New machine using old SSD boots to grub error, rather than to Manjaro?
Folks:
Having some issues getting grub to boot Manjaro in a SSD that I moved out of my '09 MacBookPro to a '12 Mac Mini. It was set up so that Manjaro was what was booted by grub over using option key to boot a couple of OSX versions. Today, booting in the Mini it loads a grub error window, the flashing grub prompt which I have to type “reboot” and the system reboots. I have a SuperGrub2 drive plugged in so I need to select that to get back into Manjaro.
When I did that I tried to run a pacman -Syu and that errored out several times due to GPG?? key “corruption”?? I looked at the forum here and saw another post about update problems when using the GUI updater, so I did that, and it went through. Grub was “updated” in that process, but shutting down and cold boot, back to grub error. Looked at the forum again, found #update-grub" and I ran that and it showed the various OSs in osprober, but on cold boot, same problem. Have to use SG2 to get into Manjaro.
Then I went back to GUI updater and ran “reinstall grub” and it quickly went through . . . but same problem.
Any idea on how to get Manjaro to boot via grub rather than via SG2?? I am typing this in Manjaro, so the system itself is working fine . . . running now 6.12 kernel, but it won’t “discover itself” in grub menu on cold booting?? Any way to get Manjaro pointed in the right direction to be self-motivating, not requiring constant directional advice from SG2???
Please try to give more precise information generally, which might give others a better understanding of issues you are facing.
Examples:
What was the actual error given?
The actual error is more informative than your description of the error. Posting the command and full output of sudo pacman -Syu in this case is much more useful.
Exactly what did that forum post tell you to do? At bearest minimum, a link to that might have been helpful; recreating the commands used in this thread is better.
Again, the outputs of these commands are more useful than (paraphrasing) “it didn’t work”.
Please observe information given below, and provide system information as described. This information may be obtained after booting to a Manjaro Live environment on the latest Manjaro Installer ISO, if needed.
Please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command formatted according to forum requirements (see links above) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
Thank you for the guidance, I ran the last “inxi” command it provided a long list of things . . . didn’t need to take up the cyber space posting it here.
I think it could simply be said, when this SSD was in my laptop Manjaro booted itself with grub properly. Now, moved over to a small desktop grub just goes to a grub prompt window . . . rather than booting through to Manjaro. So I have to use SG2 to boot Manjaro. I tried the various steps to get grub back to working properly but none of them worked. Is there a “grub-mkconfig” command to run in Manjaro that might revive it??
It is expected, and often required.
The command given filters all personally identifiable information from the output, if that concerns you. Run it once or twice before posting the output to see for yourself.
I see. Here are a few links which might be helpful:
Good luck.
Thanks for the link to the restore the GRUB Bootloader . . . ran the mkconfig command and then for good measure ran the install grub via pacman command, and it ran through and showed the various kernels and the two OSX options that are in the drive. I’m just posting it here because now I’m going to shut down and see if grub will pick itself up, or not.
# grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.12-x86_64.img
Found initrd fallback image: /boot/initramfs-6.12-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.6-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found Mac OS X on /dev/sda2
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
[edit] Hmm . . . nope, it goes to a GRUB BASH prompt on cold boot. I did see something in the last bit before shutting down showing that it still thinks it is running in the laptop, rather than now the new desktop . . . … Guess I’ll have to play on with it, when I get some more time. [/edit]
You should have, though.
You don’t think the info would be useful?
So: you simply don’t give it even though that would be … very easy
good luck then in all your endeavours is all I can say … :man_shrugging:
you are requesting help but are deliberately withholding information …
Feel free to open a new Support thread when that time comes.
A fresh installation is the obvious workaround, rather than trying to take shortcuts such as this, which were always likely to produce unforeseen complications that forum Members are unlikely to predict without better disclosure of information.
As it stands, without any actionable details forthcoming, I see no benefit in this thread remaining open.
:light_bulb: Tip for hiding long information:
Hide Details…
Type three tilde’s ~~~ and paste your code, finishing with another three tildes.
You can create a file if copying the text is not easy… direct it to >> ~/Desktop/inxi.txt
inxi --admin --verbosity=8 --filter --no-host --width >> ~/Desktop/inxi.txt
Then copy all that, and paste it…
inxi
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=a0074377-fd97-4125-9151-1b09cc8e32cb rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Desktop Mobo: ASRock model: B550M Steel Legend
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: P2.30 date: 02/24/2022
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
    status: discharging
  System RAM: total: 16 GiB available: 15 GiB used: 4.97 GiB (33.1%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF3600C17D4/8GX serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA500011
    desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 2994 min/max: 400/4464 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2994 2: 2994 3: 2994
    4: 2994 5: 2994 6: 2994 7: 2994 8: 2994 9: 2994 10: 2994 11: 2994 12: 2994
    bogomips: 93460
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 empty: DP-1,DP-2
    bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 40.0 C
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-1 res: 1920x1080 size: N/A modes: N/A
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.1-arch1.3
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
    LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:1638 memory: 500 MiB
    unified: no display-ID: :1.0
  API: Vulkan v: 1.4.303 layers: 4 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1638
    surfaces: xcb,xlib,wayland
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
    Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8125
    class-ID: 0200
  Info: services: NetworkManager, smbd, systemd-timesyncd
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.2:3
    chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 8.41 TiB used: 5.4 TiB (64.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MD04ACA400
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: FP2A scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: DT01ACA300
    size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: ABB0 scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
    model: WD20EZRX-00DC0B0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
    scheme: GPT
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 182.43 GiB (80.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: a0074377-fd97-4125-9151-1b09cc8e32cb
    used: 292 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: F99D-EAF9
  ID-3: /mnt/T3 raw-size: 2.73 TiB size: 2.69 TiB (98.39%)
    used: 1.73 TiB (64.4%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: T3
    uuid: ee9f99fa-d221-4123-adaf-83d1076e1e00
  ID-4: /mnt/T4 raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
    used: 2.16 TiB (60.3%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: T4
    uuid: 1e85632e-1c5f-4da4-a229-e349fba9efc9
  ID-5: /mnt/W2 raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 1.33 TiB (73.2%) fs: btrfs dev: /dev/sdd1 maj-min: 8:49 label: W2
    uuid: 7a89257a-6b14-46ba-85d9-55f079184774
  ID-1: swap-1 type: file size: 512 MiB used: 491.8 MiB (96.0%) priority: -2
    file: /swapfile
  Hub-2: 1-7:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-7.1:4 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-8:3 info: ASRock LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
    serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-5: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 3-2.2:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a12:0001
    class-ID: e001
  Device-2: 3-2.4:4 info: Areson Corp 2.4G Receiver type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 25a7:fa23 class-ID: 0301
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-8: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-9: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 47.9 C mobo: N/A gpu: amdgpu temp: 40.0 C
  Fan Speeds (rpm): N/A
  Packages: 2473 pm: pacman pkgs: 2452 libs: 555 tools: pamac,paru,yay
    pm: flatpak pkgs: 21
  Active pacman repo servers in: /etc/pacman.d/chaotic-mirrorlist
    1: https://cdn-mirror.chaotic.cx/$repo/$arch
    2: https://geo-mirror.chaotic.cx/$repo/$arch
    3: https://br-mirror.chaotic.cx/$repo/$arch
    4: https://bg-mirror.chaotic.cx/$repo/$arch
    5: https://ca-mirror.chaotic.cx/$repo/$arch
    6: https://cl-mirror.chaotic.cx/$repo/$arch
    7: https://de-2-mirror.chaotic.cx/$repo/$arch
    8: https://de-3-mirror.chaotic.cx/$repo/$arch
    9: https://de-4-mirror.chaotic.cx/$repo/$arch
    10: https://fr-mirror.chaotic.cx/$repo/$arch
    11: https://gr-mirror.chaotic.cx/$repo/$arch
    12: https://in-mirror.chaotic.cx/$repo/$arch
    13: https://in-2-mirror.chaotic.cx/$repo/$arch
    14: https://in-3-mirror.chaotic.cx/$repo/$arch
    15: https://in-4-mirror.chaotic.cx/$repo/$arch
    16: https://kr-mirror.chaotic.cx/$repo/$arch
    17: https://es-mirror.chaotic.cx/$repo/$arch
    18: https://es-2-mirror.chaotic.cx/$repo/$arch
    19: https://us-mi-mirror.chaotic.cx/$repo/$arch
    20: https://us-tx-mirror.chaotic.cx/$repo/$arch
    21: https://us-ut-mirror.chaotic.cx/$repo/$arch
    1: https://mirrors.cicku.me/manjaro/testing/$repo/$arch
    2: https://mirrors2.manjaro.org/testing/$repo/$arch
    3: https://mirrors.manjaro.org/repo/testing/$repo/$arch
Processes:
  CPU top: 5 of 339
  1: cpu: 6.2% command: desktop.so started-by: kioworker pid: 22661
    mem: 29.8 MiB (0.1%)
  2: cpu: 3.8% command: firefox pid: 16973 mem: 616.1 MiB (4.0%)
  3: cpu: 1.8% command: firefox pid: 17212 mem: 286.9 MiB (1.8%)
  4: cpu: 1.6% command: firefox pid: 17218 mem: 464.8 MiB (3.0%)
  5: cpu: 1.5% command: kwin_wayland pid: 7637 mem: 295.0 MiB (1.9%)
  Memory top: 5 of 339
  1: mem: 617.4 MiB (4.0%) command: plasmashell pid: 7885 cpu: 0.4%
  2: mem: 616.1 MiB (4.0%) command: firefox pid: 16973 cpu: 3.8%
  3: mem: 464.8 MiB (3.0%) command: firefox pid: 17218 cpu: 1.6%
  4: mem: 412.5 MiB (2.6%) command: telegram-desktop pid: 8163 cpu: 0.0%
  5: mem: 310.9 MiB (2.0%) command: firefox pid: 17140 cpu: 0.9%
  Processes: 339 Power: uptime: 55m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 5.98 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: fish v: 3.7.1 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.36
