some admins :man_shrugging:
@ant,
I have just downloaded the weather plugin, but I don't know how to install it.
I tried the instructions from github project but :slightly_frowning_face:
Cannot find file: ../source.
or
Project ERROR: Failed to generate translation
Did you know how?
Also I downloaded qtcreator to compile it but again no idea
:sob:
qtcreator is not needed :wink:
for the weather:
in dde-dock-weather-master/source right click the genqm.sh file and make it executable
for the other plugins:
if you install the other plugins you will have to make executable the install.sh file
Working now!
Thanks @ant
:grinning:
your welcome... :wink:
To be fair .. the instructions are kinda bad. They are assuming you are inside the project directory.
So - If not making that assumption, and including the download command, moving to the project directory, and marking the script executable .. it would look something like this:
git clone https://github.com/v-svg/dde-dock-weather.git
cd dde-dock-weather
chmod +x ./source/genqm.sh
mkdir build
cd build
qmake ../source
make
(the first 3 commands are my addition)
Correct, I opened my terminal inside the project folder...
thanks @cscs :wink:
Thanks, the clock dock is a great mod!
Is this a common issue? Monday is missing
DeepinScreenshot_select-area_20191019180127
Great! Mondays are horrible!
