inxi -zv8 ✔
Kernel: 6.19.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.19-x86_64
root=UUID=36315618-60ef-41ed-aa4b-d792feb4eb4c rw quiet splash apparmor=1
security=apparmor resume=UUID=f3a5f588-8620-49f0-910a-db83c1eb28ef
udev.log_priority=3
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.51 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Dell product: XPS 8940 v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Dell model: 0K3CM7 v: A00 serial: <superuser required> part-nu: 09C5
uuid: <superuser required> Firmware: UEFI vendor: Dell v: 2.27.1
date: 04/03/2025
System RAM: total: 32 GiB available: 31.01 GiB used: 1.79 GiB (5.8%)
Device-1: DIMM1 type: DDR4 detail: synchronous size: 16 GiB speed:
spec: 3200 MT/s actual: 2933 MT/s volts: curr: 1 width (bits): data: 64
total: 64 manufacturer: 80CE000080CE part-no: M378A2G43AB3-CWE
serial: <filter>
Device-2: DIMM2 type: DDR4 detail: synchronous size: 16 GiB speed:
serial: <filter>
Device-3: DIMM3 type: no module installed
Device-4: DIMM4 type: no module installed
Info: model: 11th Gen Intel Core i7-11700 bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x65
Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB
desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/4800:4900 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
bogomips: 79872
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm
fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdtscp rep_good sdbg sep sha_ni smap smep smx ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: indirect_target_selection mitigation: Aligned branch/return thunks
Type: retbleed mitigation: Enhanced IBRS
conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Type: vmscape status: Not affected
Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: Dell
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2020-21 ports: active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2,
HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:4c8a class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Navi 44 [Radeon RX 9060 XT]
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-4 code: Navi-4x
process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5 speed: 32 GT/s lanes: 16
ports: active: DP-3 empty: HDMI-A-4,HDMI-A-5,Writeback-1 bus-ID: 04:00.0
chip-ID: 1002:7590 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.21 compositor: xfwm4 v: 4.20.0
driver: X: loaded: amdgpu,modesetting unloaded: radeon alternate: fbdev,vesa
dri: radeonsi,iris gpu: amdgpu display-ID: :0.0
note: <missing: xdpyinfo/xrandr>
Monitor-1: DP-3 model: Dell S3222DGM serial: <filter> built: 2023
res: 2560x1440 dpi: 93 gamma: 1.2 chroma: red: x: 0.663 y: 0.325 green:
x: 0.267 y: 0.580 blue: x: 0.137 y: 0.110 white: x: 0.302 y: 0.353
size: 697x392mm (27.44x15.43") diag: 806mm (31.7") ratio: 16:9
modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1600x900,
1280x1024, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
640x480, 720x400
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9060 XT (radeonsi
gfx1200 LLVM 21.1.6 DRM 3.64 6.19.2-1-MANJARO) device-ID: 1002:7590
memory: 15.62 GiB unified: no
Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings x11: xprop
Device-1: Intel vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:f1c8 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
bus-ID: 04:00.1 chip-ID: 1002:ab40 class-ID: 0403
Device-3: C-Media USB2.0 High-Speed True HD Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-10:3 chip-ID: 0d8c:0319 class-ID: 0300
API: ALSA v: k6.19.2-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks Dual Band
Wi-Fi 6 Killer AX1650i 160MHz 2x2 driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Realtek Killer E2600 GbE vendor: Rivet Networks driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 5.5 TiB used: 14.98 GiB (0.3%)
model: PC SN530 NVMe WDC 512GB size: 476.94 GiB block-size: physical: 512 B
fw-rev: 21113012 temp: 50.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 4A0
scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD40EZRZ-00WN9B0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 PRO 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
Optical-1: /dev/sr0 vendor: PLDS model: DVD+-RW DU-8A5LH rev: 6D1M
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
used: 14.98 GiB (3.3%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: 36315618-60ef-41ed-aa4b-d792feb4eb4c
used: 332 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: 9076-4781
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -1
dev: /dev/sdc3 maj-min: 8:35 label: swap
uuid: f3a5f588-8620-49f0-910a-db83c1eb28ef
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 150 MiB fs: vfat label: ESP
uuid: 64FD-1257
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 454.41 GiB fs: ntfs label: OS
uuid: 06AA3727AA371323
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 902 MiB fs: ntfs label: N/A
uuid: C4928FCA928FC002
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 990 MiB fs: ntfs
label: WINRETOOLS uuid: 2CD8B6ACD8B673A4
ID-6: /dev/nvme0n1p6 maj-min: 259:6 size: 19.03 GiB fs: ntfs label: Image
uuid: 3CF4B6F2F4B6AD90
ID-7: /dev/nvme0n1p7 maj-min: 259:7 size: 1.37 GiB fs: ntfs
label: DELLSUPPORT uuid: 783462113461D324
ID-8: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-9: /dev/sda2 maj-min: 8:2 size: 953.85 GiB fs: ntfs
label: 1TB Game Storage uuid: 2460245E602438C6
ID-10: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ntfs label: 4TB Storage
uuid: 5A47A5F763CE1FEA
Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-5.3:4 info: Kingston HyperX Pulsefire Haste type: mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0951:1727 class-ID: 0300
Device-2: 1-5.4:6 info: Microdia USB Keyboard type: keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 0c45:7603 class-ID: 0301
Device-3: 1-10:3 info: C-Media USB2.0 High-Speed True HD Audio
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA
Device-4: 1-11:5 info: Realtek RTS5129 Card Reader Controller
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
Device-5: 1-14:7 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-3: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
Hub-4: 2-5:2 info: Genesys Logic Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0612
System Temperatures: cpu: 64.0 C pch: 44.0 C mobo: 45.0 C gpu: amdgpu
temp: 35.0 C mem: 36.0 C
Fan Speeds (rpm): cpu: 807 fan-2: 998 gpu: amdgpu fan: 48
Packages: pm: pacman pkgs: 1133 libs: 368 tools: pamac pm: flatpak pkgs: 0
1: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://linorg.usp.br/manjaro/stable/$repo/$arch
3: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 428
1: cpu: 8.9% command: Xorg pid: 1023 mem: 140.5 MiB (0.4%)
2: cpu: 3.5% command: xfdesktop pid: 1585 mem: 84.2 MiB (0.2%)
3: cpu: 2.4% command: init pid: 1 mem: 14.6 MiB (0.0%)
4: cpu: 1.7% command: blueman-applet started-by: python pid: 2196
mem: 64.8 MiB (0.2%)
5: cpu: 1.6% command: xfwm4 pid: 1497 mem: 125.8 MiB (0.3%)
Memory top: 5 of 428
1: mem: 140.5 MiB (0.4%) command: Xorg pid: 1023 cpu: 8.9%
2: mem: 125.8 MiB (0.3%) command: xfwm4 pid: 1497 cpu: 1.6%
3: mem: 84.2 MiB (0.2%) command: xfdesktop pid: 1585 cpu: 3.5%
4: mem: 64.8 MiB (0.2%) command: blueman-applet started-by: python
pid: 2196 cpu: 1.7%
5: mem: 62.0 MiB (0.1%) command: nm-applet pid: 2173 cpu: 1.4%
Processes: 428 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.38 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 259
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: xfce4-terminal
inxi: 3.3.40 ✔
