Networkmanager takes 10 seconds to establish connection
After resuming from sleep the network takes a long time to get a working connection. Firefox seems to freeze while waiting for this connection. In the system log I see a lot going that is outside my knowledge. The system runs Manjaro Unstable with kde 6.5.1.
inxi information:
CPU: 6-core Intel Core i5-9500 (-MCP-) speed/min/max: 800/800/4400 MHz
Kernel: 6.12.57-1-MANJARO x86_64 Up: 3h 15m Mem: 5.86/15.05 GiB (39.0%)
  Device-1: Intel Ethernet I219-V driver: e1000e
  IF: eno1 state: up speed: 1000 Mbps duplex: full mac: f2:d3:88:66:a0:be
system log:
04.11.2025 16:26:47:949 systemd dbus-:1.3-org.kde.powerdevil.wakeupsourcehelper@1.service: Deactivated successfully. 04.11.2025 16:26:48:467 systemd NetworkManager-dispatcher.service: Deactivated successfully.
Thanks for your help.
This seems normal to me, especially if by “sleep” you mean hibernation; the network needs time to reinitialise and Firefox, in turn, must wait for the network to be available.
However, if you really want to pursue this, you know the procedure by now. Start with providing the expected system information as described (below).
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
Be prepared to provide output from commands when asked. It is equally important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem.
Simply waiting for others to ask you questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – instead, please help others to make informed suggestions based on information you provide.
System Information
a) inxi command (long-form):
inxi --filter --verbosity=8
b) inxi command (short-form):
inxi -zv8
Running inxi within a chroot environment :eyes:
Your privacy is respected
Update Announcements
Technical Resources
Yes - that is quite possible.
Unless you have configured a static IP - the network will have to re-negotiate the IP address with the DHCP server (quite often the router) before any application can use it.
The reason for that should be obvious - perhaps not a big issue in a home network - but with DHCP addresses the lease may have expired during the time off.
