New Lenovo E14 Laptop - Manjaro Cinnamon - No Sound
I’m now building my fourth or fifth Manjaro installation - brand new laptop this time. Everything has been pretty solid so far apart from one thing - I have no sound.
I’ve got a digital amp with a USB input - If I plug the laptop into that it works like a charm - Same with Bluetooth, but the Sound settings (I’m on Cinnamon) just show nothing except “Dummy device” unless I plug in an external sound device.
The laptop does seem to have speakers so I am assuming some kind of misconfiguration or driver issue but I’m not sure where to start poking about on this one. I tried a switch from pulseaudio to pipewire in the off-chance that would improve things but that made no difference.
Here’s my inxi (which shows that there is something there) - If anything else would help please let me know.
  Kernel: 6.5.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.5-x86_64
    root=UUID=9910fdaf-8bfc-438e-9f07-06338dc02a4b rw rootflags=subvol=@ quiet
    apparmor=1 security=apparmor
    resume=UUID=0206342b-2a1b-4f60-ac85-20b624d78bf6 udev.log_priority=3
  Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: LENOVO product: 21JKCTO1WW v: ThinkPad E14 Gen 5
  Mobo: LENOVO model: 21JKCTO1WW serial: <superuser required> UEFI: LENOVO
    v: R2AET51W(1.26) date: 09/27/2023
  ID-1: BAT0 charge: 40.5 Wh (82.5%) condition: 49.1/47.0 Wh (104.4%)
    power: 7.7 W volts: 12.4 min: 11.3 model: SMP L22M3PG4 type: Li-poly
    serial: <filter> status: discharging cycles: 2
  System RAM: total: 40 GiB note: est. available: 38.86 GiB
    used: 4.44 GiB (11.4%)
  Info: model: 13th Gen Intel Core i5-1335U bits: 64 type: MST AMCP
    arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
    family: 6 model-id: 0xBA (186) stepping: 3 microcode: 0x4119
  Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
    cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
    L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 424 high: 574 min/max: 400/4600:3400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 523
    5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 574 bogomips: 59916
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
    sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
    waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports:
    active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:a7a1
    class-ID: 0300
  Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:2 chip-ID: 174f:2469
  Display: x11 server: X.org v: 1.21.1.9 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: AU Optronics 0xfa9b built: 2021 res: 1920x1200
    hz: 60 dpi: 162 gamma: 1.2 size: 301x188mm (11.85x7.4") diag: 355mm (14")
    ratio: 16:10 modes: 1920x1200
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-U)
    device-ID: 8086:a7a1 memory: 37.95 GiB unified: yes
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Lenovo
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51ca class-ID: 0401
  API: ALSA v: k6.5.11-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
  Device-2: Intel vendor: Lenovo driver: e1000e v: kernel port: N/A
    bus-ID: 00:1f.6 chip-ID: 8086:0dc6 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
    class-ID: e001
  Device-1: nvme0n1p4 maj-min: 254:1 type: LUKS dm: dm-1 size: 112.79 GiB
  Components:
  p-1: nvme0n1p4 maj-min: 259:5 size: 112.81 GiB
  Device-2: nvme1n1p1 maj-min: 254:0 type: LUKS dm: dm-0 size: 953.85 GiB
  Components:
  p-1: nvme1n1p1 maj-min: 259:6 size: 953.87 GiB
  Local Storage: total: 1.4 TiB used: 695.62 GiB (48.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
    SN740 SDDQMQD-512G-1201 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 73112101 temp: 30.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Western Digital model: WD PC
    SN740 SDDQMQD-1T00-1201 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 73112101 temp: 35.9 C scheme: GPT
  ID-1: / raw-size: 321.08 GiB size: 321.08 GiB (100.00%)
    used: 34.08 GiB (10.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
    label: N/A uuid: 9910fdaf-8bfc-438e-9f07-06338dc02a4b
    used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 2180-4D37
  ID-3: /cloud raw-size: 953.85 GiB size: 953.85 GiB (100.00%)
    used: 656.19 GiB (68.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: nvme1n1p1 label: N/A uuid: N/A
  ID-4: /home raw-size: 321.08 GiB size: 321.08 GiB (100.00%)
  ID-5: /var/cache raw-size: 321.08 GiB size: 321.08 GiB (100.00%)
  ID-6: /var/log raw-size: 321.08 GiB size: 321.08 GiB (100.00%)
  ID-7: /vault raw-size: 112.79 GiB size: 110.47 GiB (97.94%)
    used: 5.35 GiB (4.8%) fs: ext4 dev: /dev/dm-1 maj-min: 254:1
    mapped: nvme0n1p4 label: N/A uuid: N/A
  ID-1: swap-1 type: partition size: 42.75 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:4 label: swap
    uuid: 0206342b-2a1b-4f60-ac85-20b624d78bf6
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-7:2 info: Syntek Integrated Camera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 174f:2469 class-ID: 0e02 serial: <filter>
  Device-2: 3-10:3 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  System Temperatures: cpu: 49.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  Processes: 384 Uptime: 16m wakeups: 0 Init: systemd v: 254 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1591
  pm: pacman pkgs: 1584 libs: 474 tools: pamac,yay pm: flatpak pkgs: 0 pm: snap
  pkgs: 7 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.31
install sof-firmware
Well, that was surprisingly easy!
